[PATCH v6] ndbm test suite
Joel Sherrill
joel at rtems.org
Mon Jul 29 18:41:06 UTC 2019
On Mon, Jul 29, 2019 at 1:07 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> On Mon, Jul 29, 2019 at 10:44 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, Jul 29, 2019 at 11:35 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>>> Thanks Joel!
>>> Now when the testsuite patch is successfully accepted, I would like
>>> to add an example in:
>>> https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line,
>>> about wrapping a "function call" in "80 characters per line".
>> Pull. I pushed the test. It just won't get built unless your toolset has
>> ndbm.h
>> Thanks
>> This sounds like helpful guidance.
>> What's next for fenv?
> I am following what You and Gedare suggested me. I won't directly import
> fenv files,
> as sources are mixed (FreeBSD and NetBSD), I am trying to unify them.
One newlib patch per architecture even if you are merging implementations.
> I will be approaching in this manner:
> 1. I will make a header file `libc/include/fenv.h`. All function
> definitons will be mentioned. All definitons/macros which are architecture
> specific will be kept between #if / #elif / #else directives.
Avoid adding if's to the main fenv.h if you are doing bodies of the
implementation. As one example, RISC-V has its own fenv.h in
libc/machine/riscv/include and bodies of the methods in libm/machine/riscv.
fenv.h looks to be portable if sys/fenv.h is "machine" dependent. Your
if's could be factored out into machine/ARCH/include/fenv.h. Then the
portable method prototypes are in libc/include/fenv.h.
Let me ask about that on the newlib list.
> 1. Make architecture specific folders where I will Place `fenv.c`
> files.
> - Vaibhav Gupta
>>> Gedare and me discussed about it on a thread. That time he guided me for
>>> this
>>> as there is no example about in on the trac pag.
>>> Vaibhav Gupta
>>> On Mon, Jul 29, 2019 at 9:33 PM Joel Sherrill <joel at rtems.org> wrote:
>>>> Hi
>>>> Now pushed. Thanks.
>>>> I finally got a local sparc tool chain built with the git master of
>>>> newlib to build and run this test. It was a bit more complicated than I
>>>> expected.
>>>> I did add a bit of logic to the psxtests configure.ac and Makefile.am
>>>> to ensure the test was not built unless the toolset included <ndbm.h>. This
>>>> ensures that builds don't break when the toolset doesn't include it and
>>>> that git bisect will continue to work.
>>>> The RSB will need to be bumped to the git master once the github mirror
>>>> updates to include my push to libm.
>>>> On Thu, Jul 25, 2019 at 2:34 PM Joel Sherrill <joel at rtems.org> wrote:
>>>>> Hi
>>>>> I just wanted to let everyone know that I have this pending on a
>>>>> branch and can build it using the current but there is a problem linking
>>>>> libm on the newlib git master. Once I have the RSB updated, I will look at
>>>>> pushing this.
>>>>> To let Vaibhav continue pushing on fenv, if we decide the configure.ac
>>>>> should check for the newly added dbm methods before building the test, I
>>>>> will merge that into the patch.
>>>>> --joel
>>>>> On Tue, Jul 23, 2019 at 8:42 AM Vaibhav Gupta <
>>>>> vaibhavgupta40 at gmail.com> wrote:
>>>>>> testsuites/psxtests/Makefile.am | 9 +
>>>>>> testsuites/psxtests/configure.ac | 1 +
>>>>>> testsuites/psxtests/psxndbm01/init.c | 299
>>>>>> testsuites/psxtests/psxndbm01/psxndbm01.doc | 36 +++
>>>>>> testsuites/psxtests/psxndbm01/psxndbm01.scn | 29 ++
>>>>>> 5 files changed, 374 insertions(+)
>>>>>> create mode 100644 testsuites/psxtests/psxndbm01/init.c
>>>>>> create mode 100644 testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>>>> create mode 100644 testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>>>> diff --git a/testsuites/psxtests/Makefile.am
>>>>>> b/testsuites/psxtests/Makefile.am
>>>>>> index 59c9f2085b..36da591ccc 100755
>>>>>> --- a/testsuites/psxtests/Makefile.am
