[PATCH 05/10] fbd : Import from FreeBSD
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Jul 26 11:22:51 UTC 2019
 freebsd/sys/dev/fb/fb.c                   | 762 ++++++++++++++++++++++
 freebsd/sys/dev/fb/fbd.c                  | 372 +++++++++++
 freebsd/sys/dev/vt/colors/vt_termcolors.h |  63 ++
 freebsd/sys/dev/vt/hw/fb/vt_fb.h          |  54 ++
 4 files changed, 1251 insertions(+)
 create mode 100644 freebsd/sys/dev/fb/fb.c
 create mode 100644 freebsd/sys/dev/fb/fbd.c
 create mode 100644 freebsd/sys/dev/vt/colors/vt_termcolors.h
 create mode 100644 freebsd/sys/dev/vt/hw/fb/vt_fb.h
diff --git a/freebsd/sys/dev/fb/fb.c b/freebsd/sys/dev/fb/fb.c
new file mode 100644
index 00000000..a3263c91
--- /dev/null
+++ b/freebsd/sys/dev/fb/fb.c
@@ -0,0 +1,762 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1999 Kazutaka YOKOTA <yokota at zodiac.mech.utsunomiya-u.ac.jp>
+ * All rights reserved.
+ * are met:
+ *    notice, this list of conditions and the following disclaimer as
+ *    the first lines of this file unmodified.
+ * 3. The name of the author may not be used to endorse or promote products
+ *    derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/local/opt_fb.h>
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/conf.h>
+#include <sys/bus.h>
+#include <sys/kernel.h>
+#include <sys/malloc.h>
+#include <sys/module.h>
+#include <sys/uio.h>
+#include <sys/fbio.h>
+#include <sys/linker_set.h>
+#include <vm/vm.h>
+#include <vm/pmap.h>
+#include <dev/fb/fbreg.h>
+SET_DECLARE(videodriver_set, const video_driver_t);
+/* local arrays */
+ * We need at least one entry each in order to initialize a video card
+ * for the kernel console.  The arrays will be increased dynamically
+ * when necessary.
+static int		vid_malloc;
+static int		adapters = 1;
+static video_adapter_t	*adp_ini;
+static video_adapter_t	**adapter = &adp_ini;
+static video_switch_t	*vidsw_ini;
+       video_switch_t	**vidsw = &vidsw_ini;
+#ifdef FB_INSTALL_CDEV
+static struct cdevsw	*vidcdevsw_ini;
+static struct cdevsw	**vidcdevsw = &vidcdevsw_ini;
+#endif
+#define ARRAY_DELTA	4
+static int
+vid_realloc_array(void)
+	video_adapter_t **new_adp;
+	video_switch_t **new_vidsw;
+	struct cdevsw **new_cdevsw;
+#endif
+	int newsize;
+	int s;
+	if (!vid_malloc)
+		return ENOMEM;
+	s = spltty();
+	newsize = rounddown(adapters + ARRAY_DELTA, ARRAY_DELTA);
+	new_adp = malloc(sizeof(*new_adp)*newsize, M_DEVBUF, M_WAITOK | M_ZERO);
+	new_vidsw = malloc(sizeof(*new_vidsw)*newsize, M_DEVBUF,
+	    M_WAITOK | M_ZERO);
+	new_cdevsw = malloc(sizeof(*new_cdevsw)*newsize, M_DEVBUF,
+#endif
+	bcopy(adapter, new_adp, sizeof(*adapter)*adapters);
+	bcopy(vidsw, new_vidsw, sizeof(*vidsw)*adapters);
+	bcopy(vidcdevsw, new_cdevsw, sizeof(*vidcdevsw)*adapters);
+#endif
+	if (adapters > 1) {
+		free(adapter, M_DEVBUF);
+		free(vidsw, M_DEVBUF);
+		free(vidcdevsw, M_DEVBUF);
+#endif
+	adapter = new_adp;
+	vidsw = new_vidsw;
+	vidcdevsw = new_cdevsw;
+#endif
+	adapters = newsize;
+	splx(s);
+	if (bootverbose)
+		printf("fb: new array size %d\n", adapters);
+	return 0;
+static void
+vid_malloc_init(void *arg)
+	vid_malloc = TRUE;
+SYSINIT(vid_mem, SI_SUB_KMEM, SI_ORDER_ANY, vid_malloc_init, NULL);
+ * Low-level frame buffer driver functions
+ * frame buffer subdrivers, such as the VGA driver, call these functions
+ * to initialize the video_adapter structure and register it to the virtual
+ * frame buffer driver `fb'.
