GSoC PRU: AM35xx Clock driver
    Nils Hölscher
    nilhoel1 at gmail.com
    Sun Jul 28 09:22:53 UTC 2019
On Sat, 27 Jul 2019 at 14:34, Christian Mauderer <list at c-mauderer.de> wrote:
> On 24/07/2019 16:53, Nils Hölscher wrote:
> > Hi,
> > @Vijay Kumar Banerjee <mailto:vijaykumar9597 at gmail.com>  thanks for the
> > dtb file.
> > I build my file from FreeBSD master.
> > Prcm attaches now but still after the pruss driver...:
> > nexus0: <RTEMS Nexus device>
> > ofwbus0: <Open Firmware Device Tree> on nexus0
> > simplebus0: <Flattened device tree simple bus> on ofwbus0
> > *ti_pruss0: <TI Programmable Realtime Unit Subsystem> mem
> > 0x4a300000-0x4a37ffff irq 20,21,22,23,24,25,26,27 on simplebus0
> > ti_pruss0: could not enable PRUSS clock
> > device_attach: ti_pruss0 attach returned 6*
> > simplebus1: <Flattened device tree simple bus> on simplebus0*
> > am335x_prcm0: <AM335x Power and Clock Management> mem 0x200000-0x203fff
> > on simplebus1*
> Hello Nils,
> I'm not sure about the order. But what seems a little bit odd is that
> the prcm0 is found in simplebus0 while am335x_prcm0 is found on
> simplebus1. Maybe it's worth investigating how that order is created and
> how it is handled in RTEMS.
Thanks for the information.
I think the way rtems initializes the bsd modules differs from the way
described in the libbsd manuel.
But I will have to investigate that further.
> A general note regarding the prcm module: In RTEMS most (non-libbsd)
> drivers enable their power and clocks themself. Please make sure that
> the FreeBSD prcm doesn't interfere with that. Otherwise you might get
> odd effects.
Thanks I will keep that in mind.
Best,
Nils
> Best regards
> Christian
> > *====am335x_prcm_attach====*
> > Is there anything else I can do besides using MODULE_DEPENDENCY, which I
> > already use.
> > The prcm module is also a EARLY_DRIVER_MODULE.
> > Best,
> > Nils
> > On Wed, 24 Jul 2019 at 16:04, Vijay Kumar Banerjee
> > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
> >     On Wed, Jul 24, 2019 at 7:03 PM Nils Hölscher <nilhoel1 at gmail.com
> >     <mailto:nilhoel1 at gmail.com>> wrote:
> >         On Wed, 24 Jul 2019 at 15:14, Vijay Kumar Banerjee
> wrote:
> >             On Wed, Jul 24, 2019 at 6:36 PM Nils Hölscher
> >             <nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>> wrote:
> >                 Hi again,
> >             Hi Nils
> >                 I just decompiled my device tree and checked.
> >                 The probe code of the prcm driver is as follows:
> >                 static int
> >                 am335x_prcm_probe(device_t dev)
> >                     printk("am335x_prcm_probe\n");
> >                     if (!ofw_bus_status_okay(dev)){
> >                         printk("ofw_bus_status_not_okay\n");
> >                         return (ENXIO);
> >             Do you get the "ofw_bus_status_not_okay" print ?
> >         Yes. But I also see the other print. except the success one.
> >                     if (ofw_bus_is_compatible(dev, "ti,am3-prcm")) {
> >                         device_set_desc(dev, "AM335x Power and Clock
> >                 Management");
> >                         printk("PROBE SUCESSFULL\n");
> >                         return(BUS_PROBE_DEFAULT);
> >                     printk("ofw_bus incompatible\n");
> >                     return (ENXIO);
> >                 So it seems the prcm part in the device tree has to be
> >                 compatible to "ti,am3-prcm".
> >                 The thing is the decompiled device tree states just that:
> >                 prcm at 0 {
> >                                         compatible =
> >                 "ti,am3-prcm\0simple-bus";
> >             In my device tree, it runs successfully and the decompiled
> >             compatible looks like  :
> >                         prcm at 200000 {
> >                             compatible = "ti,am3-prcm";
> >                             reg = < 0x200000 0x4000 >;
> >                             linux,phandle = < 0x4a >;
> >                             phandle = < 0x4a >;
> >         OK, this is awkward, cause we both should have used the same
> >         sources.
> >     Have you checked that your source is from the tree matching the
> >     libBSD HEAD
> >     commit?
> >                                         reg = <0x00 0x2000>;
> >                                         #address-cells = <0x01>;
> >                                         #size-cells = <0x01>;
> >                                         ranges = <0x00 0x00 0x2000>;
> >                                         phandle = <0x5a>;
> >                 Any ideas would help, cause I am currently not able to
> >                 understand this behaviour.
> >                 Also without this driver even the dev_usb_bbb driver
> >                 shouldn't work.
> >                 However it attaches because it doesn't check for the
> >                 clocks error code.
> >             I remember testing this a few days ago for my fb drivers and
> >             it was attaching alright,
> >             if I remember correctly. If changing the dtb doesn't work
> >             for you, I won't mind checking
> >             again, this will give me a hint for the display issue as
> well.
> >         I will keep you updated on this.
> >         Would you be so kind and send me your compiled device tree?
> >     Please find it attached in this mail.
> >     Note: I have removed the devel from the cc because the attachment
> >     might be
> >     big for the list. Please continue the discussion in the mailing list
> >     and maybe note
> >     it somewhere that you already received the dtb from me in private
> mail.
> >     Regards,
> >     Vijay
> >                 Best,
> >                 Nils
> >                 On Wed, 24 Jul 2019 at 14:43, Nils Hölscher
> >                     Hi,
> >                     I just found out that the prcm driver fails to probe
> >                     on the simplebus and therefore cannot apply itself.
> >                     Seems like I am back to checking dtb.
> >                     Best,
> >                     Nils
> >                     On Tue, 23 Jul 2019 at 14:26, Nils Hölscher
> wrote:
> >                         Hi,
> >                         After debugging with printk, didn't get the
> >                         module loading working as suggested by Sebastian.
> >                         I just found out that my PRU driver can't be
> >                         attached, cause the AM35xx clock driver isn't
> >                         loaded.
> >                         The driver can be found her:
> https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/arm/ti/am335x/am335x_prcm.c
> >                         Can anyone tell me how to load this driver and
> >                         obisouly before I initialize my BSD modules?
> >                         FYI: The code line that fails is this one, cause
> >                         the driver hasn't been initialized.
> https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/arm/ti/am335x/am335x_prcm.c#L854
> >                         Thanks,
> >                         Nils
> >                 _______________________________________________
> >                 devel mailing list
> >                 devel at rtems.org <mailto:devel at rtems.org>
> >                 http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190728/0bacd47e/attachment-0002.html>
