[PATCH v6] ndbm test suite
Joel Sherrill
joel at rtems.org
Mon Jul 29 16:03:07 UTC 2019
Hi
Now pushed. Thanks.
I finally got a local sparc tool chain built with the git master of newlib
to build and run this test. It was a bit more complicated than I expected.
I did add a bit of logic to the psxtests configure.ac and Makefile.am to
ensure the test was not built unless the toolset included <ndbm.h>. This
ensures that builds don't break when the toolset doesn't include it and
that git bisect will continue to work.
The RSB will need to be bumped to the git master once the github mirror
updates to include my push to libm.
On Thu, Jul 25, 2019 at 2:34 PM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I just wanted to let everyone know that I have this pending on a branch
> and can build it using the current but there is a problem linking libm on
> the newlib git master. Once I have the RSB updated, I will look at pushing
> this.
> To let Vaibhav continue pushing on fenv, if we decide the configure.ac
> should check for the newly added dbm methods before building the test, I
> will merge that into the patch.
> --joel
> On Tue, Jul 23, 2019 at 8:42 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> testsuites/psxtests/Makefile.am | 9 +
>> testsuites/psxtests/configure.ac | 1 +
>> testsuites/psxtests/psxndbm01/init.c | 299 ++++++++++++++++++++
>> testsuites/psxtests/psxndbm01/psxndbm01.doc | 36 +++
>> testsuites/psxtests/psxndbm01/psxndbm01.scn | 29 ++
>> 5 files changed, 374 insertions(+)
>> create mode 100644 testsuites/psxtests/psxndbm01/init.c
>> create mode 100644 testsuites/psxtests/psxndbm01/psxndbm01.doc
>> create mode 100644 testsuites/psxtests/psxndbm01/psxndbm01.scn
>> diff --git a/testsuites/psxtests/Makefile.am
>> b/testsuites/psxtests/Makefile.am
>> index 59c9f2085b..36da591ccc 100755
>> --- a/testsuites/psxtests/Makefile.am
>> +++ b/testsuites/psxtests/Makefile.am
>> @@ -694,6 +694,15 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS)
>> $(TEST_FLAGS_psxmutexattr01) \
>> $(support_includes) -I$(top_srcdir)/include
>> endif
>> +if TEST_psxndbm01
>> +psx_tests += psxndbm01
>> +psx_screens += psxndbm01/psxndbm01.scn
>> +psx_docs += psxndbm01/psxndbm01.doc
>> +psxndbm01_SOURCES = psxndbm01/init.c
>> +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
>> + $(support_includes)
>> +endif
>> if TEST_psxobj01
>> psx_tests += psxobj01
>> psx_screens += psxobj01/psxobj01.scn
>> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
>> configure.ac
>> index 85559e4aa5..07d7ccaf55 100644
>> --- a/testsuites/psxtests/configure.ac
>> +++ b/testsuites/psxtests/configure.ac
>> @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
>> RTEMS_TEST_CHECK([psxmsgq03])
>> RTEMS_TEST_CHECK([psxmsgq04])
>> RTEMS_TEST_CHECK([psxmutexattr01])
>> +RTEMS_TEST_CHECK([psxndbm01])
>> RTEMS_TEST_CHECK([psxobj01])
>> RTEMS_TEST_CHECK([psxonce01])
>> RTEMS_TEST_CHECK([psxpasswd01])
>> diff --git a/testsuites/psxtests/psxndbm01/init.c
>> b/testsuites/psxtests/psxndbm01/init.c
>> new file mode 100644
>> index 0000000000..a1eff4bd67
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxndbm01/init.c
>> @@ -0,0 +1,299 @@
>> + * @file
>> + * @brief Test suite for ndbm.h methods
>> + * SPDX-License-Identifier: BSD-2-Clause
>> + * Copyright (C) 2019 Vaibhav Gupta
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + * notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + * notice, this list of conditions and the following disclaimer in the
>> + * documentation and/or other materials provided with the
>> distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> "AS IS"
>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
>> BE
>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>> IN
>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> OTHERWISE)
>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> OF THE
>> + * POSSIBILITY OF SUCH DAMAGE.
