[PATCH v3] ndbm test suite
Vaibhav Gupta vaibhavgupta40 at gmail.com
Wed Jul 17 17:09:09 UTC 2019
Thanks for the review!
I will re generate the patch with corrections
On Wed, Jul 17, 2019 at 10:12 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Jul 10, 2019 at 1:49 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >  testsuites/psxtests/Makefile.am      |   7 +
> >  testsuites/psxtests/configure.ac     |   1 +
> >  testsuites/psxtests/psxndbm01/init.c | 260 +++++++++++++++++++++++++++
> >  3 files changed, 268 insertions(+)
> >  create mode 100644 testsuites/psxtests/psxndbm01/init.c
> > diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> > index 59c9f2085b..7d1c0a783c 100755
> > --- a/testsuites/psxtests/Makefile.am
> > +++ b/testsuites/psxtests/Makefile.am
> > @@ -694,6 +694,13 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psxmutexattr01) \
> >         $(support_includes) -I$(top_srcdir)/include
> >  endif
> > +if TEST_psxndbm01
> > +psx_tests += psxndbm01
> > +psxndbm01_SOURCES = psxndbm01/init.c
> > +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
> > +       $(support_includes)
> > +endif
> >  if TEST_psxobj01
> >  psx_tests += psxobj01
> >  psx_screens += psxobj01/psxobj01.scn
> > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
> configure.ac
> > index 85559e4aa5..07d7ccaf55 100644
> > --- a/testsuites/psxtests/configure.ac
> > +++ b/testsuites/psxtests/configure.ac
> > @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
> >  RTEMS_TEST_CHECK([psxmsgq03])
> >  RTEMS_TEST_CHECK([psxmsgq04])
> >  RTEMS_TEST_CHECK([psxmutexattr01])
> > +RTEMS_TEST_CHECK([psxndbm01])
> >  RTEMS_TEST_CHECK([psxobj01])
> >  RTEMS_TEST_CHECK([psxonce01])
> >  RTEMS_TEST_CHECK([psxpasswd01])
> > diff --git a/testsuites/psxtests/psxndbm01/init.c
> b/testsuites/psxtests/psxndbm01/init.c
> > new file mode 100644
> > index 0000000000..b38900361d
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxndbm01/init.c
> > @@ -0,0 +1,260 @@
> > + *  @file
> > + *  @brief Test suite for ndbm.h methods
> > + * SPDX-License-Identifier: BSD-2-Clause
> > + * Copyright (C) 2019 Vaibhav Gupta
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +/* header files are listed in lexical/lexicographical/alphabetical
> order */
> > +#include <errno.h>
> > +#include <fcntl.h>      /* contains definitions of `open_flags` */
> > +#include <limits.h>
> > +#include <ndbm.h>       /* conatains declarations of ndbm methods */
> > +#include <stddef.h>
> > +#include <stdint.h>
> > +#include <stdio.h>
> > +#include <sys/stat.h>   /* contains definitions of `file_mode` */
> > +#include <string.h>
> > +#include <rtems/test.h>
> > +#include <tmacros.h>
> > +const char rtems_test_name[] = "PSXNDBM 01";
> > +#define NAME      "VARoDeK"
> > +#define PHONE_NO  "123-321-777-888"
> > +#define DB_NAME   "phones_test"
> > +#define NAME2     "VG"
> > +#define PHONE_NO2 "321-123-888-777"
> > +/* forward declarations to avoid warnings */
> > +rtems_task Init(rtems_task_argument ignored);
> > +  datum name = { NAME , sizeof( NAME ) };
> > +  datum put_phone_no = { PHONE_NO, sizeof( PHONE_NO ) };
> > +  datum get_phone_no, key;
> > +  datum name2 = { NAME2 , sizeof( NAME2 ) };
> > +  datum put_phone_no2 = { PHONE_NO2 , sizeof( PHONE_NO2 ) };
> > +  int i;
> > +  char *test_strings;
> > +  DBM *db;
> > +  TEST_BEGIN();
> > +/* A Simple test to check if ndbm methods are call-able */
> > +/* Store a simple data
> > + * This record (procedure) will be helpful in further tests
> > +  puts( "Open Database." );
> > +  db = dbm_open( DB_NAME , O_RDWR | O_CREAT | O_TRUNC , S_IRWXU );
> Remove the extra blank space character before the comma.
