[PATCH 3/3] arm/beagle: Add libdebugger support.
chrisj at rtems.org chrisj at rtems.org
Sat Jul 27 01:04:39 UTC 2019
- Port the jbang code from C++ to C to enable DBGEN.
- Hook the libdebugger ARM backend support to return the base address
  of the debug register set.
 bsps/arm/beagle/start/bspdebug.c        | 734 ++++++++++++++++++++++++
 bsps/arm/beagle/start/bspdebug.h        |  38 ++
 bsps/arm/beagle/start/bspstart.c        |   3 +
 c/src/lib/libbsp/arm/beagle/Makefile.am |   1 +
 4 files changed, 776 insertions(+)
 create mode 100644 bsps/arm/beagle/start/bspdebug.c
 create mode 100644 bsps/arm/beagle/start/bspdebug.h
diff --git a/bsps/arm/beagle/start/bspdebug.c b/bsps/arm/beagle/start/bspdebug.c
new file mode 100644
index 0000000000..d57fe97d49
--- /dev/null
+++ b/bsps/arm/beagle/start/bspdebug.c
@@ -0,0 +1,734 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 Chris Johns <chrisj at rtems.org>.  All rights reserved.
+ * Copyright (C) 2015, Dutch & Dutch.  All rights reserved.
+ * are met:
+ * This is a C version of the jbang code found in the jbang repo:
+ *   https://github.com/dutchanddutch/jbang.git
+ * Dutch & Dutch is 'zmatt' on the #beagle IRC channel. This work is all based
+ * on zmatt's research and solution.
+ * Hardware Modification
+ * The TI designers did not bring the ARM signal DBGEN to a system control
+ * register so software can not directly control it. The BBB has a pull down
+ * resister (R25) on the TRSTn JTAG signal which means software cannot
+ * reconfigure the TRSTn pin and control it. As a result software access to the
+ * ARM's debug registers is locked out. You can access the registers if you
+ * want too but hardware breakpoints and watchpoints are ignored. ARM uses
+ * hardware breakpoints to single step instructions.
+ * You need to add at least one wire for this code to work and optionally a
+ * second wire if you need to test this code to make sure it is working. The
+ * wires are small and require a small amount of soldering and soldering skill.
+ * If you add the TDO link change 'has_tdo' to '1' to enable support. This
+ * setting defaults to '0' to disable support.
+ * Steps:
+ *  1. Locate P2 on the bottom side of the board. It is the JTAG connector
+ *     pads. If you look at the underside of the board with the SD card holder
+ *     to the right the pads are top center left. There are 20 pads in two
+ *     columns. The pads are numbered 1 at the top left then 2 top right, 3 is
+ *     second top on the left, 4 is second top to the right, then the pin
+ *     number increments as you move left then right down the pads.
+ *  2. Connect P2 to P5.
+ *  3. Optionally connect P7 to P13.
+ * The resulting wiring is:
+ *       1 ===  /--=== 2
+ *       3 ===  |  === 4
+ *       5 ===--/  === 6
+ *       7 ===--\  === 8
+ *       9 ===  |  === 10
+ *      11 ===  |  === 12
+ *      13 ===--/  === 14
+ *      15 ===     === 16
+ *      17 ===     === 18
+ *      19 ===     === 20
+#include <unistd.h>
+#include <rtems/bspIo.h>
+#include <rtems/debugger/rtems-debugger-bsp.h>
+#include "bspdebug.h"
+ * Set to '1' to enable the traces.
+#define trace     0
+#define trace_reg 0
+ * TDO provided feedback for testing via EMU0.
+#define has_tdo 0
+ * Pins of interest.
+#define AM335x_PIN_CONF_TMS   116
+#define AM335x_PIN_CONF_TDI   117
+#define AM335x_PIN_CONF_TDO   118
+#define AM335x_PIN_CONF_TCK   119
+#define AM335x_PIN_CONF_TRSTN 120
+#define AM335x_PIN_CONF_EMU0  121
+ * Register base addresses.
