[PATCH 07/10] VT : Import from FreeBSD
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Jul 26 11:22:53 UTC 2019
 freebsd/sys/dev/vt/colors/vt_termcolors.c |  181 ++
 freebsd/sys/dev/vt/hw/fb/vt_fb.c          |  528 ++++
 freebsd/sys/dev/vt/vt_core.c              | 2933 +++++++++++++++++++++
 3 files changed, 3642 insertions(+)
 create mode 100644 freebsd/sys/dev/vt/colors/vt_termcolors.c
 create mode 100644 freebsd/sys/dev/vt/hw/fb/vt_fb.c
 create mode 100644 freebsd/sys/dev/vt/vt_core.c
diff --git a/freebsd/sys/dev/vt/colors/vt_termcolors.c b/freebsd/sys/dev/vt/colors/vt_termcolors.c
new file mode 100644
index 00000000..c7ef4b80
--- /dev/null
+++ b/freebsd/sys/dev/vt/colors/vt_termcolors.c
@@ -0,0 +1,181 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2013 The FreeBSD Foundation
+ * All rights reserved.
+ * This software was developed by Aleksandr Rybalko under sponsorship from the
+ * FreeBSD Foundation.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/kernel.h>
+#include <sys/libkern.h>
+#include <dev/vt/colors/vt_termcolors.h>
+static struct {
+	unsigned char r;	/* Red percentage value. */
+	unsigned char g;	/* Green percentage value. */
+	unsigned char b;	/* Blue percentage value. */
+} color_def[NCOLORS] = {
+	{0,	0,	0},	/* black */
+	{50,	0,	0},	/* dark red */
+	{0,	50,	0},	/* dark green */
+	{77,	63,	0},	/* dark yellow */
+	{20,	40,	64},	/* dark blue */
+	{50,	0,	50},	/* dark magenta */
+	{0,	50,	50},	/* dark cyan */
+	{75,	75,	75},	/* light gray */
+	{18,	20,	21},	/* dark gray */
+	{100,	0,	0},	/* light red */
+	{0,	100,	0},	/* light green */
+	{100,	100,	0},	/* light yellow */
+	{45,	62,	81},	/* light blue */
+	{100,	0,	100},	/* light magenta */
+	{0,	100,	100},	/* light cyan */
+	{100,	100,	100},	/* white */
+static int
+vt_parse_rgb_triplet(const char *rgb, unsigned char *r,
+    unsigned char *g, unsigned char *b)
+	unsigned long v;
+	const char *ptr;
+	char *endptr;
+	ptr = rgb;
+	/* Handle #rrggbb case */
+	if (*ptr == '#') {
+		if (strlen(ptr) != 7)
+			return (-1);
+		v = strtoul(ptr + 1, &endptr, 16);
+		if (*endptr != '\0')
+			return (-1);
+		*r = (v >> 16) & 0xff;
+		*g = (v >>  8) & 0xff;
+		*b = v & 0xff;
+		return (0);
+	/* "r, g, b" case */
+	v = strtoul(ptr, &endptr, 10);
+	if (ptr == endptr)
+		return (-1);
+	if (v > 255)
+		return (-1);
+	*r = v & 0xff;
+	ptr = endptr;
+	/* skip separator */
+	while (*ptr == ',' || *ptr == ' ')
+		ptr++;
+		return (-1);
+	if (v > 255)
+		return (-1);
+	*g = v & 0xff;
+	ptr = endptr;
+		ptr++;
+		return (-1);
+	if (v > 255)
+		return (-1);
+	*b = v & 0xff;
+	ptr = endptr;
+	/* skip trailing spaces */
+	while (*ptr == ' ')
+		ptr++;
+	/* unexpected characters at the end of the string */
+	if (*ptr != 0)
+		return (-1);
+	return (0);
+static void
+vt_palette_init(void)
+	int i;
+	char rgb[32];
+	char tunable[32];
+	unsigned char r, g, b;
+	for (i = 0; i < NCOLORS; i++) {
+		snprintf(tunable, sizeof(tunable),
+		    "kern.vt.color.%d.rgb", i);
+		if (TUNABLE_STR_FETCH(tunable, rgb, sizeof(rgb))) {
+			if (vt_parse_rgb_triplet(rgb, &r, &g, &b) == 0) {
+				/* convert to percentages */
+				color_def[i].r = r*100/255;
+				color_def[i].g = g*100/255;
+				color_def[i].b = b*100/255;
+int
+vt_generate_cons_palette(uint32_t *palette, int format, uint32_t rmax,
+    int roffset, uint32_t gmax, int goffset, uint32_t bmax, int boffset)
+	int i;
+	switch (format) {
+	case COLOR_FORMAT_VGA:
+			palette[i] = cons_to_vga_colors[i];
+		break;
+	case COLOR_FORMAT_RGB:
+		vt_palette_init();
+#define	CF(_f, _i) ((_f ## max * color_def[(_i)]._f / 100) << _f ## offset)
+			palette[i] = CF(r, i) | CF(g, i) | CF(b, i);
+#undef	CF
+		break;
+	default:
+		return (ENODEV);
+	return (0);
diff --git a/freebsd/sys/dev/vt/hw/fb/vt_fb.c b/freebsd/sys/dev/vt/hw/fb/vt_fb.c
index 00000000..8eb2744b
--- /dev/null
+++ b/freebsd/sys/dev/vt/hw/fb/vt_fb.c
@@ -0,0 +1,528 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <sys/systm.h>
+#include <sys/malloc.h>
+#include <sys/queue.h>
+#include <sys/fbio.h>
+#include <dev/vt/vt.h>
+#include <dev/vt/hw/fb/vt_fb.h>
+#include <vm/vm.h>
+#include <vm/pmap.h>
+static struct vt_driver vt_fb_driver = {
+	.vd_name = "fb",
+	.vd_init = vt_fb_init,
+	.vd_fini = vt_fb_fini,
+	.vd_blank = vt_fb_blank,
+	.vd_bitblt_text = vt_fb_bitblt_text,
+	.vd_invalidate_text = vt_fb_invalidate_text,
+	.vd_bitblt_bmp = vt_fb_bitblt_bitmap,
+	.vd_drawrect = vt_fb_drawrect,
+	.vd_setpixel = vt_fb_setpixel,
+	.vd_postswitch = vt_fb_postswitch,
+	.vd_priority = VD_PRIORITY_GENERIC+10,
+	.vd_fb_ioctl = vt_fb_ioctl,
+	.vd_fb_mmap = vt_fb_mmap,
+	.vd_suspend = vt_fb_suspend,
+	.vd_resume = vt_fb_resume,
+VT_DRIVER_DECLARE(vt_fb, vt_fb_driver);
+static void
+vt_fb_mem_wr1(struct fb_info *sc, uint32_t o, uint8_t v)
+	KASSERT((o < sc->fb_size), ("Offset %#08x out of fb size", o));
+	*(uint8_t *)(sc->fb_vbase + o) = v;
+static void
+vt_fb_mem_wr2(struct fb_info *sc, uint32_t o, uint16_t v)
+	*(uint16_t *)(sc->fb_vbase + o) = v;
+static void
+vt_fb_mem_wr4(struct fb_info *sc, uint32_t o, uint32_t v)
+	*(uint32_t *)(sc->fb_vbase + o) = v;
+int
+vt_fb_ioctl(struct vt_device *vd, u_long cmd, caddr_t data, struct thread *td)
+	struct fb_info *info;
+	int error = 0;
+	info = vd->vd_softc;
+	switch (cmd) {
+	case FBIOGTYPE:
+		bcopy(info, (struct fbtype *)data, sizeof(struct fbtype));
+		break;
+	case FBIO_GETWINORG:	/* get frame buffer window origin */
+		*(u_int *)data = 0;
+		break;
+	case FBIO_GETDISPSTART:	/* get display start address */
+		((video_display_start_t *)data)->x = 0;
+		((video_display_start_t *)data)->y = 0;
+		break;
+	case FBIO_GETLINEWIDTH:	/* get scan line width in bytes */
+		*(u_int *)data = info->fb_stride;
+		break;
+	case FBIO_BLANK:	/* blank display */
+		if (vd->vd_driver->vd_blank == NULL)
+			return (ENODEV);
+		vd->vd_driver->vd_blank(vd, TC_BLACK);
+		break;
+	default:
+		error = ENOIOCTL;
+		break;
+	return (error);
+int
+vt_fb_mmap(struct vt_device *vd, vm_ooffset_t offset, vm_paddr_t *paddr,
+    int prot, vm_memattr_t *memattr)
+	if (info->fb_flags & FB_FLAG_NOMMAP)
+		return (ENODEV);
+	if (offset >= 0 && offset < info->fb_size) {
+		if (info->fb_pbase == 0) {
+			*paddr = vtophys((uint8_t *)info->fb_vbase + offset);
+		} else {
+			*paddr = info->fb_pbase + offset;
+			if (info->fb_flags & FB_FLAG_MEMATTR)
+				*memattr = info->fb_memattr;
+#ifdef VM_MEMATTR_WRITE_COMBINING
+			else
+				*memattr = VM_MEMATTR_WRITE_COMBINING;
+#endif
+		return (0);
+	return (EINVAL);
+void
+vt_fb_setpixel(struct vt_device *vd, int x, int y, term_color_t color)
+	uint32_t c;
+	u_int o;
+	c = info->fb_cmap[color];
+	o = info->fb_stride * y + x * FBTYPE_GET_BYTESPP(info);
+	if (info->fb_flags & FB_FLAG_NOWRITE)
+		return;
+	KASSERT((info->fb_vbase != 0), ("Unmapped framebuffer"));
+	switch (FBTYPE_GET_BYTESPP(info)) {
+	case 1:
+		vt_fb_mem_wr1(info, o, c);
+		break;
+	case 2:
+		vt_fb_mem_wr2(info, o, c);
+		break;
+	case 3:
+		vt_fb_mem_wr1(info, o, (c >> 16) & 0xff);
+		vt_fb_mem_wr1(info, o + 1, (c >> 8) & 0xff);
+		vt_fb_mem_wr1(info, o + 2, c & 0xff);
+		break;
+	case 4:
+		vt_fb_mem_wr4(info, o, c);
+		break;
+	default:
+		/* panic? */
+		return;
+void
+vt_fb_drawrect(struct vt_device *vd, int x1, int y1, int x2, int y2, int fill,
+    term_color_t color)
+	int x, y;
+	for (y = y1; y <= y2; y++) {
+		if (fill || (y == y1) || (y == y2)) {
+			for (x = x1; x <= x2; x++)
+				vt_fb_setpixel(vd, x, y, color);
+		} else {
+			vt_fb_setpixel(vd, x1, y, color);
+			vt_fb_setpixel(vd, x2, y, color);
+void
+vt_fb_blank(struct vt_device *vd, term_color_t color)
+	uint32_t c;
+	u_int o, h;
+		return;
+	case 1:
+		for (h = 0; h < info->fb_height; h++)
+			for (o = 0; o < info->fb_stride; o++)
+				vt_fb_mem_wr1(info, h*info->fb_stride + o, c);
+		break;
+	case 2:
+			for (o = 0; o < info->fb_stride; o += 2)
+				vt_fb_mem_wr2(info, h*info->fb_stride + o, c);
+		break;
+	case 3:
+			for (o = 0; o < info->fb_stride; o += 3) {
+				    (c >> 16) & 0xff);
