[PATCH 08/10] VT : Port to RTEMS
Christian Mauderer list at c-mauderer.de
Sun Jul 28 07:57:24 UTC 2019
On 27/07/2019 22:31, Vijay Kumar Banerjee wrote:
> On Sat, Jul 27, 2019 at 7:26 PM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     I'm still not entirely convinced what VT does. I tried to remove it (had
>     to remove the vt_fb_attach() / _detach() from fbd.c too) and it still
>     works. So why do you need VT?
> I removed the VT commit and the app was not able to open the fb device,
> if you can open the device with just removing the VT part from fbd, then
> maybe some other part of the VT commit is necessary to open the device,
> I'll have a look and report and try to see if minimum to no parts of vt
> is needed.
> (We already removed most part from it, just initialization is there).
That's odd. I can just revert the two VT patches with "git revert <id>",
remove vt_fb_attach() / ..._detach() and I still get an output.
>     By the way: The fbd commits won't link without that one. So if you
>     convince me that VT is necessary you _have_ to reorder or merge fbd and
>     VT. We can't have any commits that don't compile. It would prevent to
>     use tools like `git bisect`.
> OK. I will merge them into one FBD patch then and put them before the
> display
> driver patch of am335x
>     On 26/07/2019 13:22, Vijay Kumar Banerjee wrote:
>     >  freebsd/sys/dev/vt/colors/vt_termcolors.c |  2 ++
>     >  freebsd/sys/dev/vt/hw/fb/vt_fb.c          |  2 ++
>     >  freebsd/sys/dev/vt/vt_core.c              | 30
>     >  libbsd.py                                 |  3 +++
>     >  rtemsbsd/include/machine/vm.h             |  1 +
>     >  5 files changed, 38 insertions(+)
>     > diff --git a/freebsd/sys/dev/vt/colors/vt_termcolors.c
>     b/freebsd/sys/dev/vt/colors/vt_termcolors.c
>     > index c7ef4b80..6a3836c4 100644
>     > --- a/freebsd/sys/dev/vt/colors/vt_termcolors.c
>     > +++ b/freebsd/sys/dev/vt/colors/vt_termcolors.c
>     > @@ -144,6 +144,7 @@ vt_palette_init(void)
>     >       for (i = 0; i < NCOLORS; i++) {
>     >               snprintf(tunable, sizeof(tunable),
>     >                   "kern.vt.color.%d.rgb", i);
>     > +#ifndef __rtems__
>     >               if (TUNABLE_STR_FETCH(tunable, rgb, sizeof(rgb))) {
>     >                       if (vt_parse_rgb_triplet(rgb, &r, &g, &b) ==
>     0) {
>     >                               /* convert to percentages */
>     > @@ -152,6 +153,7 @@ vt_palette_init(void)
>     >                               color_def[i].b = b*100/255;
>     > +#endif /* __rtems__ */>      }
>>     > diff --git a/freebsd/sys/dev/vt/hw/fb/vt_fb.c
>     b/freebsd/sys/dev/vt/hw/fb/vt_fb.c
>     > index 8eb2744b..c9544c06 100644
>     > --- a/freebsd/sys/dev/vt/hw/fb/vt_fb.c
>     > +++ b/freebsd/sys/dev/vt/hw/fb/vt_fb.c
>     > @@ -51,10 +51,12 @@ static struct vt_driver vt_fb_driver = {
>     >       .vd_init = vt_fb_init,
>     >       .vd_fini = vt_fb_fini,
>     >       .vd_blank = vt_fb_blank,
>     > +#ifndef __rtems__
>     >       .vd_bitblt_text = vt_fb_bitblt_text,
>     >       .vd_invalidate_text = vt_fb_invalidate_text,
>     >       .vd_bitblt_bmp = vt_fb_bitblt_bitmap,
>     >       .vd_drawrect = vt_fb_drawrect,
>     >       .vd_setpixel = vt_fb_setpixel,
>     >       .vd_postswitch = vt_fb_postswitch,
>     >       .vd_priority = VD_PRIORITY_GENERIC+10,> diff --git
>     a/freebsd/sys/dev/vt/vt_core.c b/freebsd/sys/dev/vt/vt_core.c
>     > index 5f2b1b0e..af0e47eb 100644
>     > --- a/freebsd/sys/dev/vt/vt_core.c
>     > +++ b/freebsd/sys/dev/vt/vt_core.c
>     > @@ -47,7 +47,9 @@ __FBSDID("$FreeBSD$");
>     >  #include <sys/lock.h>
>     >  #include <sys/malloc.h>
>     >  #include <sys/mutex.h>
>     > +#ifndef __rtems__
>     >  #include <sys/power.h>
>     >  #include <sys/priv.h>
>     >  #include <sys/proc.h>
>     >  #include <sys/random.h>
>     > @@ -83,6 +85,7 @@ static tc_opened_t  vtterm_opened;
>     >  static tc_ioctl_t    vtterm_ioctl;
>     >  static tc_mmap_t     vtterm_mmap;
>>     > +#ifndef __rtems__
>     >  const struct terminal_class vt_termclass = {
>     >       .tc_bell        = vtterm_bell,
>     >       .tc_cursor      = vtterm_cursor,
>     > @@ -104,6 +107,7 @@ const struct terminal_class vt_termclass = {
>     >       .tc_ioctl       = vtterm_ioctl,
>     >       .tc_mmap        = vtterm_mmap,
>     >   * Use a constant timer of 25 Hz to redraw the screen.
