[PATCH 1/3] arm: Select the TLB invalidate based on the core's Id variant.
chrisj at rtems.org chrisj at rtems.org
Sat Jul 27 01:04:37 UTC 2019
Closes #3760
 bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c | 16 ++++++++++------
 1 file changed, 10 insertions(+), 6 deletions(-)
diff --git a/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c b/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
index c2be0f566e..cf2d555d18 100644
--- a/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
+++ b/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
@@ -65,12 +65,16 @@ static uint32_t set_translation_table_entries(
   for ( i = istart; i != iend; i = (i + 1U) & index_mask ) {
     void *mva = (void *) (i << ARM_MMU_SECT_BASE_SHIFT);
-    #if defined(__ARM_ARCH_7A__)
-    arm_cp15_tlb_invalidate_entry_all_asids(mva);
-    #else
-    arm_cp15_tlb_instruction_invalidate_entry(mva);
-    arm_cp15_tlb_data_invalidate_entry(mva);
-    #endif
+#if defined(__ARM_ARCH_7A__)
+    if ((arm_cp15_get_multiprocessor_affinity() & (1 << 30)) == 0) {
+      arm_cp15_tlb_invalidate_entry_all_asids(mva);
+    else
+#endif
+      arm_cp15_tlb_instruction_invalidate_entry(mva);
+      arm_cp15_tlb_data_invalidate_entry(mva);
   _ARM_Data_synchronization_barrier();
2.20.1 (Apple Git-117)
