[PATCH v5] ndbm test suite
Mon Jul 22 21:11:48 UTC 2019
Add .scn and .doc files please. Then this is probably good to go.
On Sat, Jul 20, 2019 at 12:12 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>  testsuites/psxtests/Makefile.am      |   7 +
>  testsuites/psxtests/configure.ac     |   1 +
>  testsuites/psxtests/psxndbm01/init.c | 299 +++++++++++++++++++++++++++
>  3 files changed, 307 insertions(+)
>  create mode 100644 testsuites/psxtests/psxndbm01/init.c
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index 59c9f2085b..7d1c0a783c 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -694,6 +694,13 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxmutexattr01) \
>         $(support_includes) -I$(top_srcdir)/include
>  endif
> +if TEST_psxndbm01
> +psx_tests += psxndbm01
> +psxndbm01_SOURCES = psxndbm01/init.c
> +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
> +       $(support_includes)
> +endif
>  if TEST_psxobj01
>  psx_tests += psxobj01
>  psx_screens += psxobj01/psxobj01.scn
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index 85559e4aa5..07d7ccaf55 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
>  RTEMS_TEST_CHECK([psxmsgq03])
>  RTEMS_TEST_CHECK([psxmsgq04])
>  RTEMS_TEST_CHECK([psxmutexattr01])
> +RTEMS_TEST_CHECK([psxndbm01])
>  RTEMS_TEST_CHECK([psxobj01])
>  RTEMS_TEST_CHECK([psxonce01])
>  RTEMS_TEST_CHECK([psxpasswd01])
> diff --git a/testsuites/psxtests/psxndbm01/init.c b/testsuites/psxtests/psxndbm01/init.c
> new file mode 100644
> index 0000000000..a1eff4bd67
> --- /dev/null
> +++ b/testsuites/psxtests/psxndbm01/init.c
> @@ -0,0 +1,299 @@
> + *  @file
> + *  @brief Test suite for ndbm.h methods
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2019 Vaibhav Gupta
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +/* header files are listed in lexical/lexicographical/alphabetical order */
> +#include <errno.h>
> +#include <fcntl.h>      /* contains definitions of 'open_flags' */
> +#include <limits.h>
> +#include <ndbm.h>       /* contains declarations of ndbm methods */
> +#include <stddef.h>
> +#include <stdint.h>
> +#include <stdio.h>
> +#include <sys/stat.h>   /* contains definitions of 'file_mode' */
> +#include <string.h>
> +#include <rtems/test.h>
> +#include <tmacros.h>
> +const char rtems_test_name[] = "PSXNDBM 01";
> +#define NAME      "VARoDeK"
> +#define PHONE_NO  "123-321-777-888"
> +#define DB_NAME   "phones_test"
> +#define NAME2     "VG"
> +#define PHONE_NO2 "321-123-888-777"
> +/* forward declarations to avoid warnings */
> +rtems_task Init(rtems_task_argument ignored);
> +* This Function takes DBM* as a argument and count the number of records in the
> +* database pointed by it.
> +static int count_no_of_records( DBM *db_local )
> +  int count = 0;
> +  datum temp;
> +  for (
> +    temp = dbm_firstkey( db_local );
> +    temp.dptr != NULL;
> +    temp = dbm_nextkey( db_local ), count++
> +  return count;
> +/* Test Function Begins */
> +  datum name          = { NAME, sizeof( NAME ) };
> +  datum put_phone_no  = { PHONE_NO, sizeof( PHONE_NO ) };
> +  datum name2         = { NAME2, sizeof( NAME2 ) };
> +  datum put_phone_no2 = { PHONE_NO2, sizeof( PHONE_NO2 ) };
> +  datum get_phone_no, key;
> +  int i;
> +  char *test_strings;
> +  DBM *db;
> +  TEST_BEGIN();
> +/* A Simple test to check if ndbm methods are call-able */
> + * A Simple test to check if NDBM methods are call-able
> + * We will try to open a database and then close it.
> + * If it successful, hence we can have further tests.
> + * Also, while opening it for first time, will create that database,
> + * hence we will be able to test for 'O_RDWR | O_EXCL' case later.
> + * Meanwhile we will also store one record, this record will be helpful in
> + * further tests.
> + * And fetch it, to make sure if basic NDBM methods are working correctly.
> +  puts( "\nOpen Database." );
> +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_TRUNC, S_IRWXU );
> +  rtems_test_assert( db != NULL );
> +  /* This data will be useful in further tests */
> +  puts( "Store Records in Database." );
> +  dbm_store( db, name, put_phone_no, DBM_INSERT );
> +  puts( "Fetch Records from Database and check." );
> +  get_phone_no = dbm_fetch( db, name );
> +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO ) == 0 );
> +  puts( "Close Database." );
> +  dbm_close( db );
> +/* dbm_open() */
> +  puts( "\nTestcases for 'dbm_open()'." );
> +/* The 'DB_NAME' is already created, hence 'O_RDWR | O_EXCL' should fail. */
> +  puts( "Use 'O_CREAT | O_EXCL' to open existing file and confirm error." );
> +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_EXCL, S_IRWXU );
> +  rtems_test_assert( db == NULL );
> +  rtems_test_assert( errno == EEXIST );
> +/* Some implementations use 3 characters for the suffix and others use
> + * 4 characters for the suffix, applications should ensure that the maximum
> + * portable pathname length passed to dbm_open() is no greater than
> + * {PATH_MAX}-4 bytes, with the last component of the pathname no greater
> + * than {NAME_MAX}-4 bytes.
