[PATCH] arm/raspberrypi: Fix linker map
Mon Jul 29 05:55:36 UTC 2019
On 29/07/2019 07:49, Chris Johns wrote:
> On 29/7/19 3:45 pm, Sebastian Huber wrote:
>> On 29/07/2019 07:36, Chris Johns wrote:
>>> On 29/7/19 3:23 pm, Sebastian Huber wrote:
>>>> could someone with a Raspberry Pi please test this patch.
>>> RTEMS failed to start. It has broken something. I retested by running master
>>> again.
>> The start address changes with this patch. How does this system know what it
>> should boot?
> I only applied the patch and run it. What is the new start address so I can
> update the mkimage script?
What was the old start address? The new one is probably:
0x00200080
I am not sure about the 0x80 tail, it should be the same as it was
previously.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
