[PATCH 08/10] VT : Port to RTEMS
Christian Mauderer list at c-mauderer.de
Sat Jul 27 13:56:48 UTC 2019
I'm still not entirely convinced what VT does. I tried to remove it (had
to remove the vt_fb_attach() / _detach() from fbd.c too) and it still
works. So why do you need VT?
By the way: The fbd commits won't link without that one. So if you
convince me that VT is necessary you _have_ to reorder or merge fbd and
VT. We can't have any commits that don't compile. It would prevent to
use tools like `git bisect`.
On 26/07/2019 13:22, Vijay Kumar Banerjee wrote:
>  freebsd/sys/dev/vt/colors/vt_termcolors.c |  2 ++
>  freebsd/sys/dev/vt/hw/fb/vt_fb.c          |  2 ++
>  freebsd/sys/dev/vt/vt_core.c              | 30 +++++++++++++++++++++++
>  libbsd.py                                 |  3 +++
>  rtemsbsd/include/machine/vm.h             |  1 +
>  5 files changed, 38 insertions(+)
> diff --git a/freebsd/sys/dev/vt/colors/vt_termcolors.c b/freebsd/sys/dev/vt/colors/vt_termcolors.c
> index c7ef4b80..6a3836c4 100644
> --- a/freebsd/sys/dev/vt/colors/vt_termcolors.c
> +++ b/freebsd/sys/dev/vt/colors/vt_termcolors.c
> @@ -144,6 +144,7 @@ vt_palette_init(void)
>  	for (i = 0; i < NCOLORS; i++) {
>  		snprintf(tunable, sizeof(tunable),
>  		    "kern.vt.color.%d.rgb", i);
> +#ifndef __rtems__
>  		if (TUNABLE_STR_FETCH(tunable, rgb, sizeof(rgb))) {
>  			if (vt_parse_rgb_triplet(rgb, &r, &g, &b) == 0) {
>  				/* convert to percentages */
> @@ -152,6 +153,7 @@ vt_palette_init(void)
>  				color_def[i].b = b*100/255;
> +#endif /* __rtems__ */>  	}
> diff --git a/freebsd/sys/dev/vt/hw/fb/vt_fb.c b/freebsd/sys/dev/vt/hw/fb/vt_fb.c
> index 8eb2744b..c9544c06 100644
> --- a/freebsd/sys/dev/vt/hw/fb/vt_fb.c
> +++ b/freebsd/sys/dev/vt/hw/fb/vt_fb.c
> @@ -51,10 +51,12 @@ static struct vt_driver vt_fb_driver = {
>  	.vd_init = vt_fb_init,
>  	.vd_fini = vt_fb_fini,
>  	.vd_blank = vt_fb_blank,
> +#ifndef __rtems__
>  	.vd_bitblt_text = vt_fb_bitblt_text,
>  	.vd_invalidate_text = vt_fb_invalidate_text,
>  	.vd_bitblt_bmp = vt_fb_bitblt_bitmap,
>  	.vd_drawrect = vt_fb_drawrect,
>  	.vd_setpixel = vt_fb_setpixel,
>  	.vd_postswitch = vt_fb_postswitch,
>  	.vd_priority = VD_PRIORITY_GENERIC+10,> diff --git a/freebsd/sys/dev/vt/vt_core.c b/freebsd/sys/dev/vt/vt_core.c
> index 5f2b1b0e..af0e47eb 100644
> --- a/freebsd/sys/dev/vt/vt_core.c
> +++ b/freebsd/sys/dev/vt/vt_core.c
> @@ -47,7 +47,9 @@ __FBSDID("$FreeBSD$");
>  #include <sys/lock.h>
>  #include <sys/malloc.h>
>  #include <sys/mutex.h>
> +#ifndef __rtems__
>  #include <sys/power.h>
>  #include <sys/priv.h>
>  #include <sys/proc.h>
>  #include <sys/random.h>
> @@ -83,6 +85,7 @@ static tc_opened_t	vtterm_opened;
>  static tc_ioctl_t	vtterm_ioctl;
>  static tc_mmap_t	vtterm_mmap;
> +#ifndef __rtems__
>  const struct terminal_class vt_termclass = {
>  	.tc_bell	= vtterm_bell,
>  	.tc_cursor	= vtterm_cursor,
> @@ -104,6 +107,7 @@ const struct terminal_class vt_termclass = {
>  	.tc_ioctl	= vtterm_ioctl,
>  	.tc_mmap	= vtterm_mmap,
>   * Use a constant timer of 25 Hz to redraw the screen.
