Build failed for RTEMS Source Builder
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Jul 19 18:48:05 UTC 2019
On Sat, Jul 20, 2019, 12:03 AM Himanshu Sekhar Nayak <
himanshuwindows8.1 at gmail.com> wrote:
> Hi Chris,
> After your solution, I changed the required source directories but seems
> like idk why it needs sudo privileges ?
> https://paste.ofcode.org/38mtbHLLH9WggmRkXWZDq4r
The path /opt/ requires root privilege.
You can change it to something like
$HOME/myrtems/dir/ in your --prefix
Regards,
Vijay
> Thanks
> Himanshu
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190720/ffb75195/attachment.html>
