[PATCH] Adjust gdb-python checks
Gedare Bloom
gedare at rtems.org
Mon Jul 29 21:13:14 UTC 2019
source-builder/config/gdb-common-1.cfg | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/source-builder/config/gdb-common-1.cfg b/source-builder/config/gdb-common-1.cfg
index 159b8a5..0f028ff 100644
--- a/source-builder/config/gdb-common-1.cfg
+++ b/source-builder/config/gdb-common-1.cfg
@@ -108,7 +108,7 @@
%define gdb-host-libs -L '%{host_ldflags}'
%endif
%if %{gdb-python-config} != %{nil}
- %define gdb-python-lib-filter awk 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*python.*")) print "lib"substr($i,3)"*";}'
+ %define gdb-python-lib-filter awk 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*lpython.*")) print "lib"substr($i,3)"*";}'
%define gdb-python-config-libs %(%{gdb-python-config} --ldflags | %{gdb-python-lib-filter})
%define gdb-python-lib-check %(%{_sbdir}/sb/rtems-build-dep -c %{__cc} %{gdb-host-libs} -l %{gdb-python-config-libs})
%else
2.7.4
