GSoC Linux UIO driver for PRU
Nils Hölscher nilhoel1 at gmail.com
Wed Jul 17 09:43:29 UTC 2019
Hi,
I applied the patch and now all compiles.
But I haven't tested anything yet, I am currently working on an application
for testing.
I will keep in contact concerning the mmap patch.
Best,
Nils
On Tue, 16 Jul 2019 at 15:47, Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 16/07/2019 15:35, Vijay Kumar Banerjee wrote:
> > On Tue, Jul 16, 2019 at 6:57 PM Nils Hölscher <nilhoel1 at gmail.com
> > <mailto:nilhoel1 at gmail.com>> wrote:
> >     Thanks I have been able to resolve this.
> >     But I have run into another issue.
> >     RTEMS port of the character device switch table doesn't support
> >     a .d_mmap entry.
> https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/sys/conf.h#L199
> >     And I am not certain how the
> >     struct rtems_filesystem_file_handlers_r and the structs cdevsw are
> >     related.
> >     The current BSD driver uses two  cdevsw structs, one to manage
> >     interrupts and one to manage io.
> >     Should or can I switch them out?
> > Hi Nils,
> > I have recently worked on a patch to add d_mmap to libbsd. I couldn't
> > send it to devel because
> > it could not be tested.
> > Christian, by the time the VT issue is resolved. I would like to prepare
> > a separate clean patch
> > for the mmap, what is your suggestion about this?
> You create a clean patch only for mmap. Please don't forget to add a
> test case to the libbsd devfs test. Although I would have preferred a
> working driver to test it, it should be OK to be added without one if
> the devfs test works.
> Please send a preview of the patch (without devfs test) to the mailing
> list so that Nils can already have a look at it and try it.
> Best regards
> Christian
> >     Best,
> >     Nils
> >     On Tue, 16 Jul 2019 at 13:47, Joel Sherrill <joel at rtems.org
> >     <mailto:joel at rtems.org>> wrote:
> >         On Tue, Jul 16, 2019, 6:34 AM Nils Hölscher <nilhoel1 at gmail.com
> >             Hi,
> >             I am currently porting the pruss driver functions, that I
> >             want to add in:
> >             rtems_filesystem_file_handlers_r pruss_irq_handler.
> >             But when I add  my functions like this:
> >               .open_h =ti_pruss_irq_open
> >             I receive the following compiler warnings:
> >             ../../pruss.c:156:13: warning: initialization from
> >             incompatible pointer type [-Wincompatible-pointer-types]
> >                .open_h = ti_pruss_irq_open,
> >             ../../pruss.c:156:13: note: (near initialization for
> >             'pruss_irq_handler.open_h')
> >             ../../pruss.c:158:13: warning: initialization from
> >                .read_h = ti_pruss_irq_read,
> >             Can anyone help please?
> >         This usually means that either the prototype of the method has
> >         not been seen before it is used or the method signature does not
> >         match that expected of the indirect method pointer on the left
> >         hand side. Make sure the signature matches.
> >             The full source can be found here:
> https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/pruss.c#L91
> https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/pruss.c#L155
> >             Best,
> >             Nils
> >             On Mon, 15 Jul 2019 at 10:15, Sebastian Huber
> >             <sebastian.huber at embedded-brains.de
> >             <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >                 On 15/07/2019 10:10, Nils Hölscher wrote:
> >                 > Thanks this is very helpful.
> >                 > But has anyone an existing example of a similar driver?
> >                 > I wasn't able find one in /bsps, maybe I didn't search
> >                 long enough.
> >                 There are some in cpukit:
> >                 cpukit/libcsupport/src/consolesimple.c:
> >                 IMFS_make_generic_node(
> >                 cpukit/libcsupport/src/termios.c:  rv =
> >                 cpukit/libcsupport/src/consolesimpletask.c:
> >                 cpukit/include/rtems/imfs.h: *   rv =
> >                 cpukit/include/rtems/imfs.h:extern int
> >                 cpukit/libfs/src/imfs/imfs_make_generic_node.c:int
> >                 cpukit/dev/i2c/i2c-bus.c:  rv = IMFS_make_generic_node(
> >                 cpukit/dev/i2c/i2c-dev.c:  rv = IMFS_make_generic_node(
> >                 cpukit/dev/spi/spi-bus.c:  rv = IMFS_make_generic_node(
> >                 cpukit/libblock/src/blkdev-imfs.c:      int rv =
> >                 cpukit/libblock/src/blkdev-imfs.c:            rv =
> >                 Sebastian Huber, embedded brains GmbH
> >                 Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >                 Phone   : +49 89 189 47 41-16
> >                 Fax     : +49 89 189 47 41-09
> >                 E-Mail  : sebastian.huber at embedded-brains.de
> >                 PGP     : Public key available on request.
> >                 Diese Nachricht ist keine geschäftliche Mitteilung im
> >                 Sinne des EHUG.
> >             _______________________________________________
> >             devel mailing list
> >             devel at rtems.org <mailto:devel at rtems.org>
> >             http://lists.rtems.org/mailman/listinfo/devel
> >     devel mailing list
> > devel mailing list
> > devel at rtems.org
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190717/e2170a94/attachment-0002.html>