>     > @@ -129,6 +133,7 @@ static VT_SYSCTL_INT(debug, 0, "vt(9) debug
>     level");
>     >  static VT_SYSCTL_INT(deadtimer, 15, "Time to wait busy process in
>     VT_PROCESS mode");
>     >  static VT_SYSCTL_INT(suspendswitch, 1, "Switch to VT0 before
>     suspend");
>>     > +#ifndef __rtems__
>     >  /* Allow to disable some keyboard combinations. */
>     >  static VT_SYSCTL_INT(kbd_halt, 1, "Enable halt keyboard
>     combination.  "
>     >      "See kbdmap(5) to configure.");
>     > @@ -149,11 +154,13 @@ VT_SYSCTL_INT(splash_ncpu, 0, "Override
>     number of logos displayed "
>     >  VT_SYSCTL_INT(splash_cpu_style, 2, "Draw logo style "
>     >      "(0 = Alternate beastie, 1 = Beastie, 2 = Orb)");
>     >  VT_SYSCTL_INT(splash_cpu_duration, 10, "Hide logos after (seconds)");
>>     >  static unsigned int vt_unit = 0;
>     >  static MALLOC_DEFINE(M_VT, "vt", "vt device");
>     >  struct vt_device *main_vd = &vt_consdev;
>>     > +#ifndef __rtems__
>     >  /* Boot logo. */
>     >  extern unsigned int vt_logo_width;
>     >  extern unsigned int vt_logo_height;
>     > @@ -169,6 +176,7 @@ extern struct vt_font vt_font_default;
>     >  #ifndef SC_NO_CUTPASTE
>     >  extern struct vt_mouse_cursor vt_default_mouse_pointer;
>     >  #endif
>>     >  static int signal_vt_rel(struct vt_window *);
>     >  static int signal_vt_acq(struct vt_window *);
>     > @@ -206,6 +214,7 @@ struct vt_device  vt_consdev = {
>     >       .vd_windows = { [VT_CONSWINDOW] =  &vt_conswindow, },
>     >       .vd_curwindow = &vt_conswindow,
>     >       .vd_kbstate = 0,
>     > +#ifndef __rtems__
>     >       .vd_pastebuf = {
>     >               .vpb_buf = NULL,
>     > @@ -216,6 +225,7 @@ struct vt_device  vt_consdev = {
>     >       .vd_mcursor_fg = TC_WHITE,
>     >       .vd_mcursor_bg = TC_BLACK,
>     >  #endif
>>     >  #ifndef SC_NO_CONSDRAWN
>     >       .vd_drawn = vt_consdrawn,
>     > @@ -247,6 +257,7 @@ static struct vt_window   vt_conswindow = {
>     >       .vw_kbdmode = K_XLATE,
>     >       .vw_grabbed = 0,
>     > +#ifndef __rtems__
>     >  struct terminal vt_consterm = {
>     >       .tm_class = &vt_termclass,
>     >       .tm_softc = &vt_conswindow,
>     > @@ -270,14 +281,17 @@ SYSINIT(vt_update_static, SI_SUB_KMEM,
>     SI_ORDER_ANY, vt_update_static,
>     >  /* Delay until all devices attached, to not waste time. */
>     >  SYSINIT(vt_early_cons, SI_SUB_INT_CONFIG_HOOKS, SI_ORDER_ANY,
>     vt_upgrade,
>     >      &vt_consdev);
>>     >  /* Initialize locks/mem depended members. */
>     >  static void
>     >  vt_update_static(void *dummy)
>>     > +#ifndef __rtems__
>     >       if (!vty_enabled(VTY_VT))
>     >               return;
>     >       if (main_vd->vd_driver != NULL)
>     >               printf("VT(%s): %s %ux%u\n",
>     main_vd->vd_driver->vd_name,
>     >                   (main_vd->vd_flags & VDF_TEXTMODE) ? "text" :
>     "resolution",
>     > @@ -339,6 +353,7 @@ vt_switch_timer(void *arg)
>     >       vt_late_window_switch((struct vt_window *)arg);
>>     > +#ifndef __rtems__
>     >  static int
>     >  vt_save_kbd_mode(struct vt_window *vw, keyboard_t *kbd)
>     > @@ -429,6 +444,7 @@ vt_update_kbd_leds(struct vt_window *vw,
>     keyboard_t *kbd)
>>     >       return (ret);
