[PATCH v4] ndbm test suite
Mon Jul 22 21:11:00 UTC 2019
On Sat, Jul 20, 2019 at 12:11 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> On Fri, Jul 19, 2019 at 2:12 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Jul 18, 2019 at 11:05 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>> >  testsuites/psxtests/Makefile.am      |   7 +
>> >  testsuites/psxtests/configure.ac     |   1 +
>> >  testsuites/psxtests/psxndbm01/init.c | 305 +++++++++++++++++++++++++++
>> >  3 files changed, 313 insertions(+)
>> >  create mode 100644 testsuites/psxtests/psxndbm01/init.c
>> > diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
>> > index 59c9f2085b..7d1c0a783c 100755
>> > --- a/testsuites/psxtests/Makefile.am
>> > +++ b/testsuites/psxtests/Makefile.am
>> > @@ -694,6 +694,13 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxmutexattr01) \
>> >         $(support_includes) -I$(top_srcdir)/include
>> >  endif
>> > +if TEST_psxndbm01
>> > +psx_tests += psxndbm01
>> > +psxndbm01_SOURCES = psxndbm01/init.c
>> > +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
>> > +       $(support_includes)
>> > +endif
>> >  if TEST_psxobj01
>> >  psx_tests += psxobj01
>> >  psx_screens += psxobj01/psxobj01.scn
>> > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
>> > index 85559e4aa5..07d7ccaf55 100644
>> > --- a/testsuites/psxtests/configure.ac
>> > +++ b/testsuites/psxtests/configure.ac
>> > @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
>> >  RTEMS_TEST_CHECK([psxmsgq03])
>> >  RTEMS_TEST_CHECK([psxmsgq04])
>> >  RTEMS_TEST_CHECK([psxmutexattr01])
>> > +RTEMS_TEST_CHECK([psxndbm01])
>> >  RTEMS_TEST_CHECK([psxobj01])
>> >  RTEMS_TEST_CHECK([psxonce01])
>> >  RTEMS_TEST_CHECK([psxpasswd01])
>> > diff --git a/testsuites/psxtests/psxndbm01/init.c b/testsuites/psxtests/psxndbm01/init.c
>> > new file mode 100644
>> > index 0000000000..d3b1e36ca0
>> > --- /dev/null
>> > +++ b/testsuites/psxtests/psxndbm01/init.c
>> > @@ -0,0 +1,305 @@
>> > + *  @file
>> > + *  @brief Test suite for ndbm.h methods
>> > + * SPDX-License-Identifier: BSD-2-Clause
>> > + * Copyright (C) 2019 Vaibhav Gupta
>> > + * Redistribution and use in source and binary forms, with or without
>> > + * modification, are permitted provided that the following conditions
>> > + * are met:
>> > + * 1. Redistributions of source code must retain the above copyright
>> > + *    notice, this list of conditions and the following disclaimer.
>> > + * 2. Redistributions in binary form must reproduce the above copyright
>> > + *    notice, this list of conditions and the following disclaimer in the
>> > + *    documentation and/or other materials provided with the distribution.
>> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> > + * POSSIBILITY OF SUCH DAMAGE.
>> > +#ifdef HAVE_CONFIG_H
>> > +#include "config.h"
>> > +#endif
>> > +/* header files are listed in lexical/lexicographical/alphabetical order */
>> > +#include <errno.h>
>> > +#include <fcntl.h>      /* contains definitions of 'open_flags' */
>> > +#include <limits.h>
>> > +#include <ndbm.h>       /* contains declarations of ndbm methods */
>> > +#include <stddef.h>
>> > +#include <stdint.h>
>> > +#include <stdio.h>
>> > +#include <sys/stat.h>   /* contains definitions of 'file_mode' */
>> > +#include <string.h>
>> > +#include <rtems/test.h>
>> > +#include <tmacros.h>
>> > +const char rtems_test_name[] = "PSXNDBM 01";
>> > +#define NAME      "VARoDeK"
>> > +#define PHONE_NO  "123-321-777-888"
>> > +#define DB_NAME   "phones_test"
>> > +#define NAME2     "VG"
>> > +#define PHONE_NO2 "321-123-888-777"
>> > +/* forward declarations to avoid warnings */
>> > +rtems_task Init(rtems_task_argument ignored);
>> > +int count_no_of_records( DBM *db_local );
>> > +* This Function takes DBM* as a argument and count the number of records in the
>> > +* database pointed by it.
>> declare it 'static', and you shouldn't need the forward declaration I think.
> Yah forward declaration is not needed, and it worked without it this time.
> I don't know why it was showing "int count_no_of_records( DBM *db_local ) not found".
>> > +  int count = 0;
>> > +  datum temp;
>> > +  for(
>> space after for
> Did that.