+#define AM335x_PRCM_CM_PER     (0x44E00000)
+#define AM335x_PRCM_WKUP       (AM335x_PRCM_CM_PER + 0x400)
+#define AM335x_CONTROL_MODULE  (0x44E10000)
+#define AM335x_CONF_PIN        (AM335x_CONTROL_MODULE + 0x800)
+#define AM335x_GPIO0           (0x44e07000)
+#define AM335x_GPIO1           (0x4804c000)
+#define AM335x_GPIO2           (0x481ac000)
+#define AM335x_GPIO3           (0x481ae000)
+#define AM335x_DEBUGSS_ETM     (0x4B140000)
+#define AM335x_DEBUGSS_DEBUG   (0x4B141000)
+#define AM335x_DEBUGSS_CTI     (0x4B142000)
+#define AM335x_DEBUGSS_ICE     (0x4B143000)
+#define AM335x_DEBUGSS_DRM     (0x4B160000)
+#define AM335x_DEBUGSS_ETB     (0x4B162000)
+ * Power, Reset, Clock Management (PRCM)
+#define AM335x_PRCM_CM_PER_GPIO3_CLKCTRL (0x0b4)
+#define AM335x_PRCM_WKUP_DEBUGSS_CLKCTRL (0x014)
+#define AM335x_PRCM_CM_MODULEMODE_MASK    (3)
+#define AM335x_PRCM_CM_MODULEMODE_DISABLE (0)
+#define AM335x_PRCM_CM_MODULEMODE_ENABLE  (2)
+#define AM335x_PRCM_CM_IDLEST_MASK        (3 << 16)
+#define AM335x_PRCM_CM_IDLEST_FUNC        (0 << 16)
+#define AM335x_PRCM_CM_IDLEST_TRANS       (1 << 16)
+#define AM335x_PRCM_CM_IDLEST_IDLE        (2 << 16)
+#define AM335x_PRCM_CM_IDLEST_DISABLED    (3 << 16)
+ * Pin configurations.
+#define AM335x_PIN_IN_OFFSET  (0x138)
+#define AM335x_PIN_SLEW_FAST  (0 << 6)
+#define AM335x_PIN_SLEW_SLOW  (1 << 6)
+#define AM335x_PIN_RX_DISABLE (0 << 5)
+#define AM335x_PIN_RX_ENABLE  (1 << 5)
+#define AM335x_PIN_PULL_DIS   (1 << 3)
+#define AM335x_PIN_PULL_EN    (0 << 3)
+#define AM335x_PIN_PULL_UP    ((1 << 4) | AM335x_PIN_PULL_EN)
+#define AM335x_PIN_PULL_DOWN  ((0 << 4) | AM335x_PIN_PULL_EN)
+ * JTAG.
+typedef enum {
+  JTAG_RST,
+  JTAG_COMMIT,
+  JTAG_RUN,
+  JTAG_DATA,
+  JTAG_PAUSE
+} JTAG_STATE;
+#define AM335x_JTAG_MASK (0x0fffffff)
+#define AM335x_JTAG_ID   (0x0b94402f)
+ * ICE Pick
+#define AM335x_ICEPICK_IR_LEN         (6)
+#define AM335x_ICEPICK_IR_BYPASS      (0x3f) /* 0b11'1111 1 bit */
+#define AM335x_ICEPICK_IR_PUB_CONNECT (0x07) /* 0b00'0111 8-bit (3->4 bit indirect rw) */
+#define AM335x_ICEPICK_IR_ROUTER      (0x02) /* 0b00'0010 32-bit (7->24 bit indirect rw) */
+ * DAP
+#define AM335x_DAP_ID        (0x3ba00477)
+#define AM335x_DAP_IR_LEN    (4)
+#define AM335x_DAP_IR_ABORT  (0x08)  /* 0b'1000 */
+#define AM335x_DAP_IR_DPACC  (0x0a)  /* 0b'1010 */
+#define AM335x_DAP_IR_APACC  (0x0b)  /* 0b'1011 */
+#define AM335x_DAP_IR_IDCODE (0x0e)  /* 0b'1110 */
+#define AM335x_APB_DEBUG (0x80001000)
+ * State of JTAG.
+static JTAG_STATE jtag_state;
+ * Initialisation of icepick registers.
+static const uint32_t am335x_icepick_init_regs[2] = {
+  0x60002000,  /* assert cortex-a8 DBGEN */
+  0x2c002100,  /* link DAP into chain (takes effect at run) */
+#define AM335x_ICEPICK_INIT_REGS \
+  (sizeof(am335x_icepick_init_regs) / sizeof(am335x_icepick_init_regs[0]))
+ * Low level trace.
