[PATCH] arm/start.S: Do not use a scratch register to hold the stack pointer
Fri Jul 26 06:23:17 UTC 2019
On 26/07/2019 07:41, Chris Johns wrote:
> On 26/7/19 3:07 pm, Sebastian Huber wrote:
>> On 26/07/2019 07:06, Sebastian Huber wrote:
>>> Hello Chris,
>>> I am not sure, if using r8 is the right thing to do since r8..r14 are banked
>>> in FIQ mode. I think the bsp_start_arm_drop_hyp_mode needs to be changed to
>>> not touch r3, it can use r1 instead.
>> I think the code should move to start.S also.
> Sure, if you would like to do that. I have no time to spend on that sort of
> change. I am happy to test a change.
I sent three patches to the mailing list. Would you mind testing them on
top of the master.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