+				vt_fb_mem_wr1(info, h*info->fb_stride + o + 1,
+				    (c >> 8) & 0xff);
+				vt_fb_mem_wr1(info, h*info->fb_stride + o + 2,
+				    c & 0xff);
+		break;
+	case 4:
+			for (o = 0; o < info->fb_stride; o += 4)
+				vt_fb_mem_wr4(info, h*info->fb_stride + o, c);
+		break;
+	default:
+		/* panic? */
+		return;
+void
+vt_fb_bitblt_bitmap(struct vt_device *vd, const struct vt_window *vw,
+    const uint8_t *pattern, const uint8_t *mask,
+    unsigned int width, unsigned int height,
+    unsigned int x, unsigned int y, term_color_t fg, term_color_t bg)
+	uint32_t fgc, bgc, cc, o;
+	int bpp, bpl, xi, yi;
+	int bit, byte;
+	bpp = FBTYPE_GET_BYTESPP(info);
+	fgc = info->fb_cmap[fg];
+	bgc = info->fb_cmap[bg];
+	bpl = (width + 7) / 8; /* Bytes per source line. */
+		return;
+	/* Bound by right and bottom edges. */
+	if (y + height > vw->vw_draw_area.tr_end.tp_row) {
+		if (y >= vw->vw_draw_area.tr_end.tp_row)
+			return;
+		height = vw->vw_draw_area.tr_end.tp_row - y;
+	if (x + width > vw->vw_draw_area.tr_end.tp_col) {
+		if (x >= vw->vw_draw_area.tr_end.tp_col)
+			return;
+		width = vw->vw_draw_area.tr_end.tp_col - x;
+	for (yi = 0; yi < height; yi++) {
+		for (xi = 0; xi < width; xi++) {
+			byte = yi * bpl + xi / 8;
+			bit = 0x80 >> (xi % 8);
+			/* Skip pixel write, if mask bit not set. */
+			if (mask != NULL && (mask[byte] & bit) == 0)
+				continue;
+			o = (y + yi) * info->fb_stride + (x + xi) * bpp;
+			o += vd->vd_transpose;
+			cc = pattern[byte] & bit ? fgc : bgc;
+			switch(bpp) {
+			case 1:
+				vt_fb_mem_wr1(info, o, cc);
+				break;
+			case 2:
+				vt_fb_mem_wr2(info, o, cc);
+				break;
+			case 3:
+				/* Packed mode, so unaligned. Byte access. */
+				vt_fb_mem_wr1(info, o, (cc >> 16) & 0xff);
+				vt_fb_mem_wr1(info, o + 1, (cc >> 8) & 0xff);
+				vt_fb_mem_wr1(info, o + 2, cc & 0xff);
+				break;
+			case 4:
+				vt_fb_mem_wr4(info, o, cc);
+				break;
+			default:
+				/* panic? */
+				break;
+void
+vt_fb_bitblt_text(struct vt_device *vd, const struct vt_window *vw,
+    const term_rect_t *area)
+	unsigned int col, row, x, y;
+	struct vt_font *vf;
+	term_char_t c;
+	term_color_t fg, bg;
+	const uint8_t *pattern;
+	size_t z;
+	vf = vw->vw_font;
+	for (row = area->tr_begin.tp_row; row < area->tr_end.tp_row; ++row) {
+		for (col = area->tr_begin.tp_col; col < area->tr_end.tp_col;
+		    ++col) {
+			x = col * vf->vf_width +
+			    vw->vw_draw_area.tr_begin.tp_col;
+			y = row * vf->vf_height +
+			    vw->vw_draw_area.tr_begin.tp_row;
+			c = VTBUF_GET_FIELD(&vw->vw_buf, row, col);
+			pattern = vtfont_lookup(vf, c);
+			vt_determine_colors(c,
+			    VTBUF_ISCURSOR(&vw->vw_buf, row, col), &fg, &bg);
+			z = row * PIXEL_WIDTH(VT_FB_MAX_WIDTH) + col;
+			if (vd->vd_drawn && (vd->vd_drawn[z] == c) &&
+			    vd->vd_drawnfg && (vd->vd_drawnfg[z] == fg) &&
+			    vd->vd_drawnbg && (vd->vd_drawnbg[z] == bg))
+				continue;
+			vt_fb_bitblt_bitmap(vd, vw,
+			    pattern, NULL, vf->vf_width, vf->vf_height,
+			    x, y, fg, bg);
+			if (vd->vd_drawn)
+				vd->vd_drawn[z] = c;
+			if (vd->vd_drawnfg)
+				vd->vd_drawnfg[z] = fg;
+			if (vd->vd_drawnbg)
+				vd->vd_drawnbg[z] = bg;
+#ifndef SC_NO_CUTPASTE
+	if (!vd->vd_mshown)
+		return;
+	term_rect_t drawn_area;
+	drawn_area.tr_begin.tp_col = area->tr_begin.tp_col * vf->vf_width;
+	drawn_area.tr_begin.tp_row = area->tr_begin.tp_row * vf->vf_height;
+	drawn_area.tr_end.tp_col = area->tr_end.tp_col * vf->vf_width;
+	drawn_area.tr_end.tp_row = area->tr_end.tp_row * vf->vf_height;
+	if (vt_is_cursor_in_area(vd, &drawn_area)) {
+		    vd->vd_mcursor->map, vd->vd_mcursor->mask,
+		    vd->vd_mcursor->width, vd->vd_mcursor->height,
+		    vd->vd_mx_drawn + vw->vw_draw_area.tr_begin.tp_col,
+		    vd->vd_my_drawn + vw->vw_draw_area.tr_begin.tp_row,
+		    vd->vd_mcursor_fg, vd->vd_mcursor_bg);
+#endif
+void
+vt_fb_invalidate_text(struct vt_device *vd, const term_rect_t *area)
+	unsigned int col, row;
+	size_t z;
+		    ++col) {
+			if (vd->vd_drawn)
+				vd->vd_drawn[z] = 0;
+				vd->vd_drawnfg[z] = 0;
+				vd->vd_drawnbg[z] = 0;
+void
+vt_fb_postswitch(struct vt_device *vd)
+	if (info->enter != NULL)
+		info->enter(info->fb_priv);
+static int
+vt_fb_init_cmap(uint32_t *cmap, int depth)
+	switch (depth) {
+	case 8:
+		return (vt_generate_cons_palette(cmap, COLOR_FORMAT_RGB,
+		    0x7, 5, 0x7, 2, 0x3, 0));
+	case 15:
+		    0x1f, 10, 0x1f, 5, 0x1f, 0));
+	case 16:
+		    0x1f, 11, 0x3f, 5, 0x1f, 0));
+	case 24:
+	case 32: /* Ignore alpha. */
+		    0xff, 16, 0xff, 8, 0xff, 0));
+	default:
+		return (1);
+int
+vt_fb_init(struct vt_device *vd)
+	u_int margin;
+	int err;
+	vd->vd_height = MIN(VT_FB_MAX_HEIGHT, info->fb_height);
+	margin = (info->fb_height - vd->vd_height) >> 1;
+	vd->vd_transpose = margin * info->fb_stride;
+	vd->vd_width = MIN(VT_FB_MAX_WIDTH, info->fb_width);
+	margin = (info->fb_width - vd->vd_width) >> 1;
+	vd->vd_transpose += margin * (info->fb_bpp / NBBY);
+	vd->vd_video_dev = info->fb_video_dev;
+	if (info->fb_size == 0)
+		return (CN_DEAD);
+	if (info->fb_pbase == 0 && info->fb_vbase == 0)
+		info->fb_flags |= FB_FLAG_NOMMAP;
+	if (info->fb_cmsize <= 0) {
+		err = vt_fb_init_cmap(info->fb_cmap, FBTYPE_GET_BPP(info));
+		if (err)
+			return (CN_DEAD);
+		info->fb_cmsize = 16;
+	/* Clear the screen. */
+	/* Wakeup screen. KMS need this. */
+	vt_fb_postswitch(vd);
+	return (CN_INTERNAL);
+void
+vt_fb_fini(struct vt_device *vd, void *softc)
+	vd->vd_video_dev = NULL;
+int
+vt_fb_attach(struct fb_info *info)
+	vt_allocate(&vt_fb_driver, info);
+	return (0);
+int
+vt_fb_detach(struct fb_info *info)
+	vt_deallocate(&vt_fb_driver, info);
+	return (0);
+void
+vt_fb_suspend(struct vt_device *vd)
+	vt_suspend(vd);
+void
+vt_fb_resume(struct vt_device *vd)
+	vt_resume(vd);
diff --git a/freebsd/sys/dev/vt/vt_core.c b/freebsd/sys/dev/vt/vt_core.c
index 00000000..5f2b1b0e
--- /dev/null
+++ b/freebsd/sys/dev/vt/vt_core.c
@@ -0,0 +1,2933 @@
+ * Copyright (c) 2009, 2013 The FreeBSD Foundation
+ * This software was developed by Ed Schouten under sponsorship from the
+ * Portions of this software were developed by Oleksandr Rybalko
+ * under sponsorship from the FreeBSD Foundation.
+ * are met:
+ * SUCH DAMAGE.
+#include <sys/consio.h>
+#include <sys/eventhandler.h>
+#include <sys/kbio.h>
+#include <sys/kdb.h>
+#include <sys/lock.h>
+#include <sys/mutex.h>
+#include <sys/power.h>
+#include <sys/priv.h>
+#include <sys/proc.h>
+#include <sys/random.h>
+#include <sys/reboot.h>
+#include <sys/terminal.h>
+#include <dev/kbd/kbdreg.h>
+#if defined(__i386__) || defined(__amd64__)
+#include <machine/psl.h>
+#include <machine/frame.h>
+#endif
+static tc_bell_t	vtterm_bell;
+static tc_cursor_t	vtterm_cursor;
+static tc_putchar_t	vtterm_putchar;
+static tc_fill_t	vtterm_fill;
+static tc_copy_t	vtterm_copy;
+static tc_pre_input_t	vtterm_pre_input;
+static tc_post_input_t	vtterm_post_input;
+static tc_param_t	vtterm_param;
+static tc_done_t	vtterm_done;
+static tc_cnprobe_t	vtterm_cnprobe;
+static tc_cngetc_t	vtterm_cngetc;
+static tc_cngrab_t	vtterm_cngrab;
+static tc_cnungrab_t	vtterm_cnungrab;
+static tc_opened_t	vtterm_opened;
+static tc_ioctl_t	vtterm_ioctl;
+static tc_mmap_t	vtterm_mmap;
+const struct terminal_class vt_termclass = {
+	.tc_bell	= vtterm_bell,
+	.tc_cursor	= vtterm_cursor,
+	.tc_putchar	= vtterm_putchar,
+	.tc_fill	= vtterm_fill,
+	.tc_copy	= vtterm_copy,
+	.tc_pre_input	= vtterm_pre_input,
+	.tc_post_input	= vtterm_post_input,
+	.tc_param	= vtterm_param,
+	.tc_done	= vtterm_done,
+	.tc_cnprobe	= vtterm_cnprobe,
+	.tc_cngetc	= vtterm_cngetc,
+	.tc_cngrab	= vtterm_cngrab,
+	.tc_cnungrab	= vtterm_cnungrab,
+	.tc_opened	= vtterm_opened,
+	.tc_ioctl	= vtterm_ioctl,
+	.tc_mmap	= vtterm_mmap,
+ * Use a constant timer of 25 Hz to redraw the screen.
+ * XXX: In theory we should only fire up the timer when there is really
+ * activity. Unfortunately we cannot always start timers. We really
+ * don't want to process kernel messages synchronously, because it
+ * really slows down the system.