+static void dbg_printk(const char* format, ...) RTEMS_PRINTFLIKE(1, 2);
+static void
+dbg_printk(const char* format, ...)
+  va_list ap;
+  va_start(ap, format);
+  if (trace) {
+    vprintk(format, ap);
+  va_end(ap);
+static volatile uint32_t*
+arm_reg_addr(uint32_t base, uint32_t offset)
+  return (volatile uint32_t*) (base + offset);
+static uint32_t
+arm_reg_read(uint32_t base, uint32_t offset)
+  volatile uint32_t* addr = arm_reg_addr(base, offset);
+  uint32_t           val = *addr;
+  if (trace_reg)
+    printk("bbb: dbg: read: %08x -> %08x\n", (intptr_t) addr, val);
+  return val;
+static void
+arm_reg_write(uint32_t base, uint32_t offset, uint32_t val)
+  if (trace_reg)
+    printk("bbb: dbg: read: %08x <- %08x\n", (intptr_t) addr, val);
+  *addr = val;
+static void
+arm_reg_set(uint32_t base, uint32_t offset, uint32_t mask, uint32_t val)
+  uint32_t rval = arm_reg_read(base, offset);
+  rval &= ~mask;
+  rval |= val;
+  arm_reg_write(base, offset, rval);
+static void
+am335x_pin_config(int pin, uint32_t setting)
+  arm_reg_write(AM335x_CONF_PIN, pin * sizeof(uint32_t), setting);
+static void
+am335x_prcm_cm_enable(uint32_t clk)
+  arm_reg_set(AM335x_PRCM_CM_PER, clk,
+              AM335x_PRCM_CM_MODULEMODE_MASK,
+              AM335x_PRCM_CM_MODULEMODE_ENABLE);
+static bool
+am335x_prcm_cm_ready(uint32_t clk)
+  uint32_t val = arm_reg_read(AM335x_PRCM_CM_PER, clk) & AM335x_PRCM_CM_IDLEST_MASK;
+  return val == AM335x_PRCM_CM_IDLEST_FUNC;
+static uint32_t
+bbb_sig_bank_addr(int pin)
+  static const uint32_t bank_addr[4] = {
+    AM335x_GPIO0,
+    AM335x_GPIO1,
+    AM335x_GPIO2,
+    AM335x_GPIO3
+  return bank_addr[(pin >> 5) & 3];
+static void
+bbb_sig_set(int pin, int level)
+  uint32_t val = (0 | AM335x_PIN_PULL_UP| AM335x_PIN_SLEW_FAST |
+                  ((level != 0) ? AM335x_PIN_RX_ENABLE : AM335x_PIN_RX_DISABLE));
+  am335x_pin_config(pin, val);
+static uint32_t
+bbb_sig_get(int pin)
+  uint32_t in = arm_reg_read(bbb_sig_bank_addr(pin), AM335x_PIN_IN_OFFSET);
+  return (in >> (32 - (pin & 31))) & 1;
+static void
+bbb_tdo_init(void)
+  if (has_tdo) {
+    am335x_pin_config(AM335x_PIN_CONF_EMU0,
+                      7 | AM335x_PIN_PULL_UP |
+                      AM335x_PIN_RX_ENABLE | AM335x_PIN_SLEW_FAST);
+    am335x_prcm_cm_enable(AM335x_PRCM_CM_PER_GPIO3_CLKCTRL);
+    while (!am335x_prcm_cm_ready(AM335x_PRCM_CM_PER_GPIO3_CLKCTRL)) {}
+static uint32_t
+bbb_sig_tdo(void)
+  return has_tdo && bbb_sig_get(AM335x_PIN_CONF_EMU0) == 1 ? 1 : 0;
+static void
+bbb_sig_trst(int level)
+  bbb_sig_set(AM335x_PIN_CONF_TRSTN, level);
+static void
+bbb_sig_tck(int level)
+  bbb_sig_set(AM335x_PIN_CONF_TCK, level);
+static void
+bbb_sig_tdi(int level)
+  bbb_sig_set(AM335x_PIN_CONF_TDI, level);
+static void
+bbb_sig_tms(int level)
+  bbb_sig_set(AM335x_PIN_CONF_TMS, level);
+static void
+bbb_nap(void)
+  volatile size_t count = 1000;
+  while (count > 0)
+    --count;
+static void
+bbb_sig_tck_pulse(void)
+  bbb_nap();
+  bbb_sig_tck(1);
+  bbb_nap();
+  bbb_sig_tck(0);
+  bbb_nap();
+static void
+bbb_jtag_cmd(size_t nbits, uint32_t data)
+  size_t b;
+  for (b = 0; b < nbits; ++b, data >>= 1) {
+    bbb_sig_tms(data & 1);
+    bbb_sig_tck_pulse();
+static void
+bbb_hw_init(void)
+  dbg_printk("]] HW reset\n");
+   * Set CM_WKUP_DEBUGSS_CLKCTRL bits[1:0] = 2h, explict enable (reset does
+   * this so leave out).