> @@ -129,6 +133,7 @@ static VT_SYSCTL_INT(debug, 0, "vt(9) debug level");
>  static VT_SYSCTL_INT(deadtimer, 15, "Time to wait busy process in VT_PROCESS mode");
>  static VT_SYSCTL_INT(suspendswitch, 1, "Switch to VT0 before suspend");
> +#ifndef __rtems__
>  /* Allow to disable some keyboard combinations. */
>  static VT_SYSCTL_INT(kbd_halt, 1, "Enable halt keyboard combination.  "
>      "See kbdmap(5) to configure.");
> @@ -149,11 +154,13 @@ VT_SYSCTL_INT(splash_ncpu, 0, "Override number of logos displayed "
>  VT_SYSCTL_INT(splash_cpu_style, 2, "Draw logo style "
>      "(0 = Alternate beastie, 1 = Beastie, 2 = Orb)");
>  VT_SYSCTL_INT(splash_cpu_duration, 10, "Hide logos after (seconds)");
>  static unsigned int vt_unit = 0;
>  static MALLOC_DEFINE(M_VT, "vt", "vt device");
>  struct vt_device *main_vd = &vt_consdev;
> +#ifndef __rtems__
>  /* Boot logo. */
>  extern unsigned int vt_logo_width;
>  extern unsigned int vt_logo_height;
> @@ -169,6 +176,7 @@ extern struct vt_font vt_font_default;
>  #ifndef SC_NO_CUTPASTE
>  extern struct vt_mouse_cursor vt_default_mouse_pointer;
>  #endif
>  static int signal_vt_rel(struct vt_window *);
>  static int signal_vt_acq(struct vt_window *);
> @@ -206,6 +214,7 @@ struct vt_device	vt_consdev = {
>  	.vd_windows = { [VT_CONSWINDOW] =  &vt_conswindow, },
>  	.vd_curwindow = &vt_conswindow,
>  	.vd_kbstate = 0,
> +#ifndef __rtems__
>  	.vd_pastebuf = {
>  		.vpb_buf = NULL,
> @@ -216,6 +225,7 @@ struct vt_device	vt_consdev = {
>  	.vd_mcursor_fg = TC_WHITE,
>  	.vd_mcursor_bg = TC_BLACK,
>  #endif
>  #ifndef SC_NO_CONSDRAWN
>  	.vd_drawn = vt_consdrawn,
> @@ -247,6 +257,7 @@ static struct vt_window	vt_conswindow = {
>  	.vw_kbdmode = K_XLATE,
>  	.vw_grabbed = 0,
> +#ifndef __rtems__
>  struct terminal vt_consterm = {
>  	.tm_class = &vt_termclass,
>  	.tm_softc = &vt_conswindow,
> @@ -270,14 +281,17 @@ SYSINIT(vt_update_static, SI_SUB_KMEM, SI_ORDER_ANY, vt_update_static,
>  /* Delay until all devices attached, to not waste time. */
>  SYSINIT(vt_early_cons, SI_SUB_INT_CONFIG_HOOKS, SI_ORDER_ANY, vt_upgrade,
>      &vt_consdev);
>  /* Initialize locks/mem depended members. */
>  static void
>  vt_update_static(void *dummy)
> +#ifndef __rtems__
>  	if (!vty_enabled(VTY_VT))
>  		return;
>  	if (main_vd->vd_driver != NULL)
>  		printf("VT(%s): %s %ux%u\n", main_vd->vd_driver->vd_name,
>  		    (main_vd->vd_flags & VDF_TEXTMODE) ? "text" : "resolution",
> @@ -339,6 +353,7 @@ vt_switch_timer(void *arg)
>  	vt_late_window_switch((struct vt_window *)arg);
> +#ifndef __rtems__
>  static int
>  vt_save_kbd_mode(struct vt_window *vw, keyboard_t *kbd)
> @@ -429,6 +444,7 @@ vt_update_kbd_leds(struct vt_window *vw, keyboard_t *kbd)
>  	return (ret);
