[PATCH 3/7] rtems: Add kernel, libbsd and BSP building as packages.
chrisj at rtems.org chrisj at rtems.org
Mon Jul 22 00:10:05 UTC 2019
 rtems/config/5/bsps/beagleboneblack.bset    |  19 ++
 rtems/config/5/rtems-default.bset           |   1 -
 rtems/config/5/rtems-kernel.bset            |  15 ++
 rtems/config/5/rtems-libbsd.bset            |   8 +
 rtems/config/rtems-base.bset                |   9 +
 rtems/config/rtems-bsp.cfg                  |  42 +++-
 rtems/config/tools/rtems-kernel-4-1.cfg     | 179 +--------------
 rtems/config/tools/rtems-kernel-5.cfg       |   7 +-
 rtems/config/tools/rtems-kernel-common.cfg  | 229 ++++++++++++++++++++
 rtems/config/tools/rtems-libbsd-5.cfg       |  13 ++
 rtems/config/tools/rtems-libbsd-common.cfg  |  79 +++++++
 rtems/config/tools/rtems-tools-common-1.cfg |  15 +-
 source-builder/defaults.mc                  |  12 +-
 source-builder/sb/build.py                  |  21 +-
 source-builder/sb/config.py                 |  74 ++++---
 15 files changed, 474 insertions(+), 249 deletions(-)
 create mode 100644 rtems/config/5/bsps/beagleboneblack.bset
 create mode 100644 rtems/config/5/rtems-kernel.bset
 create mode 100644 rtems/config/5/rtems-libbsd.bset
 create mode 100644 rtems/config/tools/rtems-kernel-common.cfg
 create mode 100644 rtems/config/tools/rtems-libbsd-5.cfg
 create mode 100644 rtems/config/tools/rtems-libbsd-common.cfg
diff --git a/rtems/config/5/bsps/beagleboneblack.bset b/rtems/config/5/bsps/beagleboneblack.bset
new file mode 100644
index 0000000..68b590a
--- /dev/null
+++ b/rtems/config/5/bsps/beagleboneblack.bset
@@ -0,0 +1,19 @@
+# BeagleBone Black
+# Build into the prefix path:
+#  - ARM tools
+#  - RTEMS Kernel and BSP
+#  - LibBSD
+#  - Packages
+%define rtems_target   arm-rtems5
+%define rtems_host     arm-rtems5
+%define with_rtems_bsp beagleboneblack
+5/rtems-arm
+5/rtems-kernel
+5/rtems-libbsd
diff --git a/rtems/config/5/rtems-default.bset b/rtems/config/5/rtems-default.bset
index d57388f..47780e7 100644
--- a/rtems/config/5/rtems-default.bset
+++ b/rtems/config/5/rtems-default.bset
@@ -20,4 +20,3 @@ tools/rtems-gdb-8.2.1-1
 tools/rtems-binutils-2.32
 tools/rtems-gcc-fb371a33fa6-newlib-5c2a3661c
 tools/rtems-tools-5-1
-tools/rtems-kernel-5
diff --git a/rtems/config/5/rtems-kernel.bset b/rtems/config/5/rtems-kernel.bset
index 0000000..080af0b
--- /dev/null
+++ b/rtems/config/5/rtems-kernel.bset
@@ -0,0 +1,15 @@
+# RTEMS Kernel configuration.
+%define release 1
+# The RTEMS version and URLs
+%include rtems-version.bset
+%include rtems-urls.bset
+# Build the kernel.
+tools/rtems-kernel-5
diff --git a/rtems/config/5/rtems-libbsd.bset b/rtems/config/5/rtems-libbsd.bset
index 0000000..ff9c2e7
--- /dev/null
+++ b/rtems/config/5/rtems-libbsd.bset
@@ -0,0 +1,8 @@
+# RTEMS LibBSD configuration.
+tools/rtems-libbsd-5
diff --git a/rtems/config/rtems-base.bset b/rtems/config/rtems-base.bset
index 5a7cc98..6749ce4 100644
--- a/rtems/config/rtems-base.bset
+++ b/rtems/config/rtems-base.bset
@@ -27,3 +27,12 @@ package: rtems-%{rtems_version}-%{_target}-%{_host}-%{release}
 # Pick up the RTEMS URLs.
+# Handle the Waf install root.
+%ifos win32 mingw ming32
+ %define rtems_waf_build_root_suffix %{waf_build_root_suffix}
+%else
+ %define rtems_waf_build_root_suffix %{nil}
+%endif
diff --git a/rtems/config/rtems-bsp.cfg b/rtems/config/rtems-bsp.cfg
index 8e1c12a..404ad6a 100644
--- a/rtems/config/rtems-bsp.cfg
+++ b/rtems/config/rtems-bsp.cfg
@@ -31,19 +31,17 @@
  %define rtems_bsp_error 1
 %endif
-# The target is used by compilers or Cxc builds.
-%if %{_target} != %{nil}
- %error RTEMS BSP builds use --host and not --target
-%endif
 # We need a host from the user to specifiy the RTEMS architecture and major
-# version.
