GSoC 2019 : POSIX Compliance - Weekly Report
Vaibhav Gupta vaibhavgupta40 at gmail.com
Tue Jul 30 12:44:19 UTC 2019
On Tue, Jul 30, 2019 at 3:25 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Jul 24, 2019 at 10:43 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > Hello,
> > Progress so far:
> > - NDBM patch is pushed by newlib.
> > - NDBM Testsuite is sent to devel ([PATCH V6] ndbm test suite), its
> execution will be verified once newlib has required files. Although I have
> tested it by manually generating required file using 'autoreconf -fvi' on
> my local system.
> > Blocker:
> > - My pace got slow last week as my college started, I informed about it
> on devel.
> > Next:
> > - Implement fenv for SPARC first, then move on to ARM, PPC and others.
> What about fenv testcase?
I guess after Joel had a discussion in newlib, we will be switching code
structure for fenv, so implementation of riscv will also need to be updated.
Hence, I will implement fenv for SPARC and make test case for same.
-Vaibhav Gupta
> > Thank You
> > Vaibhav Gupta
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190730/c81b6c5d/attachment-0002.html>