+/* initialize the video_adapter_t structure */
+void
+vid_init_struct(video_adapter_t *adp, char *name, int type, int unit)
+	adp->va_flags = 0;
+	adp->va_name = name;
+	adp->va_type = type;
+	adp->va_unit = unit;
+/* Register a video adapter */
+int
+vid_register(video_adapter_t *adp)
+	const video_driver_t **list;
+	const video_driver_t *p;
+	int index;
+	for (index = 0; index < adapters; ++index) {
+		if (adapter[index] == NULL)
+			break;
+	if (index >= adapters) {
+		if (vid_realloc_array())
+			return -1;
+	adp->va_index = index;
+	adp->va_token = NULL;
+	SET_FOREACH(list, videodriver_set) {
+		p = *list;
+		if (strcmp(p->name, adp->va_name) == 0) {
+			adapter[index] = adp;
+			vidsw[index] = p->vidsw;
+			return index;
+	return -1;
+int
+vid_unregister(video_adapter_t *adp)
+	if ((adp->va_index < 0) || (adp->va_index >= adapters))
+		return ENOENT;
+	if (adapter[adp->va_index] != adp)
+		return ENOENT;
+	adapter[adp->va_index] = NULL;
+	vidsw[adp->va_index] = NULL;
+	return 0;
+/* Get video I/O function table */
+video_switch_t
+*vid_get_switch(char *name)
+		p = *list;
+		if (strcmp(p->name, name) == 0)
+			return p->vidsw;
+	return NULL;
+ * Video card client functions
+ * Video card clients, such as the console driver `syscons' and the frame
+ * buffer cdev driver, use these functions to claim and release a card for
+ * exclusive use.
+/* find the video card specified by a driver name and a unit number */
+int
+vid_find_adapter(char *driver, int unit)
+	int i;
+	for (i = 0; i < adapters; ++i) {
+		if (adapter[i] == NULL)
+			continue;
+		if (strcmp("*", driver) && strcmp(adapter[i]->va_name, driver))
+			continue;
+		if ((unit != -1) && (adapter[i]->va_unit != unit))
+			continue;
+		return i;
+	return -1;
+/* allocate a video card */
+int
+vid_allocate(char *driver, int unit, void *id)
+	int index;
+	int s;
+	s = spltty();
+	index = vid_find_adapter(driver, unit);
+	if (index >= 0) {
+		if (adapter[index]->va_token) {
+			splx(s);
+			return -1;
+		adapter[index]->va_token = id;
+	splx(s);
+	return index;
+int
+vid_release(video_adapter_t *adp, void *id)
+	int error;
+	int s;
+	s = spltty();
+	if (adp->va_token == NULL) {
+		error = EINVAL;
+	} else if (adp->va_token != id) {
+		error = EPERM;
+	} else {
+		error = 0;
+	splx(s);
+	return error;
+/* Get a video adapter structure */
+video_adapter_t
+*vid_get_adapter(int index)
+	if ((index < 0) || (index >= adapters))
+		return NULL;
+	return adapter[index];
+/* Configure drivers: this is a backdoor for the console driver XXX */
+int
+vid_configure(int flags)
+		p = *list;
+		if (p->configure != NULL)
+			(*p->configure)(flags);
+	return 0;
+ * Virtual frame buffer cdev driver functions
+ * The virtual frame buffer driver dispatches driver functions to
+ * appropriate subdrivers.