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +/* header files are listed in lexical/lexicographical/alphabetical order
>> +#include <errno.h>
>> +#include <fcntl.h> /* contains definitions of 'open_flags' */
>> +#include <limits.h>
>> +#include <ndbm.h> /* contains declarations of ndbm methods */
>> +#include <stddef.h>
>> +#include <stdint.h>
>> +#include <stdio.h>
>> +#include <sys/stat.h> /* contains definitions of 'file_mode' */
>> +#include <string.h>
>> +#include <rtems/test.h>
>> +#include <tmacros.h>
>> +const char rtems_test_name[] = "PSXNDBM 01";
>> +#define NAME "VARoDeK"
>> +#define PHONE_NO "123-321-777-888"
>> +#define DB_NAME "phones_test"
>> +#define NAME2 "VG"
>> +#define PHONE_NO2 "321-123-888-777"
>> +/* forward declarations to avoid warnings */
>> +rtems_task Init(rtems_task_argument ignored);
>> +* This Function takes DBM* as a argument and count the number of records
>> in the
>> +* database pointed by it.
>> +static int count_no_of_records( DBM *db_local )
>> + int count = 0;
>> + datum temp;
>> + for (
>> + temp = dbm_firstkey( db_local );
>> + temp.dptr != NULL;
>> + temp = dbm_nextkey( db_local ), count++
>> + return count;
>> +/* Test Function Begins */
>> + datum name = { NAME, sizeof( NAME ) };
>> + datum put_phone_no = { PHONE_NO, sizeof( PHONE_NO ) };
>> + datum name2 = { NAME2, sizeof( NAME2 ) };
>> + datum put_phone_no2 = { PHONE_NO2, sizeof( PHONE_NO2 ) };
>> + datum get_phone_no, key;
>> + int i;
>> + char *test_strings;
>> + DBM *db;
>> + TEST_BEGIN();
>> +/* A Simple test to check if ndbm methods are call-able */
>> + * A Simple test to check if NDBM methods are call-able
>> + * We will try to open a database and then close it.
>> + * If it successful, hence we can have further tests.
>> + * Also, while opening it for first time, will create that database,
>> + * hence we will be able to test for 'O_RDWR | O_EXCL' case later.
>> + * Meanwhile we will also store one record, this record will be helpful
>> in
>> + * further tests.
>> + * And fetch it, to make sure if basic NDBM methods are working
>> correctly.
>> + puts( "\nOpen Database." );
>> + db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_TRUNC, S_IRWXU );
>> + rtems_test_assert( db != NULL );
>> + /* This data will be useful in further tests */
>> + puts( "Store Records in Database." );
>> + dbm_store( db, name, put_phone_no, DBM_INSERT );
>> + puts( "Fetch Records from Database and check." );
>> + get_phone_no = dbm_fetch( db, name );
>> + rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO )
>> == 0 );
>> + puts( "Close Database." );
>> + dbm_close( db );
>> +/* dbm_open() */
>> + puts( "\nTestcases for 'dbm_open()'." );
>> +/* The 'DB_NAME' is already created, hence 'O_RDWR | O_EXCL' should
>> fail. */
>> + puts( "Use 'O_CREAT | O_EXCL' to open existing file and confirm
>> error." );
>> + db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_EXCL, S_IRWXU );
>> + rtems_test_assert( db == NULL );
>> + rtems_test_assert( errno == EEXIST );
>> +/* Some implementations use 3 characters for the suffix and others use
>> + * 4 characters for the suffix, applications should ensure that the
>> maximum
>> + * portable pathname length passed to dbm_open() is no greater than
>> + * {PATH_MAX}-4 bytes, with the last component of the pathname no greater
>> + * than {NAME_MAX}-4 bytes.
>> +/* inside 'ndbm.h' ; '#define DBM_SUFFIX ".db"' ;
>> + * 2 alphabets and 1 period, hence 3 characters are used for suffix
>> + * in this implementation.