+# version. It can be defined in rtems_host.
-%if %{_host} == %{nil} && %{rtems_bsp_error}
- %error No RTEMS host or BSP specified: --host=<arch>-rtems<ver>
+%if %{defined rtems_host}
+ %define _host %{rtems_host}
+%endif
+%if %{rtems_bsp_error}
+ %if %{_host} == %{nil} || %{_host} == %{_build}
+  %error No RTEMS host or BSP specified: --host=<arch>-rtems<ver>
+ %endif
 %endif
@@ -51,7 +49,7 @@
 %ifn %{defined with_rtems_bsp}
-  %error No RTEMS BSP specified: --rtems-bsp=arch/bsp (or --with-rtems-bsp=bsp)
+  %error No RTEMS BSP specified: --with-rtems-bsp=bsp
  %endif
  %define with_rtems_bsp sparc/erc32
 %endif
@@ -61,10 +59,16 @@
 %ifn %{defined with_tools}
  %define with_tools %{_prefix}
+ %define rtems_waf_tools %{nil}
+%else
+ %define rtems_waf_tools --rtems-tools=%{with_tools}
 %endif
 %ifn %{defined with_rtems}
  %define with_rtems %{_prefix}
+ %define rtems_waf_rtems %{nil}
+%else
+ %define rtems_waf_rtems --rtems=%{with_rtems}
 %endif
@@ -91,13 +95,18 @@
 %define rtems_bsp_libs    %{pkgconfig libs    %{_host}-%{rtems_bsp}}
 %if %{rtems_bsp_cflags} == %{nil} && %{rtems_bsp_error}
- %error No RTEMS BSP CFLAGS found; Please check the --rtems-bsp option.
+ %error No RTEMS BSP CFLAGS found; Please check the --with-rtems-bsp option.
 %endif
 %if %{rtems_bsp_ccflags} == %{nil}
  %define rtems_bsp_ccflags %{rtems_bsp_cflags}
 %endif
+# The RTEMS BSP architecture/bsp.
+%define rtems_bsp_arch_bsp %{_host_arch}/%{rtems_bsp}
 # RTEMS BSP paths
@@ -156,3 +165,12 @@
 %define host_cxxflags %{rtems_bsp_ccflags}
 %define host_ldflags  %{rtems_bsp_ldflags}
 %define host_libs     %{rtems_bsp_libs}
+%else
+%endif
diff --git a/rtems/config/tools/rtems-kernel-4-1.cfg b/rtems/config/tools/rtems-kernel-4-1.cfg
index 8c725a5..26e7d9c 100644
--- a/rtems/config/tools/rtems-kernel-4-1.cfg
+++ b/rtems/config/tools/rtems-kernel-4-1.cfg
@@ -3,181 +3,4 @@
 # This configuration file configure's, make's and install's RTEMS.
-%if %{rsb_released}
- %define rtems_kernel_version %{rsb_version}
-%else
- %define rtems_kernel_version %{rtems_version}
-%endif
-# Package details.
-Name:      %{_target}-kernel-%{rtems_kernel_version}-%{release}
-Summary:   RTEMS v%{rtems_kernel_version} for target %{_target} on host %{_host}
-Version:   %{rtems_kernel_version}
-Release:   %{release}
-URL: 	   http://www.rtems.org/
-# Build if the RSB is released or optionally enable/disable building the RTEMS
-# kernel via the command line.
-%if %{rsb_released} || %{defined with_rtems}
- %define rtems_kernel_build 1
-%else
- %define rtems_kernel_build 0
-%endif
-%if %{defined without_rtems}
-%endif
-%if %{rtems_kernel_build}
- %include %{_configdir}/checks.cfg
- %include %{_configdir}/base.cfg
- %include %{_configdir}/versions.cfg
- # A magic internal path that would break if changes in the defaults.mc
- # macro file are made.
- %define _internal_autotools_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
- # Check the version of autoconf. Check autoreconf as it is used.
- %if %{__autoreconf_ver} <= 2.68
-  %if %{__autoreconf_bindir_ver} <= 2.68
-   %if %{__autoreconf_path_ver} <= 2.68
-    %error Autoconf (autoreconf) version 2.69 or higher is needed.
-   %endif
-  %endif
- %endif
- # Source
- %if %{rsb_released}
-  %if ! %{defined rtems_kernel_compression}
-   %define rtems_kernel_compression xz
-  %endif
-  %define rtems_bootstrap 0
- %else
-  # The code in git needs to be bootstrapped. Do each build because we have
-  # no way to change what changes may have happened in the code.
-  %define rtems_bootstrap 1
- %endif
- %if ! %{defined rtems_kernel_version}
-  %define rtems_kernel_version HEAD
- %endif
- %if %{defined rtems_kernel_git_commit_hash}
-  %define rtems_kernel_git_checkout ?checkout=%{defined rtems_kernel_git_commit_hash}
- %else
-  %define rtems_kernel_git_checkout %{nil}
- %endif
- %source set rtems git://git.rtems.org/rtems.git?reset=hard?branch=%{rtems_kernel_version}?pull%{rtems_kernel_git_checkout} #
- # If C++ defined for the tool set use it to control RTEMS's setting..