> +/* inside 'ndbm.h' ; '#define  DBM_SUFFIX      ".db"' ;
> + * 2 alphabets and 1 period, hence 3 characters are used for suffix
> + * in this implementation.
> +  puts( "Use path name larger than '{PATH_MAX}-3 bytes.' and confirm error." );
> +  test_strings = (char*)malloc( PATH_MAX - 2 );
> +  for ( i = 0; i < PATH_MAX - 3; i++ ) {
> +    test_strings[i] = 'r';
> +  test_strings[i] = '\0';
> +  db = dbm_open(
> +                (const char*)test_strings,
> +                O_RDWR | O_CREAT | O_TRUNC,
> +                S_IRWXU
> +  rtems_test_assert( errno == ENAMETOOLONG );
> +  free( test_strings );
> +/* database opened for write-only access opens the files for read and
> + * write access or it will fail.
> +/* Implementation of __hash_open in newlib does not support `O_WRONLY` */
> +  puts( "Open file with write access only and confirm error." );
> +  db = dbm_open( DB_NAME, O_WRONLY, S_IRWXU );
> +  rtems_test_assert( errno == EINVAL );
> +/* dbm_store() */
> +  puts( "\nTestcases for 'dbm_store()'" );
> +  db = dbm_open( DB_NAME, O_RDWR, S_IRWXU );
> +  puts( "Insert new record with same key using 'DBM_INSERT' mode and "
> +        "confirm error." );
> +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_INSERT ) == 1 );
> +  puts( "Insert new record with same key using 'DBM_REPLACE' mode and "
> +        "confirm changes." );
> +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_REPLACE ) == 0 );
> +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO2 ) == 0 );
> +/* Revert for next tests */
> +  rtems_test_assert( dbm_store( db, name, put_phone_no, DBM_REPLACE ) == 0 );
> +  puts( "Store a new record and "
> +        "confirm that total number of records is successful 2." );
> +  rtems_test_assert( dbm_store( db, name2, put_phone_no2, DBM_INSERT ) == 0 );
> +/* Confirm number of records */
> +  rtems_test_assert( count_no_of_records( db ) == 2 );
> +  dbm_close( db );
> +/* dbm_fetch() */
> +  puts( "\nTestcases for 'dbm_fetch()'" );
> +  db = dbm_open( DB_NAME, O_RDONLY, S_IRWXU );
> +  puts( "Fetch existing records and confirm results." );
> +  get_phone_no = dbm_fetch( db, name2 );
> +  puts( "Fetch non-existing record and confirm error." );
> +  test_strings = (char*)malloc(6);
> +  strncpy( test_strings, "Hello", 5 );
> +  test_strings[5] = '\0';
> +/* The data pointed by test_string is now pointed by key.dptr */
> +  key.dptr = test_strings;
> +  key.dsize = sizeof( test_strings );
> +  get_phone_no = dbm_fetch( db, key );
> +  rtems_test_assert( get_phone_no.dptr == NULL );
> +  dbm_close( db );
> +/* We need the 'key' object, hence we cannot free 'test_strings' */
> +/* dbm_delete() */
> +  puts( "\nTestcases for 'dbm_delete()'" );
> +  puts( "Delete non-existing record and confirm error." );
> +  rtems_test_assert( dbm_delete( db, key ) != 0 );
> +  rtems_test_assert( count_no_of_records( db ) == 2);
> +  puts( "Delete existing record and "
> +        "confirm that total number of records is successful 1." );
> +  rtems_test_assert( dbm_delete( db, name ) == 0 );
> +  rtems_test_assert( count_no_of_records( db ) == 1);
> +  puts( "Confirm if correct record is deleted." );
> +/* record returned by 'dbm_firstkey()' should be the only record
> + * left, this should be checked to confirm correct working of
> + * 'dbm_firstkey()'.
> + * Check if the data is not corrupted after usage of 'dbm_delete()'
> +  puts( "Check if the data is not corrupted after usage of 'dbm_delete()'." );
> +  get_phone_no = dbm_fetch( db, dbm_firstkey( db ) );
> +/* Empty the database and then try to use 'dbm_firstkey()', the
> + * dptr pointer should point to NULL.
> +  puts( "Empty records in database and check results of 'dbm_firstkey()'." );
> +  rtems_test_assert( dbm_delete( db, dbm_firstkey( db ) ) == 0 );
> +  key = dbm_firstkey( db );
> +  rtems_test_assert( key.dptr == NULL );
> +  dbm_close( db );
> +* All cases for 'dbm_firstkey()' and 'dbm_nextkey()' were tested while
> +* performing other tests.
> +* One such case be found in count_number_of_records() function.
> +  TEST_END();
> +  rtems_test_exit(0);
> +/* NOTICE: the clock driver is explicitly disabled */
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS                  1
> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#include <rtems/confdefs.h>
> +/* end of file */
> 2.21.0