>  static int
>  vt_window_preswitch(struct vt_window *vw, struct vt_window *curvw)
> @@ -454,6 +470,7 @@ vt_window_postswitch(struct vt_window *vw)
>  	return (0);
> +#ifndef __rtems__
>  /* vt_late_window_switch will done VT switching for regular case. */
>  static int
>  vt_late_window_switch(struct vt_window *vw)
> @@ -2832,6 +2849,7 @@ vt_replace_backend(const struct vt_driver *drv, void *softc)
>  	termcn_cnregister(vd->vd_windows[VT_CONSWINDOW]->vw_terminal);
>  static void
>  vt_suspend_handler(void *priv)
> @@ -2859,8 +2877,10 @@ void
>  vt_allocate(const struct vt_driver *drv, void *softc)
> +#ifndef __rtems__
>  		return;
>  	if (main_vd->vd_driver == NULL) {
>  		main_vd->vd_driver = drv;
> @@ -2880,15 +2900,19 @@ vt_allocate(const struct vt_driver *drv, void *softc)
>  		    main_vd->vd_driver->vd_name, drv->vd_name);
> +#ifndef __rtems__
>  	vt_replace_backend(drv, softc);
>  void
>  vt_deallocate(const struct vt_driver *drv, void *softc)
> +#ifndef __rtems__
>  		return;
>  	if (main_vd->vd_prev_driver == NULL ||
>  	    main_vd->vd_driver != drv ||
> @@ -2898,7 +2922,9 @@ vt_deallocate(const struct vt_driver *drv, void *softc)
>  	printf("VT: Switching back from \"%s\" to \"%s\".\n",
>  	    main_vd->vd_driver->vd_name, main_vd->vd_prev_driver->vd_name);
> +#ifndef __rtems__
>  	vt_replace_backend(NULL, NULL);
>  void
> @@ -2910,8 +2936,10 @@ vt_suspend(struct vt_device *vd)
>  		return;
>  	/* Save current window. */
>  	vd->vd_savedwindow = vd->vd_curwindow;
> +#ifndef __rtems__
>  	/* Ask holding process to free window and switch to console window */
>  	vt_proc_window_switch(vd->vd_windows[VT_CONSWINDOW]);
>  	/* Wait for the window switch to complete. */
>  	error = 0;
> @@ -2927,7 +2955,9 @@ vt_resume(struct vt_device *vd)
>  	if (vt_suspendswitch == 0)
>  		return;
> +#ifndef __rtems__
>  	/* Switch back to saved window, if any */
>  	vt_proc_window_switch(vd->vd_savedwindow);
>  	vd->vd_savedwindow = NULL;
> diff --git a/libbsd.py b/libbsd.py
> index 71eb3577..775eeeac 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -825,6 +825,9 @@ class display(builder.Module):
>                  'sys/arm/ti/am335x/am335x_ecap.c',
>                  'sys/dev/fb/fb.c',
>                  'sys/dev/fb/fbd.c',
> +                'sys/dev/vt/hw/fb/vt_fb.c',
> +                'sys/dev/vt/vt_core.c',
> +                'sys/dev/vt/colors/vt_termcolors.c',
>              mm.generator['source']()
> diff --git a/rtemsbsd/include/machine/vm.h b/rtemsbsd/include/machine/vm.h
> index 351b7472..b90a4cf4 100644
> --- a/rtemsbsd/include/machine/vm.h
> +++ b/rtemsbsd/include/machine/vm.h
> @@ -1,2 +1,3 @@
>  #define VM_MEMATTR_DEFAULT 0
>  #define VM_MEMATTR_UNCACHEABLE 1
> +#define vtophys(a) (a)
