[PATCH 08/10] VT : Port to RTEMS
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sat Jul 27 20:31:17 UTC 2019
On Sat, Jul 27, 2019 at 7:26 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> I'm still not entirely convinced what VT does. I tried to remove it (had
> to remove the vt_fb_attach() / _detach() from fbd.c too) and it still
> works. So why do you need VT?
> I removed the VT commit and the app was not able to open the fb device,
if you can open the device with just removing the VT part from fbd, then
maybe some other part of the VT commit is necessary to open the device,
I'll have a look and report and try to see if minimum to no parts of vt is
needed.
(We already removed most part from it, just initialization is there).
> By the way: The fbd commits won't link without that one. So if you
> convince me that VT is necessary you _have_ to reorder or merge fbd and
> VT. We can't have any commits that don't compile. It would prevent to
> use tools like `git bisect`.
> OK. I will merge them into one FBD patch then and put them before the
display
driver patch of am335x
> On 26/07/2019 13:22, Vijay Kumar Banerjee wrote:
> >  freebsd/sys/dev/vt/colors/vt_termcolors.c |  2 ++
> >  freebsd/sys/dev/vt/hw/fb/vt_fb.c          |  2 ++
> >  freebsd/sys/dev/vt/vt_core.c              | 30 +++++++++++++++++++++++
> >  libbsd.py                                 |  3 +++
> >  rtemsbsd/include/machine/vm.h             |  1 +
> >  5 files changed, 38 insertions(+)
> > diff --git a/freebsd/sys/dev/vt/colors/vt_termcolors.c
> b/freebsd/sys/dev/vt/colors/vt_termcolors.c
> > index c7ef4b80..6a3836c4 100644
> > --- a/freebsd/sys/dev/vt/colors/vt_termcolors.c
> > +++ b/freebsd/sys/dev/vt/colors/vt_termcolors.c
> > @@ -144,6 +144,7 @@ vt_palette_init(void)
> >       for (i = 0; i < NCOLORS; i++) {
> >               snprintf(tunable, sizeof(tunable),
> >                   "kern.vt.color.%d.rgb", i);
> > +#ifndef __rtems__
> >               if (TUNABLE_STR_FETCH(tunable, rgb, sizeof(rgb))) {
> >                       if (vt_parse_rgb_triplet(rgb, &r, &g, &b) == 0) {
> >                               /* convert to percentages */
> > @@ -152,6 +153,7 @@ vt_palette_init(void)
> >                               color_def[i].b = b*100/255;
> > +#endif /* __rtems__ */>      }
> > diff --git a/freebsd/sys/dev/vt/hw/fb/vt_fb.c
> b/freebsd/sys/dev/vt/hw/fb/vt_fb.c
> > index 8eb2744b..c9544c06 100644
> > --- a/freebsd/sys/dev/vt/hw/fb/vt_fb.c
> > +++ b/freebsd/sys/dev/vt/hw/fb/vt_fb.c
> > @@ -51,10 +51,12 @@ static struct vt_driver vt_fb_driver = {
> >       .vd_init = vt_fb_init,
> >       .vd_fini = vt_fb_fini,
> >       .vd_blank = vt_fb_blank,
> > +#ifndef __rtems__
> >       .vd_bitblt_text = vt_fb_bitblt_text,
> >       .vd_invalidate_text = vt_fb_invalidate_text,
> >       .vd_bitblt_bmp = vt_fb_bitblt_bitmap,
> >       .vd_drawrect = vt_fb_drawrect,
> >       .vd_setpixel = vt_fb_setpixel,
> >       .vd_postswitch = vt_fb_postswitch,
> >       .vd_priority = VD_PRIORITY_GENERIC+10,> diff --git
> a/freebsd/sys/dev/vt/vt_core.c b/freebsd/sys/dev/vt/vt_core.c
> > index 5f2b1b0e..af0e47eb 100644
> > --- a/freebsd/sys/dev/vt/vt_core.c
> > +++ b/freebsd/sys/dev/vt/vt_core.c
> > @@ -47,7 +47,9 @@ __FBSDID("$FreeBSD$");
> >  #include <sys/lock.h>
> >  #include <sys/malloc.h>
> >  #include <sys/mutex.h>
> > +#ifndef __rtems__
> >  #include <sys/power.h>
> >  #include <sys/priv.h>
> >  #include <sys/proc.h>
> >  #include <sys/random.h>
> > @@ -83,6 +85,7 @@ static tc_opened_t  vtterm_opened;
> >  static tc_ioctl_t    vtterm_ioctl;
> >  static tc_mmap_t     vtterm_mmap;
> > +#ifndef __rtems__
> >  const struct terminal_class vt_termclass = {
> >       .tc_bell        = vtterm_bell,
> >       .tc_cursor      = vtterm_cursor,
> > @@ -104,6 +107,7 @@ const struct terminal_class vt_termclass = {
> >       .tc_ioctl       = vtterm_ioctl,
> >       .tc_mmap        = vtterm_mmap,
> >   * Use a constant timer of 25 Hz to redraw the screen.
