[PATCH 6/7] sb/setbuilder: Support staging of build set build before installing.
chrisj at rtems.org chrisj at rtems.org
Mon Jul 22 00:10:08 UTC 2019
- Staging lets build sets use previously built build sets.
- Fix the rtems-bsp builds to support staging.
 rtems/config/5/rtems-libbsd.bset           |   2 +-
 rtems/config/rtems-bsp.cfg                 |  28 +++-
 rtems/config/tools/rtems-libbsd-common.cfg |   2 +-
 source-builder/defaults.mc                 |  16 +-
 source-builder/sb/setbuilder.py            | 163 +++++++++++++++------
 source-builder/sb/shell.py                 |  75 ++++++++++
 6 files changed, 232 insertions(+), 54 deletions(-)
 create mode 100644 source-builder/sb/shell.py
diff --git a/rtems/config/5/rtems-libbsd.bset b/rtems/config/5/rtems-libbsd.bset
index ff9c2e7..2b84cf8 100644
--- a/rtems/config/5/rtems-libbsd.bset
+++ b/rtems/config/5/rtems-libbsd.bset
@@ -3,6 +3,6 @@
-# Build the kernel.
+# Build the BSD library for RTEMS.
 tools/rtems-libbsd-5
diff --git a/rtems/config/rtems-bsp.cfg b/rtems/config/rtems-bsp.cfg
index 404ad6a..bf1f42b 100644
--- a/rtems/config/rtems-bsp.cfg
+++ b/rtems/config/rtems-bsp.cfg
@@ -24,7 +24,7 @@
 # If a dry-run and with download ignore errors and correct setting for tools
 # and BSPs. Only after the source to download.
-%if %{_dry_run} && %{defined with_download}
+%if %{_dry_run}
  %log BSP configuration errors ignored
  %define rtems_bsp_error 0
 %else
@@ -36,7 +36,7 @@
 # version. It can be defined in rtems_host.
 %if %{defined rtems_host}
- %define _host %{rtems_host}
+ %{triplet _host %{rtems_host}}
 %endif
 %if %{rtems_bsp_error}
  %if %{_host} == %{nil} || %{_host} == %{_build}
@@ -55,18 +55,29 @@
 %endif
-# If no tools or RTEMS provided use the prefix.
+# If no tools or RTEMS provided use the prefix. If staging use the staging
+# root.
 %ifn %{defined with_tools}
- %define with_tools %{_prefix}
- %define rtems_waf_tools %{nil}
+ %if %{install_mode} == staging
+  %define with_tools %{stagingroot}
+  %define rtems_waf_tools --rtems-tools=%{with_tools}
+ %else
+  %define with_tools %{_prefix}
+  %define rtems_waf_tools %{nil}
+ %endif
 %else
 %endif
 %ifn %{defined with_rtems}
- %define with_rtems %{_prefix}
- %define rtems_waf_rtems %{nil}
+  %define with_rtems %{stagingroot}
+  %define rtems_waf_rtems --rtems=%{with_rtems}
+ %else
+  %define with_rtems %{_prefix}
+  %define rtems_waf_rtems %{nil}
+ %endif
 %else
 %endif
@@ -111,6 +122,7 @@
 # RTEMS BSP paths
 %define rtems_bsp_cc      %{_host}-gcc
+%define rtems_bsp_cxx     %{_host}-g++
 %define rtems_bsp_incpath %{with_rtems}/%{_host}/%{rtems_bsp}/include
 %define rtems_bsp_libpath %{with_rtems}/%{_host}/%{rtems_bsp}/lib
@@ -160,6 +172,8 @@
 # Map to names used for cross compiling.
+%define host_cc       %{rtems_bsp_cc}
+%define host_cxx      %{rtems_bsp_cxx}
 %define host_includes -I%{_includedir}
 %define host_cflags   %{rtems_bsp_cflags}
 %define host_cxxflags %{rtems_bsp_ccflags}
diff --git a/rtems/config/tools/rtems-libbsd-common.cfg b/rtems/config/tools/rtems-libbsd-common.cfg
index 4503e1b..f5f78f2 100644
--- a/rtems/config/tools/rtems-libbsd-common.cfg
+++ b/rtems/config/tools/rtems-libbsd-common.cfg
@@ -62,7 +62,7 @@ URL:       https://git.rtems.org/rtems-libbsd.git/
   ./waf distclean configure \
     --prefix=%{_prefix} \
     %{rtems_waf_tools} \
-    %{rtems_waf_rtems}
+    %{rtems_waf_rtems} \
     --rtems-bsp=%{rtems_bsp_arch_bsp}
   ./waf build
diff --git a/source-builder/defaults.mc b/source-builder/defaults.mc
index 1feaca1..ce5d2b0 100644
--- a/source-builder/defaults.mc
+++ b/source-builder/defaults.mc
@@ -75,6 +75,19 @@ build_ldflags:       none,    convert,  ''
 build_includes:      none,    convert,  ''
 build_libs:          none,    convert,  ''
+# Build and staging paths.