>>>>>> +++ b/testsuites/psxtests/Makefile.am
>>>>>> @@ -694,6 +694,15 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS)
>>>>>> $(TEST_FLAGS_psxmutexattr01) \
>>>>>> $(support_includes) -I$(top_srcdir)/include
>>>>>> endif
>>>>>> +if TEST_psxndbm01
>>>>>> +psx_tests += psxndbm01
>>>>>> +psx_screens += psxndbm01/psxndbm01.scn
>>>>>> +psx_docs += psxndbm01/psxndbm01.doc
>>>>>> +psxndbm01_SOURCES = psxndbm01/init.c
>>>>>> +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
>>>>>> + $(support_includes)
>>>>>> +endif
>>>>>> if TEST_psxobj01
>>>>>> psx_tests += psxobj01
>>>>>> psx_screens += psxobj01/psxobj01.scn
>>>>>> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
>>>>>> configure.ac
>>>>>> index 85559e4aa5..07d7ccaf55 100644
>>>>>> --- a/testsuites/psxtests/configure.ac
>>>>>> +++ b/testsuites/psxtests/configure.ac
>>>>>> @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
>>>>>> RTEMS_TEST_CHECK([psxmsgq03])
>>>>>> RTEMS_TEST_CHECK([psxmsgq04])
>>>>>> RTEMS_TEST_CHECK([psxmutexattr01])
>>>>>> +RTEMS_TEST_CHECK([psxndbm01])
>>>>>> RTEMS_TEST_CHECK([psxobj01])
>>>>>> RTEMS_TEST_CHECK([psxonce01])
>>>>>> RTEMS_TEST_CHECK([psxpasswd01])
>>>>>> diff --git a/testsuites/psxtests/psxndbm01/init.c
>>>>>> b/testsuites/psxtests/psxndbm01/init.c
>>>>>> new file mode 100644
>>>>>> index 0000000000..a1eff4bd67
>>>>>> --- /dev/null
>>>>>> +++ b/testsuites/psxtests/psxndbm01/init.c
>>>>>> @@ -0,0 +1,299 @@
>>>>>> + * @file
>>>>>> + * @brief Test suite for ndbm.h methods
>>>>>> + * SPDX-License-Identifier: BSD-2-Clause
>>>>>> + * Copyright (C) 2019 Vaibhav Gupta
>>>>>> + * Redistribution and use in source and binary forms, with or without
>>>>>> + * modification, are permitted provided that the following conditions
>>>>>> + * are met:
>>>>>> + * 1. Redistributions of source code must retain the above copyright
>>>>>> + * notice, this list of conditions and the following disclaimer.
>>>>>> + * 2. Redistributions in binary form must reproduce the above
>>>>>> copyright
>>>>>> in the
>>>>>> + * documentation and/or other materials provided with the
>>>>>> distribution.
>>>>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>> CONTRIBUTORS "AS IS"
>>>>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>>>> TO, THE
>>>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>> PARTICULAR PURPOSE
>>>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>>>>> CONTRIBUTORS BE
>>>>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>>>>>> OR
>>>>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>>>>>> OF
>>>>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>> BUSINESS
>>>>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>> WHETHER IN
>>>>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>> OTHERWISE)
>>>>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>> ADVISED OF THE
>>>>>> + * POSSIBILITY OF SUCH DAMAGE.
>>>>>> +#ifdef HAVE_CONFIG_H
>>>>>> +#include "config.h"
>>>>>> +#endif
>>>>>> +/* header files are listed in lexical/lexicographical/alphabetical
>>>>>> order */
>>>>>> +#include <errno.h>
>>>>>> +#include <fcntl.h> /* contains definitions of 'open_flags' */
>>>>>> +#include <limits.h>
>>>>>> +#include <ndbm.h> /* contains declarations of ndbm methods */
>>>>>> +#include <stddef.h>
>>>>>> +#include <stdint.h>
>>>>>> +#include <stdio.h>
>>>>>> +#include <sys/stat.h> /* contains definitions of 'file_mode' */
>>>>>> +#include <string.h>
>>>>>> +#include <rtems/test.h>
>>>>>> +#include <tmacros.h>
>>>>>> +const char rtems_test_name[] = "PSXNDBM 01";
>>>>>> +#define NAME "VARoDeK"
>>>>>> +#define PHONE_NO "123-321-777-888"
>>>>>> +#define DB_NAME "phones_test"
>>>>>> +#define NAME2 "VG"
>>>>>> +#define PHONE_NO2 "321-123-888-777"
>>>>>> +/* forward declarations to avoid warnings */
>>>>>> +rtems_task Init(rtems_task_argument ignored);
>>>>>> +* This Function takes DBM* as a argument and count the number of
>>>>>> records in the
>>>>>> +* database pointed by it.