+#define FB_DRIVER_NAME	"fb"
+#if 0 /* experimental */
+static devclass_t	fb_devclass;
+static int		fbprobe(device_t dev);
+static int		fbattach(device_t dev);
+static device_method_t fb_methods[] = {
+	DEVMETHOD(device_probe,		fbprobe),
+	DEVMETHOD(device_attach,	fbattach),
+	DEVMETHOD_END
+static driver_t fb_driver = {
+	FB_DRIVER_NAME,
+	fb_methods,
+	0,
+static int
+fbprobe(device_t dev)
+	int unit;
+	unit = device_get_unit(dev);
+	if (unit >= adapters)
+		return ENXIO;
+	if (adapter[unit] == NULL)
+		return ENXIO;
+	device_set_desc(dev, "generic frame buffer");
+	return 0;
+static int
+fbattach(device_t dev)
+	printf("fbattach: about to attach children\n");
+	bus_generic_attach(dev);
+	return 0;
+#endif
+#define FB_UNIT(dev)	dev2unit(dev)
+#define FB_MKMINOR(unit) (u)
+static d_open_t		fbopen;
+static d_close_t	fbclose;
+static d_read_t		fbread;
+static d_write_t	fbwrite;
+static d_ioctl_t	fbioctl;
+static d_mmap_t		fbmmap;
+static struct cdevsw fb_cdevsw = {
+	.d_version =	D_VERSION,
+	.d_flags =	D_NEEDGIANT,
+	.d_open =	fbopen,
+	.d_close =	fbclose,
+	.d_read =	fbread,
+	.d_write =	fbwrite,
+	.d_ioctl =	fbioctl,
+	.d_mmap =	fbmmap,
+	.d_name =	FB_DRIVER_NAME,
+#endif
+static int
+fb_modevent(module_t mod, int type, void *data)
+	switch (type) {
+	case MOD_LOAD:
+		break;
+	case MOD_UNLOAD:
+		printf("fb module unload - not possible for this module type\n");
+		return EINVAL;
+	default:
+		return EOPNOTSUPP;
+	return 0;
+static moduledata_t fb_mod = {
+	"fb",
+	fb_modevent,
+	NULL
+DECLARE_MODULE(fb, fb_mod, SI_SUB_PSEUDO, SI_ORDER_ANY);
+int
+fb_attach(int unit, video_adapter_t *adp, struct cdevsw *cdevsw)
+	int s;
+	if (adp->va_index >= adapters)
+		return EINVAL;
+		return EINVAL;
+	s = spltty();
+	adp->va_minor = unit;
+	vidcdevsw[adp->va_index] = cdevsw;
+	splx(s);
+	printf("fb%d at %s%d\n", adp->va_index, adp->va_name, adp->va_unit);
+	return 0;
+int
+fb_detach(int unit, video_adapter_t *adp, struct cdevsw *cdevsw)
+	int s;
+		return EINVAL;
+		return EINVAL;
+	if (vidcdevsw[adp->va_index] != cdevsw)
+		return EINVAL;
+	s = spltty();
+	vidcdevsw[adp->va_index] = NULL;
+	splx(s);
+	return 0;
+ * Generic frame buffer cdev driver functions
+ * Frame buffer subdrivers may call these functions to implement common
+ * driver functions.
+int genfbopen(genfb_softc_t *sc, video_adapter_t *adp, int flag, int mode,
+	      struct thread *td)
+	int s;
+	s = spltty();
+	if (!(sc->gfb_flags & FB_OPEN))
+		sc->gfb_flags |= FB_OPEN;
+	splx(s);
+	return 0;
+int genfbclose(genfb_softc_t *sc, video_adapter_t *adp, int flag, int mode,
+	int s;
+	s = spltty();
+	sc->gfb_flags &= ~FB_OPEN;
+	splx(s);
+	return 0;
+int genfbread(genfb_softc_t *sc, video_adapter_t *adp, struct uio *uio,
+	      int flag)
+	int size;
+	int offset;
+	int error;
+	int len;
+	error = 0;
+	size = adp->va_buffer_size/adp->va_info.vi_planes;
+	while (uio->uio_resid > 0) {
+		if (uio->uio_offset >= size)
+			break;
+		offset = uio->uio_offset%adp->va_window_size;