+#define	VT_TIMERFREQ	25
+/* Bell pitch/duration. */
+#define	VT_BELLDURATION	((5 * hz + 99) / 100)
+#define	VT_BELLPITCH	800
+#define	VT_UNIT(vw)	((vw)->vw_device->vd_unit * VT_MAXWINDOWS + \
+			(vw)->vw_number)
+static SYSCTL_NODE(_kern, OID_AUTO, vt, CTLFLAG_RD, 0, "vt(9) parameters");
+static VT_SYSCTL_INT(enable_altgr, 1, "Enable AltGr key (Do not assume R.Alt as Alt)");
+static VT_SYSCTL_INT(enable_bell, 1, "Enable bell");
+static VT_SYSCTL_INT(debug, 0, "vt(9) debug level");
+static VT_SYSCTL_INT(deadtimer, 15, "Time to wait busy process in VT_PROCESS mode");
+static VT_SYSCTL_INT(suspendswitch, 1, "Switch to VT0 before suspend");
+/* Allow to disable some keyboard combinations. */
+static VT_SYSCTL_INT(kbd_halt, 1, "Enable halt keyboard combination.  "
+    "See kbdmap(5) to configure.");
+static VT_SYSCTL_INT(kbd_poweroff, 1, "Enable Power Off keyboard combination.  "
+static VT_SYSCTL_INT(kbd_reboot, 1, "Enable reboot keyboard combination.  "
+    "See kbdmap(5) to configure (typically Ctrl-Alt-Delete).");
+static VT_SYSCTL_INT(kbd_debug, 1, "Enable key combination to enter debugger.  "
+    "See kbdmap(5) to configure (typically Ctrl-Alt-Esc).");
+static VT_SYSCTL_INT(kbd_panic, 0, "Enable request to panic.  "
+/* Used internally, not a tunable. */
+int vt_draw_logo_cpus;
+VT_SYSCTL_INT(splash_cpu, 0, "Show logo CPUs during boot");
+VT_SYSCTL_INT(splash_ncpu, 0, "Override number of logos displayed "
+    "(0 = do not override)");
+VT_SYSCTL_INT(splash_cpu_style, 2, "Draw logo style "
+    "(0 = Alternate beastie, 1 = Beastie, 2 = Orb)");
+VT_SYSCTL_INT(splash_cpu_duration, 10, "Hide logos after (seconds)");
+static unsigned int vt_unit = 0;
+static MALLOC_DEFINE(M_VT, "vt", "vt device");
+struct vt_device *main_vd = &vt_consdev;
+/* Boot logo. */
+extern unsigned int vt_logo_width;
+extern unsigned int vt_logo_height;
+extern unsigned int vt_logo_depth;
+extern unsigned char vt_logo_image[];
+#ifndef DEV_SPLASH
+#define	vtterm_draw_cpu_logos(...)	do {} while (0)
+const unsigned int vt_logo_sprite_height;
+#endif
+/* Font. */
+extern struct vt_font vt_font_default;
+extern struct vt_mouse_cursor vt_default_mouse_pointer;
+#endif
+static int signal_vt_rel(struct vt_window *);
+static int signal_vt_acq(struct vt_window *);
+static int finish_vt_rel(struct vt_window *, int, int *);
+static int finish_vt_acq(struct vt_window *);
+static int vt_window_switch(struct vt_window *);
+static int vt_late_window_switch(struct vt_window *);
+static int vt_proc_alive(struct vt_window *);
+static void vt_resize(struct vt_device *);
+static void vt_update_static(void *);
+static void vt_mouse_paste(void);
+#endif
+static void vt_suspend_handler(void *priv);
+static void vt_resume_handler(void *priv);
+SET_DECLARE(vt_drv_set, struct vt_driver);
+#define	_VTDEFH	MAX(100, PIXEL_HEIGHT(VT_FB_MAX_HEIGHT))
+#define	_VTDEFW	MAX(200, PIXEL_WIDTH(VT_FB_MAX_WIDTH))
+struct terminal	vt_consterm;
+static struct vt_window	vt_conswindow;
+#ifndef SC_NO_CONSDRAWN
+static term_char_t vt_consdrawn[PIXEL_HEIGHT(VT_FB_MAX_HEIGHT) * PIXEL_WIDTH(VT_FB_MAX_WIDTH)];
+static term_color_t vt_consdrawnfg[PIXEL_HEIGHT(VT_FB_MAX_HEIGHT) * PIXEL_WIDTH(VT_FB_MAX_WIDTH)];
+static term_color_t vt_consdrawnbg[PIXEL_HEIGHT(VT_FB_MAX_HEIGHT) * PIXEL_WIDTH(VT_FB_MAX_WIDTH)];
+#endif
+struct vt_device	vt_consdev = {
+	.vd_driver = NULL,
+	.vd_softc = NULL,
+	.vd_prev_driver = NULL,
+	.vd_prev_softc = NULL,
+	.vd_flags = VDF_INVALID,
+	.vd_windows = { [VT_CONSWINDOW] =  &vt_conswindow, },
+	.vd_curwindow = &vt_conswindow,
+	.vd_kbstate = 0,
+	.vd_pastebuf = {
+		.vpb_buf = NULL,
+		.vpb_bufsz = 0,
+		.vpb_len = 0
+	.vd_mcursor = &vt_default_mouse_pointer,
+	.vd_mcursor_fg = TC_WHITE,
+	.vd_mcursor_bg = TC_BLACK,
+#endif
+	.vd_drawn = vt_consdrawn,
+	.vd_drawnfg = vt_consdrawnfg,
+	.vd_drawnbg = vt_consdrawnbg,
+#endif
+static term_char_t vt_constextbuf[(_VTDEFW) * (VBF_DEFAULT_HISTORY_SIZE)];
+static term_char_t *vt_constextbufrows[VBF_DEFAULT_HISTORY_SIZE];
+static struct vt_window	vt_conswindow = {
+	.vw_number = VT_CONSWINDOW,
+	.vw_flags = VWF_CONSOLE,
+	.vw_buf = {
+		.vb_buffer = &vt_constextbuf[0],
+		.vb_rows = &vt_constextbufrows[0],
+		.vb_history_size = VBF_DEFAULT_HISTORY_SIZE,
+		.vb_curroffset = 0,
+		.vb_roffset = 0,
+		.vb_flags = VBF_STATIC,
+		.vb_mark_start = {.tp_row = 0, .tp_col = 0,},
+		.vb_mark_end = {.tp_row = 0, .tp_col = 0,},
+		.vb_scr_size = {
+			.tp_row = _VTDEFH,
+			.tp_col = _VTDEFW,
+	.vw_device = &vt_consdev,
+	.vw_terminal = &vt_consterm,
+	.vw_kbdmode = K_XLATE,
+	.vw_grabbed = 0,
+struct terminal vt_consterm = {
+	.tm_class = &vt_termclass,
+	.tm_softc = &vt_conswindow,
+	.tm_flags = TF_CONS,
+static struct consdev vt_consterm_consdev = {
+	.cn_ops = &termcn_cnops,
+	.cn_arg = &vt_consterm,
+	.cn_name = "ttyv0",
+/* Add to set of consoles. */
+DATA_SET(cons_set, vt_consterm_consdev);
+ * Right after kmem is done to allow early drivers to use locking and allocate
+ * memory.
+SYSINIT(vt_update_static, SI_SUB_KMEM, SI_ORDER_ANY, vt_update_static,
+    &vt_consdev);
+/* Delay until all devices attached, to not waste time. */
+SYSINIT(vt_early_cons, SI_SUB_INT_CONFIG_HOOKS, SI_ORDER_ANY, vt_upgrade,
+    &vt_consdev);
+/* Initialize locks/mem depended members. */
+static void
+vt_update_static(void *dummy)
+	if (!vty_enabled(VTY_VT))
+		return;
+	if (main_vd->vd_driver != NULL)
+		printf("VT(%s): %s %ux%u\n", main_vd->vd_driver->vd_name,
+		    (main_vd->vd_flags & VDF_TEXTMODE) ? "text" : "resolution",
+		    main_vd->vd_width, main_vd->vd_height);
+	else
+		printf("VT: init without driver.\n");
+	mtx_init(&main_vd->vd_lock, "vtdev", NULL, MTX_DEF);
+	cv_init(&main_vd->vd_winswitch, "vtwswt");
+static void
+vt_schedule_flush(struct vt_device *vd, int ms)
+	if (ms <= 0)
+		/* Default to initial value. */
+		ms = 1000 / VT_TIMERFREQ;
+	callout_schedule(&vd->vd_timer, hz / (1000 / ms));
+void
+vt_resume_flush_timer(struct vt_window *vw, int ms)
+	struct vt_device *vd = vw->vw_device;
+	if (vd->vd_curwindow != vw)
+		return;
+	if (!(vd->vd_flags & VDF_ASYNC) ||
+	    !atomic_cmpset_int(&vd->vd_timer_armed, 0, 1))
+		return;
+	vt_schedule_flush(vd, ms);
+static void
+vt_suspend_flush_timer(struct vt_device *vd)
+	 * As long as this function is called locked, callout_stop()
+	 * has the same effect like callout_drain() with regard to
+	 * preventing the callback function from executing.
+	VT_LOCK_ASSERT(vd, MA_OWNED);
+	    !atomic_cmpset_int(&vd->vd_timer_armed, 1, 0))
+		return;
+	callout_stop(&vd->vd_timer);
+static void
+vt_switch_timer(void *arg)
+	vt_late_window_switch((struct vt_window *)arg);
+static int
+vt_save_kbd_mode(struct vt_window *vw, keyboard_t *kbd)
+	int mode, ret;
+	mode = 0;
+	ret = kbdd_ioctl(kbd, KDGKBMODE, (caddr_t)&mode);
+	if (ret == ENOIOCTL)
+		ret = ENODEV;
+	if (ret != 0)
+		return (ret);
+	vw->vw_kbdmode = mode;
+	return (0);
+static int
+vt_update_kbd_mode(struct vt_window *vw, keyboard_t *kbd)
+	int ret;
+	ret = kbdd_ioctl(kbd, KDSKBMODE, (caddr_t)&vw->vw_kbdmode);
+		ret = ENODEV;
+	return (ret);
+static int
+vt_save_kbd_state(struct vt_window *vw, keyboard_t *kbd)
+	int state, ret;
+	state = 0;
+	ret = kbdd_ioctl(kbd, KDGKBSTATE, (caddr_t)&state);
+		ret = ENODEV;
+	if (ret != 0)
+		return (ret);
+	vw->vw_kbdstate &= ~LOCK_MASK;
+	vw->vw_kbdstate |= state & LOCK_MASK;
+	return (0);
+static int
+vt_update_kbd_state(struct vt_window *vw, keyboard_t *kbd)
+	int state, ret;
+	state = vw->vw_kbdstate & LOCK_MASK;
+	ret = kbdd_ioctl(kbd, KDSKBSTATE, (caddr_t)&state);
+		ret = ENODEV;
+	return (ret);
+static int
+vt_save_kbd_leds(struct vt_window *vw, keyboard_t *kbd)
+	int leds, ret;
+	leds = 0;
+	ret = kbdd_ioctl(kbd, KDGETLED, (caddr_t)&leds);
+		ret = ENODEV;
+	if (ret != 0)
+		return (ret);
+	vw->vw_kbdstate &= ~LED_MASK;
+	vw->vw_kbdstate |= leds & LED_MASK;
+	return (0);
+static int
+vt_update_kbd_leds(struct vt_window *vw, keyboard_t *kbd)
+	int leds, ret;
+	leds = vw->vw_kbdstate & LED_MASK;
+	ret = kbdd_ioctl(kbd, KDSETLED, (caddr_t)&leds);
+		ret = ENODEV;
+	return (ret);
+static int
+vt_window_preswitch(struct vt_window *vw, struct vt_window *curvw)
+	DPRINTF(40, "%s\n", __func__);
+	curvw->vw_switch_to = vw;
+	/* Set timer to allow switch in case when process hang. */
+	callout_reset(&vw->vw_proc_dead_timer, hz * vt_deadtimer,
+	    vt_switch_timer, (void *)vw);
+	/* Notify process about vt switch attempt. */
+	DPRINTF(30, "%s: Notify process.\n", __func__);
+	signal_vt_rel(curvw);
+	return (0);
+static int
+vt_window_postswitch(struct vt_window *vw)
+	signal_vt_acq(vw);
+	return (0);
+/* vt_late_window_switch will done VT switching for regular case. */
+static int
+vt_late_window_switch(struct vt_window *vw)
+	int ret;
+	callout_stop(&vw->vw_proc_dead_timer);
+	ret = vt_window_switch(vw);
+	if (ret)
+		return (ret);
+	/* Notify owner process about terminal availability. */
+	if (vw->vw_smode.mode == VT_PROCESS) {
+		ret = vt_window_postswitch(vw);
+	return (ret);
+/* Switch window. */
+static int
+vt_proc_window_switch(struct vt_window *vw)
+	struct vt_window *curvw;
+	struct vt_device *vd;
+	int ret;
+	/* Prevent switching to NULL */
+	if (vw == NULL) {
+		DPRINTF(30, "%s: Cannot switch: vw is NULL.", __func__);
+		return (EINVAL);
+	vd = vw->vw_device;
+	curvw = vd->vd_curwindow;
+	/* Check if virtual terminal is locked */
+	if (curvw->vw_flags & VWF_VTYLOCK)
+		return (EBUSY);
+	/* Check if switch already in progress */
+	if (curvw->vw_flags & VWF_SWWAIT_REL) {
+		/* Check if switching to same window */
+		if (curvw->vw_switch_to == vw) {
+			DPRINTF(30, "%s: Switch in progress to same vw.", __func__);
+			return (0);	/* success */
+		DPRINTF(30, "%s: Switch in progress to different vw.", __func__);
+		return (EBUSY);
+	/* Avoid switching to already selected window */
+	if (vw == curvw) {
+		DPRINTF(30, "%s: Cannot switch: vw == curvw.", __func__);
+	/* Ask current process permission to switch away. */
+	if (curvw->vw_smode.mode == VT_PROCESS) {
+		DPRINTF(30, "%s: VT_PROCESS ", __func__);
+		if (vt_proc_alive(curvw) == FALSE) {
+			DPRINTF(30, "Dead. Cleaning.");
+			/* Dead */
+		} else {
+			DPRINTF(30, "%s: Signaling process.\n", __func__);
+			/* Alive, try to ask him. */
+			ret = vt_window_preswitch(vw, curvw);
+			/* Wait for process answer or timeout. */
+			return (ret);
+		DPRINTF(30, "\n");
+	ret = vt_late_window_switch(vw);
+	return (ret);
+/* Switch window ignoring process locking. */
+static int
+vt_window_switch(struct vt_window *vw)
+	struct vt_window *curvw = vd->vd_curwindow;
+	keyboard_t *kbd;
+	if (kdb_active) {
+		 * When grabbing the console for the debugger, avoid
+		 * locks as that can result in deadlock.  While this
+		 * could use try locks, that wouldn't really make a
+		 * difference as there are sufficient barriers in
+		 * debugger entry/exit to be equivalent to
+		 * successfully try-locking here.