>>>>>> +static int count_no_of_records( DBM *db_local )
>>>>>> + int count = 0;
>>>>>> + datum temp;
>>>>>> + for (
>>>>>> + temp = dbm_firstkey( db_local );
>>>>>> + temp.dptr != NULL;
>>>>>> + temp = dbm_nextkey( db_local ), count++
>>>>>> + return count;
>>>>>> +/* Test Function Begins */
>>>>>> + datum name = { NAME, sizeof( NAME ) };
>>>>>> + datum put_phone_no = { PHONE_NO, sizeof( PHONE_NO ) };
>>>>>> + datum name2 = { NAME2, sizeof( NAME2 ) };
>>>>>> + datum put_phone_no2 = { PHONE_NO2, sizeof( PHONE_NO2 ) };
>>>>>> + datum get_phone_no, key;
>>>>>> + int i;
>>>>>> + char *test_strings;
>>>>>> + DBM *db;
>>>>>> + TEST_BEGIN();
>>>>>> +/* A Simple test to check if ndbm methods are call-able */
>>>>>> + * A Simple test to check if NDBM methods are call-able
>>>>>> + * We will try to open a database and then close it.
>>>>>> + * If it successful, hence we can have further tests.
>>>>>> + * Also, while opening it for first time, will create that database,
>>>>>> + * hence we will be able to test for 'O_RDWR | O_EXCL' case later.
>>>>>> + * Meanwhile we will also store one record, this record will be
>>>>>> helpful in
>>>>>> + * further tests.
>>>>>> + * And fetch it, to make sure if basic NDBM methods are working
>>>>>> correctly.
>>>>>> + puts( "\nOpen Database." );
>>>>>> + db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_TRUNC, S_IRWXU );
>>>>>> + rtems_test_assert( db != NULL );
>>>>>> + /* This data will be useful in further tests */
>>>>>> + puts( "Store Records in Database." );
>>>>>> + dbm_store( db, name, put_phone_no, DBM_INSERT );
>>>>>> + puts( "Fetch Records from Database and check." );
>>>>>> + get_phone_no = dbm_fetch( db, name );
>>>>>> + rtems_test_assert( strcmp( (const char*)get_phone_no.dptr,
>>>>>> PHONE_NO ) == 0 );
>>>>>> + puts( "Close Database." );
>>>>>> + dbm_close( db );
>>>>>> +/* dbm_open() */
>>>>>> + puts( "\nTestcases for 'dbm_open()'." );
>>>>>> +/* The 'DB_NAME' is already created, hence 'O_RDWR | O_EXCL' should
>>>>>> fail. */
>>>>>> + puts( "Use 'O_CREAT | O_EXCL' to open existing file and confirm
>>>>>> error." );
>>>>>> + db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_EXCL, S_IRWXU );
>>>>>> + rtems_test_assert( db == NULL );
>>>>>> + rtems_test_assert( errno == EEXIST );
>>>>>> +/* Some implementations use 3 characters for the suffix and others
>>>>>> use
>>>>>> + * 4 characters for the suffix, applications should ensure that the
>>>>>> maximum
>>>>>> + * portable pathname length passed to dbm_open() is no greater than
>>>>>> + * {PATH_MAX}-4 bytes, with the last component of the pathname no
>>>>>> greater
>>>>>> + * than {NAME_MAX}-4 bytes.
>>>>>> +/* inside 'ndbm.h' ; '#define DBM_SUFFIX ".db"' ;
>>>>>> + * 2 alphabets and 1 period, hence 3 characters are used for suffix
>>>>>> + * in this implementation.
>>>>>> + puts( "Use path name larger than '{PATH_MAX}-3 bytes.' and confirm
>>>>>> error." );
>>>>>> + test_strings = (char*)malloc( PATH_MAX - 2 );
>>>>>> + for ( i = 0; i < PATH_MAX - 3; i++ ) {
>>>>>> + test_strings[i] = 'r';
>>>>>> + test_strings[i] = '\0';
>>>>>> + db = dbm_open(
>>>>>> + (const char*)test_strings,
>>>>>> + O_RDWR | O_CREAT | O_TRUNC,
>>>>>> + S_IRWXU
>>>>>> + rtems_test_assert( errno == ENAMETOOLONG );
>>>>>> + free( test_strings );
>>>>>> +/* database opened for write-only access opens the files for read and
>>>>>> + * write access or it will fail.