+buildroot:           dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}'
+buildcxcroot:        dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}-cxc'
+buildxcroot:         dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}-xx'
+stagingroot:         dir,     none,     '%{_tmppath}/sb-%{_uid}-staging'
+# Install mode can be installing or staging. Defaults to installing.
+install_mode:        none,    none,     'installing'
 # Extra path a platform can override.
 _extra_path:         none,    none,     '%{_sbdir}'
 _ld_library_path:    none,    none,     'LD_LIBRARY_PATH'
@@ -96,9 +109,6 @@ _docdir:             dir,     none,     '%{_defaultdocdir}'
 _tmppath:            dir,     none,     '%{_topdir}/build/tmp'
 _tmproot:            dir,     none,     '%{_tmppath}/sb-%{_uid}/%{_bset_tmp}'
 _tmpcxcroot:         dir,     none,     '%{_tmppath}/sb-%{_uid}-cxc/%{_bset_tmp}'
-buildroot:           dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}'
-buildcxcroot:        dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}-cxc'
-buildxcroot:         dir,     none,     '%{_tmppath}/%{buildname}-%{_uid}-xx'
 _datadir:            dir,     none,     '%{_prefix}/share'
 _defaultdocdir:      dir,     none,     '%{_prefix}/share/doc'
 _exeext:             none,    none,     ''
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index 159a673..d0a119f 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
@@ -41,6 +41,7 @@ try:
     import options
     import path
     import reports
+    import shell
     import sources
     import version
 except KeyboardInterrupt:
@@ -50,6 +51,14 @@ except:
     print('error: unknown application load error', file = sys.stderr)
     sys.exit(1)
+def macro_expand(macros, _str):
+    cstr = None
+    while cstr != _str:
+        cstr = _str
+        _str = macros.expand(_str)
+        _str = shell.expand(macros, _str)
+    return _str
 class log_capture(object):
     def __init__(self):
         self.log = []
@@ -71,21 +80,21 @@ class buildset:
     """Build a set builds a set of packages."""
     def __init__(self, bset, _configs, opts, macros = None):
-        log.trace('_bset: %s: init' % (bset))
+        log.trace('_bset:   : %s: init' % (bset))
         self.configs = _configs
         self.opts = opts
         if macros is None:
             self.macros = copy.copy(opts.defaults)
         else:
             self.macros = copy.copy(macros)
-        log.trace('_bset: %s: macro defaults' % (bset))
+        log.trace('_bset:   : %s: macro defaults' % (bset))
         log.trace(str(self.macros))
         self.bset = bset
-        _target = self.macros.expand('%{_target}')
+        _target = macro_expand(self.macros, '%{_target}')
         if len(_target):
             pkg_prefix = _target
         else:
-            pkg_prefix = self.macros.expand('%{_host}')
+            pkg_prefix = macro_expand(self.macros, '%{_host}')
         self.bset_pkg = '%s-%s-set' % (pkg_prefix, self.bset)
         self.mail_header = ''
         self.mail_report = ''
@@ -152,7 +161,7 @@ class buildset:
             else:
                 raise error.general('invalid report format: %s' % (format))
             buildroot = _build.config.abspath('%{buildroot}')
-            prefix = _build.macros.expand('%{_prefix}')
+            prefix = macro_expand(_build.macros, '%{_prefix}')
             name = _build.main_package().name() + ext
             log.notice('reporting: %s -> %s' % (_config, name))
             if not _build.opts.get_arg('--no-report'):
@@ -182,17 +191,24 @@ class buildset:
     def root_copy(self, src, dst):
         what = '%s -> %s' % \
             (os.path.relpath(path.host(src)), os.path.relpath(path.host(dst)))
-        log.trace('_bset: %s: collecting: %s' % (self.bset, what))
+        log.trace('_bset:   : %s: collecting: %s' % (self.bset, what))
         self.copy(src, dst)
-    def install(self, name, buildroot, prefix):
-        dst = prefix
-        src = path.join(buildroot, prefix)
-        log.notice('installing: %s -> %s' % (name, path.host(dst)))
+    def install(self, mode, name, src, dst):
+        log.notice('%s: %s -> %s' % (mode, name, path.host(dst)))
         self.copy(src, dst)
+    def install_mode(self):
+        return macro_expand(self.macros, '%{install_mode}')
+    def installing(self):
+        return self.install_mode() == 'installing'
+    def staging(self):
+        return not self.installing()
     def canadian_cross(self, _build):
-        log.trace('_bset: Cxc for build machine: _build => _host')
+        log.trace('_bset:   : Cxc for build machine: _build => _host')
         macros_to_copy = [('%{_host}',        '%{_build}'),
                           ('%{_host_alias}',  '%{_build_alias}'),
                           ('%{_host_arch}',   '%{_build_arch}'),
@@ -204,7 +220,7 @@ class buildset:
                           ('%{_builddir}',    '%{_buildcxcdir}')]
         cxc_macros = _build.copy_init_macros()
         for m in macros_to_copy:
-            log.trace('_bset: Cxc: %s <= %s' % (m[0], cxc_macros[m[1]]))