+		len = imin(uio->uio_resid, size - uio->uio_offset);
+		len = imin(len, adp->va_window_size - offset);
+		if (len <= 0)
+			break;
+		vidd_set_win_org(adp, uio->uio_offset);
+		error = uiomove((caddr_t)(adp->va_window + offset), len, uio);
+		if (error)
+			break;
+	return error;
+int genfbwrite(genfb_softc_t *sc, video_adapter_t *adp, struct uio *uio,
+	       int flag)
+	return ENODEV;
+int genfbioctl(genfb_softc_t *sc, video_adapter_t *adp, u_long cmd,
+	       caddr_t arg, int flag, struct thread *td)
+	int error;
+	if (adp == NULL)	/* XXX */
+		return ENXIO;
+	error = vidd_ioctl(adp, cmd, arg);
+	if (error == ENOIOCTL)
+		error = ENODEV;
+	return error;
+int genfbmmap(genfb_softc_t *sc, video_adapter_t *adp, vm_ooffset_t offset,
+	      vm_offset_t *paddr, int prot, vm_memattr_t *memattr)
+	return vidd_mmap(adp, offset, paddr, prot, memattr);
+#endif /* FB_INSTALL_CDEV */
+static char
+*adapter_name(int type)
+    static struct {
+	int type;
+	char *name;
+    } names[] = {
+	{ KD_MONO,	"MDA" },
+	{ KD_HERCULES,	"Hercules" },
+	{ KD_CGA,	"CGA" },
+	{ KD_EGA,	"EGA" },
+	{ KD_VGA,	"VGA" },
+	{ KD_TGA,	"TGA" },
+	{ -1,		"Unknown" },
+    int i;
+    for (i = 0; names[i].type != -1; ++i)
+	if (names[i].type == type)
+	    break;
+    return names[i].name;
+ * Generic low-level frame buffer functions
+ * The low-level functions in the frame buffer subdriver may use these
+ * functions.
+void
+fb_dump_adp_info(char *driver, video_adapter_t *adp, int level)
+    if (level <= 0)
+	return;
+    printf("%s%d: %s%d, %s, type:%s (%d), flags:0x%x\n",
+	   FB_DRIVER_NAME, adp->va_index, driver, adp->va_unit, adp->va_name,
+	   adapter_name(adp->va_type), adp->va_type, adp->va_flags);
+    printf("%s%d: port:0x%lx-0x%lx, crtc:0x%lx, mem:0x%lx 0x%x\n",
+	   FB_DRIVER_NAME, adp->va_index, (u_long)adp->va_io_base,
+	   (u_long)adp->va_io_base + adp->va_io_size - 1,
+	   (u_long)adp->va_crtc_addr, (u_long)adp->va_mem_base,
+	   adp->va_mem_size);
+    printf("%s%d: init mode:%d, bios mode:%d, current mode:%d\n",
+	   adp->va_initial_mode, adp->va_initial_bios_mode, adp->va_mode);
+    printf("%s%d: window:%p size:%dk gran:%dk, buf:%p size:%dk\n",
+	   (void *)adp->va_window, (int)adp->va_window_size/1024,
+	   (int)adp->va_window_gran/1024, (void *)adp->va_buffer,
+	   (int)adp->va_buffer_size/1024);
+void
+fb_dump_mode_info(char *driver, video_adapter_t *adp, video_info_t *info,
+		  int level)
+    if (level <= 0)
+	return;
+    printf("%s%d: %s, mode:%d, flags:0x%x ",
+	   driver, adp->va_unit, adp->va_name, info->vi_mode, info->vi_flags);
+    if (info->vi_flags & V_INFO_GRAPHICS)
+	printf("G %dx%dx%d, %d plane(s), font:%dx%d, ",
+	       info->vi_width, info->vi_height,
+	       info->vi_depth, info->vi_planes,
+	       info->vi_cwidth, info->vi_cheight);
+    else
+	printf("T %dx%d, font:%dx%d, ",
+    printf("win:0x%lx\n", (u_long)info->vi_window);
+int
+fb_type(int adp_type)
+	static struct {
+		int	fb_type;
+		int	va_type;
+	} types[] = {
