[PATCH v5] Add mmap
Christian Mauderer list at c-mauderer.de
Sat Jul 27 11:52:39 UTC 2019
Pushed. Especially now that you have a display working with it, I'm OK
with that patch.
On 18/07/2019 10:56, Vijay Kumar Banerjee wrote:
>  freebsd/sys/kern/kern_conf.c       |  8 +++----
>  freebsd/sys/sys/conf.h             |  2 +-
>  rtemsbsd/include/machine/vm.h      |  2 ++
>  rtemsbsd/sys/fs/devfs/devfs_devs.c | 38 ++++++++++++++++++++++++++++++
>  testsuite/cdev01/test_cdev.c       | 21 ++++++++++++++++-
>  testsuite/cdev01/test_cdev01.h     |  3 ++-
>  testsuite/cdev01/test_main.c       |  4 ++++
>  7 files changed, 71 insertions(+), 7 deletions(-)
> diff --git a/freebsd/sys/kern/kern_conf.c b/freebsd/sys/kern/kern_conf.c
> index 92237d9d..560a450a 100644
> --- a/freebsd/sys/kern/kern_conf.c
> +++ b/freebsd/sys/kern/kern_conf.c
> @@ -328,8 +328,8 @@ static struct cdevsw dead_cdevsw = {
>  	.d_write =	dead_write,
>  	.d_ioctl =	dead_ioctl,
>  	.d_poll =	dead_poll,
> -#ifndef __rtems__
>  	.d_mmap =	dead_mmap,
> +#ifndef __rtems__
>  	.d_strategy =	dead_strategy,
>  #endif /* __rtems__ */
>  	.d_name =	"dead",
> @@ -522,7 +522,6 @@ giant_kqfilter(struct cdev *dev, struct knote *kn)
>  	return (retval);
> -#ifndef __rtems__
>  static int
>  giant_mmap(struct cdev *dev, vm_ooffset_t offset, vm_paddr_t *paddr, int nprot,
>      vm_memattr_t *memattr)
> @@ -541,6 +540,7 @@ giant_mmap(struct cdev *dev, vm_ooffset_t offset, vm_paddr_t *paddr, int nprot,
>  	return (retval);
> +#ifndef __rtems__
>  static int
>  giant_mmap_single(struct cdev *dev, vm_ooffset_t *offset, vm_size_t size,
>      vm_object_t *object, int nprot)
> @@ -667,8 +667,8 @@ prep_cdevsw(struct cdevsw *devsw, int flags)
>  		devsw->d_write = dead_write;
>  		devsw->d_ioctl = dead_ioctl;
>  		devsw->d_poll = dead_poll;
> -#ifndef __rtems__
>  		devsw->d_mmap = dead_mmap;
> +#ifndef __rtems__
>  		devsw->d_mmap_single = dead_mmap_single;
>  		devsw->d_strategy = dead_strategy;
>  		devsw->d_dump = dead_dump;
> @@ -702,8 +702,8 @@ prep_cdevsw(struct cdevsw *devsw, int flags)
>  	FIXUP(d_write,		no_write,	giant_write);
>  	FIXUP(d_ioctl,		no_ioctl,	giant_ioctl);
>  	FIXUP(d_poll,		no_poll,	giant_poll);
> -#ifndef __rtems__
>  	FIXUP(d_mmap,		no_mmap,	giant_mmap);
> +#ifndef __rtems__
>  	FIXUP(d_strategy,	no_strategy,	giant_strategy);
>  	FIXUP(d_kqfilter,	no_kqfilter,	giant_kqfilter);
> diff --git a/freebsd/sys/sys/conf.h b/freebsd/sys/sys/conf.h
> index 4ace162f..c0a66442 100644
> --- a/freebsd/sys/sys/conf.h
> +++ b/freebsd/sys/sys/conf.h
> @@ -209,8 +209,8 @@ struct cdevsw {
>  	d_write_t		*d_write;
>  	d_ioctl_t		*d_ioctl;
>  	d_poll_t		*d_poll;
> -#ifndef __rtems__
>  	d_mmap_t		*d_mmap;
> +#ifndef __rtems__
>  	d_strategy_t		*d_strategy;
>  	dumper_t		*d_dump;
> diff --git a/rtemsbsd/include/machine/vm.h b/rtemsbsd/include/machine/vm.h
> index e69de29b..351b7472 100644
> --- a/rtemsbsd/include/machine/vm.h
> +++ b/rtemsbsd/include/machine/vm.h
> @@ -0,0 +1,2 @@
> +#define VM_MEMATTR_DEFAULT 0
> +#define VM_MEMATTR_UNCACHEABLE 1
> diff --git a/rtemsbsd/sys/fs/devfs/devfs_devs.c b/rtemsbsd/sys/fs/devfs/devfs_devs.c
> index 7c697b0a..7b09e530 100644
> --- a/rtemsbsd/sys/fs/devfs/devfs_devs.c
> +++ b/rtemsbsd/sys/fs/devfs/devfs_devs.c
> @@ -387,6 +387,43 @@ devfs_imfs_kqfilter(rtems_libio_t *iop, struct knote *kn)
>  	return error;
> +static int
> +devfs_imfs_mmap(rtems_libio_t *iop, void **addr, size_t len, int prot,
> +    off_t off)
> +	struct cdev *cdev = devfs_imfs_get_context_by_iop(iop);
> +	struct file *fp = rtems_bsd_iop_to_fp(iop);
> +	struct thread *td = rtems_bsd_get_curthread_or_null();
