[PATCH v6] ndbm test suite
Mon Jul 29 17:14:22 UTC 2019
On Mon, Jul 29, 2019 at 11:35 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> Thanks Joel!
> Now when the testsuite patch is successfully accepted, I would like
> to add an example in:
> https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line,
> about wrapping a "function call" in "80 characters per line".
Pull. I pushed the test. It just won't get built unless your toolset has
ndbm.h
This sounds like helpful guidance.
What's next for fenv?
> Gedare and me discussed about it on a thread. That time he guided me for
> this
> as there is no example about in on the trac pag.
> Vaibhav Gupta
> On Mon, Jul 29, 2019 at 9:33 PM Joel Sherrill <joel at rtems.org> wrote:
>> Hi
>> Now pushed. Thanks.
>> I finally got a local sparc tool chain built with the git master of
>> newlib to build and run this test. It was a bit more complicated than I
>> expected.
>> I did add a bit of logic to the psxtests configure.ac and Makefile.am to
>> ensure the test was not built unless the toolset included <ndbm.h>. This
>> ensures that builds don't break when the toolset doesn't include it and
>> that git bisect will continue to work.
>> The RSB will need to be bumped to the git master once the github mirror
>> updates to include my push to libm.
>> On Thu, Jul 25, 2019 at 2:34 PM Joel Sherrill <joel at rtems.org> wrote:
>>> Hi
>>> I just wanted to let everyone know that I have this pending on a branch
>>> and can build it using the current but there is a problem linking libm on
>>> the newlib git master. Once I have the RSB updated, I will look at pushing
>>> this.
>>> To let Vaibhav continue pushing on fenv, if we decide the configure.ac
>>> should check for the newly added dbm methods before building the test, I
>>> will merge that into the patch.
>>> --joel
>>> On Tue, Jul 23, 2019 at 8:42 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>> wrote:
>>>>  testsuites/psxtests/Makefile.am             |   9 +
>>>>  testsuites/psxtests/configure.ac            |   1 +
>>>>  testsuites/psxtests/psxndbm01/init.c        | 299 ++++++++++++++++++++
>>>>  testsuites/psxtests/psxndbm01/psxndbm01.doc |  36 +++
>>>>  testsuites/psxtests/psxndbm01/psxndbm01.scn |  29 ++
>>>>  5 files changed, 374 insertions(+)
>>>>  create mode 100644 testsuites/psxtests/psxndbm01/init.c
>>>>  create mode 100644 testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>>  create mode 100644 testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>> diff --git a/testsuites/psxtests/Makefile.am
>>>> b/testsuites/psxtests/Makefile.am
>>>> index 59c9f2085b..36da591ccc 100755
>>>> --- a/testsuites/psxtests/Makefile.am
>>>> +++ b/testsuites/psxtests/Makefile.am
>>>> @@ -694,6 +694,15 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS)
>>>> $(TEST_FLAGS_psxmutexattr01) \
>>>>         $(support_includes) -I$(top_srcdir)/include
>>>>  endif
>>>> +if TEST_psxndbm01
>>>> +psx_tests += psxndbm01
>>>> +psx_screens += psxndbm01/psxndbm01.scn
>>>> +psx_docs += psxndbm01/psxndbm01.doc
>>>> +psxndbm01_SOURCES = psxndbm01/init.c
>>>> +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
>>>> +       $(support_includes)
>>>> +endif
>>>>  if TEST_psxobj01
>>>>  psx_tests += psxobj01
>>>>  psx_screens += psxobj01/psxobj01.scn
>>>> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
>>>> configure.ac
>>>> index 85559e4aa5..07d7ccaf55 100644
>>>> --- a/testsuites/psxtests/configure.ac
>>>> +++ b/testsuites/psxtests/configure.ac
>>>> @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
>>>>  RTEMS_TEST_CHECK([psxmsgq03])
>>>>  RTEMS_TEST_CHECK([psxmsgq04])