> > +  rtems_test_assert( db != NULL );
> > +  puts( "Store Records in Database." );
> > +  dbm_store( db , name , put_phone_no , DBM_INSERT );
> ditto, and more below.
> > +  puts( "Fetch Records from Database and check." );
> > +  get_phone_no = dbm_fetch( db , name );
> > +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr , PHONE_NO
> ) == 0 );
> > +  puts( "Close Database." );
> > +  dbm_close( db );
> > +/* dbm_open() */
> I would like this to be more clearly about documenting what is
> happening, as it looks from casual glance to be commented-out code one
> wonders what it does here.
> > +  puts( "\nTestcases for `dbm_open()`" );
> I would avoid the use of the back-ticks ` characters. Historically,
> they can cause problems in *nix systems.
> > +/* The `DB_NAME` is already created, hence `O_RDWR | O_EXCL` should
> fail. */
> > +  puts( "Use `O_CREAT | O_EXCL` to open existing file and confirm
> error." );
> > +  db = dbm_open( DB_NAME , O_RDWR | O_CREAT | O_EXCL , S_IRWXU );
> > +  rtems_test_assert( db == NULL );
> > +  rtems_test_assert( errno == EEXIST );
> > +/* Some implementations use 3 characters for a suffix and others use
> > + * 4 characters for a suffix, applications should ensure that the
> maximum
> > + * portable pathname length passed to dbm_open() is no greater than
> > + * {PATH_MAX}-4 bytes, with the last component of the pathname no
> greater
> > + * than {NAME_MAX}-4 bytes.
> > +/* inside `ndbm.h` ; `#define  DBM_SUFFIX      ".db"` ;
> > + * 2 alphabtes and 1 period, hence 3 characters are used for suffix
> typo: alphabets (or alphabetical)
> > + * in this implementation.
> > +  puts( "Use path name larger than `{PATH_MAX}-3 bytes.` and confirm
> error." );
> > +  test_strings = (char*)malloc( ( PATH_MAX - 2 ) );
> the parentheses around PATH_MAX - 2 are redundant
> > +  for ( i = 0 ; i < ( PATH_MAX - 3 ) ; i++ ){
> space before {.
> https://devel.rtems.org/wiki/Developer/Coding/Conventions#Formatting
> > +    test_strings[i] = 'r';
> > +  test_strings[i] = '\0';
> > +  db = dbm_open( (const char*)test_strings , O_RDWR | O_CREAT | O_TRUNC
> , S_IRWXU );
> This line is > 80 characters. Please break it apart as per
> https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line
> > +  rtems_test_assert( errno == ENAMETOOLONG );
> > +  free( test_strings );
> > +/* database opened for write-only access opens the files for read and
> > + * write access or it will fail.