+		{ FBTYPE_MDA,		KD_MONO },
+		{ FBTYPE_HERCULES,	KD_HERCULES },
+		{ FBTYPE_CGA,		KD_CGA },
+		{ FBTYPE_EGA,		KD_EGA },
+		{ FBTYPE_VGA,		KD_VGA },
+		{ FBTYPE_TGA,		KD_TGA },
+	int i;
+	for (i = 0; i < nitems(types); ++i) {
+		if (types[i].va_type == adp_type)
+			return types[i].fb_type;
+	return -1;
+int
+fb_commonioctl(video_adapter_t *adp, u_long cmd, caddr_t arg)
+	int error;
+	int s;
+	/* assert(adp != NULL) */
+	error = 0;
+	s = spltty();
+	switch (cmd) {
+	case FBIO_ADAPTER:	/* get video adapter index */
+		*(int *)arg = adp->va_index;
+		break;
+	case FBIO_ADPTYPE:	/* get video adapter type */
+		*(int *)arg = adp->va_type;
+		break;
+	case FBIO_ADPINFO:	/* get video adapter info */
+	        ((video_adapter_info_t *)arg)->va_index = adp->va_index;
+		((video_adapter_info_t *)arg)->va_type = adp->va_type;
+		bcopy(adp->va_name, ((video_adapter_info_t *)arg)->va_name,
+		      imin(strlen(adp->va_name) + 1,
+			   sizeof(((video_adapter_info_t *)arg)->va_name)));
+		((video_adapter_info_t *)arg)->va_unit = adp->va_unit;
+		((video_adapter_info_t *)arg)->va_flags = adp->va_flags;
+		((video_adapter_info_t *)arg)->va_io_base = adp->va_io_base;
+		((video_adapter_info_t *)arg)->va_io_size = adp->va_io_size;
+		((video_adapter_info_t *)arg)->va_crtc_addr = adp->va_crtc_addr;
+		((video_adapter_info_t *)arg)->va_mem_base = adp->va_mem_base;
+		((video_adapter_info_t *)arg)->va_mem_size = adp->va_mem_size;
+		((video_adapter_info_t *)arg)->va_window
+#if defined(__amd64__) || defined(__i386__)
+			= vtophys(adp->va_window);
+#else
+			= adp->va_window;
+#endif
+		((video_adapter_info_t *)arg)->va_window_size
+			= adp->va_window_size;
+		((video_adapter_info_t *)arg)->va_window_gran
+			= adp->va_window_gran;
+		((video_adapter_info_t *)arg)->va_window_orig
+			= adp->va_window_orig;
+		((video_adapter_info_t *)arg)->va_unused0
+			= adp->va_buffer != 0 ? vtophys(adp->va_buffer) : 0;
+#else
+			= adp->va_buffer;
+#endif
+		((video_adapter_info_t *)arg)->va_buffer_size
+			= adp->va_buffer_size;
+		((video_adapter_info_t *)arg)->va_mode = adp->va_mode;
+		((video_adapter_info_t *)arg)->va_initial_mode
+			= adp->va_initial_mode;
+		((video_adapter_info_t *)arg)->va_initial_bios_mode
+			= adp->va_initial_bios_mode;
+		((video_adapter_info_t *)arg)->va_line_width
+			= adp->va_line_width;
+		((video_adapter_info_t *)arg)->va_disp_start.x
+			= adp->va_disp_start.x;
+		((video_adapter_info_t *)arg)->va_disp_start.y
+			= adp->va_disp_start.y;
+		break;
+	case FBIO_MODEINFO:	/* get mode information */
+		error = vidd_get_info(adp,
+		    ((video_info_t *)arg)->vi_mode,
+		    (video_info_t *)arg);
+		if (error)
+			error = ENODEV;
+		break;
+	case FBIO_FINDMODE:	/* find a matching video mode */
+		error = vidd_query_mode(adp, (video_info_t *)arg);
+		break;
+	case FBIO_GETMODE:	/* get video mode */
+		*(int *)arg = adp->va_mode;
+		break;
+	case FBIO_SETMODE:	/* set video mode */
+		error = vidd_set_mode(adp, *(int *)arg);
