GSoC Project | Basic Support for Trace Compass
Sebastian Huber
Fri Jul 26 18:00:33 UTC 2019
----- Am 26. Jul 2019 um 14:56 schrieb Ravindra Kumar Meena rmeena840 at gmail.com:
>> Ok, very good. This look all right. It is amazing how much information
>> Trace Compass can display with only sched_switch events.
> Great!! We have something working very useful. :) :)
>> Please figure out how the state member values are defined. I think this
>> is important to improve the diagrams.
> Here is the response from lltng:
> https://lists.lttng.org/pipermail/lttng-dev/2019-July/029121.html
> What I understand from here is that _prev_state is the previous state of
> the thread(TID)).
Yes, but what is the meaning of these state values? We have to figure this out since we need a mapping from RTEMS thread states to these Linux thread states. Could you use an example trace from Linux to check if the information referenced in this email answer makes sense?
>> It would be good to get task names for the IDs. Do you have an idea how
>> we can do this?
> With task name do you mean RTEMS_RECORD_THREAD_SWITCH_IN
> and RTEMS_RECORD_THREAD_SWITCH_OUT?
> if so this can be done by calling:
> rtems_record_event_text( item->event )
Attached is a patch for RTEMS. The record server sends all thread names to the client after the header.
For thread name changes and new threads we have to think about.
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190726/0f72f84e/attachment-0002.bin>
