Build FreeBSD: FAILED 6/rtems-x86_64.bset on x86_64-freebsd12.0 (x86_64-rtems6-gdb-ff4a4474eb-x86_64-freebsd12.0-1)
Mon Jun 3 05:17:40 UTC 2019
On 03/06/2019 04:18, Chris Johns wrote:
> On 31/5/19 8:11 pm, Sebastian Huber wrote:
>> All the builds on FreeBSD 12 failed this week. The reason seems to be this:
>> grep -r ORIGINAL_AS_FOR_TARGET .
>> ./gcc/config.log:ORIGINAL_AS_FOR_TARGET=''
>> ./gcc/config.status:S["ORIGINAL_AS_FOR_TARGET"]=""
>> ./gcc/as:ORIGINAL_AS_FOR_TARGET=""
>> ./gcc/as:    original=$ORIGINAL_AS_FOR_TARGET
>> ./gcc/collect-ld:ORIGINAL_AS_FOR_TARGET=""
>> ./gcc/collect-ld:    original=$ORIGINAL_AS_FOR_TARGET
>> ./gcc/nm:ORIGINAL_AS_FOR_TARGET=""
>> ./gcc/nm:    original=$ORIGINAL_AS_FOR_TARGET
>> ./gcc/Makefile:ORIGINAL_AS_FOR_TARGET =
>> I don't know why this variable is empty.
> What does a Linux build show? I wonder if there is a Linux specific change
> introduced, for example related to sed, shell etc.
I use the GNU sed to build GCC on Freebsd. On Linux it looks like:
/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as
./gcc/nm:ORIGINAL_AS_FOR_TARGET="/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as"
./gcc/collect-ld:ORIGINAL_AS_FOR_TARGET="/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as"
./gcc/as:ORIGINAL_AS_FOR_TARGET="/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as"
./gcc/config.status:S["ORIGINAL_AS_FOR_TARGET"]="/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as"
./gcc/config.log:ORIGINAL_AS_FOR_TARGET='/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as'
If it is still broken in one week, then I will start a git bisect.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
