[PATCH 2/3] bsps/arm: Move register init to start.S
Fri Jul 26 06:17:39 UTC 2019
This makes it easier to review changes in start.S.
Update #3773.
 bsps/arm/shared/start/bsp-start-init-registers.S | 105 -----------------------
 bsps/arm/shared/start/start.S                    |  59 ++++++++++++-
 c/src/lib/libbsp/arm/tms570/Makefile.am          |   1 -
 3 files changed, 55 insertions(+), 110 deletions(-)
 delete mode 100644 bsps/arm/shared/start/bsp-start-init-registers.S
diff --git a/bsps/arm/shared/start/bsp-start-init-registers.S b/bsps/arm/shared/start/bsp-start-init-registers.S
deleted file mode 100644
index 961d3172bf..0000000000
--- a/bsps/arm/shared/start/bsp-start-init-registers.S
+++ /dev/null
@@ -1,105 +0,0 @@
- * @file
- * @brief ARM register initialization routines.
- * Copyright (c) 2015 Taller Technologies.  All rights reserved.
- * @author Martin Galvan <martin.galvan at tallertechnologies.com>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
- * These routines initialize the core and VFP registers of ARM CPUs.
- * This is necessary for boards that operate in a 1oo1D fashion,
- * such as the TMS570.
-#include <rtems/asm.h>
-.section .text
-.syntax unified
-.cpu cortex-r4
-.arm
-/* Initialization of the ARM core registers. */
-FUNCTION_ENTRY(bsp_start_init_registers_core)
-	mov r0, #0
-	mov r1, #0
-	mov r2, #0
-	mov r3, #0
-	mov r4, #0
-	mov r5, #0
-	mov r6, #0
-	mov r7, #0
-	mov r8, #0
-	mov r9, #0
-	mov r10, #0
-	mov r11, #0
-	mov r12, #0
-	mov r13, #0
-	bx lr
-FUNCTION_END(bsp_start_init_registers_core)
-/* Initialization of the FIQ mode banked registers. */
-FUNCTION_ENTRY(bsp_start_init_registers_banked_fiq)
-	mov r8, #0
-	mov r9, #0
-	mov r10, #0
-	mov r11, #0
-	mov r12, #0
-	bx lr
-FUNCTION_END(bsp_start_init_registers_banked_fiq)
-#ifdef ARM_MULTILIB_VFP
-/* Initialization of the FPU registers. */
-FUNCTION_ENTRY(bsp_start_init_registers_vfp)
-	mov r0, #0
-	vmov d0, r0, r0
-	vmov d1, r0, r0
-	vmov d2, r0, r0
-	vmov d3, r0, r0
-	vmov d4, r0, r0
-	vmov d5, r0, r0
-	vmov d6, r0, r0
-	vmov d7, r0, r0
-	vmov d8, r0, r0
-	vmov d9, r0, r0
-	vmov d10, r0, r0
-	vmov d11, r0, r0
-	vmov d12, r0, r0
-	vmov d13, r0, r0
-	vmov d14, r0, r0
-	vmov d15, r0, r0
-#ifdef ARM_MULTILIB_VFP_D32
-	vmov d16, r0, r0
-	vmov d17, r0, r0
-	vmov d18, r0, r0
-	vmov d19, r0, r0
-	vmov d20, r0, r0
-	vmov d21, r0, r0
-	vmov d22, r0, r0
-	vmov d23, r0, r0
-	vmov d24, r0, r0
-	vmov d25, r0, r0
-	vmov d26, r0, r0
-	vmov d27, r0, r0
-	vmov d28, r0, r0
-	vmov d29, r0, r0
-	vmov d30, r0, r0
-	vmov d31, r0, r0
-#endif /* ARM_MULTILIB_VFP_D32 */
-	bx lr
-FUNCTION_END(bsp_start_init_registers_vfp)
-#endif /* ARM_MULTILIB_VFP */
diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
index a7fd7eda62..1f6d38f564 100644
--- a/bsps/arm/shared/start/start.S
+++ b/bsps/arm/shared/start/start.S
@@ -146,7 +146,20 @@ _start:
 	mov	r5, r1		/* machine type number or ~0 for DT boot */
 	mov	r6, r2		/* physical address of ATAGs or DTB */
 #else /* BSP_START_NEEDS_REGISTER_INITIALIZATION */
-	bl bsp_start_init_registers_core
+	mov	r0, #0
+	mov	r1, #0
+	mov	r2, #0
+	mov	r3, #0
+	mov	r4, #0
+	mov	r5, #0
+	mov	r6, #0
+	mov	r7, #0
+	mov	r8, #0
+	mov	r9, #0
+	mov	r10, #0
+	mov	r11, #0
+	mov	r12, #0
+	mov	r13, #0
 #endif
 #ifdef RTEMS_SMP
@@ -204,7 +217,11 @@ _start:
 	sub	r3, r3, r1
 #ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
-	bl bsp_start_init_registers_banked_fiq
+	mov	r8, #0
+	mov	r9, #0
+	mov	r10, #0
+	mov	r11, #0
+	mov	r12, #0
 #endif
 	/* Enter ABT mode and set up the ABT stack pointer */
@@ -271,8 +288,42 @@ _start:
 	vmsr FPEXC, r0
-	bl bsp_start_init_registers_vfp
-#endif
+	mov	r0, #0
+	vmov	d0, r0, r0
+	vmov	d1, r0, r0
+	vmov	d2, r0, r0
+	vmov	d3, r0, r0
+	vmov	d4, r0, r0
+	vmov	d5, r0, r0
+	vmov	d6, r0, r0
+	vmov	d7, r0, r0
+	vmov	d8, r0, r0
+	vmov	d9, r0, r0
+	vmov	d10, r0, r0
+	vmov	d11, r0, r0
+	vmov	d12, r0, r0
+	vmov	d13, r0, r0
+	vmov	d14, r0, r0
+	vmov	d15, r0, r0
+#ifdef ARM_MULTILIB_VFP_D32
+	vmov	d16, r0, r0
+	vmov	d17, r0, r0
+	vmov	d18, r0, r0
+	vmov	d19, r0, r0
+	vmov	d20, r0, r0
+	vmov	d21, r0, r0
+	vmov	d22, r0, r0
+	vmov	d23, r0, r0
+	vmov	d24, r0, r0
+	vmov	d25, r0, r0
+	vmov	d26, r0, r0
+	vmov	d27, r0, r0
+	vmov	d28, r0, r0
+	vmov	d29, r0, r0
+	vmov	d30, r0, r0
+	vmov	d31, r0, r0
+#endif /* ARM_MULTILIB_VFP_D32 */
+#endif /* BSP_START_NEEDS_REGISTER_INITIALIZATION */
diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
index bbff1ec7a6..40aed64f3f 100644
--- a/c/src/lib/libbsp/arm/tms570/Makefile.am
+++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
@@ -49,7 +49,6 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb
 # Startup
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/start/bsp-start-memcpy.S
-librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/start/bsp-start-init-registers.S
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/tms570/start/bspreset.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/tms570/start/bspstart.c
2.16.4