>>>>  RTEMS_TEST_CHECK([psxmutexattr01])
>>>> +RTEMS_TEST_CHECK([psxndbm01])
>>>>  RTEMS_TEST_CHECK([psxobj01])
>>>>  RTEMS_TEST_CHECK([psxonce01])
>>>>  RTEMS_TEST_CHECK([psxpasswd01])
>>>> diff --git a/testsuites/psxtests/psxndbm01/init.c
>>>> b/testsuites/psxtests/psxndbm01/init.c
>>>> new file mode 100644
>>>> index 0000000000..a1eff4bd67
>>>> --- /dev/null
>>>> +++ b/testsuites/psxtests/psxndbm01/init.c
>>>> @@ -0,0 +1,299 @@
>>>> + *  @file
>>>> + *  @brief Test suite for ndbm.h methods
>>>> + * SPDX-License-Identifier: BSD-2-Clause
>>>> + * Copyright (C) 2019 Vaibhav Gupta
>>>> + * Redistribution and use in source and binary forms, with or without
>>>> + * modification, are permitted provided that the following conditions
>>>> + * are met:
>>>> + * 1. Redistributions of source code must retain the above copyright
>>>> + *    notice, this list of conditions and the following disclaimer.
>>>> + * 2. Redistributions in binary form must reproduce the above copyright
>>>> + *    notice, this list of conditions and the following disclaimer in
>>>> the
>>>> + *    documentation and/or other materials provided with the
>>>> distribution.
>>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>>> "AS IS"
>>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>> TO, THE
>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>> PURPOSE
>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>>> CONTRIBUTORS BE
>>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>> BUSINESS
>>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>> WHETHER IN
>>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>> OTHERWISE)
>>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>>> OF THE
>>>> + * POSSIBILITY OF SUCH DAMAGE.
>>>> +#ifdef HAVE_CONFIG_H
>>>> +#include "config.h"
>>>> +#endif
>>>> +/* header files are listed in lexical/lexicographical/alphabetical
>>>> order */
>>>> +#include <errno.h>
>>>> +#include <fcntl.h>      /* contains definitions of 'open_flags' */
>>>> +#include <limits.h>
>>>> +#include <ndbm.h>       /* contains declarations of ndbm methods */
>>>> +#include <stddef.h>
>>>> +#include <stdint.h>
>>>> +#include <stdio.h>
>>>> +#include <sys/stat.h>   /* contains definitions of 'file_mode' */
>>>> +#include <string.h>
>>>> +#include <rtems/test.h>
>>>> +#include <tmacros.h>
>>>> +const char rtems_test_name[] = "PSXNDBM 01";
>>>> +#define NAME      "VARoDeK"
>>>> +#define PHONE_NO  "123-321-777-888"
>>>> +#define DB_NAME   "phones_test"
>>>> +#define NAME2     "VG"
>>>> +#define PHONE_NO2 "321-123-888-777"
>>>> +/* forward declarations to avoid warnings */
>>>> +rtems_task Init(rtems_task_argument ignored);
>>>> +* This Function takes DBM* as a argument and count the number of
>>>> records in the
>>>> +* database pointed by it.
>>>> +static int count_no_of_records( DBM *db_local )
>>>> +  int count = 0;
>>>> +  datum temp;
>>>> +  for (
>>>> +    temp = dbm_firstkey( db_local );
>>>> +    temp.dptr != NULL;
>>>> +    temp = dbm_nextkey( db_local ), count++
>>>> +  return count;
>>>> +/* Test Function Begins */
>>>> +  datum name          = { NAME, sizeof( NAME ) };
>>>> +  datum put_phone_no  = { PHONE_NO, sizeof( PHONE_NO ) };
>>>> +  datum name2         = { NAME2, sizeof( NAME2 ) };
>>>> +  datum put_phone_no2 = { PHONE_NO2, sizeof( PHONE_NO2 ) };
>>>> +  datum get_phone_no, key;
>>>> +  int i;
>>>> +  char *test_strings;
>>>> +  DBM *db;
>>>> +  TEST_BEGIN();
>>>> +/* A Simple test to check if ndbm methods are call-able */
>>>> + * A Simple test to check if NDBM methods are call-able
>>>> + * We will try to open a database and then close it.
