[PATCH] user/bsps : Fix formatting and typo in arm/beagle
Christian Mauderer list at c-mauderer.de
Sat Jul 27 11:30:03 UTC 2019
Pushed.
On 22/07/2019 06:12, Vijay Kumar Banerjee wrote:
>  user/bsps/arm/beagle.rst | 55 +++++++++++++++++++++++++++-------------
>  1 file changed, 37 insertions(+), 18 deletions(-)
> diff --git a/user/bsps/arm/beagle.rst b/user/bsps/arm/beagle.rst
> index 84bfe2d..eb4ecfb 100644
> --- a/user/bsps/arm/beagle.rst
> +++ b/user/bsps/arm/beagle.rst
> @@ -5,10 +5,10 @@
>  beagle
> -This BSP supports four variants, `beagleboardorig`, `beagleboardxm`, `beaglebonewhite`
> -and `beagleboneblack`. The basic hardware initialization is not performed by
> -the BSP.  A boot loader with device tree support must be used to start the BSP,
> -e.g. U-Boot.
> +This BSP supports four variants, `beagleboardorig`, `beagleboardxm`,
> +`beaglebonewhite` and `beagleboneblack`. The basic hardware initialization is
> +not performed by the BSP.  A boot loader with device tree support must be used
> +to start the BSP, e.g., U-Boot.
>  TODO(These drivers are present but not documented yet):
> @@ -33,33 +33,39 @@ To boot via uboot, the ELF must be converted to a U-Boot image like below:
>  Getting the Device Tree Blob
> -The Device Tree Blob(dtb) is needed to load the device tree while starting up
> +The Device Tree Blob (DTB) is needed to load the device tree while starting up
>  the kernel. We build the dtb from the FreeBSD source matching the commit hash
>  from the libbsd HEAD of freebsd-org. For example if the HEAD is at
>  "19a6ceb89dbacf74697d493e48c388767126d418"
> -Then the right dts file is:
> +Then the right Device Tree Source (DTS) file is:
>  https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/gnu/dts/arm/am335x-boneblack.dts
> -.. code-block:: none
> +.. code-block:: shell
> +   :linenos:
>       #building the dtb
>       #We will use the script from https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/tools/fdt/make_dtb.sh
> -     export MACHINE='arm' #The make_dtb.sh script uses environment variable MACHINE
> +     #The make_dtb.sh script uses environment variable MACHINE
> +     export MACHINE='arm'
>       SCRIPT_DIR=$HOME/freebsd/sys/tools/fdt
>       #The arguments to the script are
>       # $1 -> Build Tree
>       # $2 -> DTS source file
>       # $3 -> output path of the DTB file
>       ${SCRIPT_DIR}/make_dtb.sh ${SCRIPT_DIR}/../../ \
>       ${SCRIPT_DIR}/../../gnu/dts/arm/am335x-boneblack.dts \
>       $(pwd)
>  Writing the uEnv.txt file
>  The uEnv.txt file is needed to set any environment variable before the kernel is
> -loaded. Each line is a u-boot command that the uboot will execute during
> -starting up.
> +loaded. Each line is a u-boot command that the uboot will execute during start
> +up.
>  Add the following to a file named uEnv.txt:
> @@ -72,8 +78,14 @@ Add the following to a file named uEnv.txt:
>  I2C Driver
> -This BSP uses the I2C framework and is registered using
> -``am335x_i2c_bus_register()`` the function prototype is given below:
> +For registering the `/dev/i2c-0` device, a wrapper function is provided,
> +``bbb_register_i2c_0()`` similarly ``bbb_register_i2c_1()`` and
> +``bbb_register_i2c_2()`` are respectively used to register `i2c-1` and `i2c-2`.
> +For registering an I2C device with a custom path (say `/dev/i2c-3`) the
> +function ``am335x_i2c_bus_register()`` has to be used.
> +The function prototype is given below:
>  .. code-block:: C
> @@ -84,12 +96,19 @@ This BSP uses the I2C framework and is registered using
>     rtems_vector_number irq
> -This function is needed only while registering with custom path with custom
> -values. For registering the `/dev/i2c-0` device, a wrapper function is provided,
> -``bbb_register_i2c_0()`` similarly ``bbb_register_i2c_1()`` and
> -``bbb_register_i2c_2()`` are respectively used to register `i2c-1` and `i2c-2`.
>  SPI Driver
> -The SPI device `/dev/spi-0` can be registered with ``bbb_register_spi_0()```
> +The SPI device `/dev/spi-0` can be registered with ``bbb_register_spi_0()``
> +For registering with a custom path, the ``bsp_register_spi()`` can be used.
> +.. code-block:: C
> +    rtems_status_code bsp_register_spi(
> +       const char         *bus_path,
> +       uintptr_t           register_base,
> +       rtems_vector_number irq
