[PATCH v4] ndbm test suite
Vaibhav Gupta vaibhavgupta40 at gmail.com
Sat Jul 20 06:10:21 UTC 2019
On Fri, Jul 19, 2019 at 2:12 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Jul 18, 2019 at 11:05 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >  testsuites/psxtests/Makefile.am      |   7 +
> >  testsuites/psxtests/configure.ac     |   1 +
> >  testsuites/psxtests/psxndbm01/init.c | 305 +++++++++++++++++++++++++++
> >  3 files changed, 313 insertions(+)
> >  create mode 100644 testsuites/psxtests/psxndbm01/init.c
> > diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> > index 59c9f2085b..7d1c0a783c 100755
> > --- a/testsuites/psxtests/Makefile.am
> > +++ b/testsuites/psxtests/Makefile.am
> > @@ -694,6 +694,13 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psxmutexattr01) \
> >         $(support_includes) -I$(top_srcdir)/include
> >  endif
> > +if TEST_psxndbm01
> > +psx_tests += psxndbm01
> > +psxndbm01_SOURCES = psxndbm01/init.c
> > +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
> > +       $(support_includes)
> > +endif
> >  if TEST_psxobj01
> >  psx_tests += psxobj01
> >  psx_screens += psxobj01/psxobj01.scn
> > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
> configure.ac
> > index 85559e4aa5..07d7ccaf55 100644
> > --- a/testsuites/psxtests/configure.ac
> > +++ b/testsuites/psxtests/configure.ac
> > @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
> >  RTEMS_TEST_CHECK([psxmsgq03])
> >  RTEMS_TEST_CHECK([psxmsgq04])
> >  RTEMS_TEST_CHECK([psxmutexattr01])
> > +RTEMS_TEST_CHECK([psxndbm01])
> >  RTEMS_TEST_CHECK([psxobj01])
> >  RTEMS_TEST_CHECK([psxonce01])
> >  RTEMS_TEST_CHECK([psxpasswd01])
> > diff --git a/testsuites/psxtests/psxndbm01/init.c
> b/testsuites/psxtests/psxndbm01/init.c
> > new file mode 100644
> > index 0000000000..d3b1e36ca0
> > --- /dev/null
> > +++ b/testsuites/psxtests/psxndbm01/init.c
> > @@ -0,0 +1,305 @@
> > + *  @file
> > + *  @brief Test suite for ndbm.h methods
> > + * SPDX-License-Identifier: BSD-2-Clause
> > + * Copyright (C) 2019 Vaibhav Gupta
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +/* header files are listed in lexical/lexicographical/alphabetical
> order */
> > +#include <errno.h>
> > +#include <fcntl.h>      /* contains definitions of 'open_flags' */
> > +#include <limits.h>
> > +#include <ndbm.h>       /* contains declarations of ndbm methods */
> > +#include <stddef.h>
> > +#include <stdint.h>
> > +#include <stdio.h>
> > +#include <sys/stat.h>   /* contains definitions of 'file_mode' */
> > +#include <string.h>
> > +#include <rtems/test.h>
> > +#include <tmacros.h>
> > +const char rtems_test_name[] = "PSXNDBM 01";
> > +#define NAME      "VARoDeK"
> > +#define PHONE_NO  "123-321-777-888"
> > +#define DB_NAME   "phones_test"
> > +#define NAME2     "VG"
> > +#define PHONE_NO2 "321-123-888-777"
> > +/* forward declarations to avoid warnings */
> > +rtems_task Init(rtems_task_argument ignored);
> > +int count_no_of_records( DBM *db_local );
> > +* This Function takes DBM* as a argument and count the number of
> records in the
> > +* database pointed by it.
> declare it 'static', and you shouldn't need the forward declaration I
> think.
Yah forward declaration is not needed, and it worked without it this time.
I don't know why it was showing "int count_no_of_records( DBM *db_local )
not found".
> > +  int count = 0;
> > +  datum temp;
> > +  for(
> space after for
Did that.
This formatting rule is not mentioned in
https://devel.rtems.org/wiki/Developer/Coding/Conventions
in case of loops, should i add it?
> > +    temp = dbm_firstkey( db_local );
> > +    temp.dptr != NULL;
> > +    temp = dbm_nextkey( db_local ) , count++
> no space before the comma.
