[PATCH v4] ndbm test suite
Thu Jul 18 20:42:17 UTC 2019
On Thu, Jul 18, 2019 at 11:05 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>  testsuites/psxtests/Makefile.am      |   7 +
>  testsuites/psxtests/configure.ac     |   1 +
>  testsuites/psxtests/psxndbm01/init.c | 305 +++++++++++++++++++++++++++
>  3 files changed, 313 insertions(+)
>  create mode 100644 testsuites/psxtests/psxndbm01/init.c
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index 59c9f2085b..7d1c0a783c 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -694,6 +694,13 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxmutexattr01) \
>         $(support_includes) -I$(top_srcdir)/include
>  endif
> +if TEST_psxndbm01
> +psx_tests += psxndbm01
> +psxndbm01_SOURCES = psxndbm01/init.c
> +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
> +       $(support_includes)
> +endif
>  if TEST_psxobj01
>  psx_tests += psxobj01
>  psx_screens += psxobj01/psxobj01.scn
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index 85559e4aa5..07d7ccaf55 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
>  RTEMS_TEST_CHECK([psxmsgq03])
>  RTEMS_TEST_CHECK([psxmsgq04])
>  RTEMS_TEST_CHECK([psxmutexattr01])
> +RTEMS_TEST_CHECK([psxndbm01])
>  RTEMS_TEST_CHECK([psxobj01])
>  RTEMS_TEST_CHECK([psxonce01])
>  RTEMS_TEST_CHECK([psxpasswd01])
> diff --git a/testsuites/psxtests/psxndbm01/init.c b/testsuites/psxtests/psxndbm01/init.c
> new file mode 100644
> index 0000000000..d3b1e36ca0
> --- /dev/null
> +++ b/testsuites/psxtests/psxndbm01/init.c
> @@ -0,0 +1,305 @@
> + *  @file
> + *  @brief Test suite for ndbm.h methods
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2019 Vaibhav Gupta
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +/* header files are listed in lexical/lexicographical/alphabetical order */
> +#include <errno.h>
> +#include <fcntl.h>      /* contains definitions of 'open_flags' */
> +#include <limits.h>
> +#include <ndbm.h>       /* contains declarations of ndbm methods */
> +#include <stddef.h>
> +#include <stdint.h>
> +#include <stdio.h>
> +#include <sys/stat.h>   /* contains definitions of 'file_mode' */
> +#include <string.h>
> +#include <rtems/test.h>
> +#include <tmacros.h>
> +const char rtems_test_name[] = "PSXNDBM 01";
> +#define NAME      "VARoDeK"
> +#define PHONE_NO  "123-321-777-888"
> +#define DB_NAME   "phones_test"
> +#define NAME2     "VG"
> +#define PHONE_NO2 "321-123-888-777"
> +/* forward declarations to avoid warnings */
> +rtems_task Init(rtems_task_argument ignored);
> +int count_no_of_records( DBM *db_local );
> +* This Function takes DBM* as a argument and count the number of records in the
> +* database pointed by it.
declare it 'static', and you shouldn't need the forward declaration I think.
> +  int count = 0;
> +  datum temp;
> +  for(
space after for
> +    temp = dbm_firstkey( db_local );
> +    temp.dptr != NULL;
> +    temp = dbm_nextkey( db_local ) , count++
no space before the comma.
> +  return count;
> +/* Test Function Begins */
> +  datum name          = { NAME, sizeof( NAME ) };
> +  datum put_phone_no  = { PHONE_NO, sizeof( PHONE_NO ) };
> +  datum name2         = { NAME2, sizeof( NAME2 ) };
> +  datum put_phone_no2 = { PHONE_NO2, sizeof( PHONE_NO2 ) };
> +  datum get_phone_no, key;
> +  int i;
> +  char *test_strings;
> +  DBM *db;
> +  TEST_BEGIN();
> +/* A Simple test to check if ndbm methods are call-able */
> + * A Simple test to check if NDBM methods are call-able
> + * We will try to open a database and then close it.
> + * If it successful, hence we can have further tests.
> + * Also, while opening it for first time, will create that database,
> + * hence we will be able to test for 'O_RDWR | O_EXCL' case later.
> + * Meanwhile we will also store one record, this record will be helpful in
> + * further tests.
> + * And fetch it, to make sure if basic NDBM methods are working correctly.
> +  puts( "\nOpen Database." );
> +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_TRUNC, S_IRWXU );
> +  rtems_test_assert( db != NULL );
> +  /* This data will be useful in further tests */
> +  puts( "Store Records in Database." );
> +  dbm_store( db, name, put_phone_no, DBM_INSERT );
> +  puts( "Fetch Records from Database and check." );
> +  get_phone_no = dbm_fetch( db, name );
> +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO ) == 0 );
> +  puts( "Close Database." );
> +  dbm_close( db );
> +/* dbm_open() */
> +  puts( "\nTestcases for 'dbm_open()'." );
> +/* The 'DB_NAME' is already created, hence 'O_RDWR | O_EXCL' should fail. */
> +  puts( "Use 'O_CREAT | O_EXCL' to open existing file and confirm error." );
> +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_EXCL, S_IRWXU );
> +  rtems_test_assert( db == NULL );
> +  rtems_test_assert( errno == EEXIST );
> +/* Some implementations use 3 characters for the suffix and others use
> + * 4 characters for the suffix, applications should ensure that the maximum
> + * portable pathname length passed to dbm_open() is no greater than
> + * {PATH_MAX}-4 bytes, with the last component of the pathname no greater
> + * than {NAME_MAX}-4 bytes.