+		if (curvw == vw)
+			return (0);
+		if (!(vw->vw_flags & (VWF_OPENED|VWF_CONSOLE)))
+			return (EINVAL);
+		vd->vd_curwindow = vw;
+		vd->vd_flags |= VDF_INVALID;
+		if (vd->vd_driver->vd_postswitch)
+			vd->vd_driver->vd_postswitch(vd);
+		return (0);
+	VT_LOCK(vd);
+	if (curvw == vw) {
+		/* Nothing to do. */
+		VT_UNLOCK(vd);
+		return (0);
+	if (!(vw->vw_flags & (VWF_OPENED|VWF_CONSOLE))) {
+		VT_UNLOCK(vd);
+		return (EINVAL);
+	vt_suspend_flush_timer(vd);
+	cv_broadcast(&vd->vd_winswitch);
+	VT_UNLOCK(vd);
+	vt_resume_flush_timer(vw, 0);
+	/* Restore per-window keyboard mode. */
+	mtx_lock(&Giant);
+	kbd = kbd_get_keyboard(vd->vd_keyboard);
+	if (kbd != NULL) {
+		if (curvw->vw_kbdmode == K_XLATE)
+			vt_save_kbd_state(curvw, kbd);
+		vt_update_kbd_mode(vw, kbd);
+		vt_update_kbd_state(vw, kbd);
+	mtx_unlock(&Giant);
+	DPRINTF(10, "%s(ttyv%d) done\n", __func__, vw->vw_number);
+	return (0);
+void
+vt_termsize(struct vt_device *vd, struct vt_font *vf, term_pos_t *size)
+	size->tp_row = vd->vd_height;
+	if (vt_draw_logo_cpus)
+		size->tp_row -= vt_logo_sprite_height;
+	size->tp_col = vd->vd_width;
+	if (vf != NULL) {
+		size->tp_row /= vf->vf_height;
+		size->tp_col /= vf->vf_width;
+static inline void
+vt_termrect(struct vt_device *vd, struct vt_font *vf, term_rect_t *rect)
+	rect->tr_begin.tp_row = rect->tr_begin.tp_col = 0;
+		rect->tr_begin.tp_row = vt_logo_sprite_height;
+	rect->tr_end.tp_row = vd->vd_height;
+	rect->tr_end.tp_col = vd->vd_width;
+	if (vf != NULL) {
+		    howmany(rect->tr_begin.tp_row, vf->vf_height);
+		rect->tr_end.tp_row /= vf->vf_height;
+		rect->tr_end.tp_col /= vf->vf_width;
+void
+vt_winsize(struct vt_device *vd, struct vt_font *vf, struct winsize *size)
+	size->ws_ypixel = vd->vd_height;
+		size->ws_ypixel -= vt_logo_sprite_height;
+	size->ws_row = size->ws_ypixel;
+	size->ws_col = size->ws_xpixel = vd->vd_width;
+	if (vf != NULL) {
+		size->ws_row /= vf->vf_height;
+		size->ws_col /= vf->vf_width;
+void
+vt_compute_drawable_area(struct vt_window *vw)
+	vt_axis_t height;
+	if (vw->vw_font == NULL) {
+		vw->vw_draw_area.tr_begin.tp_col = 0;
+		vw->vw_draw_area.tr_begin.tp_row = 0;
+			vw->vw_draw_area.tr_begin.tp_row = vt_logo_sprite_height;
+		vw->vw_draw_area.tr_end.tp_col = vd->vd_width;
+		vw->vw_draw_area.tr_end.tp_row = vd->vd_height;
+		return;
+	vf = vw->vw_font;
+	 * Compute the drawable area, so that the text is centered on
+	 * the screen.
+	height = vd->vd_height;
+		height -= vt_logo_sprite_height;
+	vw->vw_draw_area.tr_begin.tp_col = (vd->vd_width % vf->vf_width) / 2;
+	vw->vw_draw_area.tr_begin.tp_row = (height % vf->vf_height) / 2;
+		vw->vw_draw_area.tr_begin.tp_row += vt_logo_sprite_height;
+	vw->vw_draw_area.tr_end.tp_col = vw->vw_draw_area.tr_begin.tp_col +
+	    rounddown(vd->vd_width, vf->vf_width);
+	vw->vw_draw_area.tr_end.tp_row = vw->vw_draw_area.tr_begin.tp_row +
+	    rounddown(height, vf->vf_height);
+static void
+vt_scroll(struct vt_window *vw, int offset, int whence)
+	int diff;
+	term_pos_t size;
+	if ((vw->vw_flags & VWF_SCROLL) == 0)
+		return;
+	vt_termsize(vw->vw_device, vw->vw_font, &size);
+	diff = vthistory_seek(&vw->vw_buf, offset, whence);
+	if (diff)
+		vw->vw_device->vd_flags |= VDF_INVALID;
+static int
+vt_machine_kbdevent(int c)
+	switch (c) {
+	case SPCLKEY | DBG: /* kbdmap(5) keyword `debug`. */
+		if (vt_kbd_debug)
+			kdb_enter(KDB_WHY_BREAK, "manual escape to debugger");
+		return (1);
+	case SPCLKEY | HALT: /* kbdmap(5) keyword `halt`. */
+		if (vt_kbd_halt)
+			shutdown_nice(RB_HALT);
+		return (1);
+	case SPCLKEY | PASTE: /* kbdmap(5) keyword `paste`. */
+		/* Insert text from cut-paste buffer. */
+		vt_mouse_paste();
+#endif
+		break;
+	case SPCLKEY | PDWN: /* kbdmap(5) keyword `pdwn`. */
+		if (vt_kbd_poweroff)
+			shutdown_nice(RB_HALT|RB_POWEROFF);
+		return (1);
+	case SPCLKEY | PNC: /* kbdmap(5) keyword `panic`. */
+		 * Request to immediate panic if sysctl
+		 * kern.vt.enable_panic_key allow it.
+		if (vt_kbd_panic)
+			panic("Forced by the panic key");
+		return (1);
+	case SPCLKEY | RBT: /* kbdmap(5) keyword `boot`. */
+		if (vt_kbd_reboot)
+			shutdown_nice(RB_AUTOBOOT);
+		return (1);
+	case SPCLKEY | SPSC: /* kbdmap(5) keyword `spsc`. */
+		/* Force activatation/deactivation of the screen saver. */
+		/* TODO */
+		return (1);
+	case SPCLKEY | STBY: /* XXX Not present in kbdcontrol parser. */
+		/* Put machine into Stand-By mode. */
+		power_pm_suspend(POWER_SLEEP_STATE_STANDBY);
+		return (1);
+	case SPCLKEY | SUSP: /* kbdmap(5) keyword `susp`. */
+		/* Suspend machine. */
+		power_pm_suspend(POWER_SLEEP_STATE_SUSPEND);
+		return (1);
+	return (0);
+static void
+vt_scrollmode_kbdevent(struct vt_window *vw, int c, int console)
+	term_pos_t size;
+	/* Only special keys handled in ScrollLock mode */
+	if ((c & SPCLKEY) == 0)
+		return;
+	c &= ~SPCLKEY;
+	if (console == 0) {
+		if (c >= F_SCR && c <= MIN(L_SCR, F_SCR + VT_MAXWINDOWS - 1)) {
+			vw = vd->vd_windows[c - F_SCR];
+			vt_proc_window_switch(vw);
+			return;
+		VT_LOCK(vd);
+	switch (c) {
+	case SLK: {
+		/* Turn scrolling off. */
+		vt_scroll(vw, 0, VHS_END);
+		VTBUF_SLCK_DISABLE(&vw->vw_buf);
+		vw->vw_flags &= ~VWF_SCROLL;
+		break;
+	case FKEY | F(49): /* Home key. */
+		vt_scroll(vw, 0, VHS_SET);
+		break;
+	case FKEY | F(50): /* Arrow up. */
+		vt_scroll(vw, -1, VHS_CUR);
+		break;
+	case FKEY | F(51): /* Page up. */
+		vt_termsize(vd, vw->vw_font, &size);
+		vt_scroll(vw, -size.tp_row, VHS_CUR);
+		break;
+	case FKEY | F(57): /* End key. */
+		break;
+	case FKEY | F(58): /* Arrow down. */
+		vt_scroll(vw, 1, VHS_CUR);
+		break;
+	case FKEY | F(59): /* Page down. */
+		vt_scroll(vw, size.tp_row, VHS_CUR);
+		break;
+	if (console == 0)
+		VT_UNLOCK(vd);
+static int
+vt_processkey(keyboard_t *kbd, struct vt_device *vd, int c)
+	struct vt_window *vw = vd->vd_curwindow;
+	random_harvest_queue(&c, sizeof(c), RANDOM_KEYBOARD);
+#if VT_ALT_TO_ESC_HACK
+	if (c & RELKEY) {
+		switch (c & ~RELKEY) {
+		case (SPCLKEY | RALT):
+			if (vt_enable_altgr != 0)
+				break;
+		case (SPCLKEY | LALT):
+			vd->vd_kbstate &= ~ALKED;
+		/* Other keys ignored for RELKEY event. */
+		return (0);
+	} else {
+				break;
+			vd->vd_kbstate |= ALKED;
+#else
+	if (c & RELKEY)
+		return (0);
+#endif
+	if (vt_machine_kbdevent(c))
+		return (0);
+	if (vw->vw_flags & VWF_SCROLL) {
+		vt_scrollmode_kbdevent(vw, c, 0/* Not a console */);
+		/* Scroll mode keys handled, nothing to do more. */
+		return (0);
+	if (c & SPCLKEY) {
+		c &= ~SPCLKEY;
+			return (0);
+		switch (c) {
+		case NEXT:
+			/* Switch to next VT. */
+			c = (vw->vw_number + 1) % VT_MAXWINDOWS;
+			vw = vd->vd_windows[c];
+			return (0);
+		case PREV:
+			/* Switch to previous VT. */
+			c = (vw->vw_number + VT_MAXWINDOWS - 1) % VT_MAXWINDOWS;
+			return (0);
+		case SLK: {
+			vt_save_kbd_state(vw, kbd);
+			VT_LOCK(vd);
+			if (vw->vw_kbdstate & SLKED) {
+				/* Turn scrolling on. */
+				vw->vw_flags |= VWF_SCROLL;
+				VTBUF_SLCK_ENABLE(&vw->vw_buf);
+			} else {
+			VT_UNLOCK(vd);
+			break;
+		case FKEY | F(1):  case FKEY | F(2):  case FKEY | F(3):
+		case FKEY | F(4):  case FKEY | F(5):  case FKEY | F(6):
+		case FKEY | F(7):  case FKEY | F(8):  case FKEY | F(9):
+		case FKEY | F(10): case FKEY | F(11): case FKEY | F(12):
+			/* F1 through F12 keys. */
+			terminal_input_special(vw->vw_terminal,
+			    TKEY_F1 + c - (FKEY | F(1)));
+			break;
+			terminal_input_special(vw->vw_terminal, TKEY_HOME);
+			break;
+			terminal_input_special(vw->vw_terminal, TKEY_UP);
+			break;
+			terminal_input_special(vw->vw_terminal, TKEY_PAGE_UP);
+			break;
+		case FKEY | F(53): /* Arrow left. */
+			terminal_input_special(vw->vw_terminal, TKEY_LEFT);
+			break;
+		case FKEY | F(55): /* Arrow right. */
+			terminal_input_special(vw->vw_terminal, TKEY_RIGHT);
+			break;
+			terminal_input_special(vw->vw_terminal, TKEY_END);
+			break;
+			terminal_input_special(vw->vw_terminal, TKEY_DOWN);
+			break;
+			terminal_input_special(vw->vw_terminal, TKEY_PAGE_DOWN);
+			break;
+		case FKEY | F(60): /* Insert key. */
+			terminal_input_special(vw->vw_terminal, TKEY_INSERT);
+			break;
+		case FKEY | F(61): /* Delete key. */
+			terminal_input_special(vw->vw_terminal, TKEY_DELETE);
+			break;
+	} else if (KEYFLAGS(c) == 0) {
+		/* Don't do UTF-8 conversion when doing raw mode. */
+		if (vw->vw_kbdmode == K_XLATE) {
+			if (vd->vd_kbstate & ALKED) {
+				 * Prepend ESC sequence if one of ALT keys down.
+				terminal_input_char(vw->vw_terminal, 0x1b);
+#endif
+#if defined(KDB)
+			kdb_alt_break(c, &vd->vd_altbrk);
+#endif
+			terminal_input_char(vw->vw_terminal, KEYCHAR(c));
+		} else
+			terminal_input_raw(vw->vw_terminal, c);
+	return (0);
+static int
+vt_kbdevent(keyboard_t *kbd, int event, void *arg)
+	struct vt_device *vd = arg;
+	int c;
+	switch (event) {
+	case KBDIO_KEYINPUT:
+		break;
+	case KBDIO_UNLOADING:
+		mtx_lock(&Giant);
+		vd->vd_keyboard = -1;
+		kbd_release(kbd, (void *)vd);
+		return (0);
+	default:
+		return (EINVAL);
+	while ((c = kbdd_read_char(kbd, 0)) != NOKEY)
+		vt_processkey(kbd, vd, c);
+	return (0);
+static int
+vt_allocate_keyboard(struct vt_device *vd)
+	int		 idx0, idx;
+	keyboard_t	*k0, *k;
+	keyboard_info_t	 ki;
+	idx0 = kbd_allocate("kbdmux", -1, vd, vt_kbdevent, vd);
+	if (idx0 >= 0) {
+		DPRINTF(20, "%s: kbdmux allocated, idx = %d\n", __func__, idx0);
+		k0 = kbd_get_keyboard(idx0);
+		for (idx = kbd_find_keyboard2("*", -1, 0);
+		     idx != -1;
+		     idx = kbd_find_keyboard2("*", -1, idx + 1)) {
+			k = kbd_get_keyboard(idx);
+			if (idx == idx0 || KBD_IS_BUSY(k))
+				continue;
+			bzero(&ki, sizeof(ki));
+			strncpy(ki.kb_name, k->kb_name, sizeof(ki.kb_name));
+			ki.kb_name[sizeof(ki.kb_name) - 1] = '\0';
+			ki.kb_unit = k->kb_unit;
+			kbdd_ioctl(k0, KBADDKBD, (caddr_t) &ki);
+	} else {
+		DPRINTF(20, "%s: no kbdmux allocated\n", __func__);
+		idx0 = kbd_allocate("*", -1, vd, vt_kbdevent, vd);
+		if (idx0 < 0) {
+			DPRINTF(10, "%s: No keyboard found.\n", __func__);
+			return (-1);
+	vd->vd_keyboard = idx0;
+	DPRINTF(20, "%s: vd_keyboard = %d\n", __func__, vd->vd_keyboard);
+	return (idx0);
+static void
+vtterm_bell(struct terminal *tm)
+	struct vt_window *vw = tm->tm_softc;
+	if (!vt_enable_bell)
+		return;
+	if (vd->vd_flags & VDF_QUIET_BELL)
+		return;
+	sysbeep(1193182 / VT_BELLPITCH, VT_BELLDURATION);
+static void
+vtterm_beep(struct terminal *tm, u_int param)
+	u_int freq, period;
+		return;
+	if ((param == 0) || ((param & 0xffff) == 0)) {
+		vtterm_bell(tm);
+		return;
+	period = ((param >> 16) & 0xffff) * hz / 1000;
+	freq = 1193182 / (param & 0xffff);
+	sysbeep(freq, period);
+static void
+vtterm_cursor(struct terminal *tm, const term_pos_t *p)
+	vtbuf_cursor_position(&vw->vw_buf, p);
+static void
+vtterm_putchar(struct terminal *tm, const term_pos_t *p, term_char_t c)
+	vtbuf_putchar(&vw->vw_buf, p, c);
+static void
+vtterm_fill(struct terminal *tm, const term_rect_t *r, term_char_t c)
+	vtbuf_fill(&vw->vw_buf, r, c);
+static void
+vtterm_copy(struct terminal *tm, const term_rect_t *r,
+    const term_pos_t *p)
+	vtbuf_copy(&vw->vw_buf, r, p);
+static void
+vtterm_param(struct terminal *tm, int cmd, unsigned int arg)
+	switch (cmd) {
+	case TP_SETLOCALCURSOR:
+		 * 0 means normal (usually block), 1 means hidden, and
+		 * 2 means blinking (always block) for compatibility with
+		 * syscons.  We don't support any changes except hiding,
+		 * so must map 2 to 0.