> > +  return count;
> > +/* Test Function Begins */
> > +  datum name          = { NAME, sizeof( NAME ) };
> > +  datum put_phone_no  = { PHONE_NO, sizeof( PHONE_NO ) };
> > +  datum name2         = { NAME2, sizeof( NAME2 ) };
> > +  datum put_phone_no2 = { PHONE_NO2, sizeof( PHONE_NO2 ) };
> > +  datum get_phone_no, key;
> > +  int i;
> > +  char *test_strings;
> > +  DBM *db;
> > +  TEST_BEGIN();
> > +/* A Simple test to check if ndbm methods are call-able */
> > + * A Simple test to check if NDBM methods are call-able
> > + * We will try to open a database and then close it.
> > + * If it successful, hence we can have further tests.
> > + * Also, while opening it for first time, will create that database,
> > + * hence we will be able to test for 'O_RDWR | O_EXCL' case later.
> > + * Meanwhile we will also store one record, this record will be helpful
> in
> > + * further tests.
> > + * And fetch it, to make sure if basic NDBM methods are working
> correctly.
> > +  puts( "\nOpen Database." );
> > +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_TRUNC, S_IRWXU );
> > +  rtems_test_assert( db != NULL );
> > +  /* This data will be useful in further tests */
> > +  puts( "Store Records in Database." );
> > +  dbm_store( db, name, put_phone_no, DBM_INSERT );
> > +  puts( "Fetch Records from Database and check." );
> > +  get_phone_no = dbm_fetch( db, name );
> > +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO )
> == 0 );
> > +  puts( "Close Database." );
> > +  dbm_close( db );
> > +/* dbm_open() */
> > +  puts( "\nTestcases for 'dbm_open()'." );
> > +/* The 'DB_NAME' is already created, hence 'O_RDWR | O_EXCL' should
> fail. */
> > +  puts( "Use 'O_CREAT | O_EXCL' to open existing file and confirm
> error." );
> > +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_EXCL, S_IRWXU );
> > +  rtems_test_assert( db == NULL );
> > +  rtems_test_assert( errno == EEXIST );
> > +/* Some implementations use 3 characters for the suffix and others use
> > + * 4 characters for the suffix, applications should ensure that the
> maximum
> > + * portable pathname length passed to dbm_open() is no greater than
> > + * {PATH_MAX}-4 bytes, with the last component of the pathname no
> greater
> > + * than {NAME_MAX}-4 bytes.
> > +/* inside 'ndbm.h' ; '#define  DBM_SUFFIX      ".db"' ;
> > + * 2 alphabets and 1 period, hence 3 characters are used for suffix
> > + * in this implementation.
> > +  puts( "Use path name larger than '{PATH_MAX}-3 bytes.' and confirm
> error." );
> > +  test_strings = (char*)malloc( PATH_MAX - 2 );
> > +  for ( i = 0; i < PATH_MAX - 3; i++ )
> Put { on same line as for, with a white space before it.
> > +    test_strings[i] = 'r';
> > +  test_strings[i] = '\0';
> > +  db = dbm_open(
> > +                (const char*)test_strings,
> > +                O_RDWR | O_CREAT | O_TRUNC,
> > +                S_IRWXU
> Line up the closing parenthesis on the same indentation level as the
> first line in the statement.
And this one too, it is no where mentioned about wrapping up functions calls
in 80 characters, when needed, in this site
https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line
Should I add this too?
> > +  rtems_test_assert( errno == ENAMETOOLONG );
> > +  free( test_strings );
> > +/* database opened for write-only access opens the files for read and
> > + * write access or it will fail.
