GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena rmeena840 at gmail.com
Mon Jul 22 06:46:12 UTC 2019
> Where did you find what?
In babeltrace output the value of _prev_state is always 0, 1, 1026 but
mostly it is 0 or 1. There is no fixed pattern in the value of _prev_state
in babeltrace output.
_prev_state is a member of event.field.
> I found:
> event {
>         name = "sched_switch";
>         id = 22;
>         stream_id = 0;
>         fields := struct {
>                 integer { size = 8; align = 8; signed = 0; encoding =
> UTF8; base = 10;
> } _prev_comm[16];
>                 integer { size = 32; align = 8; signed = 1; encoding =
> none; base =
> 10; } _prev_tid;
> none; base =
> 10; } _prev_prio;
>                 integer { size = 64; align = 8; signed = 1; encoding =
> none; base =
> 10; } _prev_state;
> UTF8; base = 10;
> } _next_comm[16];
> none; base =
> 10; } _next_tid;
> none; base =
> 10; } _next_prio;
> I think the analysis tools learns the id from the event name, see
> "lttng-track-process" in lttng-analyses.
> Can you please align all the metadata exactly with the way things are
> defined in LTTNG.
Okay. Sure
> > There is one problem here we need the next_comm and next_tid value
> > before actually next record item is generated in client-side.
> You need one sched_switch event per processor. The order of record
> events is fixed. You update the sched_switch event in two steps and
> write it to the stream after the second step.
Okay. Thanks
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190722/fee4b330/attachment-0002.html>