- %if %{defined enable_cxx}
-  %define rtems_cxx %{enable_cxx}
- %endif
- # Default set up.
- %ifn %{defined rtems_posix}
-  %define rtems_posix 1
- %endif
- %ifn %{defined rtems_networking}
-  %define rtems_networking 1
- %endif
- %ifn %{defined rtems_cxx}
-  %define rtems_cxx 1
- %endif
- %ifn %{defined rtems_tests}
-  %define rtems_tests samples
- %endif
- %if %{rtems_tests} == disable
-  %define rtems_tests_opt --disable-tests
- %else
-  %define rtems_tests_opt --enable-tests=%{rtems_tests}
- %endif
- # Check the various --with/--without options we support.
- # --with-rtemsbsp   : Supported, list of BSPs
- # --without-rtemsbsp: Not supported
- # --with-tests      : Supported, samples/yes/no
- # --without-tests   : Not supported
- # --with-smp        : Supported
- # --without-smp     : Not care
- %if %{defined without_rtemsbsp}
-  %error Option --without-rtemsbsp is not supported.
- %endif
- %if %{defined without_rtems_tests}
-  %define with_rtems_tests no
- %endif
- # Prepare the source code.
- %prep
-   source_dir_rtems="rtems-%{rtems_kernel_version}"
-   %source setup rtems -q -c -n %{name}-%{version}
-   cd ${source_dir_rtems}
-   %patch setup rtems -p1
- %if %{rtems_bootstrap}
-   %if %{defined _internal_autotools_path}
-     export PATH="%{_internal_autotools_path}/bin:${PATH}"
-   %endif
-   ./bootstrap -c
-   %{_sbdir}/sb-bootstrap --preinstall
- %endif
-   cd ..
- %build
-   # Build directory support.
-   if test "%{_build}" != "%{_host}" ; then
-     build_dir="build-cxc"
-   else
-     build_dir="build"
-   fi
-   mkdir -p ${build_dir}
-   cd ${build_dir}
-   ../${source_dir_rtems}/configure \
-     --build=%{_build} --host=%{_host} \
-     --target=%{_target} \
-     %{?rtems_posix:--enable-posix}%{!?rtems_posix:--disable-posix} \
-     %{?rtems_networking:--enable-networking}%{!?rtems_networking:--disable-networking} \
-     %{?rtems_cxx:--enable-cxx}%{!?rtems_cxx:--disable-cxx} \
-     %{?with_rtems_tests:--enable-tests=%{with_rtems_tests}} \
-     %{?with_rtemsbsp:--enable-rtemsbsp="%{with_rtemsbsp}"} \
-     %{?with_rtems_smp:--enable-smp} \
-     --prefix=%{_prefix} --bindir=%{_bindir} \
-     --exec-prefix=%{_exec_prefix} \
-     --includedir=%{_includedir} --libdir=%{_libdir} \
-     --mandir=%{_mandir} --infodir=%{_infodir}
-   %{__make} %{?_smp_mflags} all
-   cd ..
- %install
-   %{__rmdir} $SB_BUILD_ROOT
-   cd ${build_dir}
-   %{__make} DESTDIR=$SB_BUILD_ROOT install
-   cd ..
-%endif
+%include tools/rtems-kernel-common.cfg
diff --git a/rtems/config/tools/rtems-kernel-5.cfg b/rtems/config/tools/rtems-kernel-5.cfg
index 5d5d654..7f23635 100644
--- a/rtems/config/tools/rtems-kernel-5.cfg
+++ b/rtems/config/tools/rtems-kernel-5.cfg
@@ -2,7 +2,10 @@
 # RTEMS 5
+%define rtems_kernel_version c4d89deaa66f9878ea5499cae7210d5815afc4fe
+%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 fa4cbcfd9d10be737b91805f1fbaccb7289f3d300a2a7aafef1713d265dd97242d00aba5f1c63ead5a889cfb2148fd9d62c79dcb6f16e61f9fa1290067159b43
-# The RTEMS build instructions. We use 4.xx Release 1.
+# The RTEMS build instructions.
-%include tools/rtems-kernel-4-1.cfg
diff --git a/rtems/config/tools/rtems-kernel-common.cfg b/rtems/config/tools/rtems-kernel-common.cfg
index 0000000..5a79340
--- /dev/null
+++ b/rtems/config/tools/rtems-kernel-common.cfg
@@ -0,0 +1,229 @@
+# RTEMS Kernel.
+# This configuration file configure's, make's and install's RTEMS.
+# If a dry-run and with download ignore errors and correct setting for tools
+# and BSPs. Only after the source to download.
+%if %{_dry_run} && %{defined with_download}
+ %log Kenrel configuration errors ignored
+ %define rtems_kernel_error 0
+%else
+ %define rtems_kernel_error 1
+%endif
+%if %{rsb_released}
+ %define rtems_kernel_version %{rsb_version}
+%endif
+# The target. It could be set in rtems_target.
