GSoC 2019 : POSIX Compliance - Weekly Report
Vaibhav Gupta vaibhavgupta40 at gmail.com
Tue Jul 30 17:29:18 UTC 2019
On Tue, Jul 30, 2019 at 7:23 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Jul 30, 2019 at 7:44 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> On Tue, Jul 30, 2019 at 3:25 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Jul 24, 2019 at 10:43 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>> wrote:
>>> > Hello,
>>> > Progress so far:
>>> > - NDBM patch is pushed by newlib.
>>> > - NDBM Testsuite is sent to devel ([PATCH V6] ndbm test suite), its
>>> execution will be verified once newlib has required files. Although I have
>>> tested it by manually generating required file using 'autoreconf -fvi' on
>>> my local system.
>>> > Blocker:
>>> > - My pace got slow last week as my college started, I informed about
>>> it on devel.
>>> > Next:
>>> > - Implement fenv for SPARC first, then move on to ARM, PPC and others.
>>> What about fenv testcase?
>> I guess after Joel had a discussion in newlib, we will be switching code
>> structure for fenv, so implementation of riscv will also need to be
>> updated.
>> Hence, I will implement fenv for SPARC and make test case for same.
> The test case can be added now if you have a RISC-V toolchain.  I expect
> the test code will
> have to be conditionalized on whether the target architecture supports the
> fenv.h methods.
> This would be best implemented with  like AC_CHECK_FUNC and pick a method
> like
> fegetround() to probe for.
Or I can use AC_CHECK_HEADER like you used for NDBM Testsuite.
> That way as you add support for other architectures, the test(s)
> will automatically get enabled.
> The alternative is like how libdebugger tests have to list specific
> architectures that are
> supported. That requires manual intervention (but is the only option for
> libdebugger).
>> -Vaibhav Gupta
>>> > Thank You
>>> > Vaibhav Gupta
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190730/9882f975/attachment-0002.html>