+		arg = (arg == 1) ? 0 : 1;
+		/* FALLTHROUGH */
+	case TP_SHOWCURSOR:
+		vtbuf_cursor_visibility(&vw->vw_buf, arg);
+		break;
+	case TP_MOUSE:
+		vw->vw_mouse_level = arg;
+		break;
+void
+vt_determine_colors(term_char_t c, int cursor,
+    term_color_t *fg, term_color_t *bg)
+	term_color_t tmp;
+	int invert;
+	invert = 0;
+	*fg = TCHAR_FGCOLOR(c);
+	if (TCHAR_FORMAT(c) & TF_BOLD)
+		*fg = TCOLOR_LIGHT(*fg);
+	*bg = TCHAR_BGCOLOR(c);
+	if (TCHAR_FORMAT(c) & TF_BLINK)
+		*bg = TCOLOR_LIGHT(*bg);
+	if (TCHAR_FORMAT(c) & TF_REVERSE)
+		invert ^= 1;
+	if (cursor)
+		invert ^= 1;
+	if (invert) {
+		tmp = *fg;
+		*fg = *bg;
+		*bg = tmp;
+int
+vt_is_cursor_in_area(const struct vt_device *vd, const term_rect_t *area)
+	unsigned int mx, my;
+	 * We use the cursor position saved during the current refresh,
+	 * in case the cursor moved since.
+	mx = vd->vd_mx_drawn + vd->vd_curwindow->vw_draw_area.tr_begin.tp_col;
+	my = vd->vd_my_drawn + vd->vd_curwindow->vw_draw_area.tr_begin.tp_row;
+	if (mx >= area->tr_end.tp_col ||
+	    mx + vd->vd_mcursor->width <= area->tr_begin.tp_col ||
+	    my >= area->tr_end.tp_row ||
+	    my + vd->vd_mcursor->height <= area->tr_begin.tp_row)
+		return (0);
+	return (1);
+static void
+vt_mark_mouse_position_as_dirty(struct vt_device *vd, int locked)
+	term_rect_t area;
+	struct vt_window *vw;
+	int x, y;
+	vw = vd->vd_curwindow;
+	vf = vw->vw_font;
+	x = vd->vd_mx_drawn;
+	y = vd->vd_my_drawn;
+	if (vf != NULL) {
+		area.tr_begin.tp_col = x / vf->vf_width;
+		area.tr_begin.tp_row = y / vf->vf_height;
+		area.tr_end.tp_col =
+		    ((x + vd->vd_mcursor->width) / vf->vf_width) + 1;
+		area.tr_end.tp_row =
+		    ((y + vd->vd_mcursor->height) / vf->vf_height) + 1;
+	} else {
+		 * No font loaded (ie. vt_vga operating in textmode).
+		 * FIXME: This fake area needs to be revisited once the
+		 * mouse cursor is supported in vt_vga's textmode.
+		area.tr_begin.tp_col = x;
+		area.tr_begin.tp_row = y;
+		area.tr_end.tp_col = x + 2;
+		area.tr_end.tp_row = y + 2;
+	if (!locked)
+		vtbuf_lock(&vw->vw_buf);
+	if (vd->vd_driver->vd_invalidate_text)
+		vd->vd_driver->vd_invalidate_text(vd, &area);
+	vtbuf_dirty(&vw->vw_buf, &area);
+	if (!locked)
+		vtbuf_unlock(&vw->vw_buf);
+#endif
+static void
+vt_set_border(struct vt_device *vd, const term_rect_t *area,
+    const term_color_t c)
+	vd_drawrect_t *drawrect = vd->vd_driver->vd_drawrect;
+	if (drawrect == NULL)
+		return;
+	/* Top bar */
+	if (area->tr_begin.tp_row > 0)
+		drawrect(vd, 0, 0, vd->vd_width - 1,
+		    area->tr_begin.tp_row - 1, 1, c);
+	/* Left bar */
+	if (area->tr_begin.tp_col > 0)
+		drawrect(vd, 0, area->tr_begin.tp_row,
+		    area->tr_begin.tp_col - 1, area->tr_end.tp_row - 1, 1, c);
+	/* Right bar */
+	if (area->tr_end.tp_col < vd->vd_width)
+		drawrect(vd, area->tr_end.tp_col, area->tr_begin.tp_row,
+		    vd->vd_width - 1, area->tr_end.tp_row - 1, 1, c);
+	/* Bottom bar */
+	if (area->tr_end.tp_row < vd->vd_height)
+		drawrect(vd, 0, area->tr_end.tp_row, vd->vd_width - 1,
+		    vd->vd_height - 1, 1, c);
+static int
+vt_flush(struct vt_device *vd)
+	term_rect_t tarea;
+	int cursor_was_shown, cursor_moved;
+#endif
+	if (vw == NULL)
+		return (0);
+	if (vd->vd_flags & VDF_SPLASH || vw->vw_flags & VWF_BUSY)
+		return (0);
+	vf = vw->vw_font;
+	if (((vd->vd_flags & VDF_TEXTMODE) == 0) && (vf == NULL))
+		return (0);
+	cursor_was_shown = vd->vd_mshown;
+	cursor_moved = (vd->vd_mx != vd->vd_mx_drawn ||
+	    vd->vd_my != vd->vd_my_drawn);
+	/* Check if the cursor should be displayed or not. */
+	if ((vd->vd_flags & VDF_MOUSECURSOR) && /* Mouse support enabled. */
+	    !(vw->vw_flags & VWF_MOUSE_HIDE) && /* Cursor displayed.      */
+	    !kdb_active && panicstr == NULL) {  /* DDB inactive.          */
+		vd->vd_mshown = 1;
+	} else {
+		vd->vd_mshown = 0;
+	 * If the cursor changed display state or moved, we must mark
+	 * the old position as dirty, so that it's erased.
+	if (cursor_was_shown != vd->vd_mshown ||
+	    (vd->vd_mshown && cursor_moved))
+		vt_mark_mouse_position_as_dirty(vd, true);
+         * Save position of the mouse cursor. It's used by backends to
+         * know where to draw the cursor and during the next refresh to
+         * erase the previous position.
+	vd->vd_mx_drawn = vd->vd_mx;
+	vd->vd_my_drawn = vd->vd_my;
+	 * If the cursor is displayed and has moved since last refresh,
+	 * mark the new position as dirty.
+	if (vd->vd_mshown && cursor_moved)
+#endif
+	vtbuf_undirty(&vw->vw_buf, &tarea);
+	/* Force a full redraw when the screen contents might be invalid. */
+	if (vd->vd_flags & (VDF_INVALID | VDF_SUSPENDED)) {
+		vd->vd_flags &= ~VDF_INVALID;
+		vt_set_border(vd, &vw->vw_draw_area, TC_BLACK);
+		vt_termrect(vd, vf, &tarea);
+			vd->vd_driver->vd_invalidate_text(vd, &tarea);
+			vtterm_draw_cpu_logos(vd);
+	if (tarea.tr_begin.tp_col < tarea.tr_end.tp_col) {
+		vd->vd_driver->vd_bitblt_text(vd, vw, &tarea);
+		return (1);
+	return (0);
+static void
+vt_timer(void *arg)
+	int changed;
+	vd = arg;
+	/* Update screen if required. */
+	changed = vt_flush(vd);
+	/* Schedule for next update. */
+	if (changed)
+		vt_schedule_flush(vd, 0);
+	else
+		vd->vd_timer_armed = 0;
+static void
+vtterm_pre_input(struct terminal *tm)
+static void
+vtterm_post_input(struct terminal *tm)
+static void
+vtterm_done(struct terminal *tm)
+	if (kdb_active || panicstr != NULL) {
+		/* Switch to the debugger. */
+		if (vd->vd_curwindow != vw) {
+		vd->vd_flags &= ~VDF_SPLASH;
+		vt_flush(vd);
+	} else if (!(vd->vd_flags & VDF_ASYNC)) {
+		vt_flush(vd);
+#ifdef DEV_SPLASH
+static void
+vtterm_splash(struct vt_device *vd)
+	vt_axis_t top, left;
+	/* Display a nice boot splash. */
+	if (!(vd->vd_flags & VDF_TEXTMODE) && (boothowto & RB_MUTE)) {
+		top = (vd->vd_height - vt_logo_height) / 2;
+		left = (vd->vd_width - vt_logo_width) / 2;
+		switch (vt_logo_depth) {
+		case 1:
+			/* XXX: Unhardcode colors! */
+			vd->vd_driver->vd_bitblt_bmp(vd, vd->vd_curwindow,
+			    vt_logo_image, NULL, vt_logo_width, vt_logo_height,
+			    left, top, TC_WHITE, TC_BLACK);
+		vd->vd_flags |= VDF_SPLASH;
+#endif
+static void
+vtterm_cnprobe(struct terminal *tm, struct consdev *cp)
+	struct vt_driver *vtd, **vtdlist, *vtdbest = NULL;
+	struct winsize wsz;
+	term_attr_t attr;
+	term_char_t c;
+		return;
+	if (vd->vd_flags & VDF_INITIALIZED)
+		/* Initialization already done. */
+		return;
+	SET_FOREACH(vtdlist, vt_drv_set) {
+		vtd = *vtdlist;
+		if (vtd->vd_probe == NULL)
+			continue;
+		if (vtd->vd_probe(vd) == CN_DEAD)
+			continue;
+		if ((vtdbest == NULL) ||
+		    (vtd->vd_priority > vtdbest->vd_priority))
+			vtdbest = vtd;
+	if (vtdbest == NULL) {
+		cp->cn_pri = CN_DEAD;
+		vd->vd_flags |= VDF_DEAD;
+	} else {
+		vd->vd_driver = vtdbest;
+		cp->cn_pri = vd->vd_driver->vd_init(vd);
+	/* Check if driver's vt_init return CN_DEAD. */
+	if (cp->cn_pri == CN_DEAD) {
+	/* Initialize any early-boot keyboard drivers */
+	kbd_configure(KB_CONF_PROBE_ONLY);
+	vd->vd_unit = atomic_fetchadd_int(&vt_unit, 1);
+	vd->vd_windows[VT_CONSWINDOW] = vw;
+	sprintf(cp->cn_name, "ttyv%r", VT_UNIT(vw));
+	/* Attach default font if not in TEXTMODE. */
+	if ((vd->vd_flags & VDF_TEXTMODE) == 0) {
+		vw->vw_font = vtfont_ref(&vt_font_default);
+		vt_compute_drawable_area(vw);
+	 * The original screen size was faked (_VTDEFW x _VTDEFH). Now
+	 * that we have the real viewable size, fix it in the static
+	 * buffer.