+		if (error)
+			error = ENODEV;	/* EINVAL? */
+		break;
+	case FBIO_GETWINORG:	/* get frame buffer window origin */
+		*(u_int *)arg = adp->va_window_orig;
+		break;
+	case FBIO_GETDISPSTART:	/* get display start address */
+		((video_display_start_t *)arg)->x = adp->va_disp_start.x;
+		((video_display_start_t *)arg)->y = adp->va_disp_start.y;
+		break;
+	case FBIO_GETLINEWIDTH:	/* get scan line width in bytes */
+		*(u_int *)arg = adp->va_line_width;
+		break;
+	case FBIO_BLANK:	/* blank display */
+		error = vidd_blank_display(adp, *(int *)arg);
+		break;
+	case FBIO_GETPALETTE:	/* get color palette */
+	case FBIO_SETPALETTE:	/* set color palette */
+		/* XXX */
+	case FBIOPUTCMAP:
+	case FBIOGETCMAP:
+	case FBIOPUTCMAPI:
+	case FBIOGETCMAPI:
+		/* XXX */
+	case FBIO_SETWINORG:	/* set frame buffer window origin */
+	case FBIO_SETDISPSTART:	/* set display start address */
+	case FBIO_SETLINEWIDTH:	/* set scan line width in pixel */
+	case FBIOGTYPE:
+	case FBIOGATTR:
+	case FBIOSVIDEO:
+	case FBIOGVIDEO:
+	case FBIOVERTICAL:
+	case FBIOSCURSOR:
+	case FBIOGCURSOR:
+	case FBIOSCURPOS:
+	case FBIOGCURPOS:
+	case FBIOGCURMAX:
+	case FBIOMONINFO:
+	case FBIOGXINFO:
+	default:
+		error = ENODEV;
+		break;
+	splx(s);
+	return error;
diff --git a/freebsd/sys/dev/fb/fbd.c b/freebsd/sys/dev/fb/fbd.c
index 00000000..60ce4bc3
--- /dev/null
+++ b/freebsd/sys/dev/fb/fbd.c
@@ -0,0 +1,372 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2013 The FreeBSD Foundation
+ * This software was developed by Aleksandr Rybalko under sponsorship from the
+ * FreeBSD Foundation.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+/* Generic framebuffer */
+/* TODO unlink from VT(9) */
+/* TODO done normal /dev/fb methods */
+#include <sys/queue.h>
+#include <machine/bus.h>
+#include <dev/vt/vt.h>
+#include <dev/vt/hw/fb/vt_fb.h>
+#include <vm/vm.h>
+#include <rtems/bsd/local/fb_if.h>
+LIST_HEAD(fb_list_head_t, fb_list_entry) fb_list_head =
+    LIST_HEAD_INITIALIZER(fb_list_head);
+struct fb_list_entry {
+	struct fb_info	*fb_info;
+	struct cdev	*fb_si;
+	LIST_ENTRY(fb_list_entry) fb_list;
+struct fbd_softc {
+	device_t	sc_dev;
+	struct fb_info	*sc_info;
+static void fbd_evh_init(void *);
+/* SI_ORDER_SECOND, just after EVENTHANDLERs initialized. */
+SYSINIT(fbd_evh_init, SI_SUB_CONFIGURE, SI_ORDER_SECOND, fbd_evh_init, NULL);
+static d_open_t		fb_open;
+static d_close_t	fb_close;
+static d_read_t		fb_read;
+static d_write_t	fb_write;
+static d_ioctl_t	fb_ioctl;
+static d_mmap_t		fb_mmap;
+	.d_open =	fb_open,
+	.d_close =	fb_close,
+	.d_read =	fb_read,
+	.d_write =	fb_write,
+	.d_ioctl =	fb_ioctl,
+	.d_mmap =	fb_mmap,
+	.d_name =	"fb",
+static int framebuffer_dev_unit = 0;
+static int
+fb_open(struct cdev *dev, int oflags, int devtype, struct thread *td)
+	return (0);
+static int
+fb_close(struct cdev *dev, int fflag, int devtype, struct thread *td)
+	return (0);
+static int
+fb_ioctl(struct cdev *dev, u_long cmd, caddr_t data, int fflag,
