[PATCH v2] user/bsps : Add documentation for Beagle
Sat Jul 20 05:02:22 UTC 2019
On Fri, Jul 19, 2019 at 7:27 PM Chris Johns <chrisj at rtems.org> wrote:
> On 20/7/19 6:41 am, Gedare Bloom wrote:
> > On Fri, Jul 19, 2019 at 11:02 AM Christian Mauderer <list at c-mauderer.de> wrote:
> >> On 19/07/2019 18:21, Gedare Bloom wrote:
> >>> Looks good to me. I'm currently not able to apply it, verify the doc
> >>> build, and push it though. (Workstation issues.)
> >> I agree that it looks OK. Thanks from me too for contributing to the
> >> documentation. It's something that most developers don't like to do
> >> therefore it's really great that you wrote that.
> Pushed.
> >> I didn't find any bugs in the instructions while reading through it. I
> >> can create a PDF out of it on my Arch Linux machine so I think it should
> >> be OK to merge it.
> >> You have tried quite a bit till you get an overlay working. If you feel
> >> like writing some more documentation, it might would be a good addition
> >> to add some notes regarding that too. I think this patch is fine as it
> >> is so if you add something please create a second patch.
> >> @Gedare: I don't touch the docs repo that often: Is there some defined
> >> test process before a commit is added? Or is building a PDF on some
> >> random machine enough?
> > I don't think the process is well-defined for the docs. However, if
> > you built the PDF and it looks good (can you build HTML too?) then go
> > ahead and push it.
> HTML is the default and always built. You need install to get a suitable
> directory tree to review with a `file://....` URL. Details are here but nothing
> is specifically said about HTML being always built:
> https://git.rtems.org/rtems-docs/tree/README.txt#n336
> The rules are not defined and maybe they should be.
> 1. HTML is always built and must build. Checking HTML is a requirement for
> posting a patch for review.
> 2. PDF is optional because the latex support is not consistent across all build
> hosts.
> 3. Please check the automatically built docs after a push to make sure all
> formats look suitable. Post a follow up patch if adjustments are needed.
> Comments?
Good rules. If you get a chance please add them to the README for now.
#1 should be for contributors, #3 is for Maintainers. #2 is optional.
> Chris