> This formatting rule is not mentioned in https://devel.rtems.org/wiki/Developer/Coding/Conventions
> in case of loops, should i add it?
It is intended to be there as "Put a single space inside and outside
of each parenthesis of a conditional expression." If it's not clear
this applies to for loops, then perhaps a minor rewording should be
done.
>> > +    temp = dbm_firstkey( db_local );
>> > +    temp.dptr != NULL;
>> > +    temp = dbm_nextkey( db_local ) , count++
>> no space before the comma.
>> > +  return count;
>> > +/* Test Function Begins */
>> > +  datum name          = { NAME, sizeof( NAME ) };
>> > +  datum put_phone_no  = { PHONE_NO, sizeof( PHONE_NO ) };
>> > +  datum name2         = { NAME2, sizeof( NAME2 ) };
>> > +  datum put_phone_no2 = { PHONE_NO2, sizeof( PHONE_NO2 ) };
>> > +  datum get_phone_no, key;
>> > +  int i;
>> > +  char *test_strings;
>> > +  DBM *db;
>> > +  TEST_BEGIN();
>> > +/* A Simple test to check if ndbm methods are call-able */
>> > + * A Simple test to check if NDBM methods are call-able
>> > + * We will try to open a database and then close it.
>> > + * If it successful, hence we can have further tests.
>> > + * Also, while opening it for first time, will create that database,
>> > + * hence we will be able to test for 'O_RDWR | O_EXCL' case later.
>> > + * Meanwhile we will also store one record, this record will be helpful in
>> > + * further tests.
>> > + * And fetch it, to make sure if basic NDBM methods are working correctly.
>> > +  puts( "\nOpen Database." );
>> > +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_TRUNC, S_IRWXU );
>> > +  rtems_test_assert( db != NULL );
>> > +  /* This data will be useful in further tests */
>> > +  puts( "Store Records in Database." );
>> > +  dbm_store( db, name, put_phone_no, DBM_INSERT );
>> > +  puts( "Fetch Records from Database and check." );
>> > +  get_phone_no = dbm_fetch( db, name );
>> > +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO ) == 0 );
>> > +  puts( "Close Database." );
>> > +  dbm_close( db );
>> > +/* dbm_open() */
>> > +  puts( "\nTestcases for 'dbm_open()'." );
>> > +/* The 'DB_NAME' is already created, hence 'O_RDWR | O_EXCL' should fail. */
>> > +  puts( "Use 'O_CREAT | O_EXCL' to open existing file and confirm error." );
>> > +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_EXCL, S_IRWXU );
>> > +  rtems_test_assert( db == NULL );
>> > +  rtems_test_assert( errno == EEXIST );
>> > +/* Some implementations use 3 characters for the suffix and others use
>> > + * 4 characters for the suffix, applications should ensure that the maximum
>> > + * portable pathname length passed to dbm_open() is no greater than
>> > + * {PATH_MAX}-4 bytes, with the last component of the pathname no greater
>> > + * than {NAME_MAX}-4 bytes.
>> > +/* inside 'ndbm.h' ; '#define  DBM_SUFFIX      ".db"' ;
>> > + * 2 alphabets and 1 period, hence 3 characters are used for suffix
>> > + * in this implementation.
>> > +  puts( "Use path name larger than '{PATH_MAX}-3 bytes.' and confirm error." );
>> > +  test_strings = (char*)malloc( PATH_MAX - 2 );
>> > +  for ( i = 0; i < PATH_MAX - 3; i++ )
>> Put { on same line as for, with a white space before it.
>> > +    test_strings[i] = 'r';
>> > +  test_strings[i] = '\0';
>> > +  db = dbm_open(
>> > +                (const char*)test_strings,
>> > +                O_RDWR | O_CREAT | O_TRUNC,
>> > +                S_IRWXU
>> Line up the closing parenthesis on the same indentation level as the
>> first line in the statement.
> And this one too, it is no where mentioned about wrapping up functions calls
> in 80 characters, when needed, in this site https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line
> Should I add this too?
An example with a function call might be nice to include there.
>> > +  rtems_test_assert( errno == ENAMETOOLONG );
>> > +  free( test_strings );
>> > +/* database opened for write-only access opens the files for read and
>> > + * write access or it will fail.