+            log.trace('_bset:   : Cxc: %s <= %s' % (m[0], cxc_macros[m[1]]))
             cxc_macros[m[0]] = cxc_macros[m[1]]
         _build.set_macros(cxc_macros)
         _build.reload()
@@ -229,12 +245,15 @@ class buildset:
         if (self.opts.get_arg('--bset-tar-file') or self.opts.canadian_cross()) \
            and not _build.macros.get('%{_disable_packaging}'):
             path.mkdir(tardir)
-            tar = path.join(tardir, _build.config.expand('%s.tar.bz2' % (_build.main_package().name())))
+            tar = path.join(tardir,
+                            _build.config.expand('%s.tar.bz2' % \
+                                                 (_build.main_package().name())))
             log.notice('tarball: %s' % (os.path.relpath(path.host(tar))))
             if not self.opts.dry_run():
                 tmproot = _build.config.expand('%{_tmproot}')
                 cmd = _build.config.expand('"cd ' + tmproot + \
-                                               ' && %{__tar} -cf - . | %{__bzip2} > ' + tar + '"')
+                                           ' && %{__tar} -cf - . | %{__bzip2} > ' + \
+                                           tar + '"')
                 _build.run(cmd, shell_opts = '-c', cwd = tmproot)
     def parse(self, bset):
@@ -249,7 +268,7 @@ class buildset:
         bsetname = bset
         if not path.exists(bsetname):
-            for cp in self.macros.expand('%{_configdir}').split(':'):
+            for cp in macro_expand(self.macros, '%{_configdir}').split(':'):
                 configdir = path.abspath(cp)
                 bsetname = path.join(configdir, bset)
                 if path.exists(bsetname):
@@ -258,7 +277,7 @@ class buildset:
             if bsetname is None:
                 raise error.general('no build set file found: %s' % (bset))
         try:
-            log.trace('_bset: %s: open: %s' % (self.bset, bsetname))
+            log.trace('_bset:   : %s: open: %s' % (self.bset, bsetname))
             bset = open(path.host(bsetname), 'r')
         except IOError as err:
             raise error.general('error opening bset file: %s' % (bsetname))
@@ -272,7 +291,7 @@ class buildset:
                 l = _clean(l)
                 if len(l) == 0:
                     continue
-                log.trace('_bset: %s: %03d: %s' % (self.bset, lc, l))
+                log.trace('_bset:   : %s: %03d: %s' % (self.bset, lc, l))
                 ls = l.split()
                 if ls[0][-1] == ':' and ls[0][:-1] == 'package':
                     self.bset_pkg = ls[1].strip()
@@ -288,8 +307,8 @@ class buildset:
                             self.macros.define(ls[1].strip())
                     elif ls[0] == '%undefine':
                         if len(ls) > 2:
-                            raise error.general('%s:%d: %undefine requires just the name' % \
-                                                    (self.bset, lc))
+                            raise error.general('%s:%d: %undefine requires ' \
+                                                'just the name' % (self.bset, lc))
                         self.macros.undefine(ls[1].strip())
                     elif ls[0] == '%include':
                         configs += self.parse(ls[1].strip())
@@ -301,7 +320,8 @@ class buildset:
                     l = l.strip()
                     c = build.find_config(l, self.configs)
                     if c is None:
-                        raise error.general('%s:%d: cannot find file: %s' % (self.bset, lc, l))
+                        raise error.general('%s:%d: cannot find file: %s' % (self.bset,
+        lc, l))
                     configs += [c]
         except:
             bset.close()
@@ -320,9 +340,12 @@ class buildset:
         if self.bset.endswith('.cfg'):
             configs = [self.bset]
         else:
-            exbset = self.macros.expand(self.bset)
+            exbset = macro_expand(self.macros, self.bset)
             self.macros['_bset'] = exbset
-            self.macros['_bset_tmp'] = build.short_name(exbset)
+            bset_tmp = build.short_name(exbset)
+            if bset_tmp.endswith('.bset'):
+                bset_tmp = bset_tmp[:-5]
+            self.macros['_bset_tmp'] = bset_tmp
             root, ext = path.splitext(exbset)
             if exbset.endswith('.bset'):
                 bset = exbset
@@ -340,7 +363,7 @@ class buildset:
         if mail:
             mail['output'].clear()
-        log.trace('_bset: %s: make' % (self.bset))
+        log.trace('_bset: %2d: %s: make' % (nesting_count, self.bset))
         log.notice('Build Set: %s' % (self.bset))
         mail_subject = '%s on %s' % (self.bset,
@@ -350,16 +373,44 @@ class buildset:
         start = datetime.datetime.now()
-        mail_report = False
-        have_errors = False
+        mail_report  = False
+        have_errors  = False
         if mail:
+        # If this is the outter most buildset it's files installed. Nested
+        # build sets staged their installed file. The staged files are install
+        # when the outtter most build finishes.