+%if %{defined rtems_target}
+ %define _target %{rtems_target}
+%endif
+%if %{_target} == %{nil} && %{rtems_kernel_error}
+ %error No RTEMS target specified: --target=<arch>-rtems<ver>.
+%endif
+# The BSP.
+%if !%{defined with_rtems_bsp} && %{rtems_kernel_error}
+%endif
+%define rtems_bsp %{with_rtems_bsp}
+# If no tools are provided use the prefix.
+%ifn %{defined with_tools}
+ %define with_tools %{_prefix}
+%endif
+# Set the path to the tools.
+%{path prepend %{with_tools}/bin}
+# Define the package.
+package: rtems-%{rtems_version}-%{_target}-%{rtems_bsp}-%{_host}-%{release}
+# Package details.
+Name:    %{_target}-kernel-%{rtems_bsp}-%{release}
+Summary: RTEMS v%{rtems_kernel_version} for target %{_target} BSP %{rtems_bsp}
+Version: %{rtems_kernel_version}
+Release: %{release}
+URL: 	 https://www.rtems.org/
+%include %{_configdir}/checks.cfg
+%include %{_configdir}/base.cfg
+%include %{_configdir}/versions.cfg
+# A magic internal path that would break if changes in the defaults.mc
+# macro file are made.
+%define _internal_autotools_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
+# Check the version of autoconf. Check autoreconf as it is used.
+%if %{__autoreconf_ver} <= 2.68
+ %if %{__autoreconf_bindir_ver} <= 2.68
+  %if %{__autoreconf_path_ver} <= 2.68
+   %error Autoconf (autoreconf) version 2.69 or higher is needed.
+  %endif
+ %endif
+%endif
+# If no tools provided use the prefix.
+%endif
+# Check options.
+%if %{defined without_rtems_posix}
+ %define rtems_posix 0
+%endif
+%if %{defined with_rtems_legacy_network}
+ %define rtems_networking 1
+%endif
+%if %{defined with_rtems_cxx}
+ %define rtems_cxx 1
+%endif
+# Source
+ %if ! %{defined rtems_kernel_compression}
+  %define rtems_kernel_compression xz
+ %endif
+ %define rtems_kernel_version %{rtems_version}
+ %define rtems_bootstrap 0
+%else
+ # The code in git needs to be bootstrapped. Do each build because we have
+ # no way to change what changes may have happened in the code.
+ %define rtems_bootstrap 1
+%endif
+%if ! %{defined rtems_kernel_version}
+ %error No RTEMS kernel version defined
+%endif
+%source set rtems_kernel --rsb-file=rtems-kernel-%{rtems_kernel_version}.tar.bz2 https://git.rtems.org/rtems/snapshot/rtems-%{rtems_kernel_version}.tar.bz2
+# If C++ defined for the tool set use it to control RTEMS's setting..
+%if %{defined enable_cxx}
+ %define rtems_cxx %{enable_cxx}
+%endif
+# Default set up.
+%ifn %{defined rtems_posix}
+ %define rtems_posix 1
+%endif
+%ifn %{defined rtems_networking}
+ %define rtems_networking 0
+%endif
+%ifn %{defined rtems_cxx}
+ %define rtems_cxx 0
+%endif
+%ifn %{defined rtems_tests}
+ %define rtems_tests samples
+%endif
+%if %{rtems_tests} == disable
+ %define rtems_tests_opt --disable-tests
+%else
+ %define rtems_tests_opt --enable-tests=%{rtems_tests}
+%endif
+# Check the various --with/--without options we support.
+# --target          : The architecture
+# --with-rtems-bsp  : The BSP
+# --with-tests      : Supported, samples/yes/no
+# --without-tests   : Not supported
+# --with-smp        : Supported
+# --without-smp     : Not care
+%if %{defined without_rtemsbsp}
+ %error Option --without-rtemsbsp is not supported.
+%endif
+%if %{defined without_rtems_tests}
+ %define with_rtems_tests no
+%endif
+# Prepare the source code.
+%prep
+  source_dir_rtems="rtems-%{rtems_kernel_version}"
+  %source setup rtems_kernel -q -c -n %{name}-%{version}
+  cd ${source_dir_rtems}
+  %patch setup rtems -p1
+%if %{rtems_bootstrap}
+  %if %{defined _internal_autotools_path}
+    export PATH="%{_internal_autotools_path}/bin:${PATH}"
+  %endif
+  ./bootstrap -c
+  %{_sbdir}/sb-bootstrap --preinstall
+%endif
+  cd ..
+%build
+  # Build directory support.
