[PATCH v2] user/bsps : Add documentation for Beagle
Christian Mauderer list at c-mauderer.de
Sat Jul 20 06:50:14 UTC 2019
On 19/07/2019 20:59, Vijay Kumar Banerjee wrote:
> On Fri, Jul 19, 2019 at 10:32 PM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     On 19/07/2019 18:21, Gedare Bloom wrote:
>     > Looks good to me. I'm currently not able to apply it, verify the doc
>     > build, and push it though. (Workstation issues.)
>     I agree that it looks OK. Thanks from me too for contributing to the
>     documentation. It's something that most developers don't like to do
>     therefore it's really great that you wrote that.
> Always glad to contribute. :)
>     I didn't find any bugs in the instructions while reading through it. I
>     can create a PDF out of it on my Arch Linux machine so I think it should
>     be OK to merge it.
>     You have tried quite a bit till you get an overlay working. If you feel
>     like writing some more documentation, it might would be a good addition
>     to add some notes regarding that too. I think this patch is fine as it
>     is so if you add something please create a second patch.
> Sure, I can write about creating and overlay and applying it to the base
> tree.
> What would be the right place to write it?
Hard to say. You worked with the Beagle BSP so for now maybe adding an
example + the command to apply an overlay there wouldn't be wrong. I
don't think there is a special "device tree" chapter right now.
Maybe an alternative would be to put a "device tree and overlay" chapter
into the README in libbsd. I think you as well as Niels are using
overlays only with libbsd.
> I have also wondered if it would be a good idea to keep the overlays in
> RTEMS
> or libBSD repo somewhere along with a script that builds a dtb from the
> freebsd-org
> tree and applies the overlay.
If you want you can create a script for libbsd to build the dtb.
Although cloning the freebsd-org submodule is optional, it can give a
good hint how to build a target dtb. If you do that, please create it in
a way that it's easy to tell which device tree should be build.
An alternative could be to just put the hand full of commands in the
README in libbsd.
Keeping overlays in libbsd or RTEMS is maybe not that optimal. Overlays
are quite target / application specific. So I'm a bit afraid of a big
number of poorly maintained files. I would prefer to have only a small
number of examples for overlays in the README. Other overlays are more
target specific.
>     @Gedare: I don't touch the docs repo that often: Is there some defined
>     test process before a commit is added? Or is building a PDF on some
>     random machine enough?
>     Best regards
>     Christian
>     > On Fri, Jul 19, 2019 at 2:07 AM Vijay Kumar Banerjee
>     > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>     >>  user/bsps/arm/beagle.rst | 110
>     >>  1 file changed, 108 insertions(+), 2 deletions(-)
>     >> diff --git a/user/bsps/arm/beagle.rst b/user/bsps/arm/beagle.rst
>     >> index a36efde..eb4ecfb 100644
>     >> --- a/user/bsps/arm/beagle.rst
>     >> +++ b/user/bsps/arm/beagle.rst
>     >> @@ -1,8 +1,114 @@
>     >>  .. SPDX-License-Identifier: CC-BY-SA-4.0
>     >> -.. Copyright (C) 2019 TBD
>     >> +.. Copyright (C) 2019 Vijay Kumar Banerjee
>     >>  beagle
>     >> -TODO.
>     >> +This BSP supports four variants, `beagleboardorig`, `beagleboardxm`,
>     >> +`beaglebonewhite` and `beagleboneblack`. The basic hardware
>     initialization is
>     >> +not performed by the BSP.  A boot loader with device tree
>     support must be used
>     >> +to start the BSP, e.g., U-Boot.
>     >> +TODO(These drivers are present but not documented yet):
>     >> + *  Clock driver.
>     >> + *  Network Interface Driver.
>     >> + *  SDcard driver.
>     >> + *  GPIO Driver.
>     >> + *  Console driver.
>     >> + *  PWM Driver.
>     >> + *  RTC driver.
>     >> +Boot via U-Boot
>     >> +To boot via uboot, the ELF must be converted to a U-Boot image
>     like below:
>     >> +.. code-block:: none
>     >> +    arm-rtems5-objcopy hello.exe -O app.bin
>     >> +    gzip 9 app.bin
>     >> +    mkimage -A arm -O linux -T kernel -a 0x80000000 -e
>     0x80000000 -n RTEMS -d app.bin.gz rtems-app.img
>     >> +Getting the Device Tree Blob
>     >> +The Device Tree Blob (DTB) is needed to load the device tree
>     while starting up
>     >> +the kernel. We build the dtb from the FreeBSD source matching
>     the commit hash
>     >> +from the libbsd HEAD of freebsd-org. For example if the HEAD is at
>     >> +"19a6ceb89dbacf74697d493e48c388767126d418"
>     >> +Then the right Device Tree Source (DTS) file is:
>     +https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/gnu/dts/arm/am335x-boneblack.dts
>     >> +.. code-block:: shell
>     >> +   :linenos:
>     >> +     #building the dtb
>     >> +     #We will use the script from
>     https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/tools/fdt/make_dtb.sh
>     >> +     #The make_dtb.sh script uses environment variable MACHINE
>     >> +     export MACHINE='arm'
>     >> +     SCRIPT_DIR=$HOME/freebsd/sys/tools/fdt
>     >> +     #The arguments to the script are
>     >> +     # $1 -> Build Tree
>     >> +     # $2 -> DTS source file
>     >> +     # $3 -> output path of the DTB file
>     >> +     ${SCRIPT_DIR}/make_dtb.sh ${SCRIPT_DIR}/../../ \
>     >> +     ${SCRIPT_DIR}/../../gnu/dts/arm/am335x-boneblack.dts \
>     >> +     $(pwd)
>     >> +Writing the uEnv.txt file
>     >> +The uEnv.txt file is needed to set any environment variable
>     before the kernel is
>     >> +loaded. Each line is a u-boot command that the uboot will
>     execute during start
>     >> +up.
>     >> +Add the following to a file named uEnv.txt:
>     >> +     setenv bootdelay 5
>     >> +     uenvcmd=run boot
>     >> +     boot=fatload mmc 0 0x80800000 rtems-app.img ; fatload mmc 0
>     0x88000000 am335x-boneblack.dtb ; bootm 0x80800000 - 0x88000000
>     >> +I2C Driver
>     >> +For registering the `/dev/i2c-0` device, a wrapper function is
>     provided,
>     >> +``bbb_register_i2c_0()`` similarly ``bbb_register_i2c_1()`` and
>     >> +``bbb_register_i2c_2()`` are respectively used to register
>     `i2c-1` and `i2c-2`.
>     >> +For registering an I2C device with a custom path (say
>     `/dev/i2c-3`) the
>     >> +function ``am335x_i2c_bus_register()`` has to be used.
>     >> +The function prototype is given below:
>     >> +.. code-block:: C
>     >> +   int am335x_i2c_bus_register(
>     >> +   const char         *bus_path,
>     >> +   uintptr_t           register_base,
>     >> +   uint32_t            input_clock,
>     >> +   rtems_vector_number irq
>     >> +SPI Driver
>     >> +The SPI device `/dev/spi-0` can be registered with
>     ``bbb_register_spi_0()``
>     >> +For registering with a custom path, the ``bsp_register_spi()``
>     can be used.
>     >> +.. code-block:: C
>     >> +    rtems_status_code bsp_register_spi(
>     >> 2.20.1
>     >> _______________________________________________
>     >> devel mailing list
>     >> devel at rtems.org <mailto:devel at rtems.org>
>     >> http://lists.rtems.org/mailman/listinfo/devel
>     > devel mailing list