+	if (vd->vd_width != 0 && vd->vd_height != 0)
+		vt_termsize(vd, vw->vw_font, &vw->vw_buf.vb_scr_size);
+	vtbuf_init_early(&vw->vw_buf);
+	vt_winsize(vd, vw->vw_font, &wsz);
+	c = (boothowto & RB_MUTE) == 0 ? TERMINAL_KERN_ATTR :
+	    TERMINAL_NORM_ATTR;
+	attr.ta_format = TCHAR_FORMAT(c);
+	attr.ta_fgcolor = TCHAR_FGCOLOR(c);
+	attr.ta_bgcolor = TCHAR_BGCOLOR(c);
+	terminal_set_winsize_blank(tm, &wsz, 1, &attr);
+	if (vtdbest != NULL) {
+#ifdef DEV_SPLASH
+		if (!vt_splash_cpu)
+			vtterm_splash(vd);
+#endif
+		vd->vd_flags |= VDF_INITIALIZED;
+static int
+vtterm_cngetc(struct terminal *tm)
+	keyboard_t *kbd;
+	u_int c;
+	if (vw->vw_kbdsq && *vw->vw_kbdsq)
+		return (*vw->vw_kbdsq++);
+	/* Make sure the splash screen is not there. */
+	if (vd->vd_flags & VDF_SPLASH) {
+		/* Remove splash */
+		/* Mark screen as invalid to force update */
+		vt_flush(vd);
+	/* Stripped down keyboard handler. */
+	if (kbd == NULL)
+		return (-1);
+	/* Force keyboard input mode to K_XLATE */
+	vw->vw_kbdmode = K_XLATE;
+	/* Switch the keyboard to polling to make it work here. */
+	kbdd_poll(kbd, TRUE);
+	c = kbdd_read_char(kbd, 0);
+	kbdd_poll(kbd, FALSE);
+	if (c & RELKEY)
+		return (-1);
+		vt_scrollmode_kbdevent(vw, c, 1/* Console mode */);
+		vt_flush(vd);
+		return (-1);
+	/* Stripped down handling of vt_kbdevent(), without locking, etc. */
+		switch (c) {
+		case SPCLKEY | SLK:
+			} else {
+			break;
+		/* XXX: KDB can handle history. */
+		case SPCLKEY | FKEY | F(50): /* Arrow up. */
+			vw->vw_kbdsq = "\x1b[A";
+			break;
+		case SPCLKEY | FKEY | F(58): /* Arrow down. */
+			vw->vw_kbdsq = "\x1b[B";
+			break;
+		case SPCLKEY | FKEY | F(55): /* Arrow right. */
+			vw->vw_kbdsq = "\x1b[C";
+			break;
+		case SPCLKEY | FKEY | F(53): /* Arrow left. */
+			vw->vw_kbdsq = "\x1b[D";
+			break;
+		/* Force refresh to make scrollback work. */
+		vt_flush(vd);
+		return (KEYCHAR(c));
+	return (-1);
+static void
+vtterm_cngrab(struct terminal *tm)
+	keyboard_t *kbd;
+	vw = tm->tm_softc;
+	if (!cold)
+		vt_window_switch(vw);
+	if (kbd == NULL)
+		return;
+	if (vw->vw_grabbed++ > 0)
+		return;
+	 * Make sure the keyboard is accessible even when the kbd device
+	 * driver is disabled.
+	kbdd_enable(kbd);
+	/* We shall always use the keyboard in the XLATE mode here. */
+	vw->vw_prev_kbdmode = vw->vw_kbdmode;
+static void
+vtterm_cnungrab(struct terminal *tm)
+	keyboard_t *kbd;
+	if (kbd == NULL)
+		return;
+	if (--vw->vw_grabbed > 0)
+		return;
+	vw->vw_kbdmode = vw->vw_prev_kbdmode;
+	kbdd_disable(kbd);
+static void
+vtterm_opened(struct terminal *tm, int opened)
+	VT_LOCK(vd);
+	if (opened)
+		vw->vw_flags |= VWF_OPENED;
+	else {
+		vw->vw_flags &= ~VWF_OPENED;
+		/* TODO: finish ACQ/REL */
+	VT_UNLOCK(vd);
+static int
+vt_change_font(struct vt_window *vw, struct vt_font *vf)
+	struct terminal *tm = vw->vw_terminal;
+	term_pos_t size;
+	 * Changing fonts.
+	 * Changing fonts is a little tricky.  We must prevent
+	 * simultaneous access to the device, so we must stop
+	 * the display timer and the terminal from accessing.
+	 * We need to switch fonts and grow our screen buffer.
+	 * XXX: Right now the code uses terminal_mute() to
+	 * prevent data from reaching the console driver while
+	 * resizing the screen buffer.  This isn't elegant...
+	VT_LOCK(vd);
+	if (vw->vw_flags & VWF_BUSY) {
+		/* Another process is changing the font. */
+		VT_UNLOCK(vd);
+		return (EBUSY);
+	vw->vw_flags |= VWF_BUSY;
+	VT_UNLOCK(vd);
+	vt_termsize(vd, vf, &size);
+	vt_winsize(vd, vf, &wsz);
+	/* Grow the screen buffer and terminal. */
+	terminal_mute(tm, 1);
+	vtbuf_grow(&vw->vw_buf, &size, vw->vw_buf.vb_history_size);
+	terminal_set_winsize_blank(tm, &wsz, 0, NULL);
+	terminal_set_cursor(tm, &vw->vw_buf.vb_cursor);
+	terminal_mute(tm, 0);
+	/* Actually apply the font to the current window. */
+	VT_LOCK(vd);
+	if (vw->vw_font != vf && vw->vw_font != NULL && vf != NULL) {
+		 * In case vt_change_font called to update size we don't need
+		 * to update font link.
+		vtfont_unref(vw->vw_font);
+		vw->vw_font = vtfont_ref(vf);
+	 * Compute the drawable area and move the mouse cursor inside
+	 * it, in case the new area is smaller than the previous one.
+	vd->vd_mx = min(vd->vd_mx,
+	    vw->vw_draw_area.tr_end.tp_col -
+	    vw->vw_draw_area.tr_begin.tp_col - 1);
+	vd->vd_my = min(vd->vd_my,
+	    vw->vw_draw_area.tr_end.tp_row -
+	    vw->vw_draw_area.tr_begin.tp_row - 1);
+	/* Force a full redraw the next timer tick. */
+	if (vd->vd_curwindow == vw) {
+	vw->vw_flags &= ~VWF_BUSY;
+	VT_UNLOCK(vd);
+	return (0);
+static int
+vt_proc_alive(struct vt_window *vw)
+	struct proc *p;
+	if (vw->vw_smode.mode != VT_PROCESS)
+		return (FALSE);
+	if (vw->vw_proc) {
+		if ((p = pfind(vw->vw_pid)) != NULL)
+			PROC_UNLOCK(p);
+		if (vw->vw_proc == p)
+			return (TRUE);
+		vw->vw_proc = NULL;
+		vw->vw_smode.mode = VT_AUTO;
+		DPRINTF(1, "vt controlling process %d died\n", vw->vw_pid);
+		vw->vw_pid = 0;
+	return (FALSE);
+static int
+signal_vt_rel(struct vt_window *vw)
+		return (FALSE);
+	if (vw->vw_proc == NULL || vt_proc_alive(vw) == FALSE) {
+		vw->vw_pid = 0;
+		return (TRUE);
+	vw->vw_flags |= VWF_SWWAIT_REL;
+	PROC_LOCK(vw->vw_proc);
+	kern_psignal(vw->vw_proc, vw->vw_smode.relsig);
+	PROC_UNLOCK(vw->vw_proc);
+	DPRINTF(1, "sending relsig to %d\n", vw->vw_pid);
+	return (TRUE);
+static int
+signal_vt_acq(struct vt_window *vw)
+		return (FALSE);
+	if (vw == vw->vw_device->vd_windows[VT_CONSWINDOW])
+		cnavailable(vw->vw_terminal->consdev, FALSE);
+		vw->vw_pid = 0;
+		return (TRUE);
+	vw->vw_flags |= VWF_SWWAIT_ACQ;
+	kern_psignal(vw->vw_proc, vw->vw_smode.acqsig);
+	DPRINTF(1, "sending acqsig to %d\n", vw->vw_pid);
+	return (TRUE);
+static int
+finish_vt_rel(struct vt_window *vw, int release, int *s)
+	if (vw->vw_flags & VWF_SWWAIT_REL) {
+		vw->vw_flags &= ~VWF_SWWAIT_REL;
+		if (release) {
+			callout_drain(&vw->vw_proc_dead_timer);
+			vt_late_window_switch(vw->vw_switch_to);
+		return (0);
+	return (EINVAL);
+static int
+finish_vt_acq(struct vt_window *vw)
+	if (vw->vw_flags & VWF_SWWAIT_ACQ) {
+		vw->vw_flags &= ~VWF_SWWAIT_ACQ;
+		return (0);
+	return (EINVAL);
+static void
+vt_mouse_terminput_button(struct vt_device *vd, int button)
+	char mouseb[6] = "\x1B[M";
+	int i, x, y;
+	vf = vw->vw_font;
+	/* Translate to char position. */
+	x = vd->vd_mx / vf->vf_width;
+	y = vd->vd_my / vf->vf_height;
+	/* Avoid overflow. */
+	x = MIN(x, 255 - '!');
+	y = MIN(y, 255 - '!');
+	mouseb[3] = ' ' + button;
+	mouseb[4] = '!' + x;
+	mouseb[5] = '!' + y;
+	for (i = 0; i < sizeof(mouseb); i++)
+		terminal_input_char(vw->vw_terminal, mouseb[i]);
+static void
+vt_mouse_terminput(struct vt_device *vd, int type, int x, int y, int event,
+    int cnt)
+	switch (type) {
+	case MOUSE_BUTTON_EVENT:
+		if (cnt > 0) {
+			/* Mouse button pressed. */
+			if (event & MOUSE_BUTTON1DOWN)
+				vt_mouse_terminput_button(vd, 0);
+			if (event & MOUSE_BUTTON2DOWN)
+				vt_mouse_terminput_button(vd, 1);
+			if (event & MOUSE_BUTTON3DOWN)
+				vt_mouse_terminput_button(vd, 2);
+		} else {
+			/* Mouse button released. */
+			vt_mouse_terminput_button(vd, 3);
+		break;
+#ifdef notyet
+	case MOUSE_MOTION_EVENT:
+		if (mouse->u.data.z < 0) {
+			/* Scroll up. */
+			sc_mouse_input_button(vd, 64);
+		} else if (mouse->u.data.z > 0) {
+			/* Scroll down. */
+			sc_mouse_input_button(vd, 65);
+		break;
+#endif
+static void
+vt_mouse_paste()
+	term_char_t *buf;
+	int i, len;
+	len = VD_PASTEBUFLEN(main_vd);
+	buf = VD_PASTEBUF(main_vd);
+	len /= sizeof(term_char_t);
+	for (i = 0; i < len; i++) {
+		if (buf[i] == '\0')
+			continue;
+		terminal_input_char(main_vd->vd_curwindow->vw_terminal,
+		    buf[i]);
+void
+vt_mouse_event(int type, int x, int y, int event, int cnt, int mlevel)
+	term_pos_t size;
+	int len, mark;
+	vd = main_vd;
+	vf = vw->vw_font;
+	mark = 0;
+	if (vw->vw_flags & (VWF_MOUSE_HIDE | VWF_GRAPHICS))
+		 * Either the mouse is disabled, or the window is in
+		 * "graphics mode". The graphics mode is usually set by
+		 * an X server, using the KDSETMODE ioctl.
+		return;
+	if (vf == NULL)	/* Text mode. */
+		return;
+	 * TODO: add flag about pointer position changed, to not redraw chars
+	 * under mouse pointer when nothing changed.
+	if (vw->vw_mouse_level > 0)
+		vt_mouse_terminput(vd, type, x, y, event, cnt);
+	switch (type) {
+	case MOUSE_ACTION:
+		/* Movement */
+		x += vd->vd_mx;
+		y += vd->vd_my;
+		/* Apply limits. */
+		x = MAX(x, 0);
+		y = MAX(y, 0);
+		x = MIN(x, (size.tp_col * vf->vf_width) - 1);
+		y = MIN(y, (size.tp_row * vf->vf_height) - 1);
+		vd->vd_mx = x;
+		vd->vd_my = y;
+		if (vd->vd_mstate & MOUSE_BUTTON1DOWN)
+			vtbuf_set_mark(&vw->vw_buf, VTB_MARK_MOVE,
+			    vd->vd_mx / vf->vf_width,
+			    vd->vd_my / vf->vf_height);
+		return; /* Done */
+		/* Buttons */
+		break;
+	default:
+	switch (event) {
+	case MOUSE_BUTTON1DOWN:
+		switch (cnt % 4) {
+		case 0:	/* up */
+			mark = VTB_MARK_END;
+			break;
+		case 1: /* single click: start cut operation */
+			mark = VTB_MARK_START;
+			break;
+		case 2:	/* double click: cut a word */
+			mark = VTB_MARK_WORD;
+			break;
+		case 3:	/* triple click: cut a line */
+			mark = VTB_MARK_ROW;
+			break;
+		break;
+	case VT_MOUSE_PASTEBUTTON:
+		switch (cnt) {
+		case 0:	/* up */
+			break;
+		default:
+			vt_mouse_paste();
+			break;
+	case VT_MOUSE_EXTENDBUTTON:
+		switch (cnt) {
+		case 0:	/* up */
+			if (!(vd->vd_mstate & MOUSE_BUTTON1DOWN))
+				mark = VTB_MARK_EXTEND;
+			else
+				mark = 0;
+			break;
+		default:
+			break;
+		break;
+	default:
+	/* Save buttons state. */
+	if (cnt > 0)
+		vd->vd_mstate |= event;
+	else
+		vd->vd_mstate &= ~event;
+	if (vtbuf_set_mark(&vw->vw_buf, mark, vd->vd_mx / vf->vf_width,
+	    vd->vd_my / vf->vf_height) == 1) {
+		 * We have something marked to copy, so update pointer to
+		 * window with selection.