+        if nesting_count != 1:
+            if self.installing():
+                self.macros['install_mode'] = 'staging'
+                # Prepend staging areas, bin directory tothe
+                # path. Lets the later package depend on the eailier
+                # ones.
+                pathprepend = ['%{stagingroot}/bin'] + \
+                    macro_expand(self.macros, '%{_pathprepend}').split(':')
+                pathprepend = [pp for pp in pathprepend if len(pp)]
+                if len(pathprepend) == 1:
+                    self.macros['_pathprepend'] = pathprepend[0]
+                else:
+                    self.macros['_pathprepend'] = ':'.join(pathprepend)
+        # Only the outter build set can have staging to install. Get the staging
+        # root via the config because it could require a valid config.
+        have_staging = False
         try:
             configs = self.load()
-            log.trace('_bset: %s: configs: %s'  % (self.bset, ','.join(configs)))
+            log.trace('_bset: %2d: %s: configs: %s'  % (nesting_count,
+                                                        self.bset, ', '.join(configs)))
             sizes_valid = False
             builds = []
@@ -374,14 +425,20 @@ class buildset:
                     opts = copy.copy(self.opts)
                     macros = copy.copy(self.macros)
                     if configs[s].endswith('.bset'):
-                        log.trace('_bset: == %2d %s' % (nesting_count + 1, '=' * 75))
+                        log.trace('_bset: %2d: %s %s' % (nesting_count,
+                                                         configs[s],
+                                                         '=' * (74 - len(configs[s]))))
                         bs = buildset(configs[s], self.configs, opts, macros)
                         bs.build(deps, nesting_count, mail)
+                            have_staging = True
                         del bs
                     elif configs[s].endswith('.cfg'):
                         if mail:
                             mail_report = True
-                        log.trace('_bset: -- %2d %s' % (nesting_count + 1, '-' * 75))
+                                                         configs[s],
                         try:
                             b = build.build(configs[s],
                                             self.opts.get_arg('--pkg-tar-files'),
@@ -412,7 +469,7 @@ class buildset:
                         # Dump post build macros.
-                        log.trace('_bset: macros post-build')
+                        log.trace('_bset:   : macros post-build')
                         log.trace(str(b.macros))
                     else:
                         raise error.general('invalid config type: %s' % (configs[s]))
@@ -436,19 +493,25 @@ class buildset:
                     else:
                         raise
-            # Installing ...
+            # Installing or staging ...
-            log.trace('_bset: installing: deps:%r no-install:%r' % \
-                      (deps is None, self.opts.no_install()))
-            if deps is None \
-               and not self.opts.no_install() \
-               and not have_errors:
+            log.trace('_bset: %2d: %s: deps:%r no-install:%r' % \
+                      (nesting_count, self.install_mode(),
+                       deps is None, self.opts.no_install()))
+            log.trace('_bset: %2d: %s: builds: %s' % \
+                       ', '.join([b.name() for b in builds])))
+            if deps is None and not have_errors:
                 for b in builds:
-                    log.trace('_bset: installing: %r' % b.installable())
+                    log.trace('_bset:   : %s: %r' % (self.install_mode(),
+                                                     b.installable()))
                     if b.installable():
-                        self.install(b.name(),
-                                     b.config.expand('%{buildroot}'),
-                                     b.config.expand('%{_prefix}'))
+                        prefix = b.config.expand('%{_prefix}')
+                        buildroot = path.join(b.config.expand('%{buildroot}'), prefix)
+                        if self.staging():
+                            prefix = b.config.expand('%{stagingroot}')
+                        self.install(self.install_mode(), b.name(), buildroot, prefix)
