[PATCH] devel/sis: Fix building the SIS on FreeBSD
chrisj at rtems.org chrisj at rtems.org
Tue Jul 23 11:51:14 UTC 2019
- Update to SIS 2.17 which has internal readline support for
  the hosts which do not have readline.
Closes #3763
 bare/config/devel/sis-2-1.cfg     |  5 ++---
 rtems/config/5/rtems-riscv.bset   |  2 +-
 rtems/config/5/rtems-sparc.bset   |  3 +--
 source-builder/config/sis-2-1.cfg | 17 +++++------------
 4 files changed, 9 insertions(+), 18 deletions(-)
diff --git a/bare/config/devel/sis-2-1.cfg b/bare/config/devel/sis-2-1.cfg
index ad6e527..c896522 100644
--- a/bare/config/devel/sis-2-1.cfg
+++ b/bare/config/devel/sis-2-1.cfg
@@ -8,11 +8,10 @@
 %include %{_configdir}/base.cfg
-%define sis_version 2.16
-%hash sha256 sis-%{sis_version}.tar.bz2 37cdb8f5cc1255e273423f580f5c76755e5851dabb677f6bc1100f27557b8dce
+%define sis_version 2.17
+%hash sha256 sis-%{sis_version}.tar.bz2 5125a8924688223b8341c2c26f51490069035da764e43f422c3fc119ddcae1a3
 # The sis build instructions. We use 2.15
 %include %{_configdir}/sis-2-1.cfg
diff --git a/rtems/config/5/rtems-riscv.bset b/rtems/config/5/rtems-riscv.bset
index bff4c44..a7964ef 100644
--- a/rtems/config/5/rtems-riscv.bset
+++ b/rtems/config/5/rtems-riscv.bset
@@ -14,4 +14,4 @@ tools/rtems-gdb-8.2.1-1
 tools/rtems-binutils-2.32
 tools/rtems-gcc-9.1.0-newlib-5c2a3661c
 tools/rtems-tools-5-1
-devel/sis-2-1.cfg
+devel/sis-2-1
diff --git a/rtems/config/5/rtems-sparc.bset b/rtems/config/5/rtems-sparc.bset
index 23ddaca..60bb792 100644
--- a/rtems/config/5/rtems-sparc.bset
+++ b/rtems/config/5/rtems-sparc.bset
@@ -2,5 +2,4 @@
 %define rtems_arch sparc
 %define with_libgomp
 %include 5/rtems-default.bset
-devel/sis-2-1.cfg
+devel/sis-2-1
diff --git a/source-builder/config/sis-2-1.cfg b/source-builder/config/sis-2-1.cfg
index a07b2db..9875728 100644
--- a/source-builder/config/sis-2-1.cfg
+++ b/source-builder/config/sis-2-1.cfg
@@ -31,26 +31,19 @@ Release:   %{release}
   cd sis-%{sis_version}
-  ac_prefix=%{_prefix}
-  if test "%{_build}" != "%{_host}" ; then
-    CFLAGS_FOR_BUILD="-g -O2 -Wall"
-  fi
-  export CFLAGS CFLAGS_FOR_BUILD CC
   if test "%{_target}" != "" ; then
     SIS_PREFIX="%{_target}-"
   fi
-  CFLAGS="$SB_CFLAGS" \
+  %{host_build_flags}
   ./configure \
-    --build=%{_build} --host=%{_host} \
+    --build=%{_build} --host=%{_host} --target=%{_target} \
     --program-prefix="$SIS_PREFIX" \
-    --prefix=${ac_prefix}
+    --prefix=${_prefix}
   %{__make} %{?_smp_mflags} all
-  unset CFLAGS_FOR_BUILD
   cd ${build_top}
 %install
2.20.1