+		switch (mark) {
+		case VTB_MARK_END:
+		case VTB_MARK_WORD:
+		case VTB_MARK_ROW:
+		case VTB_MARK_EXTEND:
+			break;
+		default:
+			/* Other types of mark do not require to copy data. */
+			return;
+		/* Get current selection size in bytes. */
+		len = vtbuf_get_marked_len(&vw->vw_buf);
+		if (len <= 0)
+			return;
+		/* Reallocate buffer only if old one is too small. */
+		if (len > VD_PASTEBUFSZ(vd)) {
+			VD_PASTEBUF(vd) = realloc(VD_PASTEBUF(vd), len, M_VT,
+			    M_WAITOK | M_ZERO);
+			/* Update buffer size. */
+			VD_PASTEBUFSZ(vd) = len;
+		/* Request copy/paste buffer data, no more than `len' */
+		vtbuf_extract_marked(&vw->vw_buf, VD_PASTEBUF(vd),
+		    VD_PASTEBUFSZ(vd));
+		VD_PASTEBUFLEN(vd) = len;
+		/* XXX VD_PASTEBUF(vd) have to be freed on shutdown/unload. */
+void
+vt_mouse_state(int show)
+	vd = main_vd;
+	switch (show) {
+	case VT_MOUSE_HIDE:
+		vw->vw_flags |= VWF_MOUSE_HIDE;
+		break;
+	case VT_MOUSE_SHOW:
+		vw->vw_flags &= ~VWF_MOUSE_HIDE;
+		break;
+	/* Mark mouse position as dirty. */
+	vt_mark_mouse_position_as_dirty(vd, false);
+#endif
+static int
+vtterm_mmap(struct terminal *tm, vm_ooffset_t offset, vm_paddr_t * paddr,
+    int nprot, vm_memattr_t *memattr)
+	if (vd->vd_driver->vd_fb_mmap)
+		return (vd->vd_driver->vd_fb_mmap(vd, offset, paddr, nprot,
+		    memattr));
+	return (ENXIO);
+static int
+vtterm_ioctl(struct terminal *tm, u_long cmd, caddr_t data,
+    struct thread *td)
+	keyboard_t *kbd;
+	int error, i, s;
+#if defined(COMPAT_FREEBSD6) || defined(COMPAT_FREEBSD5) || \
+    defined(COMPAT_FREEBSD4) || defined(COMPAT_43)
+	int ival;
+	switch (cmd) {
+	case _IO('v', 4):
+		cmd = VT_RELDISP;
+		break;
+	case _IO('v', 5):
+		cmd = VT_ACTIVATE;
+		break;
+	case _IO('v', 6):
+		cmd = VT_WAITACTIVE;
+		break;
+	case _IO('K', 20):
+		cmd = KDSKBSTATE;
+		break;
+	case _IO('K', 67):
+		cmd = KDSETRAD;
+		break;
+	case _IO('K', 7):
+		cmd = KDSKBMODE;
+		break;
+	case _IO('K', 8):
+		cmd = KDMKTONE;
+		break;
+	case _IO('K', 63):
+		cmd = KIOCSOUND;
+		break;
+	case _IO('K', 66):
+		cmd = KDSETLED;
+		break;
+	case _IO('c', 110):
+		cmd = CONS_SETKBD;
+		break;
+	default:
+		goto skip_thunk;
+	ival = IOCPARM_IVAL(data);
+	data = (caddr_t)&ival;
+skip_thunk:
+#endif
+	switch (cmd) {
+	case KDSETRAD:		/* set keyboard repeat & delay rates (old) */
+		if (*(int *)data & ~0x7f)
+			return (EINVAL);
+		/* FALLTHROUGH */
+	case GIO_KEYMAP:
+	case PIO_KEYMAP:
+	case GIO_DEADKEYMAP:
+	case PIO_DEADKEYMAP:
+	case GETFKEY:
+	case SETFKEY:
+	case KDGKBINFO:
+	case KDGKBTYPE:
+	case KDGETREPEAT:	/* get keyboard repeat & delay rates */
+	case KDSETREPEAT:	/* set keyboard repeat & delay rates (new) */
+	case KBADDKBD:		/* add/remove keyboard to/from mux */
+	case KBRELKBD: {
+		error = 0;
+		mtx_lock(&Giant);
+		if (kbd != NULL)
+			error = kbdd_ioctl(kbd, cmd, data);
+		if (error == ENOIOCTL) {
+			if (cmd == KDGKBTYPE) {
+				/* always return something? XXX */
+				*(int *)data = 0;
+			} else {
+				return (ENODEV);
+		return (error);
+	case KDGKBSTATE: {	/* get keyboard state (locks) */
+		error = 0;
+		if (vw == vd->vd_curwindow) {
+			mtx_lock(&Giant);
+			if (kbd != NULL)
+				error = vt_save_kbd_state(vw, kbd);
+			if (error != 0)
+				return (error);
+		*(int *)data = vw->vw_kbdstate & LOCK_MASK;
+		return (error);
+	case KDSKBSTATE: {	/* set keyboard state (locks) */
+		int state;
+		state = *(int *)data;
+		if (state & ~LOCK_MASK)
+			return (EINVAL);
+		vw->vw_kbdstate |= state;
+		error = 0;
+			mtx_lock(&Giant);
+			if (kbd != NULL)
+				error = vt_update_kbd_state(vw, kbd);
+		return (error);
+	case KDGETLED: {	/* get keyboard LED status */
+		error = 0;
+			mtx_lock(&Giant);
+			if (kbd != NULL)
+				error = vt_save_kbd_leds(vw, kbd);
+			if (error != 0)
+				return (error);
+		*(int *)data = vw->vw_kbdstate & LED_MASK;
+		return (error);
+	case KDSETLED: {	/* set keyboard LED status */
+		int leds;
+		leds = *(int *)data;
+		if (leds & ~LED_MASK)
+			return (EINVAL);
+		vw->vw_kbdstate |= leds;
+		error = 0;
+			mtx_lock(&Giant);
+			if (kbd != NULL)
+				error = vt_update_kbd_leds(vw, kbd);
+		return (error);
+	case KDGETMODE:
+		*(int *)data = (vw->vw_flags & VWF_GRAPHICS) ?
+		    KD_GRAPHICS : KD_TEXT;
+		return (0);
+	case KDGKBMODE: {
+		error = 0;
+			mtx_lock(&Giant);
+			if (kbd != NULL)
+				error = vt_save_kbd_mode(vw, kbd);
+			if (error != 0)
+				return (error);
+		*(int *)data = vw->vw_kbdmode;
+		return (error);
+	case KDSKBMODE: {
+		int mode;
+		mode = *(int *)data;
+		switch (mode) {
+		case K_XLATE:
+		case K_RAW:
+		case K_CODE:
+			error = 0;
+				mtx_lock(&Giant);
+				if (kbd != NULL)
+					error = vt_update_kbd_mode(vw, kbd);
+			return (error);
+		default:
+			return (EINVAL);
+	case FBIOGTYPE:
+		if (vd->vd_driver->vd_fb_ioctl)
+			return (vd->vd_driver->vd_fb_ioctl(vd, cmd, data, td));
+		break;
+	case CONS_BLANKTIME:
+		/* XXX */
+		return (0);
+	case CONS_HISTORY:
+		if (*(int *)data < 0)
+			return EINVAL;
+		if (*(int *)data != vd->vd_curwindow->vw_buf.vb_history_size)
+			vtbuf_sethistory_size(&vd->vd_curwindow->vw_buf,
+			    *(int *)data);
+		return 0;
+	case CONS_GET:
+		/* XXX */
+		*(int *)data = M_CG640x480;
+		return (0);
+	case CONS_BELLTYPE:	/* set bell type sound */
+		if ((*(int *)data) & CONS_QUIET_BELL)
+			vd->vd_flags |= VDF_QUIET_BELL;
+		else
+			vd->vd_flags &= ~VDF_QUIET_BELL;
+		return (0);
+	case CONS_GETINFO: {
+		vid_info_t *vi = (vid_info_t *)data;
+		if (vi->size != sizeof(struct vid_info))
+			return (EINVAL);
+			mtx_lock(&Giant);
+			if (kbd != NULL)
+		vi->m_num = vd->vd_curwindow->vw_number + 1;
+		vi->mk_keylock = vw->vw_kbdstate & LOCK_MASK;
+		/* XXX: other fields! */
+		return (0);
+	case CONS_GETVERS:
+		*(int *)data = 0x200;
+		return (0);
+	case CONS_MODEINFO:
+		/* XXX */
+		return (0);
+	case CONS_MOUSECTL: {
+		mouse_info_t *mouse = (mouse_info_t*)data;
+		 * All the commands except MOUSE_SHOW nd MOUSE_HIDE
+		 * should not be applied to individual TTYs, but only to
+		 * consolectl.
+		switch (mouse->operation) {
+		case MOUSE_HIDE:
+			if (vd->vd_flags & VDF_MOUSECURSOR) {
+				vd->vd_flags &= ~VDF_MOUSECURSOR;
+				vt_mouse_state(VT_MOUSE_HIDE);
+#endif
+			return (0);
+		case MOUSE_SHOW:
+			if (!(vd->vd_flags & VDF_MOUSECURSOR)) {
+				vd->vd_flags |= VDF_MOUSECURSOR;
+				vd->vd_mx = vd->vd_width / 2;
+				vd->vd_my = vd->vd_height / 2;
+				vt_mouse_state(VT_MOUSE_SHOW);
+#endif
+			return (0);
+		default:
+			return (EINVAL);
+	case PIO_VFONT: {
+		if (vd->vd_flags & VDF_TEXTMODE)
+			return (ENOTSUP);
+		error = vtfont_load((void *)data, &vf);
+		if (error != 0)
+			return (error);
+		error = vt_change_font(vw, vf);
+		vtfont_unref(vf);
+		return (error);
+	case PIO_VFONT_DEFAULT: {
+		/* Reset to default font. */
+		error = vt_change_font(vw, &vt_font_default);
+		return (error);
+	case GIO_SCRNMAP: {
+		scrmap_t *sm = (scrmap_t *)data;
+		/* We don't have screen maps, so return a handcrafted one. */
+		for (i = 0; i < 256; i++)
+			sm->scrmap[i] = i;
+		return (0);
+	case KDSETMODE:
+		 * FIXME: This implementation is incomplete compared to
+		 * syscons.
