GSoC 2019 : POSIX Compliance - Weekly Report
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Tue Jul 30 15:22:29 UTC 2019
On Tue, Jul 30, 2019 at 8:49 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Jul 30, 2019 at 10:15 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> On Tue, Jul 30, 2019 at 7:23 PM Joel Sherrill <joel at rtems.org> wrote:
>>> On Tue, Jul 30, 2019 at 7:44 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>> wrote:
>>>> On Tue, Jul 30, 2019 at 3:25 AM Gedare Bloom <gedare at rtems.org> wrote:
>>>>> On Wed, Jul 24, 2019 at 10:43 AM Vaibhav Gupta <
>>>>> vaibhavgupta40 at gmail.com> wrote:
>>>>> > Hello,
>>>>> > Progress so far:
>>>>> > - NDBM patch is pushed by newlib.
>>>>> > - NDBM Testsuite is sent to devel ([PATCH V6] ndbm test suite), its
>>>>> execution will be verified once newlib has required files. Although I have
>>>>> tested it by manually generating required file using 'autoreconf -fvi' on
>>>>> my local system.
>>>>> > Blocker:
>>>>> > - My pace got slow last week as my college started, I informed about
>>>>> it on devel.
>>>>> > Next:
>>>>> > - Implement fenv for SPARC first, then move on to ARM, PPC and
>>>>> others.
>>>>> What about fenv testcase?
>>>> I guess after Joel had a discussion in newlib, we will be switching code
>>>> structure for fenv, so implementation of riscv will also need to be
>>>> updated.
>>>> Hence, I will implement fenv for SPARC and make test case for same.
>>> The test case can be added now if you have a RISC-V toolchain. I expect
>>> the test code will
>>> have to be conditionalized on whether the target architecture supports
>>> the fenv.h methods.
>> Okay then I will start working on testsuite, I will build riscv
>> toolchain.
>>> This would be best implemented with like AC_CHECK_FUNC and pick a
>>> method like
>>> fegetround() to probe for.
>> You mentioned that you have pushed NDBM testsuite in a conditional way on
>> your branch,
>> that will make testsuite compile only if ndbm tools are present. Can I
>> get that code?
>> It will be helpful for me.
> Sorry. I posted to devel@ but forgot to push. I just pushed it.
No problem, Thanks :)!
> --joel
>> - Vaibhav Gupta
>>> That way as you add support for other architectures, the test(s)
>>> will automatically get enabled.
>>> The alternative is like how libdebugger tests have to list specific
>>> architectures that are
>>> supported. That requires manual intervention (but is the only option for
>>> libdebugger).
>>>> -Vaibhav Gupta
>>>>> > Thank You
>>>>> > Vaibhav Gupta
>>>>> > _______________________________________________
>>>>> > devel mailing list
>>>>> > devel at rtems.org
>>>>> > http://lists.rtems.org/mailman/listinfo/devel
>>>> devel mailing list
>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190730/cecab83a/attachment-0001.html>