>> + puts( "Use path name larger than '{PATH_MAX}-3 bytes.' and confirm
>> error." );
>> + test_strings = (char*)malloc( PATH_MAX - 2 );
>> + for ( i = 0; i < PATH_MAX - 3; i++ ) {
>> + test_strings[i] = 'r';
>> + test_strings[i] = '\0';
>> + db = dbm_open(
>> + (const char*)test_strings,
>> + O_RDWR | O_CREAT | O_TRUNC,
>> + S_IRWXU
>> + rtems_test_assert( errno == ENAMETOOLONG );
>> + free( test_strings );
>> +/* database opened for write-only access opens the files for read and
>> + * write access or it will fail.
>> +/* Implementation of __hash_open in newlib does not support `O_WRONLY` */
>> + puts( "Open file with write access only and confirm error." );
>> + db = dbm_open( DB_NAME, O_WRONLY, S_IRWXU );
>> + rtems_test_assert( errno == EINVAL );
>> +/* dbm_store() */
>> + puts( "\nTestcases for 'dbm_store()'" );
>> + db = dbm_open( DB_NAME, O_RDWR, S_IRWXU );
>> + puts( "Insert new record with same key using 'DBM_INSERT' mode and "
>> + "confirm error." );
>> + rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_INSERT ) ==
>> 1 );
>> == 0 );
>> + puts( "Insert new record with same key using 'DBM_REPLACE' mode and "
>> + "confirm changes." );
>> + rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_REPLACE )
>> == 0 );
>> + rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO2 )
>> == 0 );
>> +/* Revert for next tests */
>> + rtems_test_assert( dbm_store( db, name, put_phone_no, DBM_REPLACE ) ==
>> 0 );
>> + puts( "Store a new record and "
>> + "confirm that total number of records is successful 2." );
>> + rtems_test_assert( dbm_store( db, name2, put_phone_no2, DBM_INSERT )
>> == 0 );
>> +/* Confirm number of records */
>> + rtems_test_assert( count_no_of_records( db ) == 2 );
>> + dbm_close( db );
>> +/* dbm_fetch() */
>> + puts( "\nTestcases for 'dbm_fetch()'" );
>> + db = dbm_open( DB_NAME, O_RDONLY, S_IRWXU );
>> + puts( "Fetch existing records and confirm results." );
>> == 0 );
>> + get_phone_no = dbm_fetch( db, name2 );
>> == 0 );
>> + puts( "Fetch non-existing record and confirm error." );
>> + test_strings = (char*)malloc(6);
>> + strncpy( test_strings, "Hello", 5 );
>> + test_strings[5] = '\0';
>> +/* The data pointed by test_string is now pointed by key.dptr */
>> + key.dptr = test_strings;
>> + key.dsize = sizeof( test_strings );
>> + get_phone_no = dbm_fetch( db, key );
>> + rtems_test_assert( get_phone_no.dptr == NULL );
>> + dbm_close( db );
>> +/* We need the 'key' object, hence we cannot free 'test_strings' */
>> +/* dbm_delete() */
>> + puts( "\nTestcases for 'dbm_delete()'" );
>> + puts( "Delete non-existing record and confirm error." );
>> + rtems_test_assert( dbm_delete( db, key ) != 0 );
>> + rtems_test_assert( count_no_of_records( db ) == 2);
>> + puts( "Delete existing record and "
>> + "confirm that total number of records is successful 1." );
>> + rtems_test_assert( dbm_delete( db, name ) == 0 );
>> + rtems_test_assert( count_no_of_records( db ) == 1);
>> + puts( "Confirm if correct record is deleted." );
>> +/* record returned by 'dbm_firstkey()' should be the only record
>> + * left, this should be checked to confirm correct working of
>> + * 'dbm_firstkey()'.
>> + * Check if the data is not corrupted after usage of 'dbm_delete()'
>> + puts( "Check if the data is not corrupted after usage of
>> 'dbm_delete()'." );
>> + get_phone_no = dbm_fetch( db, dbm_firstkey( db ) );
>> == 0 );
>> +/* Empty the database and then try to use 'dbm_firstkey()', the
>> + * dptr pointer should point to NULL.