+  am335x_prcm_cm_enable(AM335x_PRCM_WKUP_DEBUGSS_CLKCTRL);
+  while (!am335x_prcm_cm_ready(AM335x_PRCM_WKUP_DEBUGSS_CLKCTRL)) {}
+  bbb_tdo_init();
+static void
+bbb_jtag_reset(void)
+  dbg_printk("]] JTAG reset\n");
+  bbb_sig_trst(0);
+  bbb_sig_tck(0);
+  bbb_sig_tdi(1);
+  bbb_jtag_cmd(7, 0x1f /* 0b1'1111 */);
+static void
+bbb_jtag_commit(void)
+  if (jtag_state == JTAG_DATA) {
+    dbg_printk("]] JTAG commit\n");
+    bbb_jtag_cmd(2, 0x3 /* 0b11 */);
+    jtag_state = JTAG_COMMIT;
+static void
+bbb_jtag_run(size_t ncycles)
+  dbg_printk("]] JTAG run: %zu\n", ncycles);
+  bbb_jtag_commit();
+  bbb_jtag_cmd(ncycles, 0);
+  jtag_state = JTAG_RUN;
+static uint32_t
+bbb_jtag_xfer(size_t nbits)
+  uint32_t in = 0;
+  size_t   b;
+  dbg_printk("]] JTAG xfer: %zu\n", nbits);
+  for (b = 0; b < nbits; ++b) {
+    in |= bbb_sig_tdo() << b;
+  dbg_printk("]] JTAG xfer: in: %08x\n", in);
+  return in;
+static uint32_t
+bbb_jtag_xfer_out(size_t nbits, uint32_t out)
+  uint32_t in = 0;
+  size_t   b;
+  dbg_printk("]] JTAG xfer out: %zu %08x\n", nbits, out);
+  for (b = 0; b < nbits; ++b, out >>= 1) {
+    bbb_sig_tdi(out & 1);
+  dbg_printk("]] JTAG xfer out: in: %08x\n", in);
+  return in;
+static void
+bbb_jtag_dr(void)
+  dbg_printk("]] JTAG dr\n");
+  bbb_jtag_cmd(2, 0xb01);
+  jtag_state = JTAG_DATA;
+static uint32_t
+bbb_jtag_dr_out(size_t nbits, uint32_t out)
+  uint32_t in;
+  dbg_printk("]] JTAG dr out\n");
+  bbb_jtag_dr();
+  in = bbb_jtag_xfer_out(nbits, out);
+  return in;
+static void
+bbb_jtag_ir(void)
+  dbg_printk("]] JTAG ir\n");
+  bbb_jtag_cmd(3, 0x3 /* 0b011 */);
+static uint32_t
+bbb_jtag_ir_out(size_t nbits, uint32_t out)
+  uint32_t in;
+  dbg_printk("]] JTAG ir out\n");
+  bbb_jtag_ir();
+  return in;
+static bool
+bbb_jtag_hw_init(void)
+  bool match = true;
+  bbb_jtag_reset();
+  bbb_sig_trst(1);
+  bbb_jtag_run(100);
+  if (has_tdo) {
+    uint32_t id = bbb_jtag_dr_out(32, 0);
+    match = (id & AM335x_JTAG_MASK) == AM335x_JTAG_ID;
+    printk("bbb: dbg: JTAG Id: %08x (%s)\n",
+	       id, match ? "match" : "mismatch");
+  return match;
+static bool
+bbb_icepick_init(void)
+  size_t r;
+  bbb_jtag_ir_out(AM335x_ICEPICK_IR_LEN, AM335x_ICEPICK_IR_PUB_CONNECT);
+  bbb_jtag_dr_out(8, 0x89 /* 0b'1000'1001 */);
+  if (has_tdo && bbb_jtag_dr_out(8, 0) != 0x9 /* 0b1001 */) {
+    printk("bbb: dbg: ICEPick connect failure\n");
+    return false;
+  bbb_jtag_ir_out(AM335x_ICEPICK_IR_LEN, AM335x_ICEPICK_IR_ROUTER);