+		switch (*(int *)data) {
+		case KD_TEXT:
+		case KD_TEXT1:
+		case KD_PIXEL:
+			vw->vw_flags &= ~VWF_GRAPHICS;
+			break;
+		case KD_GRAPHICS:
+			vw->vw_flags |= VWF_GRAPHICS;
+			break;
+		return (0);
+	case KDENABIO:		/* allow io operations */
+		error = priv_check(td, PRIV_IO);
+		if (error != 0)
+			return (error);
+		error = securelevel_gt(td->td_ucred, 0);
+		if (error != 0)
+			return (error);
+		td->td_frame->tf_eflags |= PSL_IOPL;
+#elif defined(__amd64__)
+		td->td_frame->tf_rflags |= PSL_IOPL;
+#endif
+		return (0);
+	case KDDISABIO:		/* disallow io operations (default) */
+		td->td_frame->tf_eflags &= ~PSL_IOPL;
+		td->td_frame->tf_rflags &= ~PSL_IOPL;
+#endif
+		return (0);
+	case KDMKTONE:		/* sound the bell */
+		vtterm_beep(tm, *(u_int *)data);
+		return (0);
+	case KIOCSOUND:		/* make tone (*data) hz */
+		/* TODO */
+		return (0);
+	case CONS_SETKBD:	/* set the new keyboard */
+		mtx_lock(&Giant);
+		error = 0;
+		if (vd->vd_keyboard != *(int *)data) {
+			kbd = kbd_get_keyboard(*(int *)data);
+			if (kbd == NULL) {
+				return (EINVAL);
+			i = kbd_allocate(kbd->kb_name, kbd->kb_unit,
+			    (void *)vd, vt_kbdevent, vd);
+			if (i >= 0) {
+				if (vd->vd_keyboard != -1) {
+					vt_save_kbd_state(vd->vd_curwindow, kbd);
+				kbd = kbd_get_keyboard(i);
+				vd->vd_keyboard = i;
+				vt_update_kbd_mode(vd->vd_curwindow, kbd);
+				vt_update_kbd_state(vd->vd_curwindow, kbd);
+			} else {
+				error = EPERM;	/* XXX */
+		return (error);
+	case CONS_RELKBD:	/* release the current keyboard */
+		mtx_lock(&Giant);
+		error = 0;
+				return (EINVAL);
+			error = kbd_release(kbd, (void *)vd);
+			if (error == 0) {
+		return (error);
+	case VT_ACTIVATE: {
+		int win;
+		win = *(int *)data - 1;
+		DPRINTF(5, "%s%d: VT_ACTIVATE ttyv%d ", SC_DRIVER_NAME,
+		    VT_UNIT(vw), win);
+		if ((win >= VT_MAXWINDOWS) || (win < 0))
+			return (EINVAL);
+		return (vt_proc_window_switch(vd->vd_windows[win]));
+	case VT_GETACTIVE:
+		*(int *)data = vd->vd_curwindow->vw_number + 1;
+		return (0);
+	case VT_GETINDEX:
+		*(int *)data = vw->vw_number + 1;
+		return (0);
+	case VT_LOCKSWITCH:
+		/* TODO: Check current state, switching can be in progress. */
+		if ((*(int *)data) == 0x01)
+			vw->vw_flags |= VWF_VTYLOCK;
+		else if ((*(int *)data) == 0x02)
+			vw->vw_flags &= ~VWF_VTYLOCK;
+		else
+			return (EINVAL);
+		return (0);
+	case VT_OPENQRY:
+		VT_LOCK(vd);
+		for (i = 0; i < VT_MAXWINDOWS; i++) {
+			vw = vd->vd_windows[i];
+			if (vw == NULL)
+				continue;
+			if (!(vw->vw_flags & VWF_OPENED)) {
+				VT_UNLOCK(vd);
+				return (0);
+		VT_UNLOCK(vd);
+		return (EINVAL);
+	case VT_WAITACTIVE: {
+		unsigned int idx;
+		error = 0;
+		idx = *(unsigned int *)data;
+		if (idx > VT_MAXWINDOWS)
+			return (EINVAL);
+		if (idx > 0)
+			vw = vd->vd_windows[idx - 1];
+		VT_LOCK(vd);
+		while (vd->vd_curwindow != vw && error == 0)
+			error = cv_wait_sig(&vd->vd_winswitch, &vd->vd_lock);
+		VT_UNLOCK(vd);
+		return (error);
+	case VT_SETMODE: {	/* set screen switcher mode */
+		struct vt_mode *mode;
+		struct proc *p1;
+		mode = (struct vt_mode *)data;
+		DPRINTF(5, "%s%d: VT_SETMODE ", SC_DRIVER_NAME, VT_UNIT(vw));
+			p1 = pfind(vw->vw_pid);
+			if (vw->vw_proc == p1 && vw->vw_proc != td->td_proc) {
+				if (p1)
+					PROC_UNLOCK(p1);
+				DPRINTF(5, "error EPERM\n");
+				return (EPERM);
+			if (p1)
+				PROC_UNLOCK(p1);
+		if (mode->mode == VT_AUTO) {
+			vw->vw_pid = 0;
+			DPRINTF(5, "VT_AUTO, ");
+				cnavailable(vw->vw_terminal->consdev, TRUE);
+			/* were we in the middle of the vty switching process? */
+			if (finish_vt_rel(vw, TRUE, &s) == 0)
+				DPRINTF(5, "reset WAIT_REL, ");
+			if (finish_vt_acq(vw) == 0)
+				DPRINTF(5, "reset WAIT_ACQ, ");
+			return (0);
+		} else if (mode->mode == VT_PROCESS) {
+			if (!ISSIGVALID(mode->relsig) ||
+			    !ISSIGVALID(mode->acqsig) ||
+			    !ISSIGVALID(mode->frsig)) {
+				DPRINTF(5, "error EINVAL\n");
+				return (EINVAL);
+			DPRINTF(5, "VT_PROCESS %d, ", td->td_proc->p_pid);
+			bcopy(data, &vw->vw_smode, sizeof(struct vt_mode));
+			vw->vw_proc = td->td_proc;
+			vw->vw_pid = vw->vw_proc->p_pid;
+		} else {
+			DPRINTF(5, "VT_SETMODE failed, unknown mode %d\n",
+			    mode->mode);
+			return (EINVAL);
+		DPRINTF(5, "\n");
+		return (0);
+	case VT_GETMODE:	/* get screen switcher mode */
+		bcopy(&vw->vw_smode, data, sizeof(struct vt_mode));
+		return (0);
+	case VT_RELDISP:	/* screen switcher ioctl */
+		 * This must be the current vty which is in the VT_PROCESS
+		 * switching mode...
+		if ((vw != vd->vd_curwindow) || (vw->vw_smode.mode !=
+		    VT_PROCESS)) {
+			return (EINVAL);
+		/* ...and this process is controlling it. */
+		if (vw->vw_proc != td->td_proc) {
+			return (EPERM);
+		error = EINVAL;
+		switch(*(int *)data) {
+		case VT_FALSE:	/* user refuses to release screen, abort */
+			if ((error = finish_vt_rel(vw, FALSE, &s)) == 0)
+				DPRINTF(5, "%s%d: VT_RELDISP: VT_FALSE\n",
+				    SC_DRIVER_NAME, VT_UNIT(vw));
+			break;
+		case VT_TRUE:	/* user has released screen, go on */
+			/* finish_vt_rel(..., TRUE, ...) should not be locked */
+				if ((error = finish_vt_rel(vw, TRUE, &s)) == 0)
+					DPRINTF(5, "%s%d: VT_RELDISP: VT_TRUE\n",
+			} else {
+				error = EINVAL;
+			return (error);
+		case VT_ACKACQ:	/* acquire acknowledged, switch completed */
+			if ((error = finish_vt_acq(vw)) == 0)
+				DPRINTF(5, "%s%d: VT_RELDISP: VT_ACKACQ\n",
+			break;
+		default:
+			break;
+		return (error);
+	return (ENOIOCTL);
+static struct vt_window *
+vt_allocate_window(struct vt_device *vd, unsigned int window)
+	struct terminal *tm;
+	term_pos_t size;
+	vw = malloc(sizeof *vw, M_VT, M_WAITOK|M_ZERO);
+	vw->vw_device = vd;
+	vw->vw_number = window;
+	vtbuf_init(&vw->vw_buf, &size);
+	tm = vw->vw_terminal = terminal_alloc(&vt_termclass, vw);
+	terminal_set_winsize(tm, &wsz);
+	vd->vd_windows[window] = vw;
+	callout_init(&vw->vw_proc_dead_timer, 0);
+	return (vw);
+void
+vt_upgrade(struct vt_device *vd)
+	unsigned int i;
+	int register_handlers;
+		return;
+	if (main_vd->vd_driver == NULL)
+		return;
+		if (vw == NULL) {
+			/* New window. */
+			vw = vt_allocate_window(vd, i);
+		if (!(vw->vw_flags & VWF_READY)) {
+			terminal_maketty(vw->vw_terminal, "v%r", VT_UNIT(vw));
+			vw->vw_flags |= VWF_READY;
+			if (vw->vw_flags & VWF_CONSOLE) {
+				/* For existing console window. */
+				EVENTHANDLER_REGISTER(shutdown_pre_sync,
+				    vt_window_switch, vw, SHUTDOWN_PRI_DEFAULT);
+	VT_LOCK(vd);
+	if (vd->vd_curwindow == NULL)
+		vd->vd_curwindow = vd->vd_windows[VT_CONSWINDOW];
+	register_handlers = 0;
+	if (!(vd->vd_flags & VDF_ASYNC)) {
+		/* Attach keyboard. */
+		vt_allocate_keyboard(vd);
+		/* Init 25 Hz timer. */
+		callout_init_mtx(&vd->vd_timer, &vd->vd_lock, 0);
+		 * Start timer when everything ready.
+		 * Note that the operations here are purposefully ordered.
+		 * We need to ensure vd_timer_armed is non-zero before we set
+		 * the VDF_ASYNC flag. That prevents this function from
+		 * racing with vt_resume_flush_timer() to update the
+		 * callout structure.
+		atomic_add_acq_int(&vd->vd_timer_armed, 1);
+		vd->vd_flags |= VDF_ASYNC;
+		callout_reset(&vd->vd_timer, hz / VT_TIMERFREQ, vt_timer, vd);
+		register_handlers = 1;
+	VT_UNLOCK(vd);
+	/* Refill settings with new sizes. */
+	vt_resize(vd);
+	if (register_handlers) {
+		/* Register suspend/resume handlers. */
+		EVENTHANDLER_REGISTER(power_suspend_early, vt_suspend_handler,
+		    vd, EVENTHANDLER_PRI_ANY);
+		EVENTHANDLER_REGISTER(power_resume, vt_resume_handler, vd,
+		    EVENTHANDLER_PRI_ANY);
+static void
+vt_resize(struct vt_device *vd)
+	int i;
+		VT_LOCK(vd);
+		/* Assign default font to window, if not textmode. */
+		if (!(vd->vd_flags & VDF_TEXTMODE) && vw->vw_font == NULL)
+		VT_UNLOCK(vd);
+		/* Resize terminal windows */
+		while (vt_change_font(vw, vw->vw_font) == EBUSY) {
+			DPRINTF(100, "%s: vt_change_font() is busy, "
+			    "window %d\n", __func__, i);
+static void
+vt_replace_backend(const struct vt_driver *drv, void *softc)
+	vd = main_vd;
+	if (vd->vd_flags & VDF_ASYNC) {
+		/* Stop vt_flush periodic task. */
+		VT_LOCK(vd);
+		VT_UNLOCK(vd);
+		 * Mute current terminal until we done. vt_change_font (called
+		 * from vt_resize) will unmute it.
+		terminal_mute(vd->vd_curwindow->vw_terminal, 1);
+	 * Reset VDF_TEXTMODE flag, driver who require that flag (vt_vga) will
+	 * set it.
+	VT_LOCK(vd);
+	vd->vd_flags &= ~VDF_TEXTMODE;
+	if (drv != NULL) {
+		 * We want to upgrade from the current driver to the
+		 * given driver.
+		vd->vd_prev_driver = vd->vd_driver;
+		vd->vd_prev_softc = vd->vd_softc;
+		vd->vd_driver = drv;
+		vd->vd_softc = softc;
+		vd->vd_driver->vd_init(vd);
+	} else if (vd->vd_prev_driver != NULL && vd->vd_prev_softc != NULL) {
+		 * No driver given: we want to downgrade to the previous
+		 * driver.
+		const struct vt_driver *old_drv;
+		void *old_softc;
+		old_drv = vd->vd_driver;
+		old_softc = vd->vd_softc;
+		vd->vd_driver = vd->vd_prev_driver;
+		vd->vd_softc = vd->vd_prev_softc;
+		vd->vd_prev_driver = NULL;
+		vd->vd_prev_softc = NULL;
+		vd->vd_flags |= VDF_DOWNGRADE;
+		if (old_drv->vd_fini)
+			old_drv->vd_fini(vd, old_softc);
+		vd->vd_flags &= ~VDF_DOWNGRADE;
+	VT_UNLOCK(vd);
+	/* Update windows sizes and initialize last items. */
+	vt_upgrade(vd);
+#ifdef DEV_SPLASH
+#endif
+		/* Allow to put chars now. */
+		terminal_mute(vd->vd_curwindow->vw_terminal, 0);
+		/* Rerun timer for screen updates. */
+		vt_resume_flush_timer(vd->vd_curwindow, 0);
+	 * Register as console. If it already registered, cnadd() will ignore
+	 * it.
+	termcn_cnregister(vd->vd_windows[VT_CONSWINDOW]->vw_terminal);
+static void
+vt_suspend_handler(void *priv)
+	vd = priv;
+	vd->vd_flags |= VDF_SUSPENDED;
+	if (vd->vd_driver != NULL && vd->vd_driver->vd_suspend != NULL)
+		vd->vd_driver->vd_suspend(vd);
+static void
+vt_resume_handler(void *priv)
+	vd = priv;
+	if (vd->vd_driver != NULL && vd->vd_driver->vd_resume != NULL)
+		vd->vd_driver->vd_resume(vd);
+	vd->vd_flags &= ~VDF_SUSPENDED;
+void
+vt_allocate(const struct vt_driver *drv, void *softc)
+		return;
+	if (main_vd->vd_driver == NULL) {
+		main_vd->vd_driver = drv;
+		printf("VT: initialize with new VT driver \"%s\".\n",
+		    drv->vd_name);
+	} else {
+		 * Check if have rights to replace current driver. For example:
+		 * it is bad idea to replace KMS driver with generic VGA one.
+		if (drv->vd_priority <= main_vd->vd_driver->vd_priority) {
+			printf("VT: Driver priority %d too low. Current %d\n ",
+			    drv->vd_priority, main_vd->vd_driver->vd_priority);
+			return;
+		printf("VT: Replacing driver \"%s\" with new \"%s\".\n",
+		    main_vd->vd_driver->vd_name, drv->vd_name);
+	vt_replace_backend(drv, softc);
+void
+vt_deallocate(const struct vt_driver *drv, void *softc)
+		return;
+	if (main_vd->vd_prev_driver == NULL ||
+	    main_vd->vd_driver != drv ||
+	    main_vd->vd_softc != softc)
+		return;
+	printf("VT: Switching back from \"%s\" to \"%s\".\n",
+	    main_vd->vd_driver->vd_name, main_vd->vd_prev_driver->vd_name);
+	vt_replace_backend(NULL, NULL);
+void
+vt_suspend(struct vt_device *vd)
+	int error;
+	if (vt_suspendswitch == 0)
+		return;
+	/* Save current window. */
+	vd->vd_savedwindow = vd->vd_curwindow;
+	/* Ask holding process to free window and switch to console window */
+	vt_proc_window_switch(vd->vd_windows[VT_CONSWINDOW]);
+	/* Wait for the window switch to complete. */
+	error = 0;
+	VT_LOCK(vd);
+	while (vd->vd_curwindow != vd->vd_windows[VT_CONSWINDOW] && error == 0)
+	VT_UNLOCK(vd);
+void
+vt_resume(struct vt_device *vd)
+		return;
+	/* Switch back to saved window, if any */
+	vt_proc_window_switch(vd->vd_savedwindow);
+	vd->vd_savedwindow = NULL;
2.20.1