+	struct fb_info *info;
+	int error;
+	error = 0;
+	info = dev->si_drv1;
+	switch (cmd) {
+	case FBIOGTYPE:
+		bcopy(info, (struct fbtype *)data, sizeof(struct fbtype));
+		break;
+		*(u_int *)data = 0;
+		break;
+		((video_display_start_t *)data)->x = 0;
+		((video_display_start_t *)data)->y = 0;
+		break;
+		*(u_int *)data = info->fb_stride;
+		break;
+		if (info->setblankmode != NULL)
+			error = info->setblankmode(info->fb_priv, *(int *)data);
+		break;
+	default:
+		error = ENOIOCTL;
+		break;
+	return (error);
+static int
+fb_read(struct cdev *dev, struct uio *uio, int ioflag)
+	return (0); /* XXX nothing to read, yet */
+static int
+fb_write(struct cdev *dev, struct uio *uio, int ioflag)
+	return (0); /* XXX nothing written */
+static int
+fb_mmap(struct cdev *dev, vm_ooffset_t offset, vm_paddr_t *paddr, int nprot,
+    vm_memattr_t *memattr)
+	if (info->fb_flags & FB_FLAG_NOMMAP)
+		return (ENODEV);
+	if (offset >= 0 && offset < info->fb_size) {
+		if (info->fb_pbase == 0)
+			*paddr = vtophys((uint8_t *)info->fb_vbase + offset);
+		else
+			*paddr = info->fb_pbase + offset;
+		if (info->fb_flags & FB_FLAG_MEMATTR)
+			*memattr = info->fb_memattr;
+		return (0);
+	return (EINVAL);
+static int
+fb_init(struct fb_list_entry *entry, int unit)
+	info = entry->fb_info;
+	entry->fb_si = make_dev(&fb_cdevsw, unit, UID_ROOT, GID_WHEEL,
+	    0600, "fb%d", unit);
+	entry->fb_si->si_drv1 = info;
+	info->fb_cdev = entry->fb_si;
+	return (0);
+int
+fbd_list()
+	struct fb_list_entry *entry;
+	if (LIST_EMPTY(&fb_list_head))
+		return (ENOENT);
+	LIST_FOREACH(entry, &fb_list_head, fb_list) {
+		printf("FB %s @%p\n", entry->fb_info->fb_name,
+		    (void *)entry->fb_info->fb_pbase);
+	return (0);
+static struct fb_list_entry *
+fbd_find(struct fb_info* info)
+	struct fb_list_entry *entry, *tmp;
+	LIST_FOREACH_SAFE(entry, &fb_list_head, fb_list, tmp) {
+		if (entry->fb_info == info) {
+			return (entry);
+	return (NULL);
+int
+fbd_register(struct fb_info* info)
+	int err, first;
+	first = 0;
+		first++;
+	entry = fbd_find(info);
+	if (entry != NULL) {
+		/* XXX Update framebuffer params */
+		return (0);
+	entry = malloc(sizeof(struct fb_list_entry), M_DEVBUF, M_WAITOK|M_ZERO);
+	entry->fb_info = info;
+	LIST_INSERT_HEAD(&fb_list_head, entry, fb_list);
+	err = fb_init(entry, framebuffer_dev_unit++);
+	if (err)
+		return (err);
+	if (first) {
+		err = vt_fb_attach(info);
+		if (err)
+			return (err);
+	return (0);
+int
+fbd_unregister(struct fb_info* info)
+			LIST_REMOVE(entry, fb_list);
+				vt_fb_detach(info);
+			free(entry, M_DEVBUF);
+			return (0);
+	return (ENOENT);
+static void
+register_fb_wrap(void *arg, void *ptr)
+	fbd_register((struct fb_info *)ptr);
+static void
+unregister_fb_wrap(void *arg, void *ptr)
+	fbd_unregister((struct fb_info *)ptr);
+static void
+fbd_evh_init(void *ctx)
+	EVENTHANDLER_REGISTER(register_framebuffer, register_fb_wrap, NULL,
+	    EVENTHANDLER_PRI_ANY);
+	EVENTHANDLER_REGISTER(unregister_framebuffer, unregister_fb_wrap, NULL,