>>>>>> +/* Implementation of __hash_open in newlib does not support
>>>>>> `O_WRONLY` */
>>>>>> + puts( "Open file with write access only and confirm error." );
>>>>>> + db = dbm_open( DB_NAME, O_WRONLY, S_IRWXU );
>>>>>> + rtems_test_assert( errno == EINVAL );
>>>>>> +/* dbm_store() */
>>>>>> + puts( "\nTestcases for 'dbm_store()'" );
>>>>>> + db = dbm_open( DB_NAME, O_RDWR, S_IRWXU );
>>>>>> + puts( "Insert new record with same key using 'DBM_INSERT' mode and
>>>>>> + "confirm error." );
>>>>>> + rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_INSERT
>>>>>> ) == 1 );
>>>>>> PHONE_NO ) == 0 );
>>>>>> + puts( "Insert new record with same key using 'DBM_REPLACE' mode
>>>>>> and "
>>>>>> + "confirm changes." );
>>>>>> + rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_REPLACE
>>>>>> ) == 0 );
>>>>>> PHONE_NO2 ) == 0 );
>>>>>> +/* Revert for next tests */
>>>>>> + rtems_test_assert( dbm_store( db, name, put_phone_no, DBM_REPLACE
>>>>>> ) == 0 );
>>>>>> + puts( "Store a new record and "
>>>>>> + "confirm that total number of records is successful 2." );
>>>>>> + rtems_test_assert( dbm_store( db, name2, put_phone_no2, DBM_INSERT
>>>>>> ) == 0 );
>>>>>> +/* Confirm number of records */
>>>>>> + rtems_test_assert( count_no_of_records( db ) == 2 );
>>>>>> + dbm_close( db );
>>>>>> +/* dbm_fetch() */
>>>>>> + puts( "\nTestcases for 'dbm_fetch()'" );
>>>>>> + db = dbm_open( DB_NAME, O_RDONLY, S_IRWXU );
>>>>>> + puts( "Fetch existing records and confirm results." );
>>>>>> PHONE_NO ) == 0 );
>>>>>> + get_phone_no = dbm_fetch( db, name2 );
>>>>>> PHONE_NO2 ) == 0 );
>>>>>> + puts( "Fetch non-existing record and confirm error." );
>>>>>> + test_strings = (char*)malloc(6);
>>>>>> + strncpy( test_strings, "Hello", 5 );
>>>>>> + test_strings[5] = '\0';
>>>>>> +/* The data pointed by test_string is now pointed by key.dptr */
>>>>>> + key.dptr = test_strings;
>>>>>> + key.dsize = sizeof( test_strings );
>>>>>> + get_phone_no = dbm_fetch( db, key );
>>>>>> + rtems_test_assert( get_phone_no.dptr == NULL );
>>>>>> + dbm_close( db );
>>>>>> +/* We need the 'key' object, hence we cannot free 'test_strings' */
>>>>>> +/* dbm_delete() */
>>>>>> + puts( "\nTestcases for 'dbm_delete()'" );
>>>>>> + puts( "Delete non-existing record and confirm error." );
>>>>>> + rtems_test_assert( dbm_delete( db, key ) != 0 );
>>>>>> + rtems_test_assert( count_no_of_records( db ) == 2);
>>>>>> + puts( "Delete existing record and "
>>>>>> + "confirm that total number of records is successful 1." );
>>>>>> + rtems_test_assert( dbm_delete( db, name ) == 0 );
>>>>>> + rtems_test_assert( count_no_of_records( db ) == 1);
>>>>>> + puts( "Confirm if correct record is deleted." );
>>>>>> +/* record returned by 'dbm_firstkey()' should be the only record
>>>>>> + * left, this should be checked to confirm correct working of
>>>>>> + * 'dbm_firstkey()'.
>>>>>> + * Check if the data is not corrupted after usage of 'dbm_delete()'
>>>>>> + puts( "Check if the data is not corrupted after usage of
>>>>>> 'dbm_delete()'." );
>>>>>> + get_phone_no = dbm_fetch( db, dbm_firstkey( db ) );
>>>>>> PHONE_NO2 ) == 0 );
>>>>>> +/* Empty the database and then try to use 'dbm_firstkey()', the
>>>>>> + * dptr pointer should point to NULL.
>>>>>> + puts( "Empty records in database and check results of
>>>>>> 'dbm_firstkey()'." );
>>>>>> + rtems_test_assert( dbm_delete( db, dbm_firstkey( db ) ) == 0 );
>>>>>> + key = dbm_firstkey( db );
>>>>>> + rtems_test_assert( key.dptr == NULL );
>>>>>> + dbm_close( db );
>>>>>> +* All cases for 'dbm_firstkey()' and 'dbm_nextkey()' were tested
>>>>>> while
>>>>>> +* performing other tests.