> +/* inside 'ndbm.h' ; '#define  DBM_SUFFIX      ".db"' ;
> + * 2 alphabets and 1 period, hence 3 characters are used for suffix
> + * in this implementation.
> +  puts( "Use path name larger than '{PATH_MAX}-3 bytes.' and confirm error." );
> +  test_strings = (char*)malloc( PATH_MAX - 2 );
> +  for ( i = 0; i < PATH_MAX - 3; i++ )
Put { on same line as for, with a white space before it.
> +    test_strings[i] = 'r';
> +  test_strings[i] = '\0';
> +  db = dbm_open(
> +                (const char*)test_strings,
> +                O_RDWR | O_CREAT | O_TRUNC,
> +                S_IRWXU
Line up the closing parenthesis on the same indentation level as the
first line in the statement.
> +  rtems_test_assert( errno == ENAMETOOLONG );
> +  free( test_strings );
> +/* database opened for write-only access opens the files for read and
> + * write access or it will fail.
> +/* Implementation of __hash_open in newlib does not support `O_WRONLY` */
> +  puts( "Open file with write access only and confirm error." );
> +  db = dbm_open( DB_NAME , O_WRONLY , S_IRWXU );
no spaces before commas
> +  rtems_test_assert( errno == EINVAL );
> +/* dbm_store() */
> +  puts( "\nTestcases for 'dbm_store()'" );
> +  db = dbm_open( DB_NAME , O_RDWR , S_IRWXU );
> +  puts( "Insert new record with same key using 'DBM_INSERT' mode and "
> +        "confirm error." );
> +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_INSERT ) == 1 );
> +  puts( "Insert new record with same key using 'DBM_REPLACE' mode and "
> +        "confirm changes." );
> +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_REPLACE ) == 0 );
> +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO2 ) == 0 );
> +/* Revert for next tests */
> +  rtems_test_assert( dbm_store( db, name, put_phone_no, DBM_REPLACE ) == 0 );
> +  puts( "Store a new record and "
> +        "confirm that total number of records is successful 2." );
> +  rtems_test_assert( dbm_store( db, name2, put_phone_no2, DBM_INSERT ) == 0 );
> +/* Confirm number of records */
> +  rtems_test_assert( count_no_of_records( db ) == 2 );
> +  dbm_close( db );
> +/* dbm_fetch() */
> +  puts( "\nTestcases for 'dbm_fetch()'" );
> +  db = dbm_open( DB_NAME, O_RDONLY, S_IRWXU );
> +  puts( "Fetch existing records and confirm results." );
> +  get_phone_no = dbm_fetch( db, name2 );
> +  puts( "Fetch non-existing record and confirm error." );
> +  test_strings = (char*)malloc(6);
> +  strncpy( test_strings, "Hello", 5 );
> + * We could have used test_strings[5], but since its a dynamic data, we wrote
> + * it in the form of dereference of a pointer.
> +  *(test_strings + 5) = '\0';
Why? this is equivalent to test_strings[5] = 0; and can either be
written as such, or how you did it, but we don't need the comment.
Usually it is preferred to avoid pointer arithmetic when an array
notation suffices.
> +/* The data pointed by test_string is now pointed by key.dptr */
> +  key.dptr = test_strings;
> +  key.dsize = sizeof( test_strings );
> +  get_phone_no = dbm_fetch( db, key );
> +  rtems_test_assert( get_phone_no.dptr == NULL );
> +  dbm_close( db );
> +/* We need the 'key' boject, hence we cannot free 'test_strings' */
typo:  object
> +/* dbm_delete() */
> +  puts( "\nTestcases for 'dbm_delete()'" );
> +  db = dbm_open( DB_NAME, O_RDWR, S_IRWXU );
> +  puts( "Delete non-existing record and confirm error." );
> +  rtems_test_assert( dbm_delete( db, key ) != 0 );
> +  rtems_test_assert( count_no_of_records( db ) == 2);
> +  puts( "Delete existing record and "
> +        "confirm that total number of records is successful 1." );
> +  rtems_test_assert( dbm_delete( db, name ) == 0 );
> +  rtems_test_assert( count_no_of_records( db ) == 1);
> +  puts( "Confirm if correct record is deleted." );
> +/* record returned by 'dbm_firstkey()' should be the only record
> + * left, this should be checked to confirm correct working of
> + * 'dbm_firstkey()'.
> + * Check if the data is not corrupted after usage of 'dbm_delete()'
> +  puts( "Check if the data is not corrupted after usage of 'dbm_delete()'." );
> +  get_phone_no = dbm_fetch( db, dbm_firstkey( db ) );
> +/* Empty the database and then try to use 'dbm_firstkey()', the
> + * dptr pointer should point to NULL.
> +  puts( "Empty records in database and check results of 'dbm_firstkey()'." );
> +  rtems_test_assert( dbm_delete( db, dbm_firstkey( db ) ) == 0 );
> +  key = dbm_firstkey( db );
> +  rtems_test_assert( key.dptr == NULL );
> +  dbm_close( db );
> +* All cases for 'dbm_firstkey()' and 'dbm_nextkey()' were tested while
> +* performing other tests.
> +* One such case be found in count_number_of_records() function.
> +  TEST_END();
> +  rtems_test_exit(0);
> +/* NOTICE: the clock driver is explicitly disabled */
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS                  1
> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#include <rtems/confdefs.h>
> +/* end of file */
> 2.21.0
