Coverity Model
Fri Jul 19 16:13:33 UTC 2019
Hi Sebastian,
On Fri, Jul 19, 2019 at 2:57 AM Sebastian Huber
> Hello,
> you can add a model file to Coverity to reduce the false positive rate
> of the static analysis. I didn't check that the RTEMS scan can profit
> from this since we already supply a lot of code to the scan. What I
> found interesting is that Qemu uses this:
> https://github.com/qemu/qemu/blob/master/scripts/coverity-model.c
> There is a comment in it:
> " * The model file must be uploaded by an admin in the analysis settings of
>   * http://scan.coverity.com/projects/378"
> So, it seems the open source project scan is (or at least was)
> customizable. I my project settings view, I don't have analysis
> settings. Joel, would you mind having a look at this?
Yes, we have that setting available, and have a basic modeling file
already. I have it in my TODO to work on the modeling file, and
generally to improve our use of Coverity.
The modeling file we have is:
typedef unsigned int uint32_t;
void rtems_fatal_error_occurred(uint32_t the_error)
  __coverity_panic__();
#define rtems_interrupt_disable( _level ) \
  do { \
    _level = 0; \
  } while(0)
> Another option would be to add a model file (and other files which
> configure Coverity) to the repository. Users with a full Coverity
> installation can then check the RTEMS sources with a RTEMS project
> defined setting. Code changes can then reference that the change was due
> to a scan result which will is only available to users with access to a
> full Coverity installation.
This is a good idea.
> devel mailing list
> devel at rtems.org
