GSoC PRU: AM35xx Clock driver
Nils Hölscher nilhoel1 at gmail.com
Wed Jul 31 12:54:59 UTC 2019
Hi,
I have been reading into the FreeBSD init code the past few days,
especially for Driver_MODULE.
Expect an Blog entry today or tomorrow.
Because I don't have JTAG, it took me quite some time.
With BUS_DEBUG enabled I saw that the problem is indeed that the pruss unit
is discovered too early.
Is this device tree related?
I am not sure, cause the overlay I am using is from the BSD community.
I added my output to a gist and link to the interesting parts.
The EARLY_DRIVER_MODULE's are indeed loaded first.
https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L125
Nexus bus attaches and the driver goes over every discovered device and
tries to attach the drivers in order:
https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L326
ofwbus gets discovered:
https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L747
Here the ti_pruss device gets discovered too early in the fdt and fails:
https://gist.github.com/nilhoel1/dac4b9d6b1798b97846b24162ef227e4#file-bus_debug-output-log-L904
I still haven't found the loop running over fdt.
And it seems that the device tree only gets one iteration.
But the BSD man page for EARLY_DRIVER_MODULE states that every PASS_LEVEL
has an iteration.
     The *EARLY*_*DRIVER*_*MODULE*() macro allows a driver to	be
registered for a
     specific pass level.  The boot time probe and attach process makes	*multi-
     ple passes	over the device	tree*.  Certain critical	drivers	that provide
     basic services needed by other devices are	attach during earlier passes.
     Most drivers are attached in a final general pass.	 A driver that
     attaches during an	early pass must	register for a specific	pass level
     (BUS_PASS_*) via the *pass* argument.  Once a driver	is registered it is
     available to attach to devices for	all subsequent passes."
https://www.freebsd.org/cgi/man.cgi?query=DRIVER_MODULE&sektion=9&apropos=0&manpath=FreeBSD+12.0-RELEASE+and+Ports
Best,
Nils
On Sun, 28 Jul 2019 at 11:34, Christian Mauderer <list at c-mauderer.de> wrote:
> On 28/07/2019 11:22, Nils Hölscher wrote:
> > On Sat, 27 Jul 2019 at 14:34, Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     On 24/07/2019 16:53, Nils Hölscher wrote:
> >     > Hi,
> >     > @Vijay Kumar Banerjee <mailto:vijaykumar9597 at gmail.com
> >     <mailto:vijaykumar9597 at gmail.com>>  thanks for the
> >     > dtb file.
> >     > I build my file from FreeBSD master.
> >     > Prcm attaches now but still after the pruss driver...:
> >     > nexus0: <RTEMS Nexus device>
> >     > ofwbus0: <Open Firmware Device Tree> on nexus0
> >     > simplebus0: <Flattened device tree simple bus> on ofwbus0
> >     > *ti_pruss0: <TI Programmable Realtime Unit Subsystem> mem
> >     > 0x4a300000-0x4a37ffff irq 20,21,22,23,24,25,26,27 on simplebus0
> >     > ti_pruss0: could not enable PRUSS clock
> >     > device_attach: ti_pruss0 attach returned 6*
> >     > simplebus1: <Flattened device tree simple bus> on simplebus0*
> >     > am335x_prcm0: <AM335x Power and Clock Management> mem
> >     0x200000-0x203fff
> >     > on simplebus1*
> >     Hello Nils,
> >     I'm not sure about the order. But what seems a little bit odd is that
> >     the prcm0 is found in simplebus0 while am335x_prcm0 is found on
> >     simplebus1. Maybe it's worth investigating how that order is created
> and
> >     how it is handled in RTEMS.
> > Thanks for the information.
> > I think the way rtems initializes the bsd modules differs from the way
> > described in the libbsd manuel.
> > But I will have to investigate that further.
> I'm not 100% sure but as far as I know the _modules_ should be
> initialized in the given order (early module prior to normal module).
> But the device detection is something different. I think there is some
> loop in simplebus that loops over the devices and asks every driver
> whether it wants to handle that device. If yes the driver can have it.
> If no the device is unhandled.
> For a module that is mentioned in the device tree I would expect that
> the order in the device tree binary is the one used. For devices outside
> of the device tree most likely some link order is used.
> If you have a debugger you might want to search for the loops and take a
> look at when they are called and how they add devices. I don't think
> that there are that many early modules yet that would use the device
> tree. So it's possible that there is some call missing that would parse
> the device tree for early modules.
> >     A general note regarding the prcm module: In RTEMS most (non-libbsd)
> >     drivers enable their power and clocks themself. Please make sure that
> >     the FreeBSD prcm doesn't interfere with that. Otherwise you might get
> >     odd effects.
> > Thanks I will keep that in mind.
> > Best,
> > Nils
> >     Best regards
> >     Christian
> >     > *====am335x_prcm_attach====*
> >     > Is there anything else I can do besides using MODULE_DEPENDENCY,
> >     which I
> >     > already use.
> >     > The prcm module is also a EARLY_DRIVER_MODULE.