> > +/* Implemenation of __hash_open in newlib does not support `O_WRONLY` */
> typo: Implementation
> > +  puts( "Open file with write access only and confirm error." );
> > +  db = dbm_open( DB_NAME , O_WRONLY , S_IRWXU );
> > +  rtems_test_assert( errno == EINVAL );
> > +/* dbm_store() */
> > +  puts( "\nTestcases for `dbm_store()`" );
> > +  db = dbm_open( DB_NAME , O_RDWR , S_IRWXU );
> > +  puts( "Insert new record with same key using `DBM_INSERT` mode and
> confirm error." );
> > +  rtems_test_assert( dbm_store( db , name , put_phone_no2 , DBM_INSERT
> ) == 1 );
> also too long. fix all lines > 80 characters
> ) == 0 );
> > +  puts( "Insert new record with same key using `DBM_REPLACE` mode and
> confirm changes." );
> > +  rtems_test_assert( dbm_store( db , name , put_phone_no2 , DBM_REPLACE
> ) == 0 );
> > +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr , PHONE_NO2
> ) == 0 );
> > +/* Revert for next tests*/
> > +  rtems_test_assert( dbm_store( db , name , put_phone_no , DBM_REPLACE
> ) == 0 );
> > +  puts( "Store a new record and confirm, total number of records is
> successful 2." );
> > +  rtems_test_assert( dbm_store( db , name2 , put_phone_no2 , DBM_INSERT
> ) == 0 );
> > +  for(key = dbm_firstkey( db ) , i = 0; key.dptr != NULL; key =
> dbm_nextkey( db ) , i++ );
> add spaces around ( after for:
> > +  rtems_test_assert( i == 2);
> spacing
> > +  dbm_close( db );
> > +/* dbm_fetch() */
> > +  puts( "\nTestcases for `dbm_fetch()`" );
> > +  db = dbm_open( DB_NAME , O_RDONLY , S_IRWXU );
> > +  puts( "Fetch existing records and confirm results." );
> ) == 0 );
> > +  get_phone_no = dbm_fetch( db , name2 );
> ) == 0 );
> > +  puts( "Fetch non-existing record and conform error." );
> typo: confirm
> > +  test_strings = (char*)malloc(6);
> > +  strcpy( test_strings , "Hello" );
> suggest you use strncpy.
> > +  key.dptr = test_strings;
> > +  key.dsize = sizeof( test_strings );
> > +  get_phone_no = dbm_fetch( db , key );
> > +  rtems_test_assert( get_phone_no.dptr == NULL );
> > +  dbm_close( db );
> > +/* dbm_delete() */
> > +  puts( "\nTestcases for `dbm_delete()`" );
> > +  puts( "Delte non-existing record and confirm error." );
> typo: Delete
> > +  rtems_test_assert( dbm_delete( db , key ) != 0 );
> since you are repeating this logic many times, you might consider
> writing a helper function to count the records in the db. It will make
> the test easier to read too.
Sure, I must confirm for this from Newlib first. Or else I can make
a user-defined function in a tesuite itself for this purpose.
It will take database name as an argument and count number of
records.
> > +  puts("Delete existing record and confirm, total number of records is
> successful 1.");
> > +  rtems_test_assert( dbm_delete( db , name ) == 0 );
> > +  rtems_test_assert( i == 1);
> > +  puts("Confirm if correct record is deleted.");
> > +/* record returned by `dbm_firstkey()` should be the only record
> > + * left, this should be checked to confirm correct working of
> > + * `dbm_firstkey()`.
> > + * Check if the data is not corrupted after usage of `dbm_delete()`
> > +  puts( "Check if the data is not corrupted after usage of
> `dbm_delete()`." );
> > +  get_phone_no = dbm_fetch( db , dbm_firstkey( db ) );
> ) == 0 );
> > +/* Empty the database and then try to use `dbm_firstkey()`, the
> > + * dptr pointer should point to NULL.
> > +  puts( "Empty records in database and check results of
> `dbm_firstkey()`." );
> > +  rtems_test_assert( dbm_delete( db , dbm_firstkey( db ) ) == 0 );
> > +  key = dbm_firstkey( db );
> > +  rtems_test_assert( key.dptr == NULL );
> > +  dbm_close( db );
> > +/* `dbm_firstkey()` */
> > +  puts( "\nTestcases for `dbm_firstkey()`" );
> > +  puts( "All cases tested while performing above tests." );
> > +/* `dbm_nextkey()` */
> > +  puts( "\nTestcases for `dbm_nextkey()`" );
> these are not necessary print statements then. you can just make it a
> comment somewhere in here that those functions are tested already.
> > +  TEST_END();
> > +  rtems_test_exit(0);
> > +/* NOTICE: the clock driver is explicitly disabled */
> > +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > +#define CONFIGURE_MAXIMUM_TASKS                  1
> > +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > +#include <rtems/confdefs.h>
> > +/* end of file */
> > 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190717/28038950/attachment-0002.html>