>>>> + * If it successful, hence we can have further tests.
>>>> + * Also, while opening it for first time, will create that database,
>>>> + * hence we will be able to test for 'O_RDWR | O_EXCL' case later.
>>>> + * Meanwhile we will also store one record, this record will be
>>>> helpful in
>>>> + * further tests.
>>>> + * And fetch it, to make sure if basic NDBM methods are working
>>>> correctly.
>>>> +  puts( "\nOpen Database." );
>>>> +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_TRUNC, S_IRWXU );
>>>> +  rtems_test_assert( db != NULL );
>>>> +  /* This data will be useful in further tests */
>>>> +  puts( "Store Records in Database." );
>>>> +  dbm_store( db, name, put_phone_no, DBM_INSERT );
>>>> +  puts( "Fetch Records from Database and check." );
>>>> +  get_phone_no = dbm_fetch( db, name );
>>>> +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO
>>>> ) == 0 );
>>>> +  puts( "Close Database." );
>>>> +  dbm_close( db );
>>>> +/* dbm_open() */
>>>> +  puts( "\nTestcases for 'dbm_open()'." );
>>>> +/* The 'DB_NAME' is already created, hence 'O_RDWR | O_EXCL' should
>>>> fail. */
>>>> +  puts( "Use 'O_CREAT | O_EXCL' to open existing file and confirm
>>>> error." );
>>>> +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_EXCL, S_IRWXU );
>>>> +  rtems_test_assert( db == NULL );
>>>> +  rtems_test_assert( errno == EEXIST );
>>>> +/* Some implementations use 3 characters for the suffix and others use
>>>> + * 4 characters for the suffix, applications should ensure that the
>>>> maximum
>>>> + * portable pathname length passed to dbm_open() is no greater than
>>>> + * {PATH_MAX}-4 bytes, with the last component of the pathname no
>>>> greater
>>>> + * than {NAME_MAX}-4 bytes.
>>>> +/* inside 'ndbm.h' ; '#define  DBM_SUFFIX      ".db"' ;
>>>> + * 2 alphabets and 1 period, hence 3 characters are used for suffix
>>>> + * in this implementation.
>>>> +  puts( "Use path name larger than '{PATH_MAX}-3 bytes.' and confirm
>>>> error." );
>>>> +  test_strings = (char*)malloc( PATH_MAX - 2 );
>>>> +  for ( i = 0; i < PATH_MAX - 3; i++ ) {
>>>> +    test_strings[i] = 'r';
>>>> +  test_strings[i] = '\0';
>>>> +  db = dbm_open(
>>>> +                (const char*)test_strings,
>>>> +                O_RDWR | O_CREAT | O_TRUNC,
>>>> +                S_IRWXU
>>>> +  rtems_test_assert( errno == ENAMETOOLONG );
>>>> +  free( test_strings );
>>>> +/* database opened for write-only access opens the files for read and
>>>> + * write access or it will fail.