> >     > Best,
> >     > Nils
> >     > On Wed, 24 Jul 2019 at 16:04, Vijay Kumar Banerjee
> >     > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>
> >     <mailto:vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>>>
> >     wrote:
> >     >     On Wed, Jul 24, 2019 at 7:03 PM Nils Hölscher
> >     <nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>
> >     >     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>>
> wrote:
> >     >         On Wed, 24 Jul 2019 at 15:14, Vijay Kumar Banerjee
> >     <mailto:vijaykumar9597 at gmail.com> <mailto:vijaykumar9597 at gmail.com
> >     <mailto:vijaykumar9597 at gmail.com>>> wrote:
> >     >             On Wed, Jul 24, 2019 at 6:36 PM Nils Hölscher
> >     <mailto:nilhoel1 at gmail.com <mailto:nilhoel1 at gmail.com>>> wrote:
> >     >                 Hi again,
> >     >             Hi Nils
> >     >                 I just decompiled my device tree and checked.
> >     >                 The probe code of the prcm driver is as follows:
> >     >                 static int
> >     >                 am335x_prcm_probe(device_t dev)
> >     >                     printk("am335x_prcm_probe\n");
> >     >                     if (!ofw_bus_status_okay(dev)){
> >     >                         printk("ofw_bus_status_not_okay\n");
> >     >                         return (ENXIO);
> >     >             Do you get the "ofw_bus_status_not_okay" print ?
> >     >         Yes. But I also see the other print. except the success
> one.
> >     >                     if (ofw_bus_is_compatible(dev, "ti,am3-prcm"))
> >     >                         device_set_desc(dev, "AM335x Power and
> Clock
> >     >                 Management");
> >     >                         printk("PROBE SUCESSFULL\n");
> >     >                         return(BUS_PROBE_DEFAULT);
> >     >                     printk("ofw_bus incompatible\n");
> >     >                     return (ENXIO);
> >     >                 So it seems the prcm part in the device tree has
> to be
> >     >                 compatible to "ti,am3-prcm".
> >     >                 The thing is the decompiled device tree states
> >     just that:
> >     >                 prcm at 0 {
> >     >                                         compatible =
> >     >                 "ti,am3-prcm\0simple-bus";
> >     >             In my device tree, it runs successfully and the
> decompiled
> >     >             compatible looks like  :
> >     >                         prcm at 200000 {
> >     >                             compatible = "ti,am3-prcm";
> >     >                             reg = < 0x200000 0x4000 >;
> >     >                             linux,phandle = < 0x4a >;
> >     >                             phandle = < 0x4a >;
> >     >         OK, this is awkward, cause we both should have used the
> same
> >     >         sources.
> >     >     Have you checked that your source is from the tree matching the
> >     >     libBSD HEAD
> >     >     commit?
> >     >                                         reg = <0x00 0x2000>;
> >     >                                         #address-cells = <0x01>;
> >     >                                         #size-cells = <0x01>;
> >     >                                         ranges = <0x00 0x00
> 0x2000>;
> >     >                                         phandle = <0x5a>;
> >     >                 Any ideas would help, cause I am currently not
> able to
> >     >                 understand this behaviour.
> >     >                 Also without this driver even the dev_usb_bbb
> driver
> >     >                 shouldn't work.
> >     >                 However it attaches because it doesn't check for
> the
> >     >                 clocks error code.
> >     >             I remember testing this a few days ago for my fb
> >     drivers and
> >     >             it was attaching alright,
> >     >             if I remember correctly. If changing the dtb doesn't
> work
> >     >             for you, I won't mind checking
> >     >             again, this will give me a hint for the display issue
> >     as well.
> >     >         I will keep you updated on this.
> >     >         Would you be so kind and send me your compiled device
> tree?
> >     >     Please find it attached in this mail.
> >     >     Note: I have removed the devel from the cc because the
> >     >     might be
> >     >     big for the list. Please continue the discussion in the
> >     mailing list
> >     >     and maybe note
> >     >     it somewhere that you already received the dtb from me in
> >     private mail.
> >     >     Regards,
> >     >     Vijay
> >     >                 Best,
> >     >                 Nils
> >     >                 On Wed, 24 Jul 2019 at 14:43, Nils Hölscher
> >     >                     Hi,
> >     >                     I just found out that the prcm driver fails to
> >     probe
> >     >                     on the simplebus and therefore cannot apply
> >     itself.
> >     >                     Seems like I am back to checking dtb.
> >     >                     Best,
> >     >                     Nils
> >     >                     On Tue, 23 Jul 2019 at 14:26, Nils Hölscher
> >     <mailto:nilhoel1 at gmail.com> <mailto:nilhoel1 at gmail.com
> >     >                         Hi,
> >     >                         After debugging with printk, didn't get the
> >     >                         module loading working as suggested by
> >     Sebastian.
> >     >                         I just found out that my PRU driver can't
> be
> >     >                         attached, cause the AM35xx clock driver
> isn't
> >     >                         loaded.
> >     >                         The driver can be found her:
> https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/arm/ti/am335x/am335x_prcm.c
> >     >                         Can anyone tell me how to load this driver
> and
> >     >                         obisouly before I initialize my BSD
> modules?
> >     >                         FYI: The code line that fails is this one,
> >     cause
> >     >                         the driver hasn't been initialized.
> https://github.com/RTEMS/rtems-libbsd/blob/610349693dd31d8b0efd33776516b7187cc5cda2/freebsd/sys/arm/ti/am335x/am335x_prcm.c#L854
> >     >                         Thanks,
> >     >                         Nils
> >     >                 _______________________________________________
> >     >                 devel mailing list
> >     >                 devel at rtems.org <mailto:devel at rtems.org>
> >     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> >     >                 http://lists.rtems.org/mailman/listinfo/devel
> >     > devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190731/03e4d701/attachment-0002.html>