             # Sizes ...
@@ -469,7 +532,8 @@ class buildset:
                 for p in builds[0].config.expand('%{_patchdir}').split(':'):
                     size_patches += path.get_size(p)
                 size_total = size_sources + size_patches + size_installed
-                build_max_size_human = build.humanize_number(size_build_max + size_installed, 'B')
+                build_max_size_human = build.humanize_number(size_build_max +
                 build_total_size_human = build.humanize_number(size_total, 'B')
                 build_sources_size_human = build.humanize_number(size_sources, 'B')
                 build_patches_size_human = build.humanize_number(size_patches, 'B')
@@ -499,6 +563,21 @@ class buildset:
             for b in builds:
                 del b
+            # If builds have been staged install into the finaly prefix.
+            if have_staging and not self.opts.no_install() and not have_errors:
+                log.trace('_bset: %2d: install staging' % (nesting_count))
+                stagingroot = macro_expand(self.macros, '%{stagingroot}')
+                prefix = macro_expand(self.macros, '%{_prefix}')
+                self.install(self.install_mode(), self.bset, stagingroot, prefix)
+                staging_size = path.get_size(stagingroot)
+                if not self.opts.no_clean() or self.opts.always_clean():
+                    log.notice('clean staging: %s' % (self.bset))
+                    log.trace('cleanup: %s' % (stagingroot))
+                    self.rmdir(stagingroot)
+                log.notice('Staging Size: %s' % (build.humanize_number(staging_size)))
         except error.general as gerr:
             if not build_error:
                 log.stderr(str(gerr))
@@ -586,7 +665,7 @@ def run():
             if to_addr is not None:
                 mail['to'] = to_addr[1]
             else:
-                mail['to'] = opts.defaults.expand('%{_mail_tools_to}')
+                mail['to'] = macro_expand(opts.defaults, '%{_mail_tools_to}')
             mail['from'] = mail['mail'].from_address()
         log.notice('RTEMS Source Builder - Set Builder, %s' % (version.str()))
         opts.log_info()
@@ -606,7 +685,7 @@ def run():
         else:
             deps = None
         if not list_bset_cfg_files(opts, configs):
-            prefix = opts.defaults.expand('%{_prefix}')
+            prefix = macro_expand(opts.defaults, '%{_prefix}')
             if opts.canadian_cross():
                 opts.disable_install()
diff --git a/source-builder/sb/shell.py b/source-builder/sb/shell.py
new file mode 100644
index 0000000..bebbe8a
--- /dev/null
+++ b/source-builder/sb/shell.py
@@ -0,0 +1,75 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2019 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+# This code builds a package compiler tool suite given a tool set. A tool
+# set lists the various tools. These are specific tool configurations.
+from __future__ import print_function
+try:
+    import error
+    import execute
+    import log
+    import options
+except KeyboardInterrupt:
+    print('abort: user terminated', file = sys.stderr)
+    sys.exit(1)
+except:
+    print('error: unknown application load error', file = sys.stderr)
+    sys.exit(1)
+def expand(macros, line):
+    # Parse the line and handle nesting '()' pairs.
+    def _exec(shell_macro):
+        output = ''
+        if len(shell_macro) > 3:
+            e = execute.capture_execution()
+            if options.host_windows:
+                cmd = '%s -c "%s"' % (macros.expand('%{__sh}'), shell_macro[2:-1])
+            else:
+                cmd = shell_macro[2:-1]
+            exit_code, proc, output = e.shell(cmd)
+            log.trace('shell-output: %d %s' % (exit_code, output))
+            if exit_code != 0:
+                raise error.general('shell macro failed: %s: %d: %s' % (cmd,
+        exit_code,
+        output))
+        return output
+    updating = True
+    while updating:
+        updating = False
+        pos = line.find('%(')
+        if pos >= 0:
+            braces = 0
+            for p in range(pos + 2, len(line)):
+                if line[p] == '(':
+                    braces += 1
+                elif line[p] == ')':
+                    if braces > 0:
+                        braces -= 1
+                    else:
+                        line = line[:pos] + _exec(line[pos:p + 1]) + line[p + 1:]
+                        updating = True
+                        break
+    return line
2.19.1
