[PATCH v2] user/bsps : Add documentation for Beagle
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Jul 19 18:59:17 UTC 2019
On Fri, Jul 19, 2019 at 10:32 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 19/07/2019 18:21, Gedare Bloom wrote:
> > Looks good to me. I'm currently not able to apply it, verify the doc
> > build, and push it though. (Workstation issues.)
> I agree that it looks OK. Thanks from me too for contributing to the
> documentation. It's something that most developers don't like to do
> therefore it's really great that you wrote that.
> Always glad to contribute. :)
> I didn't find any bugs in the instructions while reading through it. I
> can create a PDF out of it on my Arch Linux machine so I think it should
> be OK to merge it.
> You have tried quite a bit till you get an overlay working. If you feel
> like writing some more documentation, it might would be a good addition
> to add some notes regarding that too. I think this patch is fine as it
> is so if you add something please create a second patch.
> Sure, I can write about creating and overlay and applying it to the base
tree.
What would be the right place to write it?
I have also wondered if it would be a good idea to keep the overlays in
RTEMS
or libBSD repo somewhere along with a script that builds a dtb from the
freebsd-org
tree and applies the overlay.
> @Gedare: I don't touch the docs repo that often: Is there some defined
> test process before a commit is added? Or is building a PDF on some
> random machine enough?
> Best regards
> Christian
> > On Fri, Jul 19, 2019 at 2:07 AM Vijay Kumar Banerjee
> > <vijaykumar9597 at gmail.com> wrote:
> >>  user/bsps/arm/beagle.rst | 110 ++++++++++++++++++++++++++++++++++++++-
> >>  1 file changed, 108 insertions(+), 2 deletions(-)
> >> diff --git a/user/bsps/arm/beagle.rst b/user/bsps/arm/beagle.rst
> >> index a36efde..eb4ecfb 100644
> >> --- a/user/bsps/arm/beagle.rst
> >> +++ b/user/bsps/arm/beagle.rst
> >> @@ -1,8 +1,114 @@
> >>  .. SPDX-License-Identifier: CC-BY-SA-4.0
> >> -.. Copyright (C) 2019 TBD
> >> +.. Copyright (C) 2019 Vijay Kumar Banerjee
> >>  beagle
> >> -TODO.
> >> +This BSP supports four variants, `beagleboardorig`, `beagleboardxm`,
> >> +`beaglebonewhite` and `beagleboneblack`. The basic hardware
> initialization is
> >> +not performed by the BSP.  A boot loader with device tree support must
> be used
> >> +to start the BSP, e.g., U-Boot.
> >> +TODO(These drivers are present but not documented yet):
> >> + *  Clock driver.
> >> + *  Network Interface Driver.
> >> + *  SDcard driver.
> >> + *  GPIO Driver.
> >> + *  Console driver.
> >> + *  PWM Driver.
> >> + *  RTC driver.
> >> +Boot via U-Boot
> >> +To boot via uboot, the ELF must be converted to a U-Boot image like
> below:
> >> +.. code-block:: none
> >> +    arm-rtems5-objcopy hello.exe -O app.bin
> >> +    gzip 9 app.bin
> >> +    mkimage -A arm -O linux -T kernel -a 0x80000000 -e 0x80000000 -n
> RTEMS -d app.bin.gz rtems-app.img
> >> +Getting the Device Tree Blob
> >> +The Device Tree Blob (DTB) is needed to load the device tree while
> starting up
> >> +the kernel. We build the dtb from the FreeBSD source matching the
> commit hash
> >> +from the libbsd HEAD of freebsd-org. For example if the HEAD is at
> >> +"19a6ceb89dbacf74697d493e48c388767126d418"
> >> +Then the right Device Tree Source (DTS) file is:
> https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/gnu/dts/arm/am335x-boneblack.dts
> >> +.. code-block:: shell
> >> +   :linenos:
> >> +     #building the dtb
> >> +     #We will use the script from
> https://github.com/freebsd/freebsd/blob/19a6ceb89dbacf74697d493e48c388767126d418/sys/tools/fdt/make_dtb.sh
> >> +     #The make_dtb.sh script uses environment variable MACHINE
> >> +     export MACHINE='arm'
> >> +     SCRIPT_DIR=$HOME/freebsd/sys/tools/fdt
> >> +     #The arguments to the script are
> >> +     # $1 -> Build Tree
> >> +     # $2 -> DTS source file
> >> +     # $3 -> output path of the DTB file
> >> +     ${SCRIPT_DIR}/make_dtb.sh ${SCRIPT_DIR}/../../ \
> >> +     ${SCRIPT_DIR}/../../gnu/dts/arm/am335x-boneblack.dts \
> >> +     $(pwd)
> >> +Writing the uEnv.txt file
> >> +The uEnv.txt file is needed to set any environment variable before the
> kernel is
> >> +loaded. Each line is a u-boot command that the uboot will execute
> during start
> >> +up.
> >> +Add the following to a file named uEnv.txt:
> >> +     setenv bootdelay 5
> >> +     uenvcmd=run boot
> >> +     boot=fatload mmc 0 0x80800000 rtems-app.img ; fatload mmc 0
> 0x88000000 am335x-boneblack.dtb ; bootm 0x80800000 - 0x88000000
> >> +I2C Driver
> >> +For registering the `/dev/i2c-0` device, a wrapper function is
> provided,
> >> +``bbb_register_i2c_0()`` similarly ``bbb_register_i2c_1()`` and
> >> +``bbb_register_i2c_2()`` are respectively used to register `i2c-1` and
> `i2c-2`.
> >> +For registering an I2C device with a custom path (say `/dev/i2c-3`) the
> >> +function ``am335x_i2c_bus_register()`` has to be used.
> >> +The function prototype is given below:
> >> +.. code-block:: C
> >> +   int am335x_i2c_bus_register(
> >> +   const char         *bus_path,
> >> +   uintptr_t           register_base,
> >> +   uint32_t            input_clock,
> >> +   rtems_vector_number irq
> >> +SPI Driver
> >> +The SPI device `/dev/spi-0` can be registered with
> ``bbb_register_spi_0()``
> >> +For registering with a custom path, the ``bsp_register_spi()`` can be
> used.
> >> +.. code-block:: C
> >> +    rtems_status_code bsp_register_spi(
> >> 2.20.1
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190720/5f3a1de0/attachment-0002.html>
