GSoC Project | Basic Support for Trace Compass
Tue Jul 23 05:00:34 UTC 2019
On 23/07/2019 06:35, Ravindra Kumar Meena wrote:
>     You have to maintain this information per CPU.
> Have made changes.
> https://github.com/rmeena840/rtems-tools/commit/b70b1f820241ab97828c29a23982a4b34b95fe03
> https://github.com/rmeena840/rtems-tools/commit/0becdc4025583d255f9ef976cfde275a86601d11
I said this before, do not add global variables like this:
  static void print_item( client_context *cctx, const client_item *item )
    switch_event switch_event;
    event_header_extended event_header_extended;
    char item_data_str[256];
    FILE **f = cctx->event_streams;
+  static size_t event_counter = 1;
+  static uint8_t prev_comm[16];
+  static int32_t prev_tid;
+  static uint32_t cpu_id;
+  static uint64_t ns;
Move all your state to client_context. I said also that you have to
create the sched_switch event per CPU.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