> +	struct file *fpop;
> +	struct cdevsw *dsw;
> +	int error, ref;
> +	if (td != 0) {
> +		if (cdev == NULL) {
> +			error = ENXIO;
> +			goto err;
> +		if (cdev->si_flags & SI_ALIAS) {
> +			cdev = cdev->si_parent;
> +		dsw = dev_refthread(cdev, &ref);
> +		if (dsw == NULL) {
> +			error = ENXIO;
> +			goto err;
> +		fpop = td->td_fpop;
> +		curthread->td_fpop = fp;
> +		error = dsw->d_mmap( cdev, off, (vm_paddr_t *) addr, prot, VM_MEMATTR_DEFAULT);
> +		td->td_fpop = fpop;
> +		dev_relthread(cdev, ref);
> +	} else {
> +		error = ENOMEM;
> +err:
> +	return rtems_bsd_error_to_status_and_errno(error);
>  static const rtems_filesystem_file_handlers_r devfs_imfs_handlers = {
>  	.open_h = devfs_imfs_open,
>  	.close_h = devfs_imfs_close,
> @@ -403,6 +440,7 @@ static const rtems_filesystem_file_handlers_r devfs_imfs_handlers = {
>  	.kqfilter_h = devfs_imfs_kqfilter,
>  	.readv_h = devfs_imfs_readv,
>  	.writev_h = devfs_imfs_writev,
> +	.mmap_h = devfs_imfs_mmap,
>  static const IMFS_node_control devfs_imfs_control = IMFS_GENERIC_INITIALIZER(
> diff --git a/testsuite/cdev01/test_cdev.c b/testsuite/cdev01/test_cdev.c
> index 19fb1a5e..f6851fdd 100644
> --- a/testsuite/cdev01/test_cdev.c
> +++ b/testsuite/cdev01/test_cdev.c
> @@ -30,8 +30,10 @@
>  #include <machine/rtems-bsd-kernel-space.h>
> +#include <machine/vm.h>
>  #include <sys/types.h>
>  #include <sys/conf.h>
> +#include <sys/mman.h>
>  #include <rtems/seterr.h>
> @@ -46,6 +48,7 @@ static	d_write_t	testwrite;
>  static	d_ioctl_t	testioctl;
>  static	d_poll_t	testpoll;
>  static	d_kqfilter_t	testkqfilter;
> +static	d_mmap_t	testmmap;
>  static struct cdevsw test_cdevsw = {
>  	.d_version =	D_VERSION,
> @@ -59,6 +62,7 @@ static struct cdevsw test_cdevsw = {
>  	.d_ioctl =	testioctl,
>  	.d_poll =	testpoll,
>  	.d_kqfilter =	testkqfilter,
> +	.d_mmap =	testmmap,
>  static	int
> @@ -77,7 +81,7 @@ testclose(struct cdev *dev, int fflag, int devtype, struct thread *td)
>  	test_state *state = dev->si_drv1;
> -	assert(*state == TEST_KQFILTER);
> +	assert(*state == TEST_MMAP);
>  	*state = TEST_CLOSED;
>  	return 0;
> @@ -148,6 +152,21 @@ testkqfilter(struct cdev *dev, struct knote *kn)
>  	return TEST_KQ_ERRNO;
> +static int
> +testmmap(struct cdev *dev, vm_ooffset_t offset, vm_paddr_t *paddr,
> +         int nprot, vm_memattr_t *memattr)
> +	test_state *state = dev->si_drv1;
> +	assert(paddr != NULL);
> +	assert(memattr == VM_MEMATTR_DEFAULT);
> +	assert(nprot == (PROT_READ | PROT_WRITE));
> +	assert(*state == TEST_KQFILTER);
> +	*state = TEST_MMAP;
> +	return 0;
>  void
>  test_make_dev(test_state *state, const char *name)
> diff --git a/testsuite/cdev01/test_cdev01.h b/testsuite/cdev01/test_cdev01.h
> index a83001b5..58866a0c 100644
> --- a/testsuite/cdev01/test_cdev01.h
> +++ b/testsuite/cdev01/test_cdev01.h
> @@ -42,7 +42,8 @@ typedef enum {
>  	TEST_WRITEV,
>  	TEST_POLL,
>  	TEST_KQFILTER,
> -	TEST_CLOSED
> +	TEST_MMAP,
> +	TEST_CLOSED,
>  } test_state;
>  void test_make_dev(test_state *state, const char *name);
> diff --git a/testsuite/cdev01/test_main.c b/testsuite/cdev01/test_main.c
> index cbff9133..23aefa86 100644
> --- a/testsuite/cdev01/test_main.c
> +++ b/testsuite/cdev01/test_main.c
> @@ -35,6 +35,7 @@
>  #include <sys/time.h>
>  #include <sys/uio.h>
>  #include <sys/ioctl.h>
>  #include <assert.h>
>  #include <errno.h>
> @@ -125,6 +126,9 @@ static void test_cdev(const char *path)
>  	assert(rv == -1);
>  	assert(errno == TEST_KQ_ERRNO);
> +	rv = mmap(NULL, 1, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0);
> +	assert(rv == 0);
>  	rv = close(fd);
>  	assert(rv == 0);