>>>> +/* Implementation of __hash_open in newlib does not support `O_WRONLY`
>>>> +  puts( "Open file with write access only and confirm error." );
>>>> +  db = dbm_open( DB_NAME, O_WRONLY, S_IRWXU );
>>>> +  rtems_test_assert( errno == EINVAL );
>>>> +/* dbm_store() */
>>>> +  puts( "\nTestcases for 'dbm_store()'" );
>>>> +  db = dbm_open( DB_NAME, O_RDWR, S_IRWXU );
>>>> +  puts( "Insert new record with same key using 'DBM_INSERT' mode and "
>>>> +        "confirm error." );
>>>> +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_INSERT )
>>>> == 1 );
>>>> ) == 0 );
>>>> +  puts( "Insert new record with same key using 'DBM_REPLACE' mode and "
>>>> +        "confirm changes." );
>>>> +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_REPLACE )
>>>> == 0 );
>>>> +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO2
>>>> ) == 0 );
>>>> +/* Revert for next tests */
>>>> +  rtems_test_assert( dbm_store( db, name, put_phone_no, DBM_REPLACE )
>>>> == 0 );
>>>> +  puts( "Store a new record and "
>>>> +        "confirm that total number of records is successful 2." );
>>>> +  rtems_test_assert( dbm_store( db, name2, put_phone_no2, DBM_INSERT )
>>>> == 0 );
>>>> +/* Confirm number of records */
>>>> +  rtems_test_assert( count_no_of_records( db ) == 2 );
>>>> +  dbm_close( db );
>>>> +/* dbm_fetch() */
>>>> +  puts( "\nTestcases for 'dbm_fetch()'" );
>>>> +  db = dbm_open( DB_NAME, O_RDONLY, S_IRWXU );
>>>> +  puts( "Fetch existing records and confirm results." );
>>>> ) == 0 );
>>>> +  get_phone_no = dbm_fetch( db, name2 );
>>>> ) == 0 );
>>>> +  puts( "Fetch non-existing record and confirm error." );
>>>> +  test_strings = (char*)malloc(6);
>>>> +  strncpy( test_strings, "Hello", 5 );
>>>> +  test_strings[5] = '\0';
>>>> +/* The data pointed by test_string is now pointed by key.dptr */
>>>> +  key.dptr = test_strings;
>>>> +  key.dsize = sizeof( test_strings );
>>>> +  get_phone_no = dbm_fetch( db, key );
>>>> +  rtems_test_assert( get_phone_no.dptr == NULL );
>>>> +  dbm_close( db );
>>>> +/* We need the 'key' object, hence we cannot free 'test_strings' */
>>>> +/* dbm_delete() */
>>>> +  puts( "\nTestcases for 'dbm_delete()'" );
>>>> +  puts( "Delete non-existing record and confirm error." );
>>>> +  rtems_test_assert( dbm_delete( db, key ) != 0 );
>>>> +  rtems_test_assert( count_no_of_records( db ) == 2);
>>>> +  puts( "Delete existing record and "
>>>> +        "confirm that total number of records is successful 1." );
>>>> +  rtems_test_assert( dbm_delete( db, name ) == 0 );
>>>> +  rtems_test_assert( count_no_of_records( db ) == 1);
>>>> +  puts( "Confirm if correct record is deleted." );
>>>> +/* record returned by 'dbm_firstkey()' should be the only record
>>>> + * left, this should be checked to confirm correct working of
>>>> + * 'dbm_firstkey()'.
>>>> + * Check if the data is not corrupted after usage of 'dbm_delete()'
>>>> +  puts( "Check if the data is not corrupted after usage of
>>>> 'dbm_delete()'." );
>>>> +  get_phone_no = dbm_fetch( db, dbm_firstkey( db ) );
>>>> ) == 0 );
>>>> +/* Empty the database and then try to use 'dbm_firstkey()', the
>>>> + * dptr pointer should point to NULL.
>>>> +  puts( "Empty records in database and check results of
>>>> 'dbm_firstkey()'." );
>>>> +  rtems_test_assert( dbm_delete( db, dbm_firstkey( db ) ) == 0 );
>>>> +  key = dbm_firstkey( db );
>>>> +  rtems_test_assert( key.dptr == NULL );
>>>> +  dbm_close( db );
>>>> +* All cases for 'dbm_firstkey()' and 'dbm_nextkey()' were tested while
>>>> +* performing other tests.
>>>> +* One such case be found in count_number_of_records() function.