+  for (r = 0; r < AM335x_ICEPICK_INIT_REGS; ++r) {
+    uint32_t val = am335x_icepick_init_regs[r];
+    bbb_jtag_dr_out(32, val | (1 << 31));
+    if (has_tdo && ((bbb_jtag_dr_out(32, 0) >> 24) != (val >> 24))) {
+      printk("bbb: dbg: ICEPick write failure\n");
+      return false;
+  bbb_jtag_ir_out(AM335x_ICEPICK_IR_LEN, AM335x_ICEPICK_IR_BYPASS);
+  bbb_jtag_run(16);
+  return true;
+static void
+bbb_dap_ir(uint32_t reg)
+  static uint32_t last_ir = AM335x_DAP_IR_IDCODE;
+  if (reg != last_ir) {
+    last_ir = reg;
+    bbb_jtag_ir();
+    bbb_jtag_xfer_out(AM335x_DAP_IR_LEN, reg);
+    bbb_jtag_xfer_out(AM335x_ICEPICK_IR_LEN, AM335x_ICEPICK_IR_BYPASS);
+static uint32_t
+bbb_dap_op(uint32_t ir, uint32_t op, uint32_t arg)
+  uint32_t res;
+  bbb_dap_ir(ir);
+  bbb_jtag_dr();
+  res = bbb_jtag_xfer_out(3, op);
+  if (has_tdo && res != 0x2 /* 0b010 */) {
+    printk("bbb: dbg: DAP status code: %08x\n", res);
+  res = bbb_jtag_xfer_out(32, arg);
+   * ICEPick in bypass.
+  bbb_jtag_xfer(1);
+   * No always needed, but it does not burt.
+  bbb_jtag_run(1);
+  return res;
+static uint32_t
+bbb_dap_csw(void)
+  return bbb_dap_op(AM335x_DAP_IR_DPACC, 0x3 /* 0b011 */, 0);
+static uint32_t
+bbb_dap_set_csw(uint32_t val)
+  return bbb_dap_op(AM335x_DAP_IR_DPACC, 0x2 /* 0b010 */, val);
+static uint32_t
+bbb_dap_set_sel(uint32_t val)
+  return bbb_dap_op(AM335x_DAP_IR_DPACC, 0x4 /* 0b100 */, val);
+static uint32_t
+bbb_dap_nop(void)
+  return bbb_dap_op(AM335x_DAP_IR_DPACC, 0x6 /* 0b110 */, 0);
+static uint32_t
+bbb_ap_set_csw(uint32_t val)
+  return bbb_dap_op(AM335x_DAP_IR_APACC, 0x0 /* 0b000 */, val);
+static uint32_t
+bbb_ap_set_addr(uint32_t val)
+  return bbb_dap_op(AM335x_DAP_IR_APACC, 0x2 /* 0b010 */, val);
+static uint32_t
+bbb_ap_data(void)
+  return bbb_dap_op(AM335x_DAP_IR_APACC, 0x7 /* 0b111 */, 0);
+static uint32_t
+bbb_ap_set_data(uint32_t val)
+  return bbb_dap_op(AM335x_DAP_IR_APACC, 0x6 /* 0b110 */, val);
+static uint32_t
+bbb_dap_check(void)
+  uint32_t data = bbb_dap_csw();
+  uint32_t csw = bbb_dap_nop();
+  if (has_tdo && csw != 0xf0000000) {
+    printk("bbb: dbg: DP-CSW unexpected value: %08x\n", csw);
+  return data;
+static bool
+bbb_dap_init(void)
+  bool ok = true;
+  if (has_tdo) {
+    ok = id == AM335x_DAP_ID;
+    printk("bbb: dbg: DAP JTAG Id: %08x (%s)\n",
+           id, ok ? "match" : "mismatch");
+  if (ok) {
+     * Power up and clear errors.