+  if test "%{_build}" != "%{_host}" ; then
+    build_dir="build-cxc"
+  else
+    build_dir="build"
+  fi
+  mkdir -p ${build_dir}
+  cd ${build_dir}
+  ../${source_dir_rtems}/configure \
+    --build=%{_build} --host=%{_host} \
+    --target=%{_target} \
+    --enable-rtemsbsp="%{rtems_bsp}" \
+    %{?rtems_posix:--enable-posix}%{!?rtems_posix:--disable-posix} \
+    %{?rtems_networking:--enable-networking}%{!?rtems_networking:--disable-networking} \
+    %{?rtems_cxx:--enable-cxx}%{!?rtems_cxx:--disable-cxx} \
+    %{?with_rtems_tests:--enable-tests=%{with_rtems_tests}} \
+    %{?with_rtems_smp:--enable-smp} \
+    --prefix=%{_prefix} --bindir=%{_bindir} \
+    --exec-prefix=%{_exec_prefix} \
+    --includedir=%{_includedir} --libdir=%{_libdir} \
+    --mandir=%{_mandir} --infodir=%{_infodir}
+  %{__make} %{?_smp_mflags} all
+  cd ..
+%install
+  %{__rmdir} $SB_BUILD_ROOT
+  cd ${build_dir}
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  cd ..
diff --git a/rtems/config/tools/rtems-libbsd-5.cfg b/rtems/config/tools/rtems-libbsd-5.cfg
index 0000000..8f0141b
--- /dev/null
+++ b/rtems/config/tools/rtems-libbsd-5.cfg
@@ -0,0 +1,13 @@
+# RTEMS 5 LibBSD
+%define rtems_libbsd_version 313e1d5f1c8c7cd8e3d458628b040ce1c264d23c
+%hash sha512 rtems-libbsd-%{rtems_libbsd_version}.tar.bz2 1282b46eacbda01fc3eb3d3fc67c5a0d02d07f3d097b381133ad823bdbdd920c95e9faabb5430f1634ac3f1b4c797850d3a0d6a4b2aa523e677d65fe82a036a3
+%define rtems_waf_version ad6c6e8771b95dffa73a7dc1167d98d208f17cb0
+%hash sha512 rtems-waf-%{rtems_waf_version}.tar.bz2 9866ab0772cbd3aa4e641a14fad2c85acf79d8e6e08de05c32e985bb76b9f04a0a615093320b406ff4660ec1964f2c0778453b44a8b1358c6f04ccd7561cad1c
+# The RTEMS LibBSD build instructions.
+%include tools/rtems-libbsd-common.cfg
diff --git a/rtems/config/tools/rtems-libbsd-common.cfg b/rtems/config/tools/rtems-libbsd-common.cfg
index 0000000..4503e1b
--- /dev/null
+++ b/rtems/config/tools/rtems-libbsd-common.cfg
@@ -0,0 +1,79 @@
+# RTEMS LibBSD
+# This configuration file configure's, build's and install's libbsd.a.
+%if %{release} == %{nil}
+%define release 1
+%endif
+Name:      rtems-libbsd-v%{rtems_libbsd_version}-%{_host}-%{release}
+Summary:   RTEMS LibBSD provides libbsd, a FreeBSD kernel set of
+           services for RTEMS.
+Version:   %{rtems_libbsd_version}
+URL:       https://git.rtems.org/rtems-libbsd.git/
+# LibBSD is packaged as the release version when released.
+ %define rtems_libbsd_version %{rsb_version}
+%endif
+# RTEMS BSP support.
+%include rtems-bsp.cfg
+# LibBSD Source.
+#  Collect and install rtems_waf as cgit snapshots to not caputre submodules,
+#  which is a good thing because we would collect the entire FreeBSD source
+%source set rtems_libbsd https://git.rtems.org/rtems-libbsd/snapshot/rtems-libbsd-%{rtems_libbsd_version}.tar.bz2
+%source set rtems_waf    https://git.rtems.org/rtems_waf/snapshot/rtems_waf-%{rtems_waf_version}.tar.bz2
+%prep
+  build_top=$(pwd)
+  source_dir_libbsd="rtems-libbsd-%{rtems_libbsd_version}"
+  %source setup rtems_libbsd -q -n rtems-libbsd-%{rtems_libbsd_version}
+  %source setup rtems_waf -q -s 1 -c -a -n rtems-libbsd-%{rtems_libbsd_version}/rtems_waf
+  cd ${build_top}
+# Build the source code.
+%build
+  build_top=$(pwd)
+  %{host_build_flags}
+  cd ${source_dir_libbsd}
+  ./waf distclean configure \
+    --prefix=%{_prefix} \
+    %{rtems_waf_tools} \
+    %{rtems_waf_rtems}
+    --rtems-bsp=%{rtems_bsp_arch_bsp}
+  ./waf build
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  %{__rmdir} ${SB_BUILD_ROOT}
+  ./waf --destdir=$SB_BUILD_ROOT%{rtems_waf_build_root_suffix} install
+  cd ${build_top}
diff --git a/rtems/config/tools/rtems-tools-common-1.cfg b/rtems/config/tools/rtems-tools-common-1.cfg
index b15fbce..c15f514 100644
--- a/rtems/config/tools/rtems-tools-common-1.cfg
+++ b/rtems/config/tools/rtems-tools-common-1.cfg
@@ -58,19 +58,6 @@ License:   BSD-2-Clause + GPL-2.0
-  # If on Windows we need to add the driver prefix to the built root as waf
-  # strips the driver prefix from the prefix path when joining it to the
-  # destdir path. Waf is correct in doing this and the RSB is design to match
-  # the configure behaviour which treats the whole path including the drive
-  # prefix as part of the path as just a path.