> > +/* Implementation of __hash_open in newlib does not support `O_WRONLY`
> > +  puts( "Open file with write access only and confirm error." );
> > +  db = dbm_open( DB_NAME , O_WRONLY , S_IRWXU );
> no spaces before commas
> > +  rtems_test_assert( errno == EINVAL );
> > +/* dbm_store() */
> > +  puts( "\nTestcases for 'dbm_store()'" );
> > +  db = dbm_open( DB_NAME , O_RDWR , S_IRWXU );
> > +  puts( "Insert new record with same key using 'DBM_INSERT' mode and "
> > +        "confirm error." );
> > +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_INSERT )
> == 1 );
> == 0 );
> > +  puts( "Insert new record with same key using 'DBM_REPLACE' mode and "
> > +        "confirm changes." );
> > +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_REPLACE )
> == 0 );
> > +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO2
> ) == 0 );
> > +/* Revert for next tests */
> > +  rtems_test_assert( dbm_store( db, name, put_phone_no, DBM_REPLACE )
> == 0 );
> > +  puts( "Store a new record and "
> > +        "confirm that total number of records is successful 2." );
> > +  rtems_test_assert( dbm_store( db, name2, put_phone_no2, DBM_INSERT )
> == 0 );
> > +/* Confirm number of records */
> > +  rtems_test_assert( count_no_of_records( db ) == 2 );
> > +  dbm_close( db );
> > +/* dbm_fetch() */
> > +  puts( "\nTestcases for 'dbm_fetch()'" );
> > +  db = dbm_open( DB_NAME, O_RDONLY, S_IRWXU );
> > +  puts( "Fetch existing records and confirm results." );
> == 0 );
> > +  get_phone_no = dbm_fetch( db, name2 );
> ) == 0 );
> > +  puts( "Fetch non-existing record and confirm error." );
> > +  test_strings = (char*)malloc(6);
> > +  strncpy( test_strings, "Hello", 5 );
> > + * We could have used test_strings[5], but since its a dynamic data, we
> wrote
> > + * it in the form of dereference of a pointer.
> > +  *(test_strings + 5) = '\0';
> Why? this is equivalent to test_strings[5] = 0; and can either be
> written as such, or how you did it, but we don't need the comment.
Yah, actually it was due to my coding style, I usually use pointer
arithmetic when using pointers, and hence mentioned comment.
Although I have replaced it with test_strings[5] = '\0', now.
> Usually it is preferred to avoid pointer arithmetic when an array
> notation suffices.
> > +/* The data pointed by test_string is now pointed by key.dptr */
> > +  key.dptr = test_strings;
> > +  key.dsize = sizeof( test_strings );
> > +  get_phone_no = dbm_fetch( db, key );
> > +  rtems_test_assert( get_phone_no.dptr == NULL );
> > +  dbm_close( db );
> > +/* We need the 'key' boject, hence we cannot free 'test_strings' */
> typo:  object
> > +/* dbm_delete() */
> > +  puts( "\nTestcases for 'dbm_delete()'" );
> > +  db = dbm_open( DB_NAME, O_RDWR, S_IRWXU );
> > +  puts( "Delete non-existing record and confirm error." );
> > +  rtems_test_assert( dbm_delete( db, key ) != 0 );
> > +  rtems_test_assert( count_no_of_records( db ) == 2);
> > +  puts( "Delete existing record and "
> > +        "confirm that total number of records is successful 1." );
> > +  rtems_test_assert( dbm_delete( db, name ) == 0 );
> > +  rtems_test_assert( count_no_of_records( db ) == 1);
> > +  puts( "Confirm if correct record is deleted." );
> > +/* record returned by 'dbm_firstkey()' should be the only record
> > + * left, this should be checked to confirm correct working of
> > + * 'dbm_firstkey()'.
> > + * Check if the data is not corrupted after usage of 'dbm_delete()'
> > +  puts( "Check if the data is not corrupted after usage of
> 'dbm_delete()'." );
> > +  get_phone_no = dbm_fetch( db, dbm_firstkey( db ) );
> ) == 0 );
> > +/* Empty the database and then try to use 'dbm_firstkey()', the
> > + * dptr pointer should point to NULL.
> > +  puts( "Empty records in database and check results of
> 'dbm_firstkey()'." );
> > +  rtems_test_assert( dbm_delete( db, dbm_firstkey( db ) ) == 0 );
> > +  key = dbm_firstkey( db );
> > +  rtems_test_assert( key.dptr == NULL );
> > +  dbm_close( db );
> > +* All cases for 'dbm_firstkey()' and 'dbm_nextkey()' were tested while
> > +* performing other tests.
> > +* One such case be found in count_number_of_records() function.
> > +  TEST_END();
> > +  rtems_test_exit(0);
> > +/* NOTICE: the clock driver is explicitly disabled */
> > +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > +#define CONFIGURE_MAXIMUM_TASKS                  1
> > +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > +#include <rtems/confdefs.h>
> > +/* end of file */
> > 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190720/84a6cd6f/attachment-0002.html>
