GSoC PRU: AM35xx Clock driver
Nils Hölscher
nilhoel1 at gmail.com
Wed Jul 24 13:33:38 UTC 2019
On Wed, 24 Jul 2019 at 15:14, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On Wed, Jul 24, 2019 at 6:36 PM Nils Hölscher <nilhoel1 at gmail.com> wrote:
>> Hi again,
>> Hi Nils
>> I just decompiled my device tree and checked.
>> The probe code of the prcm driver is as follows:
>> static int
>> am335x_prcm_probe(device_t dev)
>> printk("am335x_prcm_probe\n");
>> if (!ofw_bus_status_okay(dev)){
>> printk("ofw_bus_status_not_okay\n");
>> return (ENXIO);
>> Do you get the "ofw_bus_status_not_okay" print ?
Yes. But I also see the other print. except the success one.
> if (ofw_bus_is_compatible(dev, "ti,am3-prcm")) {
>> device_set_desc(dev, "AM335x Power and Clock Management");
>> printk("PROBE SUCESSFULL\n");
>> return(BUS_PROBE_DEFAULT);
>> printk("ofw_bus incompatible\n");
>> return (ENXIO);
>> So it seems the prcm part in the device tree has to be compatible to
>> "ti,am3-prcm".
>> The thing is the decompiled device tree states just that:
>> prcm at 0 {
>> compatible = "ti,am3-prcm\0simple-bus";
> In my device tree, it runs successfully and the decompiled compatible
> looks like :
> prcm at 200000 {
> compatible = "ti,am3-prcm";
> reg = < 0x200000 0x4000 >;
> linux,phandle = < 0x4a >;
> phandle = < 0x4a >;
OK, this is awkward, cause we both should have used the same sources.
> reg = <0x00 0x2000>;
>> #address-cells = <0x01>;
>> #size-cells = <0x01>;
>> ranges = <0x00 0x00 0x2000>;
>> phandle = <0x5a>;
>> Any ideas would help, cause I am currently not able to understand this
>> behaviour.
>> Also without this driver even the dev_usb_bbb driver shouldn't work.
>> However it attaches because it doesn't check for the clocks error code.
> I remember testing this a few days ago for my fb drivers and it was
> attaching alright,
> if I remember correctly. If changing the dtb doesn't work for you, I won't
> mind checking
> again, this will give me a hint for the display issue as well.
I will keep you updated on this.
Would you be so kind and send me your compiled device tree?
> Best,
>> Nils
>> On Wed, 24 Jul 2019 at 14:43, Nils Hölscher <nilhoel1 at gmail.com> wrote:
>>> Hi,
>>> I just found out that the prcm driver fails to probe on the simplebus
>>> and therefore cannot apply itself.
>>> Seems like I am back to checking dtb.
>>> Best,
>>> Nils
>>> On Tue, 23 Jul 2019 at 14:26, Nils Hölscher <nilhoel1 at gmail.com> wrote:
>>>> Hi,
>>>> After debugging with printk, didn't get the module loading working as
>>>> suggested by Sebastian.
>>>> I just found out that my PRU driver can't be attached, cause the AM35xx
>>>> clock driver isn't loaded.
>>>> The driver can be found her:
>>>> https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/arm/ti/am335x/am335x_prcm.c
>>>> Can anyone tell me how to load this driver and obisouly before I
>>>> initialize my BSD modules?
>>>> FYI: The code line that fails is this one, cause the driver hasn't been
>>>> initialized.
>>>> https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/arm/ti/am335x/am335x_prcm.c#L854
>>>> Thanks,
>>>> Nils
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190724/edea5aad/attachment-0002.html>
