[PATCH 1/3] user/rsb/deployment.rst: Fix typo.
Joel Sherrill
joel at rtems.org
Mon Jul 29 13:37:21 UTC 2019
user/rsb/deployment.rst | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/user/rsb/deployment.rst b/user/rsb/deployment.rst
index ad5dd57..afbf13a 100644
--- a/user/rsb/deployment.rst
+++ b/user/rsb/deployment.rst
@@ -81,7 +81,7 @@ A build set tar file is created by adding ``--bset-tar-file`` option to the
3. Creating the build set tar file.
You can also suppress installing the files using the ``--no-install``
-option. This is useful if your prefix is not accessiable, for example when
+option. This is useful if your prefix is not accessible, for example when
building Canadian cross compiled tool sets:
.. code-block:: none
1.8.3.1
