Building RTEMS with Clang (LLVM)
Tue Jul 30 23:02:05 UTC 2019
I updated that page. Please have a look. You'll need to build RTEMS
out-of-tree, usually in a parallel build directory to your checked-out
rtems.git.
On Mon, Jul 15, 2019 at 11:20 AM Prajjwal Dangal
<prajjwal.dangal at gmail.com> wrote:
> Hi there,
> I tried following the steps in the link https://devel.rtems.org/wiki/Projects/CLANG to build RTEMS with clang. I was able to build newlib for arm and i386 archs but wasn't sure which directory I was supposed to run rtems configure from. The above link doesn't touch on that part.
> Thanks,
> Prajjwal
> Prajjwal Dangal |  Graduate Research Assistant | T - 202-640-3076
> Department of Electrical Engineering and Computer Science
> Howard University, Washington DC, USA, 20001
> www.linkedin.com/in/prajjwaldangal
> devel mailing list
> devel at rtems.org
