Build FreeBSD: FAILED 6/rtems-x86_64.bset on x86_64-freebsd12.0 (x86_64-rtems6-gdb-ff4a4474eb-x86_64-freebsd12.0-1)
Mon Jun 3 09:12:40 UTC 2019
On 03/06/2019 07:17, Sebastian Huber wrote:
> On 03/06/2019 04:18, Chris Johns wrote:
>> On 31/5/19 8:11 pm, Sebastian Huber wrote:
>>> All the builds on FreeBSD 12 failed this week. The reason seems to
>>> be this:
>>> grep -r ORIGINAL_AS_FOR_TARGET .
>>> ./gcc/config.log:ORIGINAL_AS_FOR_TARGET=''
>>> ./gcc/config.status:S["ORIGINAL_AS_FOR_TARGET"]=""
>>> ./gcc/as:ORIGINAL_AS_FOR_TARGET=""
>>> ./gcc/as:    original=$ORIGINAL_AS_FOR_TARGET
>>> ./gcc/collect-ld:ORIGINAL_AS_FOR_TARGET=""
>>> ./gcc/collect-ld:    original=$ORIGINAL_AS_FOR_TARGET
>>> ./gcc/nm:ORIGINAL_AS_FOR_TARGET=""
>>> ./gcc/nm:    original=$ORIGINAL_AS_FOR_TARGET
>>> ./gcc/Makefile:ORIGINAL_AS_FOR_TARGET =
>>> I don't know why this variable is empty.
>> What does a Linux build show? I wonder if there is a Linux specific
>> change
>> introduced, for example related to sed, shell etc.
> I use the GNU sed to build GCC on Freebsd. On Linux it looks like:
> /scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as
> ./gcc/nm:ORIGINAL_AS_FOR_TARGET="/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as"
> ./gcc/collect-ld:ORIGINAL_AS_FOR_TARGET="/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as"
> ./gcc/as:ORIGINAL_AS_FOR_TARGET="/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as"
> ./gcc/config.status:S["ORIGINAL_AS_FOR_TARGET"]="/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as"
> ./gcc/config.log:ORIGINAL_AS_FOR_TARGET='/scratch/git-rtems-source-builder/rtems/build/tmp/sb-sebastian_h/6/rtems-aarch64.bset/opt/rtems/5/bin/aarch64-rtems6-as'
> If it is still broken in one week, then I will start a git bisect.
It was not a GCC build issue:
building: aarch64-rtems6-gdb-4f6d070adb-x86_64-freebsd12.0-1
error: building aarch64-rtems6-gdb-4f6d070adb-x86_64-freebsd12.0-1
Build FAILED
   See error report:
rsb-report-aarch64-rtems6-gdb-4f6d070adb-x86_64-freebsd12.0-1.txt
config: tools/rtems-binutils-head.cfg
package: aarch64-rtems6-binutils-4f6d070adb-x86_64-freebsd12.0-1
building: aarch64-rtems6-binutils-4f6d070adb-x86_64-freebsd12.0-1
error: building aarch64-rtems6-binutils-4f6d070adb-x86_64-freebsd12.0-1
Build FAILED
   See error report:
rsb-report-aarch64-rtems6-binutils-4f6d070adb-x86_64-freebsd12.0-1.txt
config: tools/rtems-gcc-head-newlib-head.cfg
package:
aarch64-rtems6-gcc-0f4558599b9-newlib-d5daede26-x86_64-freebsd12.0-1
download:
https://codeload.github.com/RTEMS/gnu-mirror-gcc/tar.gz/0f4558599b9 ->
sources/gnu-mirror-gcc-0f4558599b9.tar.gz
RSB continued with the build set even though some steps failed because I
used  --keep-going.
https://www.sourceware.org/ml/binutils/2019-06/msg00008.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