>>     >  static int
>     >  vt_window_preswitch(struct vt_window *vw, struct vt_window *curvw)
>     > @@ -454,6 +470,7 @@ vt_window_postswitch(struct vt_window *vw)
>     >       return (0);
>>     > +#ifndef __rtems__
>     >  /* vt_late_window_switch will done VT switching for regular case. */
>     >  static int
>     >  vt_late_window_switch(struct vt_window *vw)
>     > @@ -2832,6 +2849,7 @@ vt_replace_backend(const struct vt_driver
>     *drv, void *softc)
>     >       termcn_cnregister(vd->vd_windows[VT_CONSWINDOW]->vw_terminal);
>>     >  static void
>     >  vt_suspend_handler(void *priv)
>     > @@ -2859,8 +2877,10 @@ void
>     >  vt_allocate(const struct vt_driver *drv, void *softc)
>>     > +#ifndef __rtems__
>     >               return;
>>     >       if (main_vd->vd_driver == NULL) {
>     >               main_vd->vd_driver = drv;
>     > @@ -2880,15 +2900,19 @@ vt_allocate(const struct vt_driver *drv,
>     void *softc)
>     >                   main_vd->vd_driver->vd_name, drv->vd_name);
>>     > +#ifndef __rtems__
>     >       vt_replace_backend(drv, softc);
>>     >  void
>     >  vt_deallocate(const struct vt_driver *drv, void *softc)
>>     > +#ifndef __rtems__
>     >               return;
>>     >       if (main_vd->vd_prev_driver == NULL ||
>     >           main_vd->vd_driver != drv ||
>     > @@ -2898,7 +2922,9 @@ vt_deallocate(const struct vt_driver *drv,
>     void *softc)
>     >       printf("VT: Switching back from \"%s\" to \"%s\".\n",
>     main_vd->vd_prev_driver->vd_name);
>>     > +#ifndef __rtems__
>     >       vt_replace_backend(NULL, NULL);
>>     >  void
>     > @@ -2910,8 +2936,10 @@ vt_suspend(struct vt_device *vd)
>     >               return;
>     >       /* Save current window. */
>     >       vd->vd_savedwindow = vd->vd_curwindow;
>     > +#ifndef __rtems__
>     >       /* Ask holding process to free window and switch to console
>     window */
>     >       vt_proc_window_switch(vd->vd_windows[VT_CONSWINDOW]);
>>     >       /* Wait for the window switch to complete. */
>     >       error = 0;
>     > @@ -2927,7 +2955,9 @@ vt_resume(struct vt_device *vd)
>>     >       if (vt_suspendswitch == 0)
>     >               return;
>     > +#ifndef __rtems__
>     >       /* Switch back to saved window, if any */
>     >       vt_proc_window_switch(vd->vd_savedwindow);
>     >       vd->vd_savedwindow = NULL;
>     > diff --git a/libbsd.py b/libbsd.py
>     > index 71eb3577..775eeeac 100644
>     > --- a/libbsd.py
>     > +++ b/libbsd.py
>     > @@ -825,6 +825,9 @@ class display(builder.Module):
>     >                  'sys/arm/ti/am335x/am335x_ecap.c',
>     >                  'sys/dev/fb/fb.c',
>     >                  'sys/dev/fb/fbd.c',
>     > +                'sys/dev/vt/hw/fb/vt_fb.c',
>     > +                'sys/dev/vt/vt_core.c',
>     > +                'sys/dev/vt/colors/vt_termcolors.c',
>     >              mm.generator['source']()
>     > diff --git a/rtemsbsd/include/machine/vm.h
>     b/rtemsbsd/include/machine/vm.h
>     > index 351b7472..b90a4cf4 100644
>     > --- a/rtemsbsd/include/machine/vm.h
>     > +++ b/rtemsbsd/include/machine/vm.h
>     > @@ -1,2 +1,3 @@
>     >  #define VM_MEMATTR_DEFAULT 0
>     >  #define VM_MEMATTR_UNCACHEABLE 1
>     > +#define vtophys(a) (a)
