[PATCH v3] Add mmap
Nils Hölscher nilhoel1 at gmail.com
Wed Jul 17 09:10:38 UTC 2019
On Wed, 17 Jul 2019 at 09:03, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
>  freebsd/sys/kern/kern_conf.c       |  8 +++----
>  freebsd/sys/sys/conf.h             |  2 +-
>  rtemsbsd/include/machine/vm.h      |  2 ++
>  rtemsbsd/sys/fs/devfs/devfs_devs.c | 34 ++++++++++++++++++++++++++++++
>  testsuite/cdev01/test_cdev.c       | 17 ++++++++++++++-
>  testsuite/cdev01/test_cdev01.h     |  3 ++-
>  testsuite/cdev01/test_main.c       |  4 ++++
>  7 files changed, 63 insertions(+), 7 deletions(-)
> diff --git a/freebsd/sys/kern/kern_conf.c b/freebsd/sys/kern/kern_conf.c
> index 92237d9d..560a450a 100644
> --- a/freebsd/sys/kern/kern_conf.c
> +++ b/freebsd/sys/kern/kern_conf.c
> @@ -328,8 +328,8 @@ static struct cdevsw dead_cdevsw = {
>         .d_write =      dead_write,
>         .d_ioctl =      dead_ioctl,
>         .d_poll =       dead_poll,
> -#ifndef __rtems__
>         .d_mmap =       dead_mmap,
> +#ifndef __rtems__
>         .d_strategy =   dead_strategy,
>  #endif /* __rtems__ */
>         .d_name =       "dead",
> @@ -522,7 +522,6 @@ giant_kqfilter(struct cdev *dev, struct knote *kn)
>         return (retval);
> -#ifndef __rtems__
>  static int
>  giant_mmap(struct cdev *dev, vm_ooffset_t offset, vm_paddr_t *paddr, int
> nprot,
>      vm_memattr_t *memattr)
> @@ -541,6 +540,7 @@ giant_mmap(struct cdev *dev, vm_ooffset_t offset,
> vm_paddr_t *paddr, int nprot,
>         return (retval);
> +#ifndef __rtems__
>  static int
>  giant_mmap_single(struct cdev *dev, vm_ooffset_t *offset, vm_size_t size,
>      vm_object_t *object, int nprot)
> @@ -667,8 +667,8 @@ prep_cdevsw(struct cdevsw *devsw, int flags)
>                 devsw->d_write = dead_write;
>                 devsw->d_ioctl = dead_ioctl;
>                 devsw->d_poll = dead_poll;
> -#ifndef __rtems__
>                 devsw->d_mmap = dead_mmap;
> +#ifndef __rtems__
>                 devsw->d_mmap_single = dead_mmap_single;
>                 devsw->d_strategy = dead_strategy;
>                 devsw->d_dump = dead_dump;
> @@ -702,8 +702,8 @@ prep_cdevsw(struct cdevsw *devsw, int flags)
>         FIXUP(d_write,          no_write,       giant_write);
>         FIXUP(d_ioctl,          no_ioctl,       giant_ioctl);
>         FIXUP(d_poll,           no_poll,        giant_poll);
> -#ifndef __rtems__
>         FIXUP(d_mmap,           no_mmap,        giant_mmap);
> +#ifndef __rtems__
>         FIXUP(d_strategy,       no_strategy,    giant_strategy);
>         FIXUP(d_kqfilter,       no_kqfilter,    giant_kqfilter);
> diff --git a/freebsd/sys/sys/conf.h b/freebsd/sys/sys/conf.h
> index 4ace162f..c0a66442 100644
> --- a/freebsd/sys/sys/conf.h
> +++ b/freebsd/sys/sys/conf.h
> @@ -209,8 +209,8 @@ struct cdevsw {
>         d_write_t               *d_write;
>         d_ioctl_t               *d_ioctl;
>         d_poll_t                *d_poll;
> -#ifndef __rtems__
>         d_mmap_t                *d_mmap;
> +#ifndef __rtems__
>         d_strategy_t            *d_strategy;
>         dumper_t                *d_dump;
> diff --git a/rtemsbsd/include/machine/vm.h b/rtemsbsd/include/machine/vm.h
> index e69de29b..351b7472 100644
> --- a/rtemsbsd/include/machine/vm.h
> +++ b/rtemsbsd/include/machine/vm.h
> @@ -0,0 +1,2 @@
 Hi,
+#define VM_MEMATTR_DEFAULT 0
> +#define VM_MEMATTR_UNCACHEABLE 1
Are you sure that these values are correct in general?