-  %ifos win32 mingw ming32
-   SB_BUILD_ROOT_WAF=$SB_BUILD_ROOT$(echo %{_prefix} | cut -c 1-2)
-  %else
-  %endif
   cd ${source_dir_rtems_tools}
-  ./waf --destdir=$SB_BUILD_ROOT_WAF install
   cd ${build_top}
diff --git a/source-builder/defaults.mc b/source-builder/defaults.mc
index 646be78..1feaca1 100644
--- a/source-builder/defaults.mc
+++ b/source-builder/defaults.mc
@@ -184,7 +184,7 @@ __sed:               exe,     required, '/usr/bin/sed'
 __setup_post:        exe,     none,     '%{__chmod} -R a+rX,g-w,o-w .'
 __sh:                exe,     required, '/bin/sh'
 __tar:               exe,     required, '/usr/bin/tar'
-__tar_extract:       exe,     none,     '%{__tar} -xvvf'
+__tar_extract:       exe,     none,     '%{__tar} -xvv'
 __touch:             exe,     required, '/usr/bin/touch'
 __unzip:             exe,     required, '/usr/bin/unzip'
 __xz:                exe,     required, '/usr/bin/xz'
@@ -390,3 +390,13 @@ iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,\
 ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,\
 utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,\
 win_1253,win_1254,win_1255,win_1256,win_1257,win_1258'''
+# Waf build root suffix, only use for win32 mingw ming32 OSs
+# If on Windows we need to add the driver prefix to the built root as waf
+# strips the driver prefix from the prefix path when joining it to the
+# destdir path. Waf is correct in doing this and the RSB is design to match
+# the configure behaviour which treats the whole path including the drive
+# prefix as part of the path as just a path.
+waf_build_root_suffix:   none,  none, ' %(echo %{_prefix} | cut -c 1-2)'
diff --git a/source-builder/sb/build.py b/source-builder/sb/build.py
index faa11cc..abc50c0 100644
--- a/source-builder/sb/build.py
+++ b/source-builder/sb/build.py
@@ -203,7 +203,7 @@ class build:
             not _disable_installing and \
             not _canadian_cross
-    def source(self, name):
+    def source(self, name, strip_components):
         # Return the list of sources. Merge in any macro defined sources as
         # these may be overridden by user loaded macros.
@@ -246,6 +246,10 @@ class build:
             url = self.config.expand(' '.join(url))
             src = download.parse_url(url, '_sourcedir', self.config, self.opts, file_override)
             download.get_file(src['url'], src['local'], self.opts, self.config)
+            if strip_components > 0:
+                tar_extract = '%%{__tar_extract} --strip-components %d' % (strip_components)
+            else:
+                tar_extract = '%{__tar_extract}'
             if 'symlink' in src:
                 sname = name.replace('-', '_')
                 src['script'] = '%%{__ln_s} %s ${source_dir_%s}' % (src['symlink'], sname)
@@ -255,9 +259,9 @@ class build:
                 src['script'] = '%s %s' % (src['compressed'], src['local'])
                 if src['compressed-type'] != 'zip':
-                    src['script'] += ' | %{__tar_extract} -'
+                    src['script'] += ' | %s -f -' % (tar_extract)
             else:
-                src['script'] = '%%{__tar_extract} %s' % (src['local'])
+                src['script'] = '%s -f %s' % (tar_extract, src['local'])
             srcs += [src]
         return srcs
@@ -266,7 +270,7 @@ class build:
         setup_name = args[1]
         args = args[1:]
         try:
-            opts, args = getopt.getopt(args[1:], 'qDcn:ba')
+            opts, args = getopt.getopt(args[1:], 'qDcn:bas:')
         except getopt.GetoptError as ge:
             raise error.general('source setup error: %s' % str(ge))
         quiet = False
@@ -276,6 +280,7 @@ class build:
         deleted_dir = False
         created_dir = False
         changed_dir = False
+        strip_components = 0
         opt_name = None
         for o in opts:
             if o[0] == '-q':
@@ -290,8 +295,12 @@ class build:
                 unpack_before_chdir = True
             elif o[0] == '-a':
                 unpack_before_chdir = False
+            elif o[0] == '-s':
+                if not o[1].isdigit():
+                    raise error.general('source setup error: invalid strip count: %s' % (o[1]))
+                strip_components = int(o[1])
         name = None
-        for source in self.source(setup_name):
+        for source in self.source(setup_name, strip_components):
             if name is None:
                 if opt_name is None:
                     if source:
@@ -301,7 +310,7 @@ class build:
                 else:
                     name = opt_name
             self.script_build.append(self.config.expand('cd %{_builddir}'))
-            if not deleted_dir and  delete_before_unpack:
+            if not deleted_dir and delete_before_unpack:
                 self.script_build.append(self.config.expand('%{__rm} -rf ' + name))
                 deleted_dir = True