+/* Newbus methods. */
+static int
+fbd_probe(device_t dev)
+	return (BUS_PROBE_NOWILDCARD);
+static int
+fbd_attach(device_t dev)
+	struct fbd_softc *sc;
+	int err;
+	sc = device_get_softc(dev);
+	sc->sc_dev = dev;
+	sc->sc_info = FB_GETINFO(device_get_parent(dev));
+	if (sc->sc_info == NULL)
+		return (ENXIO);
+	err = fbd_register(sc->sc_info);
+	return (err);
+static int
+fbd_detach(device_t dev)
+	int err;
+	err = fbd_unregister(sc->sc_info);
+	return (err);
+static device_method_t fbd_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,		fbd_probe),
+	DEVMETHOD(device_attach,	fbd_attach),
+	DEVMETHOD(device_detach,	fbd_detach),
+	DEVMETHOD(device_shutdown,	bus_generic_shutdown),
+	{ 0, 0 }
+driver_t fbd_driver = {
+	"fbd",
+	fbd_methods,
+	sizeof(struct fbd_softc)
+devclass_t	fbd_devclass;
+DRIVER_MODULE(fbd, fb, fbd_driver, fbd_devclass, 0, 0);
+DRIVER_MODULE(fbd, drmn, fbd_driver, fbd_devclass, 0, 0);
+DRIVER_MODULE(fbd, udl, fbd_driver, fbd_devclass, 0, 0);
+MODULE_VERSION(fbd, 1);
diff --git a/freebsd/sys/dev/vt/colors/vt_termcolors.h b/freebsd/sys/dev/vt/colors/vt_termcolors.h
index 00000000..8a8c7b65
--- /dev/null
+++ b/freebsd/sys/dev/vt/colors/vt_termcolors.h
@@ -0,0 +1,63 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+enum vt_color_format {
+	COLOR_FORMAT_BW = 0,
+	COLOR_FORMAT_GRAY,
+	COLOR_FORMAT_VGA,		/* Color Index. */
+	COLOR_FORMAT_RGB,
+	COLOR_FORMAT_ARGB,
+        COLOR_FORMAT_CMYK,
+        COLOR_FORMAT_HSL,
+        COLOR_FORMAT_YUV,
+        COLOR_FORMAT_YCbCr,
+        COLOR_FORMAT_YPbPr,
+        COLOR_FORMAT_MAX = 15,
+#define NCOLORS	16
+ * Between console's palette and VGA's one:
+ *   - blue and red are swapped (1 <-> 4)
+ *   - yellow and cyan are swapped (3 <-> 6)
+static const int cons_to_vga_colors[NCOLORS] = {
+	0,  4,  2,  6,  1,  5,  3,  7,
+	8, 12, 10, 14,  9, 13, 11, 15
+/* Helper to fill color map used by driver */
+int vt_generate_cons_palette(uint32_t *palette, int format, uint32_t rmax,
+    int roffset, uint32_t gmax, int goffset, uint32_t bmax, int boffset);
diff --git a/freebsd/sys/dev/vt/hw/fb/vt_fb.h b/freebsd/sys/dev/vt/hw/fb/vt_fb.h
index 00000000..42b395e8
--- /dev/null
+++ b/freebsd/sys/dev/vt/hw/fb/vt_fb.h
@@ -0,0 +1,54 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _DEV_VT_HW_FB_VT_FB_H_
+#define	_DEV_VT_HW_FB_VT_FB_H_
+/* Generic framebuffer interface call vt_fb_attach to init VT(9) */
+int vt_fb_attach(struct fb_info *info);
+void vt_fb_resume(struct vt_device *vd);
+void vt_fb_suspend(struct vt_device *vd);
+int vt_fb_detach(struct fb_info *info);
+vd_init_t		vt_fb_init;
+vd_fini_t		vt_fb_fini;
+vd_blank_t		vt_fb_blank;
+vd_bitblt_text_t	vt_fb_bitblt_text;
+vd_invalidate_text_t	vt_fb_invalidate_text;
+vd_bitblt_bmp_t		vt_fb_bitblt_bitmap;
+vd_drawrect_t		vt_fb_drawrect;
+vd_setpixel_t		vt_fb_setpixel;
+vd_postswitch_t		vt_fb_postswitch;
+vd_fb_ioctl_t		vt_fb_ioctl;
+vd_fb_mmap_t		vt_fb_mmap;
+#endif /* _DEV_VT_HW_FB_VT_FB_H_ */
2.20.1