BSD defines this only for ARM versions smaller 6.
https://github.com/freebsd/freebsd/blob/1d6e4247415d264485ee94b59fdbc12e0c566fd0/sys/arm/include/vm.h
> diff --git a/rtemsbsd/sys/fs/devfs/devfs_devs.c
> b/rtemsbsd/sys/fs/devfs/devfs_devs.c
> index 7c697b0a..9878936f 100644
> --- a/rtemsbsd/sys/fs/devfs/devfs_devs.c
> +++ b/rtemsbsd/sys/fs/devfs/devfs_devs.c
> @@ -387,6 +387,39 @@ devfs_imfs_kqfilter(rtems_libio_t *iop, struct knote
> *kn)
>         return error;
> +static int
> +devfs_imfs_mmap(rtems_libio_t *iop, void **addr, size_t len, int prot,
> +    off_t off)
> +       struct cdev *cdev = devfs_imfs_get_context_by_iop(iop);
> +       struct file *fp = rtems_bsd_iop_to_fp(iop);
> +       struct thread *td = rtems_bsd_get_curthread_or_null();
> +       struct file *fpop;
> +       struct cdevsw *dsw;
> +       int error, ref;
> +       if (td != 0) {
> +               if (cdev == NULL) {
> +                       error = ENXIO;
> +               if (cdev->si_flags & SI_ALIAS) {
> +                       cdev = cdev->si_parent;
> +               dsw = dev_refthread(cdev, &ref);
> +               if (dsw == NULL) {
> +                       error = ENXIO;
> +               fpop = td->td_fpop;
> +               curthread->td_fpop = fp;
> +               error = dsw->d_mmap( cdev, off, (vm_paddr_t *) addr, prot,
> VM_MEMATTR_DEFAULT);
> +               td->td_fpop = fpop;
> +               dev_relthread(cdev, ref);
> +       } else {
> +               error = ENOMEM;
> +       return error;
>  static const rtems_filesystem_file_handlers_r devfs_imfs_handlers = {
>         .open_h = devfs_imfs_open,
>         .close_h = devfs_imfs_close,
> @@ -403,6 +436,7 @@ static const rtems_filesystem_file_handlers_r
>         .kqfilter_h = devfs_imfs_kqfilter,
>         .readv_h = devfs_imfs_readv,
>         .writev_h = devfs_imfs_writev,
> +       .mmap_h = devfs_imfs_mmap,
>  static const IMFS_node_control devfs_imfs_control =
> IMFS_GENERIC_INITIALIZER(
> diff --git a/testsuite/cdev01/test_cdev.c b/testsuite/cdev01/test_cdev.c
> index 19fb1a5e..bff455cf 100644
> --- a/testsuite/cdev01/test_cdev.c
> +++ b/testsuite/cdev01/test_cdev.c
> @@ -32,6 +32,7 @@
>  #include <machine/rtems-bsd-kernel-space.h>
>  #include <sys/types.h>
>  #include <sys/conf.h>
> +#include <sys/mman.h>
>  #include <rtems/seterr.h>
> @@ -46,6 +47,7 @@ static        d_write_t       testwrite;
>  static d_ioctl_t       testioctl;
>  static d_poll_t        testpoll;
>  static d_kqfilter_t    testkqfilter;
> +static d_mmap_t        testmmap;
>  static struct cdevsw test_cdevsw = {
>         .d_version =    D_VERSION,
> @@ -59,6 +61,7 @@ static struct cdevsw test_cdevsw = {
>         .d_ioctl =      testioctl,
>         .d_poll =       testpoll,
>         .d_kqfilter =   testkqfilter,
> +       .d_mmap =       testmmap,
>  static int
> @@ -77,7 +80,7 @@ testclose(struct cdev *dev, int fflag, int devtype,
> struct thread *td)
>         test_state *state = dev->si_drv1;
> -       assert(*state == TEST_KQFILTER);
> +       assert(*state == TEST_MMAP);
>         *state = TEST_CLOSED;
>         return 0;
> @@ -148,6 +151,18 @@ testkqfilter(struct cdev *dev, struct knote *kn)
>         return TEST_KQ_ERRNO;
> +static int
> +testmmap(struct cdev *dev, vm_ooffset_t offset, vm_paddr_t *paddr,
> +         int nprot, vm_memattr_t *memattr)
> +       test_state *state = dev->si_drv1;
> +       assert(*state == TEST_KQFILTER);
> +       *state = TEST_MMAP;
> +       return 0;
>  void
>  test_make_dev(test_state *state, const char *name)
> diff --git a/testsuite/cdev01/test_cdev01.h
> b/testsuite/cdev01/test_cdev01.h
> index a83001b5..58866a0c 100644
> --- a/testsuite/cdev01/test_cdev01.h
> +++ b/testsuite/cdev01/test_cdev01.h
> @@ -42,7 +42,8 @@ typedef enum {
>         TEST_WRITEV,
>         TEST_POLL,
>         TEST_KQFILTER,
> -       TEST_CLOSED
> +       TEST_MMAP,
> +       TEST_CLOSED,
>  } test_state;
>  void test_make_dev(test_state *state, const char *name);
> diff --git a/testsuite/cdev01/test_main.c b/testsuite/cdev01/test_main.c
> index cbff9133..23aefa86 100644
> --- a/testsuite/cdev01/test_main.c
> +++ b/testsuite/cdev01/test_main.c
> @@ -35,6 +35,7 @@
>  #include <sys/time.h>
>  #include <sys/uio.h>
>  #include <sys/ioctl.h>
>  #include <assert.h>
>  #include <errno.h>
> @@ -125,6 +126,9 @@ static void test_cdev(const char *path)
>         assert(rv == -1);
>         assert(errno == TEST_KQ_ERRNO);
> +       rv = mmap(NULL, 1, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0);
> +       assert(rv == 0);
>         rv = close(fd);
>         assert(rv == 0);
> 2.20.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190717/742846b3/attachment-0002.html>