             if not created_dir and create_dir:
diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
index 93a74f3..2c3a13e 100644
--- a/source-builder/sb/config.py
+++ b/source-builder/sb/config.py
@@ -504,9 +504,9 @@ class file:
                         if not f.startswith('-W'):
                             fflags += [f]
                     pkg_flags = ' '.join(fflags)
-                log.trace('pkgconfig: %s: %s' % (flags, pkg_flags))
+                log.trace('pkgconfig: %s:  %s' % (flags, pkg_flags))
             except pkgconfig.error as pe:
-                self._error('pkgconfig: %s: %s' % (flags, pe))
+                self._error('pkgconfig: %s:  %s' % (flags, pe))
             except:
                 raise error.internal('pkgconfig failure')
         if pkg_flags is None:
@@ -719,7 +719,7 @@ class file:
         else:
             if ls[1] == 'select':
                 self.macros.lock_read_map()
-                log.trace('config: %s: %3d: _disable_select: %s' % (self.name, self.lc,
+                log.trace('config: %s: %3d:  _disable_select: %s' % (self.name, self.lc,
        ls[1]))
             else:
                 log.warning(self._name_line_msg('invalid disable statement: %s' % (ls[1])))
@@ -729,7 +729,7 @@ class file:
             log.warning(self._name_line_msg('invalid select statement'))
         else:
             r = self.macros.set_read_map(ls[1])
-            log.trace('config: %s: %3d: _select: %s %s %r' % \
+            log.trace('config: %s: %3d:  _select: %s %s %r' % \
                            r, ls[1], self.macros.maps()))
@@ -768,7 +768,7 @@ class file:
                 del self.macros[mn]
     def _ifs(self, config, ls, label, iftrue, isvalid, dir, info):
-        log.trace('config: %s: %3d: _ifs[%i]: dir=%s %i %r' % \
+        log.trace('config: %s: %3d:  _ifs[%i]: dir=%s %i %r' % \
                   (self.name, self.lc, self.if_depth, str(dir), len(ls), ls))
         in_dir = dir
         in_iftrue = True
@@ -788,7 +788,7 @@ class file:
                     self._error(label + ' without %endif')
                     raise error.general('terminating build')
                 if r[1] == '%endif':
-                    log.trace('config: %s: %3d: _ifs[%i]: %%endif: dir=%s %s %s %r' % \
+                    log.trace('config: %s: %3d:  _ifs[%i]: %%endif: dir=%s %s %s %r' % \
                                str(dir), r[1], this_isvalid, data))
                     if in_dir is None:
@@ -824,7 +824,7 @@ class file:
         sls = reduce(add, ls[1:], '').split()
         cls = sls
-        log.trace('config: %s: %3d: _if[%i]: %s' % (self.name, self.lc,
+        log.trace('config: %s: %3d:  _if[%i]: %s' % (self.name, self.lc,
                                                     self.if_depth, sls))
         self.if_depth += 1
@@ -839,22 +839,22 @@ class file:
                 elif cls[0] == '&&':
                     join_op = 'and'
                 cls = cls[1:]
-                log.trace('config: %s: %3d: _if[%i]: joining: %s' % (self.name, self.lc,
-        self.if_depth,
-        join_op))
+                log.trace('config: %s: %3d:  _if[%i]: joining: %s' % (self.name, self.lc,
+        self.if_depth,
+        join_op))
             ori = 0
             andi = 0
             i = len(cls)
             if '||' in cls:
                 ori = cls.index('||')
-                log.trace('config: %s: %3d: _if[%i}: OR found at %i' % (self.name, self.lc,
-        self.if_depth,
-        ori))
+                log.trace('config: %s: %3d:  _if[%i}: OR found at %i' % (self.name, self.lc,
+        self.if_depth,
+        ori))
             if '&&' in cls:
                 andi = cls.index('&&')
-                log.trace('config: %s: %3d: _if[%i]: AND found at %i' % (self.name, self.lc,
-        self.if_depth,
-        andi))
+                log.trace('config: %s: %3d:  _if[%i]: AND found at %i' % (self.name, self.lc,
+        self.if_depth,
+        andi))
             if ori > 0 or andi > 0:
                 if ori == 0:
                     i = andi
@@ -864,9 +864,9 @@ class file:
                     i = andi
                 else:
                     i = andi
-                log.trace('config: %s: %3d: _if[%i]: next OP found at %i' % (self.name, self.lc,
-        self.if_depth,
-        i))
+                log.trace('config: %s: %3d:  _if[%i]: next OP found at %i' % (self.name, self.lc,
+        self.if_depth,
+        i))
             ls = cls[:i]
             if len(ls) == 0:
                 self._error('invalid if expression: ' + reduce(add, sls, ''))
@@ -963,10 +963,10 @@ class file:
             else:
                 cistrue = istrue
-            log.trace('config: %s: %3d: _if[%i]:  %s %s %s %s' % (self.name, self.lc,
-        self.if_depth,
-        ifls, str(cistrue),
-        join_op, str(istrue)))
+            log.trace('config: %s: %3d:  _if[%i]:  %s %s %s %s' % (self.name, self.lc,