>> > +/* Implementation of __hash_open in newlib does not support `O_WRONLY` */
>> > +  puts( "Open file with write access only and confirm error." );
>> > +  db = dbm_open( DB_NAME , O_WRONLY , S_IRWXU );
>> no spaces before commas
>> > +  rtems_test_assert( errno == EINVAL );
>> > +/* dbm_store() */
>> > +  puts( "\nTestcases for 'dbm_store()'" );
>> > +  db = dbm_open( DB_NAME , O_RDWR , S_IRWXU );
>> > +  puts( "Insert new record with same key using 'DBM_INSERT' mode and "
>> > +        "confirm error." );
>> > +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_INSERT ) == 1 );
>> > +  puts( "Insert new record with same key using 'DBM_REPLACE' mode and "
>> > +        "confirm changes." );
>> > +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_REPLACE ) == 0 );
>> > +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO2 ) == 0 );
>> > +/* Revert for next tests */
>> > +  rtems_test_assert( dbm_store( db, name, put_phone_no, DBM_REPLACE ) == 0 );
>> > +  puts( "Store a new record and "
>> > +        "confirm that total number of records is successful 2." );
>> > +  rtems_test_assert( dbm_store( db, name2, put_phone_no2, DBM_INSERT ) == 0 );
>> > +/* Confirm number of records */
>> > +  rtems_test_assert( count_no_of_records( db ) == 2 );
>> > +  dbm_close( db );
>> > +/* dbm_fetch() */
>> > +  puts( "\nTestcases for 'dbm_fetch()'" );
>> > +  db = dbm_open( DB_NAME, O_RDONLY, S_IRWXU );
>> > +  puts( "Fetch existing records and confirm results." );
>> > +  get_phone_no = dbm_fetch( db, name2 );
>> > +  puts( "Fetch non-existing record and confirm error." );
>> > +  test_strings = (char*)malloc(6);
>> > +  strncpy( test_strings, "Hello", 5 );
>> > + * We could have used test_strings[5], but since its a dynamic data, we wrote
>> > + * it in the form of dereference of a pointer.
>> > +  *(test_strings + 5) = '\0';
>> Why? this is equivalent to test_strings[5] = 0; and can either be
>> written as such, or how you did it, but we don't need the comment.
> Yah, actually it was due to my coding style, I usually use pointer
> arithmetic when using pointers, and hence mentioned comment.
> Although I have replaced it with test_strings[5] = '\0', now.
>> Usually it is preferred to avoid pointer arithmetic when an array
>> notation suffices.
>> > +/* The data pointed by test_string is now pointed by key.dptr */
>> > +  key.dptr = test_strings;
>> > +  key.dsize = sizeof( test_strings );
>> > +  get_phone_no = dbm_fetch( db, key );
>> > +  rtems_test_assert( get_phone_no.dptr == NULL );
>> > +  dbm_close( db );
>> > +/* We need the 'key' boject, hence we cannot free 'test_strings' */
>> typo:  object
>> > +/* dbm_delete() */
>> > +  puts( "\nTestcases for 'dbm_delete()'" );
>> > +  db = dbm_open( DB_NAME, O_RDWR, S_IRWXU );
>> > +  puts( "Delete non-existing record and confirm error." );
>> > +  rtems_test_assert( dbm_delete( db, key ) != 0 );
>> > +  rtems_test_assert( count_no_of_records( db ) == 2);
>> > +  puts( "Delete existing record and "
>> > +        "confirm that total number of records is successful 1." );
>> > +  rtems_test_assert( dbm_delete( db, name ) == 0 );
>> > +  rtems_test_assert( count_no_of_records( db ) == 1);
>> > +  puts( "Confirm if correct record is deleted." );
>> > +/* record returned by 'dbm_firstkey()' should be the only record
>> > + * left, this should be checked to confirm correct working of
>> > + * 'dbm_firstkey()'.
>> > + * Check if the data is not corrupted after usage of 'dbm_delete()'
>> > +  puts( "Check if the data is not corrupted after usage of 'dbm_delete()'." );
>> > +  get_phone_no = dbm_fetch( db, dbm_firstkey( db ) );
>> > +/* Empty the database and then try to use 'dbm_firstkey()', the
>> > + * dptr pointer should point to NULL.
>> > +  puts( "Empty records in database and check results of 'dbm_firstkey()'." );
>> > +  rtems_test_assert( dbm_delete( db, dbm_firstkey( db ) ) == 0 );
>> > +  key = dbm_firstkey( db );
>> > +  rtems_test_assert( key.dptr == NULL );
>> > +  dbm_close( db );
>> > +* All cases for 'dbm_firstkey()' and 'dbm_nextkey()' were tested while
>> > +* performing other tests.
>> > +* One such case be found in count_number_of_records() function.
>> > +  TEST_END();
>> > +  rtems_test_exit(0);
>> > +/* NOTICE: the clock driver is explicitly disabled */
>> > +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> > +#define CONFIGURE_MAXIMUM_TASKS                  1
>> > +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
>> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> > +#include <rtems/confdefs.h>
>> > +/* end of file */
>> > 2.21.0
