GSoC 2019 : POSIX Compliance - Weekly Report
Joel Sherrill
joel at rtems.org
Tue Jul 30 13:53:26 UTC 2019
On Tue, Jul 30, 2019 at 7:44 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> On Tue, Jul 30, 2019 at 3:25 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Wed, Jul 24, 2019 at 10:43 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>> > Hello,
>> > Progress so far:
>> > - NDBM patch is pushed by newlib.
>> > - NDBM Testsuite is sent to devel ([PATCH V6] ndbm test suite), its
>> execution will be verified once newlib has required files. Although I have
>> tested it by manually generating required file using 'autoreconf -fvi' on
>> my local system.
>> > Blocker:
>> > - My pace got slow last week as my college started, I informed about it
>> on devel.
>> > Next:
>> > - Implement fenv for SPARC first, then move on to ARM, PPC and others.
>> What about fenv testcase?
> I guess after Joel had a discussion in newlib, we will be switching code
> structure for fenv, so implementation of riscv will also need to be
> updated.
> Hence, I will implement fenv for SPARC and make test case for same.
The test case can be added now if you have a RISC-V toolchain. I expect
the test code will
have to be conditionalized on whether the target architecture supports the
fenv.h methods.
This would be best implemented with like AC_CHECK_FUNC and pick a method
like
fegetround() to probe for. That way as you add support for other
architectures, the test(s)
will automatically get enabled.
The alternative is like how libdebugger tests have to list specific
architectures that are
supported. That requires manual intervention (but is the only option for
libdebugger).
> -Vaibhav Gupta
>> > Thank You
>> > Vaibhav Gupta
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190730/d46be489/attachment-0001.html>
