Potential SIS or RTEMS/libbsd problem
Mon Jun 3 21:45:18 UTC 2019
On 3/6/19 5:51 pm, Jiri Gaisler wrote:
> On 6/3/19 4:14 AM, Chris Johns wrote:
>> On 1/6/19 6:58 am, Jiri Gaisler wrote:
>>> I have pushed a small patch to fix some build problems on Cygwin and FreeBSD. I don't know how fast we want to progress, but I could prepare a patch for RSB to use the new sis repository and skip the sis patches for gdb. I guess this would also have include updating any documentation that refers to the old sis ...
>> I am happy to move to using a separate sis executable built by the RSB and for
>> the gdb versions and patches to stop being maintained.
> OK, I will look at this on some rainy day ...
>> By the way have you looked at the GDB pipe interface to the a remote executable?
>> It would be interesting to know how using that transport effects the ^C issue on
>> Windows.
> I will check this. However, I thought pipes were unidirectional on linux...?
It uses the stdin and stdout of the child process for the remote protocol. It
means you need to send console output over the remote protocol which could be
considered a feature :)
See ...
https://github.com/RTEMS/sourceware-mirror-binutils-gdb/blob/master/gdb/gdbserver/remote-utils.c#L337
The nice thing about using a pipe is gdb handles the external simulator so you
do not need to coordinate two processes. This makes scripting tools like
rtems-test simpler.