>>>>>> +* One such case be found in count_number_of_records() function.
>>>>>> + TEST_END();
>>>>>> + rtems_test_exit(0);
>>>>>> +/* NOTICE: the clock driver is explicitly disabled */
>>>>>> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>>>>>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>>>> +#define CONFIGURE_MAXIMUM_TASKS 1
>>>>>> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
>>>>>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>>>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>>>>>> +#include <rtems/confdefs.h>
>>>>>> +/* end of file */
>>>>>> diff --git a/testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>>>> b/testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>>>> index 0000000000..cdaeb40911
>>>>>> --- /dev/null
>>>>>> +++ b/testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>>>> @@ -0,0 +1,36 @@
>>>>>> +This File describes the concepts tested by this test suite.
>>>>>> +ndbm.h - routines to manage data files that contain key/data pairs.
>>>>>> +test suite name: PSXNDBM 01
>>>>>> +- A Simple test to check if NDBM methods are call-able.
>>>>>> + - Check if able to run the routine to Open Database.
>>>>>> + - Check if able to run the routine to store a record in database.
>>>>>> + - Check if able to run the routine to fetch a record from database.
>>>>>> + - Check if able to run the routine to close the database.
>>>>>> +- Test Cases for 'dbm_open()'.
>>>>>> + - Verify the error when trying to open existing file with 'O_RDWR
>>>>>> | O_EXCL'
>>>>>> + flags.
>>>>>> + - Verify the error when trying to open file with pathname longer
>>>>>> than
>>>>>> + {PATHMAX}-3 bytes.
>>>>>> + - Verify the error when trying to open file with only write access.
>>>>>> +- Test Cases for 'dbm_store()'.
>>>>>> + - Verify the error when trying to insert a record using same key
>>>>>> with
>>>>>> + 'DBM_INSERT' mode.
>>>>>> + - Verify the updated record when trying to insert a record using
>>>>>> same key
>>>>>> + with 'DBM_REPLACE' mode.
>>>>>> + - Verify if able to save more than one record in database.
>>>>>> +- Test Cases for 'dbm_fetch()'.
>>>>>> + - Verify the data fetched from database.
>>>>>> + - Verify the error when tring to fetch non-existing record.
>>>>>> +- Test Cases for 'dbm_delete()'.
>>>>>> + - Veriy the error when trying to delete non-existing record.
>>>>>> + - Delete one record and verify results.
>>>>>> + - Check if correct record is deleted.
>>>>>> + - Verify if other data is not corrupted during delete.
>>>>>> + - Empty the databse and verify the value returned by
>>>>>> 'dbm_firstkey()'.
>>>>>> \ No newline at end of file
>>>>>> diff --git a/testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>>>> b/testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>>>> index 0000000000..3fa386630a
>>>>>> --- /dev/null
>>>>>> +++ b/testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>>>> @@ -0,0 +1,29 @@
>>>>>> +*** PSXNDBM 01 Test ***
>>>>>> +Open Database.
>>>>>> +Store Records in Database.
>>>>>> +Fetch Records from Database and check.
>>>>>> +Close Database.
>>>>>> +Testcases for 'dbm_open()'.
>>>>>> +Use 'O_CREAT | O_EXCL' to open existing file and confirm error.
>>>>>> +Use path name larger than '{PATH_MAX}-3 bytes.' and confirm error.
>>>>>> +Open file with write access only and confirm error.
>>>>>> +Testcases for 'dbm_store()'
>>>>>> +Insert new record with same key using 'DBM_INSERT' mode and confirm
>>>>>> error.
>>>>>> +Insert new record with same key using 'DBM_REPLACE' mode and confirm
>>>>>> changes.
>>>>>> +Store a new record and confirm that total number of records is
>>>>>> successful 2.
>>>>>> +Testcases for 'dbm_fetch()'
>>>>>> +Fetch existing records and confirm results.
>>>>>> +Fetch non-existing record and confirm error.
>>>>>> +Testcases for 'dbm_delete()'
>>>>>> +Delete non-existing record and confirm error.
>>>>>> +Delete existing record and confirm that total number of records is
>>>>>> successful 1.
>>>>>> +Confirm if correct record is deleted.
>>>>>> +Check if the data is not corrupted after usage of 'dbm_delete()'.
>>>>>> +Empty records in database and check results of 'dbm_firstkey()'.
>>>>>> +*** END OF TEST PSXNDBM 01 ***
>>>>>> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190729/7cece267/attachment-0001.html>