+        self.if_depth,
+        ifls, str(cistrue),
+        join_op, str(istrue)))
         if invert:
             cistrue = not cistrue
@@ -975,8 +975,8 @@ class file:
         self.if_depth -= 1
-        log.trace('config: %s: %3d: _if[%i]: %r' % (self.name, self.lc,
-                                                    self.if_depth, ifs_return))
+        log.trace('config: %s: %3d:  _if[%i]: %r' % (self.name, self.lc,
+                                                     self.if_depth, ifs_return))
         return ifs_return
@@ -1036,8 +1036,12 @@ class file:
             l = _clean(l)
             if len(l) == 0:
                 continue
-            log.trace('config: %s: %0d: %s %s' % \
-                          (self.name, self.lc, str(isvalid), l))
+            if isvalid:
+                indicator = '>'
+            else:
+                indicator = ' '
+            log.trace('config: %s: %3d:%s%s [%s]' % \
+                          (self.name, self.lc, indicator, l, str(isvalid)))
             lo = l
             if isvalid:
                 l = self._expand(l)
@@ -1090,12 +1094,12 @@ class file:
                 elif ls[0] == '%if':
                     d = self._if(config, ls, isvalid, dir, info)
                     if len(d):
-                        log.trace('config: %s: %3d: %%if: %s' % (self.name, self.lc, d))
+                        log.trace('config: %s: %3d:  %%if: %s' % (self.name, self.lc, d))
                         return ('data', d)
                 elif ls[0] == '%ifn':
                     d = self._if(config, ls, isvalid, dir, info, True)
                     if len(d):
-                        log.trace('config: %s: %3d: %%ifn: %s' % (self.name, self.lc, d))
+                        log.trace('config: %s: %3d:  %%ifn: %s' % (self.name, self.lc, d))
                         return ('data', d)
                 elif ls[0] == '%ifos':
                     d = self._ifos(config, ls, isvalid, dir, info)
@@ -1142,7 +1146,7 @@ class file:
                     if isvalid:
                         for d in self._directive:
                             if ls[0].strip() == d:
-                                log.trace('config: %s: %0d: _parse: directive: %s' % \
+                                log.trace('config: %s: %3d:  _parse: directive: %s' % \
                                           (self.name, self.lc, ls[0].strip()))
                                 return ('directive', ls[0].strip(), ls[1:])
                         log.warning(self._name_line_msg("unknown directive: '" + ls[0] + "'"))
@@ -1176,7 +1180,7 @@ class file:
         return (directive, info, data)
     def _process_data(self, results, directive, info, data):
-        log.trace('config: %s: %3d: _process_data: result=#%r# directive=#%s# info=#%r# data=#%r#' % \
+        log.trace('config: %s: %3d:  _process_data: result=#%r# directive=#%s# info=#%r# data=#%r#' % \
                   (self.name, self.lc, results, directive, info, data))
         new_data = []
         for l in results[1]:
@@ -1192,7 +1196,7 @@ class file:
             if not directive:
                 l = self._expand(l)
                 ls = self.tags.split(l, 1)
-                log.trace('config: %s: %3d: _tag: %s %s' % (self.name, self.lc, l, ls))
+                log.trace('config: %s: %3d:  _tag: %s %s' % (self.name, self.lc, l, ls))
                 if len(ls) > 1:
                     info = ls[0].lower()
                     if info[-1] == ':':
@@ -1206,7 +1210,7 @@ class file:
                     log.warning(self._name_line_msg("invalid format: '%s'" % (info_data[:-1])))
             else:
                 l = self._expand(l)
-                log.trace('config: %s: %3d: _data: %s %s' % (self.name, self.lc, l, new_data))
+                log.trace('config: %s: %3d:  _data: %s %s' % (self.name, self.lc, l, new_data))
                 new_data.append(l)
         return (directive, info, data + new_data)
@@ -1222,7 +1226,7 @@ class file:
         self.package = _package
     def _directive_extend(self, dir, data):
-        log.trace('config: %s: %3d: _directive_extend: %s: %r' % (self.name, self.lc, dir, data))
+        log.trace('config: %s: %3d:  _directive_extend: %s: %r' % (self.name, self.lc, dir, data))
         self._packages[self.package].directive_extend(dir, data)
     def _info_append(self, info, data):
@@ -1295,7 +1299,7 @@ class file:
                 raise error.general('no config file found: %s' % (cfgname))
         try:
-            log.trace('config: %s: _open: %s' % (self.name, path.host(configname)))
+            log.trace('config: %s:  _open: %s' % (self.name, path.host(configname)))
             config = open(path.host(configname), 'r')
         except IOError as err:
             raise error.general('error opening config file: %s' % (path.host(configname)))
2.19.1
