[PATCH] arm/start.S: Do not use a scratch register to hold the stack pointer
Fri Jul 26 05:07:47 UTC 2019
On 26/07/2019 07:06, Sebastian Huber wrote:
> Hello Chris,
> I am not sure, if using r8 is the right thing to do since r8..r14 are
> banked in FIQ mode. I think the bsp_start_arm_drop_hyp_mode needs to be
> changed to not touch r3, it can use r1 instead.
I think the code should move to start.S also.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