>> + puts( "Empty records in database and check results of
>> 'dbm_firstkey()'." );
>> + rtems_test_assert( dbm_delete( db, dbm_firstkey( db ) ) == 0 );
>> + key = dbm_firstkey( db );
>> + rtems_test_assert( key.dptr == NULL );
>> + dbm_close( db );
>> +* All cases for 'dbm_firstkey()' and 'dbm_nextkey()' were tested while
>> +* performing other tests.
>> +* One such case be found in count_number_of_records() function.
>> + TEST_END();
>> + rtems_test_exit(0);
>> +/* NOTICE: the clock driver is explicitly disabled */
>> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> +#define CONFIGURE_MAXIMUM_TASKS 1
>> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> +#include <rtems/confdefs.h>
>> +/* end of file */
>> diff --git a/testsuites/psxtests/psxndbm01/psxndbm01.doc
>> b/testsuites/psxtests/psxndbm01/psxndbm01.doc
>> index 0000000000..cdaeb40911
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxndbm01/psxndbm01.doc
>> @@ -0,0 +1,36 @@
>> +This File describes the concepts tested by this test suite.
>> +ndbm.h - routines to manage data files that contain key/data pairs.
>> +test suite name: PSXNDBM 01
>> +- A Simple test to check if NDBM methods are call-able.
>> + - Check if able to run the routine to Open Database.
>> + - Check if able to run the routine to store a record in database.
>> + - Check if able to run the routine to fetch a record from database.
>> + - Check if able to run the routine to close the database.
>> +- Test Cases for 'dbm_open()'.
>> + - Verify the error when trying to open existing file with 'O_RDWR |
>> O_EXCL'
>> + flags.
>> + - Verify the error when trying to open file with pathname longer than
>> + {PATHMAX}-3 bytes.
>> + - Verify the error when trying to open file with only write access.
>> +- Test Cases for 'dbm_store()'.
>> + - Verify the error when trying to insert a record using same key with
>> + 'DBM_INSERT' mode.
>> + - Verify the updated record when trying to insert a record using same
>> key
>> + with 'DBM_REPLACE' mode.
>> + - Verify if able to save more than one record in database.
>> +- Test Cases for 'dbm_fetch()'.
>> + - Verify the data fetched from database.
>> + - Verify the error when tring to fetch non-existing record.
>> +- Test Cases for 'dbm_delete()'.
>> + - Veriy the error when trying to delete non-existing record.
>> + - Delete one record and verify results.
>> + - Check if correct record is deleted.
>> + - Verify if other data is not corrupted during delete.
>> + - Empty the databse and verify the value returned by 'dbm_firstkey()'.
>> \ No newline at end of file
>> diff --git a/testsuites/psxtests/psxndbm01/psxndbm01.scn
>> b/testsuites/psxtests/psxndbm01/psxndbm01.scn
>> index 0000000000..3fa386630a
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxndbm01/psxndbm01.scn
>> @@ -0,0 +1,29 @@
>> +*** PSXNDBM 01 Test ***
>> +Open Database.
>> +Store Records in Database.
>> +Fetch Records from Database and check.
>> +Close Database.
>> +Testcases for 'dbm_open()'.
>> +Use 'O_CREAT | O_EXCL' to open existing file and confirm error.
>> +Use path name larger than '{PATH_MAX}-3 bytes.' and confirm error.
>> +Open file with write access only and confirm error.
>> +Testcases for 'dbm_store()'
>> +Insert new record with same key using 'DBM_INSERT' mode and confirm
>> error.
>> +Insert new record with same key using 'DBM_REPLACE' mode and confirm
>> changes.
>> +Store a new record and confirm that total number of records is
>> successful 2.
>> +Testcases for 'dbm_fetch()'
>> +Fetch existing records and confirm results.
>> +Fetch non-existing record and confirm error.
>> +Testcases for 'dbm_delete()'
>> +Delete non-existing record and confirm error.
>> +Delete existing record and confirm that total number of records is
>> successful 1.
>> +Confirm if correct record is deleted.
>> +Check if the data is not corrupted after usage of 'dbm_delete()'.
>> +Empty records in database and check results of 'dbm_firstkey()'.
>> +*** END OF TEST PSXNDBM 01 ***
>> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190729/b21f2dee/attachment-0001.html>