> > @@ -129,6 +133,7 @@ static VT_SYSCTL_INT(debug, 0, "vt(9) debug level");
> >  static VT_SYSCTL_INT(deadtimer, 15, "Time to wait busy process in
> VT_PROCESS mode");
> >  static VT_SYSCTL_INT(suspendswitch, 1, "Switch to VT0 before suspend");
> > +#ifndef __rtems__
> >  /* Allow to disable some keyboard combinations. */
> >  static VT_SYSCTL_INT(kbd_halt, 1, "Enable halt keyboard combination.  "
> >      "See kbdmap(5) to configure.");
> > @@ -149,11 +154,13 @@ VT_SYSCTL_INT(splash_ncpu, 0, "Override number of
> logos displayed "
> >  VT_SYSCTL_INT(splash_cpu_style, 2, "Draw logo style "
> >      "(0 = Alternate beastie, 1 = Beastie, 2 = Orb)");
> >  VT_SYSCTL_INT(splash_cpu_duration, 10, "Hide logos after (seconds)");
> >  static unsigned int vt_unit = 0;
> >  static MALLOC_DEFINE(M_VT, "vt", "vt device");
> >  struct vt_device *main_vd = &vt_consdev;
> > +#ifndef __rtems__
> >  /* Boot logo. */
> >  extern unsigned int vt_logo_width;
> >  extern unsigned int vt_logo_height;
> > @@ -169,6 +176,7 @@ extern struct vt_font vt_font_default;
> >  #ifndef SC_NO_CUTPASTE
> >  extern struct vt_mouse_cursor vt_default_mouse_pointer;
> >  #endif
> >  static int signal_vt_rel(struct vt_window *);
> >  static int signal_vt_acq(struct vt_window *);
> > @@ -206,6 +214,7 @@ struct vt_device  vt_consdev = {
> >       .vd_windows = { [VT_CONSWINDOW] =  &vt_conswindow, },
> >       .vd_curwindow = &vt_conswindow,
> >       .vd_kbstate = 0,
> > +#ifndef __rtems__
> >       .vd_pastebuf = {
> >               .vpb_buf = NULL,
> > @@ -216,6 +225,7 @@ struct vt_device  vt_consdev = {
> >       .vd_mcursor_fg = TC_WHITE,
> >       .vd_mcursor_bg = TC_BLACK,
> >  #endif
> >  #ifndef SC_NO_CONSDRAWN
> >       .vd_drawn = vt_consdrawn,
> > @@ -247,6 +257,7 @@ static struct vt_window   vt_conswindow = {
> >       .vw_kbdmode = K_XLATE,
> >       .vw_grabbed = 0,
> > +#ifndef __rtems__
> >  struct terminal vt_consterm = {
> >       .tm_class = &vt_termclass,
> >       .tm_softc = &vt_conswindow,
> > @@ -270,14 +281,17 @@ SYSINIT(vt_update_static, SI_SUB_KMEM,
> SI_ORDER_ANY, vt_update_static,
> >  /* Delay until all devices attached, to not waste time. */
> >  SYSINIT(vt_early_cons, SI_SUB_INT_CONFIG_HOOKS, SI_ORDER_ANY,
> vt_upgrade,
> >      &vt_consdev);
> >  /* Initialize locks/mem depended members. */
> >  static void
> >  vt_update_static(void *dummy)
> > +#ifndef __rtems__
> >       if (!vty_enabled(VTY_VT))
> >               return;
> >       if (main_vd->vd_driver != NULL)
> >               printf("VT(%s): %s %ux%u\n", main_vd->vd_driver->vd_name,
> >                   (main_vd->vd_flags & VDF_TEXTMODE) ? "text" :
> "resolution",
> > @@ -339,6 +353,7 @@ vt_switch_timer(void *arg)
> >       vt_late_window_switch((struct vt_window *)arg);
> > +#ifndef __rtems__
> >  static int
> >  vt_save_kbd_mode(struct vt_window *vw, keyboard_t *kbd)
> > @@ -429,6 +444,7 @@ vt_update_kbd_leds(struct vt_window *vw, keyboard_t
> *kbd)
> >       return (ret);
> >  static int
> >  vt_window_preswitch(struct vt_window *vw, struct vt_window *curvw)
