[PATCH] Adjust gdb-python checks
Mon Jul 29 22:27:26 UTC 2019
done
On Mon, Jul 29, 2019 at 4:10 PM Chris Johns <chrisj at rtems.org> wrote:
> Thank you for the fix. It is a nice solution to the extra path on Linux.
> OK to push.
> Chris
> On 30/7/19 7:13 am, Gedare Bloom wrote:
> >  source-builder/config/gdb-common-1.cfg | 2 +-
> >  1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/source-builder/config/gdb-common-1.cfg b/source-builder/config/gdb-common-1.cfg
> > index 159b8a5..0f028ff 100644
> > --- a/source-builder/config/gdb-common-1.cfg
> > +++ b/source-builder/config/gdb-common-1.cfg
> > @@ -108,7 +108,7 @@
> >      %define gdb-host-libs -L '%{host_ldflags}'
> >    %endif
> >    %if %{gdb-python-config} != %{nil}
> > -    %define gdb-python-lib-filter awk 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*python.*")) print "lib"substr($i,3)"*";}'
> > +    %define gdb-python-lib-filter awk 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*lpython.*")) print "lib"substr($i,3)"*";}'
> >      %define gdb-python-config-libs %(%{gdb-python-config} --ldflags | %{gdb-python-lib-filter})
> >      %define gdb-python-lib-check %(%{_sbdir}/sb/rtems-build-dep -c %{__cc} %{gdb-host-libs} -l %{gdb-python-config-libs})
> >    %else
