Build failed for RTEMS Source Builder
Sat Jul 20 00:58:13 UTC 2019
On 20/7/19 4:48 am, Vijay Kumar Banerjee wrote:
> On Sat, Jul 20, 2019, 12:03 AM Himanshu Sekhar Nayak
> <himanshuwindows8.1 at gmail.com <mailto:himanshuwindows8.1 at gmail.com>> wrote:
>     Hi Chris,
>     After your solution, I changed the required source directories
Great. Are you able to please post the patch?
> but seems
>     like idk why it needs sudo privileges ?
>     https://paste.ofcode.org/38mtbHLLH9WggmRkXWZDq4r
> The path /opt/ requires root privilege.
> You can change it to something like
> $HOME/myrtems/dir/ in your --prefix
Yes or you can create /opt/rtems and set the permissions onto allow you as as
user to install the tools.