> > @@ -454,6 +470,7 @@ vt_window_postswitch(struct vt_window *vw)
> >       return (0);
> > +#ifndef __rtems__
> >  /* vt_late_window_switch will done VT switching for regular case. */
> >  static int
> >  vt_late_window_switch(struct vt_window *vw)
> > @@ -2832,6 +2849,7 @@ vt_replace_backend(const struct vt_driver *drv,
> void *softc)
> >       termcn_cnregister(vd->vd_windows[VT_CONSWINDOW]->vw_terminal);
> >  static void
> >  vt_suspend_handler(void *priv)
> > @@ -2859,8 +2877,10 @@ void
> >  vt_allocate(const struct vt_driver *drv, void *softc)
> > +#ifndef __rtems__
> >               return;
> >       if (main_vd->vd_driver == NULL) {
> >               main_vd->vd_driver = drv;
> > @@ -2880,15 +2900,19 @@ vt_allocate(const struct vt_driver *drv, void
> *softc)
> >                   main_vd->vd_driver->vd_name, drv->vd_name);
> > +#ifndef __rtems__
> >       vt_replace_backend(drv, softc);
> >  void
> >  vt_deallocate(const struct vt_driver *drv, void *softc)
> > +#ifndef __rtems__
> >               return;
> >       if (main_vd->vd_prev_driver == NULL ||
> >           main_vd->vd_driver != drv ||
> > @@ -2898,7 +2922,9 @@ vt_deallocate(const struct vt_driver *drv, void
> *softc)
> >       printf("VT: Switching back from \"%s\" to \"%s\".\n",
> >           main_vd->vd_driver->vd_name, main_vd->vd_prev_driver->vd_name);
> > +#ifndef __rtems__
> >       vt_replace_backend(NULL, NULL);
> >  void
> > @@ -2910,8 +2936,10 @@ vt_suspend(struct vt_device *vd)
> >               return;
> >       /* Save current window. */
> >       vd->vd_savedwindow = vd->vd_curwindow;
> > +#ifndef __rtems__
> >       /* Ask holding process to free window and switch to console window
> >       vt_proc_window_switch(vd->vd_windows[VT_CONSWINDOW]);
> >       /* Wait for the window switch to complete. */
> >       error = 0;
> > @@ -2927,7 +2955,9 @@ vt_resume(struct vt_device *vd)
> >       if (vt_suspendswitch == 0)
> >               return;
> > +#ifndef __rtems__
> >       /* Switch back to saved window, if any */
> >       vt_proc_window_switch(vd->vd_savedwindow);
> >       vd->vd_savedwindow = NULL;
> > diff --git a/libbsd.py b/libbsd.py
> > index 71eb3577..775eeeac 100644
> > --- a/libbsd.py
> > +++ b/libbsd.py
> > @@ -825,6 +825,9 @@ class display(builder.Module):
> >                  'sys/arm/ti/am335x/am335x_ecap.c',
> >                  'sys/dev/fb/fb.c',
> >                  'sys/dev/fb/fbd.c',
> > +                'sys/dev/vt/hw/fb/vt_fb.c',
> > +                'sys/dev/vt/vt_core.c',
> > +                'sys/dev/vt/colors/vt_termcolors.c',
> >              mm.generator['source']()
> > diff --git a/rtemsbsd/include/machine/vm.h
> b/rtemsbsd/include/machine/vm.h
> > index 351b7472..b90a4cf4 100644
> > --- a/rtemsbsd/include/machine/vm.h
> > +++ b/rtemsbsd/include/machine/vm.h
> > @@ -1,2 +1,3 @@
> >  #define VM_MEMATTR_DEFAULT 0
> >  #define VM_MEMATTR_UNCACHEABLE 1
> > +#define vtophys(a) (a)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190728/1d35aa0a/attachment-0002.html>