>>>> +  TEST_END();
>>>> +  rtems_test_exit(0);
>>>> +/* NOTICE: the clock driver is explicitly disabled */
>>>> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>>>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>> +#define CONFIGURE_MAXIMUM_TASKS                  1
>>>> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
>>>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>>>> +#include <rtems/confdefs.h>
>>>> +/* end of file */
>>>> diff --git a/testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>> b/testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>> index 0000000000..cdaeb40911
>>>> --- /dev/null
>>>> +++ b/testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>> @@ -0,0 +1,36 @@
>>>> +This File describes the concepts tested by this test suite.
>>>> +ndbm.h - routines to manage data files that contain key/data pairs.
>>>> +test suite name: PSXNDBM 01
>>>> +- A Simple test to check if NDBM methods are call-able.
>>>> +  - Check if able to run the routine to Open Database.
>>>> +  - Check if able to run the routine to store a record in database.
>>>> +  - Check if able to run the routine to fetch a record from database.
>>>> +  - Check if able to run the routine to close the database.
>>>> +- Test Cases for 'dbm_open()'.
>>>> +  - Verify the error when trying to open existing file with 'O_RDWR |
>>>> O_EXCL'
>>>> +    flags.
>>>> +  - Verify the error when trying to open file with pathname longer than
>>>> +    {PATHMAX}-3 bytes.
>>>> +  - Verify the error when trying to open file with only write access.
>>>> +- Test Cases for 'dbm_store()'.
>>>> +  - Verify the error when trying to insert a record using same key with
>>>> +    'DBM_INSERT' mode.
>>>> +  - Verify the updated record when trying to insert a record using
>>>> same key
>>>> +    with 'DBM_REPLACE' mode.
>>>> +  - Verify if able to save more than one record in database.
>>>> +- Test Cases for 'dbm_fetch()'.
>>>> +  - Verify the data fetched from database.
>>>> +  - Verify the error when tring to fetch non-existing record.
>>>> +- Test Cases for 'dbm_delete()'.
>>>> +  - Veriy the error when trying to delete non-existing record.
>>>> +  - Delete one record and verify results.
>>>> +  - Check if correct record is deleted.
>>>> +  - Verify if other data is not corrupted during delete.
>>>> +  - Empty the databse and verify the value returned by
>>>> 'dbm_firstkey()'.
>>>> \ No newline at end of file
>>>> diff --git a/testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>> b/testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>> index 0000000000..3fa386630a
>>>> --- /dev/null
>>>> +++ b/testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>> @@ -0,0 +1,29 @@
>>>> +*** PSXNDBM 01 Test ***
>>>> +Open Database.
>>>> +Store Records in Database.
>>>> +Fetch Records from Database and check.
>>>> +Close Database.
>>>> +Testcases for 'dbm_open()'.
>>>> +Use 'O_CREAT | O_EXCL' to open existing file and confirm error.
>>>> +Use path name larger than '{PATH_MAX}-3 bytes.' and confirm error.
>>>> +Open file with write access only and confirm error.
>>>> +Testcases for 'dbm_store()'
>>>> +Insert new record with same key using 'DBM_INSERT' mode and confirm
>>>> error.
>>>> +Insert new record with same key using 'DBM_REPLACE' mode and confirm
>>>> changes.
>>>> +Store a new record and confirm that total number of records is
>>>> successful 2.
>>>> +Testcases for 'dbm_fetch()'
>>>> +Fetch existing records and confirm results.
>>>> +Fetch non-existing record and confirm error.
>>>> +Testcases for 'dbm_delete()'
>>>> +Delete non-existing record and confirm error.
>>>> +Delete existing record and confirm that total number of records is
>>>> successful 1.
>>>> +Confirm if correct record is deleted.
>>>> +Check if the data is not corrupted after usage of 'dbm_delete()'.
>>>> +Empty records in database and check results of 'dbm_firstkey()'.
>>>> +*** END OF TEST PSXNDBM 01 ***
>>>> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190729/f2641284/attachment-0002.html>
