Requirement Identifiers
Mon Jul 29 22:25:28 UTC 2019
On Tue, Jul 23, 2019 at 9:36 AM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I am not sure if I am derailing this or helping. I think we need to seriously
> consider that we want these to be easy to manage and the logical names
> should reflect the natural groups in RTEMS.
> I lean to something simple like this without the arbitrary sections. ARINC 653
> doesn't have odd subsections beyond something like this.
> Classic
>    Classic-General
>    Classic-Task
> POSIX
> If we go to a third level of outline which isn't based on API or RTEMS logical
> category, then we end up separating error from functional requirements and
> the other categories ECCS had.
>   Classic-Task-Error
>   Classic-Task-Functional
>   Classic-Task-Performance (What would these be anyway?)
> The above seems like an unnatural organization to me from a human
> maintenance view.
> The following would naturally sort the requirements in a manageable manner.
> And I don't think we will disagree about where most requirements go.
> Classic-Task-Create
> Classic-Task-Delete
> I could see marking a requirement as functional or error. if each error is
> a requirements, then we will have 1000s of those. It could make the
> printed requirements document nicer.
> We don't have a fancy tool to manage requirements. I think having an organization
> that reflects the public API view of RTEMS will help us all maintain them and make
> it easier to add. I don't want 10K requirements in a random number pool and arbitrary
> subcategories that are meaningless.
> We have to be careful to do what makes them presentable to humans.
It would seem wise to make the hierarchy of requirements follow the
same organization as the hierarchy of the Manual documentation.
> --joel
> On Mon, Jul 22, 2019 at 9:40 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> ----- Am 22. Jul 2019 um 15:55 schrieb joel joel at rtems.org:
>> > On Mon, Jul 22, 2019 at 12:53 AM Sebastian Huber <
>> >> Hello,
>> >> I would like to clarify one detail with respect to the requirement
>> >> identifiers. The current consensus is that the requirements should be
>> >> grouped by component, e.g.
>> >> RTEMS
>> >> ^-- RTEMS-Classic
>> >>      ^-- RTMES-Classic-Task
>> >>      ^-- RTMES-Classic-Semaphore
>> >> ^-- RTEMS-POSIX
>> >> The group name and a number forms the identifier, e.g.
>> >> RTEMS-Classic-Task-0123. We may use number groups as well, e.g.
>> >> RTEMS-Classic-Task-01xx could be task create requirements. Now the detail:
>> >> On 11/07/2019 10:15, Sebastian Huber wrote:
>> >> > The standard ECSS-E-ST-10-06C recommends
>> >> > in section 8.2.6 that the identifier should reflect the type of the
>> >> > requirement
>> >> > and the life profile situation.  Other standards may have other
>> >> > recommendations.  To avoid a bias of RTEMS in the direction of ECSS, this
>> >> > recommendation will not be followed.
>> >> I would like to move any other meta information about requirements to
>> >> the requirement file as attributes. For example in the file
>> >> RTEMS-Classic-Task-0123.yml:
>> >> text: |
>> >>    If the id parameter is NULL, then the rtems_task_create() directive
>> >> shall return RTEMS_INVALID_ADDRESS.
>> >> type: functional
>> >> rational: |
>> >>    The set of stupid developers is non-empty.
>> >> The alternative is to create subgroups for each type, e.g.
>> >> RTEMS
>> >> ^-- RTEMS-Classic
>> >>          ^-- RTMES-Classic-Task-Func
>> >>          ^-- RTMES-Classic-Task-Perf
>> >>          ^-- RTMES-Classic-Task-Iface
>> >>          ^-- RTMES-Classic-Task-Whatever
>> >>          ^-- RTMES-Classic-Semaphore-Func
>> >>          ^-- RTMES-Classic-Semaphore-Perf
>> >>          ^-- RTMES-Classic-Semaphore-Iface
>> >>          ^-- RTMES-Classic-Semaphore-Whatever
>> >> ^-- RTEMS-POSIX
>> >> I would not do this. It ties us to the grouping defined by ECSS. The
>> >> identifiers are longer. The hierarchy is deeper. Using attributes is
>> >> much more flexible.
>> >> What do you think?
>> > I think everything about a single requirement should be in the yaml file
>> > with the requirement. I do not want them split out.
>> Sorry for not being clear enough. The requirements are self-contained.
>> The question is if a requirement type (or other attributes) should be contained in the identifier?
>> > ARINC 653 has the following for each requirement and note that the
>> > formal requirements and test cases are described in "part 3" of the
>> > standard. Part 1 is required APIs and Part 2 is optional ones.
>> > - ID
>> > - Reference to the main standard
>> > - Description including objectives (rationale?)
>> > - Comments.
>> > IDs are "COMPONENT-MANAGER/CATEGORY-NNNN". Component is API
>> > for the ones I see. The Manager/Category can be "GEN" or an API code.
>> > Then the numbers appear to be 10 apart.
>> > We should consider categories for configuration and internal things
>> > that are hard to accurately reflect from API requirements. Off the top
>> > of my head, FIFO or Priority blocking has one Score requirement
>> > but lots of API visible ones. The various schedulers may be another.
>> Yes, but the grouping is another topic. I would like to get the identifiers fixed first.
> devel mailing list
> devel at rtems.org