+    bbb_dap_set_csw(0x50000032);
+    bbb_dap_check();
+     * Select and configure APB-AP.
+    bbb_dap_set_sel(1 << 24);
+    bbb_ap_set_csw(0xe3000012);
+  return ok;
+static uint32_t
+bbb_ap_read(uint32_t addr)
+  uint32_t data;
+  bbb_ap_set_addr(addr);
+  bbb_ap_data();
+  data = bbb_dap_check();
+  if (has_tdo) {
+    dbg_printk("bbb: dbg: read 0x%08x -> 0x%08x\n", addr, data);
+  return data;
+static uint32_t
+bbb_ap_write(uint32_t addr, uint32_t data)
+  bbb_ap_set_data(data);
+  return bbb_dap_check();
+static void
+bbb_show_auth_status(uint32_t addr)
+  if (has_tdo) {
+    const char* privs[] = {
+      "public invasive debug",
+      "public non-invasive debug",
+      "secure invasive debug",
+      "secure non-invasive debug",
+    uint32_t val = bbb_ap_read(addr + 0xfb8);
+    size_t   s;
+    printk("bbb: dbg: auth status: %08x\n", val);
+    for (s = 0; s < (sizeof(privs) / sizeof(privs[0])); ++s, val >>= 2) {
+      printk("bbb: dbg: %s: ", privs[s]);
+      if ((val & 1) != 0)
+        printk("granted");
+      else if ((val & 2) != 0)
+        printk("denied");
+      printk("\n");
+static uint32_t
+bbb_debug_rx(void)
+  /* debugger -> core */
+  uint32_t data;
+  asm volatile("mrc p14, 0, %0, c0, c5, 0" : "=r" (data));
+  return data;
+bool
+rtems_debugger_arm_debug_configure(void)
+  const uint32_t addr = (intptr_t) &rtems_debugger_arm_debug_configure;
+  bbb_hw_init();
+  if (!bbb_jtag_hw_init())
+    return false;
+  if (!bbb_icepick_init())
+    return false;
+  if (!bbb_dap_init())
+    return false;
+  bbb_show_auth_status(AM335x_APB_DEBUG);
+  bbb_ap_read(AM335x_APB_DEBUG + 0x314);
+  bbb_ap_read(AM335x_APB_DEBUG + 0x088);
+  bbb_ap_write(AM335x_APB_DEBUG + 0x080, addr);
+  usleep(1000);
+  if (bbb_debug_rx() != addr) {
+    printk("bbb: dbg: path test failure\n");
+    return false;
+  return true;
+void*
+bbb_arm_debug_registers(void)
+  return (void*) AM335x_DEBUGSS_DEBUG;
+void*
+rtems_debugger_arm_debug_registers(void)
+  return bbb_arm_debug_registers();
diff --git a/bsps/arm/beagle/start/bspdebug.h b/bsps/arm/beagle/start/bspdebug.h
index 0000000000..7e423a0459
--- /dev/null
+++ b/bsps/arm/beagle/start/bspdebug.h
@@ -0,0 +1,38 @@
+ * are met:
+#ifndef BBB_BSPDEBUG_H
+#define BBB_BSPDEBUG_H
+ * Internal BSP call to create a concrete reference to
+ * rtems_debugger_arm_debug_registers override the libdebugger reference.
+void* bbb_arm_debug_registers(void);
+#endif
diff --git a/bsps/arm/beagle/start/bspstart.c b/bsps/arm/beagle/start/bspstart.c
index 292b576aef..47db5cc529 100644
--- a/bsps/arm/beagle/start/bspstart.c
+++ b/bsps/arm/beagle/start/bspstart.c
@@ -17,6 +17,8 @@
 #include <bsp/irq-generic.h>
 #include <bsp/fdt.h>
 void bsp_start(void)
 #if IS_DM3730
@@ -27,6 +29,7 @@ void bsp_start(void)
 #endif
   bsp_interrupt_initialize();
   printk("\nRTEMS Beagleboard: %s\n", type);
+  printk("        ARM Debug: 0x%08x\n", (intptr_t) bbb_arm_debug_registers());
 uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 332536c428..090168983d 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -52,6 +52,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
 # Startup
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/start/bspdebug.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/start/bspreset.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/start/bspstart.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/start/bspstarthooks.c
2.20.1 (Apple Git-117)
